--- ray/src/gen/gensurf.c 1989/09/10 16:45:16 1.2 +++ ray/src/gen/gensurf.c 2003/04/23 00:52:33 2.10 @@ -1,9 +1,6 @@ -/* Copyright (c) 1989 Regents of the University of California */ - #ifndef lint -static char SCCSid[] = "$SunId$ LBL"; +static const char RCSid[] = "$Id: gensurf.c,v 2.10 2003/04/23 00:52:33 greg Exp $"; #endif - /* * gensurf.c - program to generate functional surfaces * @@ -14,142 +11,155 @@ static char SCCSid[] = "$SunId$ LBL"; * rule applied to (s,t). * * 4/3/87 + * + * 4/16/02 Added conditional vertex output */ -#include +#include "standard.h" -#define XNAME "X_" /* x function name */ -#define YNAME "Y_" /* y function name */ -#define ZNAME "Z_" /* z function name */ +char XNAME[] = "X`SYS"; /* x function name */ +char YNAME[] = "Y`SYS"; /* y function name */ +char ZNAME[] = "Z`SYS"; /* z function name */ -#define PI 3.14159265358979323846 +char VNAME[] = "valid"; /* valid vertex name */ -#define FTINY 1e-7 +#define ABS(x) ((x)>=0 ? (x) : -(x)) -#define vertex(p) printf(vformat, (p)[0], (p)[1], (p)[2]) +#define ZEROVECT(v) (DOT(v,v) <= FTINY*FTINY) +#define pvect(p) printf(vformat, (p)[0], (p)[1], (p)[2]) + char vformat[] = "%15.9g %15.9g %15.9g\n"; +char tsargs[] = "4 surf_dx surf_dy surf_dz surf.cal\n"; +char texname[] = "Phong"; -double funvalue(), dist2(), fdot(), l_hermite(), argument(); +int smooth = 0; /* apply smoothing? */ +int objout = 0; /* output .OBJ format? */ +char *modname, *surfname; + /* recorded data flags */ +#define HASBORDER 01 +#define TRIPLETS 02 + /* a data structure */ +struct { + int flags; /* data type */ + short m, n; /* number of s and t values */ + FLOAT *data; /* the data itself, s major sort */ +} datarec; /* our recorded data */ + +double l_hermite(), l_bezier(), l_bspline(), l_dataval(); +extern double funvalue(), argument(); + +typedef struct { + int valid; /* point is valid (vertex number) */ + FVECT p; /* vertex position */ + FVECT n; /* average normal */ + FLOAT uv[2]; /* (u,v) position */ +} POINT; + + main(argc, argv) int argc; char *argv[]; { - static double *xyz[4]; - double *row0, *row1, *dp; - double v1[3], v2[3], vc1[3], vc2[3]; - double a1, a2; + extern long eclock; + POINT *row0, *row1, *row2, *rp; int i, j, m, n; char stmp[256]; - double d; - register int k; - varset("PI", PI); - funset("hermite", 5, l_hermite); + varset("PI", ':', PI); + funset("hermite", 5, ':', l_hermite); + funset("bezier", 5, ':', l_bezier); + funset("bspline", 5, ':', l_bspline); if (argc < 8) goto userror; for (i = 8; i < argc; i++) if (!strcmp(argv[i], "-e")) - scompile(NULL, argv[++i]); + scompile(argv[++i], NULL, 0); else if (!strcmp(argv[i], "-f")) fcompile(argv[++i]); + else if (!strcmp(argv[i], "-s")) + smooth++; + else if (!strcmp(argv[i], "-o")) + objout++; else goto userror; - sprintf(stmp, "%s(s,t)=%s;", XNAME, argv[3]); - scompile(NULL, stmp); - sprintf(stmp, "%s(s,t)=%s;", YNAME, argv[4]); - scompile(NULL, stmp); - sprintf(stmp, "%s(s,t)=%s;", ZNAME, argv[5]); - scompile(NULL, stmp); + modname = argv[1]; + surfname = argv[2]; m = atoi(argv[6]); n = atoi(argv[7]); if (m <= 0 || n <= 0) goto userror; - - row0 = (double *)malloc((n+1)*3*sizeof(double)); - row1 = (double *)malloc((n+1)*3*sizeof(double)); - if (row0 == NULL || row1 == NULL) { + if (!strcmp(argv[5], "-") || access(argv[5], 4) == 0) { /* file? */ + funset(ZNAME, 2, ':', l_dataval); + if (!strcmp(argv[5],argv[3]) && !strcmp(argv[5],argv[4])) { + loaddata(argv[5], m, n, 3); + funset(XNAME, 2, ':', l_dataval); + funset(YNAME, 2, ':', l_dataval); + } else { + loaddata(argv[5], m, n, 