--- ray/src/gen/gensurf.c 1990/05/26 19:44:40 1.8 +++ ray/src/gen/gensurf.c 1992/02/05 21:05:00 2.3 @@ -18,9 +18,9 @@ static char SCCSid[] = "$SunId$ LBL"; #include "standard.h" -#define XNAME "X_" /* x function name */ -#define YNAME "Y_" /* y function name */ -#define ZNAME "Z_" /* z function name */ +char XNAME[] = "X`SYS`"; /* x function name */ +char YNAME[] = "Y`SYS`"; /* y function name */ +char ZNAME[] = "Z`SYS`"; /* z function name */ #define ABS(x) ((x)>=0 ? (x) : -(x)) @@ -34,8 +34,19 @@ int smooth = 0; /* apply smoothing? */ char *modname, *surfname; -double funvalue(), l_hermite(), l_bezier(), l_bspline(), argument(); + /* recorded data flags */ +#define HASBORDER 01 +#define TRIPLETS 02 + /* a data structure */ +struct { + int flags; /* data type */ + short m, n; /* number of s and t values */ + FLOAT *data; /* the data itself, s major sort */ +} datarec; /* our recorded data */ +double l_hermite(), l_bezier(), l_bspline(), l_dataval(); +extern double funvalue(), argument(); + typedef struct { FVECT p; /* vertex position */ FVECT n; /* average normal */ @@ -46,21 +57,22 @@ main(argc, argv) int argc; char *argv[]; { + extern long eclock; POINT *row0, *row1, *row2, *rp; int i, j, m, n; char stmp[256]; - varset("PI", PI); - funset("hermite", 5, l_hermite); - funset("bezier", 5, l_bezier); - funset("bspline", 5, l_bspline); + varset("PI", ':', PI); + funset("hermite", 5, ':', l_hermite); + funset("bezier", 5, ':', l_bezier); + funset("bspline", 5, ':', l_bspline); if (argc < 8) goto userror; for (i = 8; i < argc; i++) if (!strcmp(argv[i], "-e")) - scompile(NULL, argv[++i]); + scompile(argv[++i], NULL, 0); else if (!strcmp(argv[i], "-f")) fcompile(argv[++i]); else if (!strcmp(argv[i], "-s")) @@ -70,17 +82,31 @@ char *argv[]; modname = argv[1]; surfname = argv[2]; - sprintf(stmp, "%s(s,t)=%s;", XNAME, argv[3]); - scompile(NULL, stmp); - sprintf(stmp, "%s(s,t)=%s;", YNAME, argv[4]); - scompile(NULL, stmp); - sprintf(stmp, "%s(s,t)=%s;", ZNAME, argv[5]); - scompile(NULL, stmp); m = atoi(argv[6]); n = atoi(argv[7]); if (m <= 0 || n <= 0) goto userror; - + if (!strcmp(argv[5], "-") || access(argv[5], 4) == 0) { /* file? */ + funset(ZNAME, 2, ':', l_dataval); + if (!strcmp(argv[5],argv[3]) && !strcmp(argv[5],argv[4])) { + loaddata(argv[5], m, n, 3); + funset(XNAME, 2, ':', l_dataval); + funset(YNAME, 2, ':', l_dataval); + } else { + loaddata(argv[5], m, n, 1); + sprintf(stmp, "%s(s,t)=%s;", XNAME, argv[3]); + scompile(stmp, NULL, 0); + sprintf(stmp, "%s(s,t)=%s;", YNAME, argv[4]); + scompile(stmp, NULL, 0); + } + } else { + sprintf(stmp, "%s(s,t)=%s;", XNAME, argv[3]); + scompile(stmp, NULL, 0); + sprintf(stmp, "%s(s,t)=%s;", YNAME, argv[4]); + scompile(stmp, NULL, 0); + sprintf(stmp, "%s(s,t)=%s;", ZNAME, argv[5]); + scompile(stmp, NULL, 0); + } row0 = (POINT *)malloc((n+3)*sizeof(POINT)); row1 = (POINT *)malloc((n+3)*sizeof(POINT)); row2 = (POINT *)malloc((n+3)*sizeof(POINT)); @@ -91,6 +117,7 @@ char *argv[]; row0++; row1++; row2++; /* print header */ printhead(argc, argv); + eclock = 0; /* initialize */ comprow(-1.0/m, row0, n); comprow(0.0, row1, n); @@ -126,6 +153,107 @@ userror: } +loaddata(file, m, n, pointsize) /* load point data from file */ +char *file; +int m, n; +int pointsize; +{ + extern char *fgetword(); + FILE *fp; + char word[64]; + register int size; + register FLOAT *dp; + + datarec.flags = HASBORDER; /* assume border values */ + datarec.m = m+1; + datarec.n = n+1; + size = datarec.m*datarec.n*pointsize; + if (pointsize == 3) + datarec.flags |= TRIPLETS; + dp = (FLOAT *)malloc(size*sizeof(FLOAT)); + if ((datarec.data = dp) == NULL) { + fputs("Out of memory\n", stderr); + exit(1); + } + if (!strcmp(file, "-")) { + file = ""; + fp = stdin; + } else if ((fp = fopen(file, "r")) == NULL) { + fputs(file, stderr); + fputs(": cannot open\n", stderr); + exit(1); + } + while (size > 0 && fgetword(word, sizeof(word), fp) != NULL) { + if (!isflt(word)) { + fprintf(stderr, "%s: garbled data value: %s\n", + file, word); + exit(1); + } + *dp++ = atof(word); + size--; + } + if (size == (m+n+1)*pointsize) { /* no border after all */ + dp = (FLOAT *)realloc((char *)datarec.data, + m*n*pointsize*sizeof(FLOAT)); + if (dp != NULL) + datarec.data = dp; + datarec.flags &= ~HASBORDER; + datarec.m = m; + datarec.n = n; + size = 0; + } + if (datarec.m < 2 || datarec.n < 2 || size != 0 || + fgetword(word, sizeof(word), fp) != NULL) { + fputs(file, stderr); + fputs(": bad number of data points\n", stderr); + exit(1); + } + fclose(fp); +} + + +double +l_dataval(nam) /* return recorded data value */ +char *nam; +{ + double u, v; + register int i, j; + register FLOAT *dp; + double d00, d01, d10, d11; + /* compute coordinates */ + u = argument(1); v = argument(2); + if (datarec.flags & HASBORDER) { + i = u *= datarec.m-1; + j = v *= datarec.n-1; + } else { + i = u = u*datarec.m - .5; + j = v = v*datarec.n - .5; + } + if (i < 0) i = 0; + else if (i > datarec.m-2) i = datarec.m-2; + if (j < 0) j = 0; + else if (j > datarec.n-2) j = datarec.n-2; + /* compute value */ + if (datarec.flags & TRIPLETS) { + dp = datarec.data + 3*(j*datarec.m + i); + if (nam == ZNAME) + dp += 2; + else if (nam == YNAME) + dp++; + d00 = dp[0]; d01 = dp[3]; + dp += 3*datarec.m; + d10 = dp[0]; d11 = dp[3]; + } else { + dp = datarec.data + j*datarec.m + i; + d00 = dp[0]; d01 = dp[1]; + dp += datarec.m; + d10 = dp[0]; d11 = dp[1]; + } + /* bilinear interpolation */ + return((j+1-v)*((i+1-u)*d00+(u-i)*d01)+(v-j)*((i+1-u)*d10+(u-i)*d11)); +} + + putsquare(p0, p1, p2, p3) /* put out a square */ POINT *p0, *p1, *p2, *p3; { @@ -246,25 +374,16 @@ compnorms(r0, r1, r2, siz) /* compute row of averaged register POINT *r0, *r1, *r2; int siz; { - FVECT v1, v2, vc; + FVECT v1, v2; register int i; if (!smooth) /* not needed if no smoothing */ return; /* compute middle points */ while (siz-- >= 0) { - fvsum(v1, r2[0].p, r1[0].p, -1.0); - fvsum(v2, r1[1].p, r1[0].p, -1.0); + fvsum(v1, r2[0].p, r0[0].p, -1.0); + fvsum(v2, r1[1].p, r1[-1].p, -1.0); fcross(r1[0].n, v1, v2); - fvsum(v1, r0[0].p, r1[0].p, -1.0); - fcross(vc, v2, v1); - fvsum(r1[0].n, r1[0].n, vc, 1.0); - fvsum(v2, r1[-1].p, r1[0].p, -1.0); - fcross(vc, v1, v2); - fvsum(r1[0].n, r1[0].n, vc, 1.0); - fvsum(v1, r2[0].p, r1[0].p, -1.0); - fcross(vc, v2, v1); - fvsum(r1[0].n, r1[0].n, vc, 1.0); normalize(r1[0].n); r0++; r1++; r2++; } @@ -280,7 +399,7 @@ POINT *p0, *p1, *p2, *p3; #define v ((ax+2)%3) register int ax; - double eqnmat[4][4]; + MAT4 eqnmat; FVECT v1; register int i, j; @@ -334,29 +453,29 @@ POINT *p0, *p1, *p2, *p3; */ invmat(inverse,mat) -double mat[4][4],inverse[4][4]; +MAT4 inverse, mat; { #define SWAP(a,b,t) (t=a,a=b,b=t) - double m4tmp[4][4]; + MAT4 m4tmp; register int i,j,k; register double temp; - bcopy((char *)mat, (char *)m4tmp, sizeof(m4tmp)); + copymat4(m4tmp, mat); /* set inverse to identity */ for (i = 0; i < 4; i++) for (j = 0; j < 4; j++) inverse[i][j] = i==j ? 1.0 : 0.0; for(i = 0; i < 4; i++) { - /* Look for raw with largest pivot and swap raws */ + /* Look for row with largest pivot and swap rows */ temp = FTINY; j = -1; for(k = i; k < 4; k++) if(ABS(m4tmp[k][i]) > temp) { temp = ABS(m4tmp[k][i]); j = k; } - if(j == -1) /* No replacing raw -> no inverse */ + if(j == -1) /* No replacing row -> no inverse */ return(0); if (j != i) for(k = 0; k < 4; k++) {
