--- ray/src/gen/gensurf.c 2007/10/09 04:44:54 2.17 +++ ray/src/gen/gensurf.c 2012/03/11 22:27:17 2.21 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: gensurf.c,v 2.17 2007/10/09 04:44:54 greg Exp $"; +static const char RCSid[] = "$Id: gensurf.c,v 2.21 2012/03/11 22:27:17 greg Exp $"; #endif /* * gensurf.c - program to generate functional surfaces @@ -34,8 +34,8 @@ char VNAME[] = "valid"; /* valid vertex name */ #define pvect(p) printf(vformat, (p)[0], (p)[1], (p)[2]) -char vformat[] = "%15.9g %15.9g %15.9g\n"; -char tsargs[] = "4 surf_dx surf_dy surf_dz surf.cal\n"; +char vformat[] = "%18.12g %18.12g %18.12g\n"; +char tsargs[] = "4 surf_dx surf_dy surf_dz surf.cal"; char texname[] = "Phong"; int smooth = 0; /* apply smoothing? */ @@ -58,6 +58,7 @@ double l_hermite(), l_bezier(), l_bspline(), l_datava typedef struct { int valid; /* point is valid (vertex number) */ + int nvalid; /* normal is valid */ FVECT p; /* vertex position */ FVECT n; /* average normal */ RREAL uv[2]; /* (u,v) position */ @@ -229,7 +230,7 @@ loaddata( /* load point data from file */ size--; } if (size == (m+n+1)*pointsize) { /* no border after all */ - dp = (RREAL *)realloc((void *)datarec.data, + dp = (RREAL *)realloc(datarec.data, m*n*pointsize*sizeof(RREAL)); if (dp != NULL) datarec.data = dp; @@ -298,15 +299,19 @@ putobjrow( /* output vertex row to .OBJ */ ) { static int nverts = 0; + static int nnorms = 0; for ( ; n-- >= 0; rp++) { if (!rp->valid) continue; fputs("v ", stdout); pvect(rp->p); - if (smooth && !ZEROVECT(rp->n)) + if (smooth && !ZEROVECT(rp->n)) { printf("\tvn %.9g %.9g %.9g\n", rp->n[0], rp->n[1], rp->n[2]); + rp->nvalid = ++nnorms; + } else + rp->nvalid = 0; printf("\tvt %.9g %.9g\n", rp->uv[0], rp->uv[1]); rp->valid = ++nverts; } @@ -344,35 +349,24 @@ putsquare( /* put out a square */ if (!(ok1 | ok2)) return; if (objout) { /* output .OBJ faces */ - int p0n=0, p1n=0, p2n=0, p3n=0; - if (smooth) { - if (!ZEROVECT(p0->n)) - p0n = p0->valid; - if (!ZEROVECT(p1->n)) - p1n = p1->valid; - if (!ZEROVECT(p2->n)) - p2n = p2->valid; - if (!ZEROVECT(p3->n)) - p3n = p3->valid; - } if (ok1 & ok2 && fdot(vc1,vc2) >= 1.0-FTINY*FTINY) { printf("f %d/%d/%d %d/%d/%d %d/%d/%d %d/%d/%d\n", - p0->valid, p0->valid, p0n, - p1->valid, p1->valid, p1n, - p3->valid, p3->valid, p3n, - p2->valid, p2->valid, p2n); + p0->valid, p0->valid, p0->nvalid, + p1->valid, p1->valid, p1->nvalid, + p3->valid, p3->valid, p3->nvalid, + p2->valid, p2->valid, p2->nvalid); return; } if (ok1) printf("f %d/%d/%d %d/%d/%d %d/%d/%d\n", - p0->valid, p0->valid, p0n, - p1->valid, p1->valid, p1n, - p2->valid, p2->valid, p2n); + p0->valid, p0->valid, p0->nvalid, + p1->valid, p1->valid, p1->nvalid, + p2->valid, p2->valid, p2->nvalid); if (ok2) printf("f %d/%d/%d %d/%d/%d %d/%d/%d\n", - p2->valid, p2->valid, p2n, - p1->valid, p1->valid, p1n, - p3->valid, p3->valid, p3n); + p2->valid, p2->valid, p2->nvalid, + p1->valid, p1->valid, p1->nvalid, + p3->valid, p3->valid, p3->nvalid); return; } /* compute normal interpolation */ @@ -382,8 +376,7 @@ putsquare( /* put out a square */ if (ok1 & ok2 && fdot(vc1,vc2) >= 1.0-FTINY*FTINY) { printf("\n%s ", modname); if (axis != -1) { - printf("texfunc %s\n", texname); - printf(tsargs); + printf("texfunc %s\n%s\n", texname, tsargs); printf("0\n13\t%d\n", axis); pvect(norm[0]); pvect(norm[1]); @@ -405,8 +398,7 @@ putsquare( /* put out a square */ if (ok1) { printf("\n%s ", modname); if (axis != -1) { - printf("texfunc %s\n", texname); - printf(tsargs); + printf("texfunc %s\n%s\n", texname, tsargs); printf("0\n13\t%d\n", axis); pvect(norm[0]); pvect(norm[1]); @@ -424,8 +416,7 @@ putsquare( /* put out a square */ if (ok2) { printf("\n%s ", modname); if (axis != -1) { - printf("texfunc %s\n", texname); - printf(tsargs); + printf("texfunc %s\n%s\n", texname, tsargs); printf("0\n13\t%d\n", axis); pvect(norm[0]); pvect(norm[1]);