1); + sprintf(stmp, "%s(s,t)=%s;", XNAME, argv[3]); + scompile(stmp, NULL, 0); + sprintf(stmp, "%s(s,t)=%s;", YNAME, argv[4]); + scompile(stmp, NULL, 0); + } + } else { + sprintf(stmp, "%s(s,t)=%s;", XNAME, argv[3]); + scompile(stmp, NULL, 0); + sprintf(stmp, "%s(s,t)=%s;", YNAME, argv[4]); + scompile(stmp, NULL, 0); + sprintf(stmp, "%s(s,t)=%s;", ZNAME, argv[5]); + scompile(stmp, NULL, 0); + } + row0 = (POINT *)malloc((n+3)*sizeof(POINT)); + row1 = (POINT *)malloc((n+3)*sizeof(POINT)); + row2 = (POINT *)malloc((n+3)*sizeof(POINT)); + if (row0 == NULL || row1 == NULL || row2 == NULL) { fprintf(stderr, "%s: out of memory\n", argv[0]); quit(1); } - + row0++; row1++; row2++; + /* print header */ printhead(argc, argv); - - comprow(0.0, row1, n); /* compute zeroeth row */ - + eclock = 0; + /* initialize */ + comprow(-1.0/m, row0, n); + comprow(0.0, row1, n); + comprow(1.0/m, row2, n); + compnorms(row0, row1, row2, n); + if (objout) { + printf("\nusemtl %s\n\n", modname); + putobjrow(row1, n); + } + /* for each row */ for (i = 0; i < m; i++) { /* compute next row */ - dp = row0; + rp = row0; row0 = row1; - row1 = dp; - comprow((double)(i+1)/m, row1, n); + row1 = row2; + row2 = rp; + comprow((double)(i+2)/m, row2, n); + compnorms(row0, row1, row2, n); + if (objout) + putobjrow(row1, n); for (j = 0; j < n; j++) { - /* get vertices */ - xyz[0] = row0 + 3*j; - xyz[1] = row1 + 3*j; - xyz[2] = xyz[0] + 3; - xyz[3] = xyz[1] + 3; - /* rotate vertices */ - if (dist2(xyz[0],xyz[3]) < dist2(xyz[1],xyz[2])-FTINY) { - dp = xyz[0]; - xyz[0] = xyz[1]; - xyz[1] = xyz[3]; - xyz[3] = xyz[2]; - xyz[2] = dp; - } - /* get normals */ - for (k = 0; k < 3; k++) { - v1[k] = xyz[1][k] - xyz[0][k]; - v2[k] = xyz[2][k] - xyz[0][k]; - } - fcross(vc1, v1, v2); - a1 = fdot(vc1, vc1); - for (k = 0; k < 3; k++) { - v1[k] = xyz[2][k] - xyz[3][k]; - v2[k] = xyz[1][k] - xyz[3][k]; - } - fcross(vc2, v1, v2); - a2 = fdot(vc2, vc2); - /* check coplanar */ - if (a1 > FTINY*FTINY && a2 > FTINY*FTINY) { - d = fdot(vc1, vc2); - if (d*d/a1/a2 >= 1.0-FTINY*FTINY) { - if (d > 0.0) { /* coplanar */ - printf( - "\n%s polygon %s.%d.%d\n", - argv[1], argv[2], i+1, j+1); - printf("0\n0\n12\n"); - vertex(xyz[0]); - vertex(xyz[1]); - vertex(xyz[3]); - vertex(xyz[2]); - } /* else overlapped */ - continue; - } /* else bent */ - } - /* check triangles */ - if (a1 > FTINY*FTINY) { - printf("\n%s polygon %s.%da%d\n", - argv[1], argv[2], i+1, j+1); - printf("0\n0\n9\n"); - vertex(xyz[0]); - vertex(xyz[1]); - vertex(xyz[2]); - } - if (a2 > FTINY*FTINY) { - printf("\n%s polygon %s.%db%d\n", - argv[1], argv[2], i+1, j+1); - printf("0\n0\n9\n"); - vertex(xyz[2]); - vertex(xyz[1]); - vertex(xyz[3]); - } + int orient = (j & 1); + /* put polygons */ + if (!(row0[j].valid && row1[j+1].valid)) + orient = 1; + else if (!(row1[j].valid && row0[j+1].valid)) + orient = 0; + if (orient) + putsquare(&row0[j], &row1[j], + &row0[j+1], &row1[j+1]); + else + putsquare(&row1[j], &row1[j+1], + &row0[j], &row0[j+1]); } } @@ -157,30 +167,392 @@ char *argv[]; userror: fprintf(stderr, "Usage: %s material name ", argv[0]); - fprintf(stderr, "x(s,t) y(s,t) z(s,t) m n [-e expr] [-f file]\n"); + fprintf(stderr, "x(s,t) y(s,t) z(s,t) m n [-s][-e expr][-f file]\n"); quit(1); } +loaddata(file, m, n, pointsize) /* load point data from file */ +char *file; +int m, n; +int pointsize; +{ + FILE *fp; + char word[64]; + register int size; + register FLOAT *dp; + + datarec.flags = HASBORDER; /* assume border values */ + datarec.m = m+1; + datarec.n = n+1; + size = datarec.m*datarec.n*pointsize; + if (pointsize == 3) + datarec.flags |= TRIPLETS; + dp = (FLOAT *)malloc(size*sizeof(FLOAT)); + if ((datarec.data = dp) == NULL) { + fputs("Out of memory\n", stderr); + exit(1); + } + if (!strcmp(file, "-")) { + file = ""; + fp = stdin; + } else if ((fp = fopen(file, "r")) == NULL) { + fputs(file, stderr); + fputs(": cannot open\n", stderr); + exit(1); + } + while (size > 0 && fgetword(word, sizeof(word), fp) != NULL) { + if (!isflt(word)) { + fprintf(stderr, "%s: garbled data value: %s\n", + file, word); + exit(1); + } + *dp++ = atof(word); + size--; + } + if (size == (m+n+1)*pointsize) { /* no border after all */ + dp = (FLOAT *)realloc((void *)datarec.data, + m*n*pointsize*sizeof(FLOAT)); + if (dp != NULL) + datarec.data = dp; + datarec.flags &= ~HASBORDER; + datarec.m = m; + datarec.n = n; + size = 0; + } + if (datarec.m < 2 || datarec.n < 2 || size != 0 || + fgetword(word, sizeof(word), fp) != NULL) { + fputs(file, stderr); + fputs(": bad number of data points\n", stderr); + exit(1); + } + fclose(fp); +} + + +double +l_dataval(nam) /* return recorded data value */ +char *nam; +{ + double u, v; + register int i, j; + register FLOAT *dp; + double d00, d01, d10, d11; + /* compute coordinates */ + u = argument(1); v = argument(2); + if (datarec.flags & HASBORDER) { + i = u *= datarec.m-1; + j = v *= datarec.n-1; + } else { + i = u = u*datarec.m - .5; + j = v = v*datarec.n - .5; + } + if (i < 0) i = 0; + else if (i > datarec.m-2) i = datarec.m-2; + if (j < 0) j = 0; + else if (j > datarec.n-2) j = datarec.n-2; + /* compute value */ + if (datarec.flags & TRIPLETS) { + dp = datarec.data + 3*(j*datarec.m + i); + if (nam == ZNAME) + dp += 2; + else if (nam == YNAME) + dp++; + d00 = dp[0]; d01 = dp[3]; + dp += 3*datarec.m; + d10 = dp[0]; d11 = dp[3]; + } else { + dp = datarec.data + j*datarec.m + i; + d00 = dp[0]; d01 = dp[1]; + dp += datarec.m; + d10 = dp[0]; d11 = dp[1]; + } + /* bilinear interpolation */ + return((j+1-v)*((i+1-u)*d00+(u-i)*d01)+(v-j)*((i+1-u)*d10+(u-i)*d11)); +} + + +putobjrow(rp, n) /* output vertex row to .OBJ */ +register POINT *rp; +int n; +{ + static int nverts = 0; + + for ( ; n-- >= 0; rp++) { + if (!rp->valid) + continue; + fputs("v ", stdout); + pvect(rp->p); + if (smooth && !ZEROVECT(rp->n)) + printf("\tvn %.9g %.9g %.9g\n", + rp->n[0], rp->n[1], rp->n[2]); + printf("\tvt %.9g %.9g\n", rp->uv[0], rp->uv[1]); + rp->valid = ++nverts; + } +} + + +putsquare(p0, p1, p2, p3) /* put out a square */ +POINT *p0, *p1, *p2, *p3; +{ + static int nout = 0; + FVECT norm[4]; + int axis; + FVECT v1, v2, vc1, vc2; + int ok1, ok2; + /* compute exact normals */ + ok1 = (p0->valid && p1->valid && p2->valid); + if (ok1) { + VSUB(v1, p1->p, p0->p); + VSUB(v2, p2->p, p0->p); + fcross(vc1, v1, v2); + ok1 = (normalize(vc1) != 0.0); + } + ok2 = (p1->valid && p2->valid && p3->valid); + if (ok2) { + VSUB(v1, p2->p, p3->p); + VSUB(v2, p1->p, p3->p); + fcross(vc2, v1, v2); + ok2 = (normalize(vc2) != 0.0); + } + if (!(ok1 | ok2)) + return; + if (objout) { /* output .OBJ faces */ + int p0n=0, p1n=0, p2n=0, p3n=0; + if (smooth) { + if (!ZEROVECT(p0->n)) + p0n = p0->valid; + if (!ZEROVECT(p1->n)) + p1n = p1->valid; + if (!ZEROVECT(p2->n)) + p2n = p2->valid; + if (!ZEROVECT(p3->n)) + p3n = p3->valid; + } + if (ok1 & ok2 && fdot(vc1,vc2) >= 1.0-FTINY*FTINY) { + printf("f %d/%d/%d %d/%d/%d %d/%d/%d %d/%d/%d\n", + p0->valid, p0->valid, p0n, + p1->valid, p1->valid, p1n, + p3->valid, p3->valid, p3n, + p2->valid, p2->valid, p2n); + return; + } + if (ok1) + printf("f %d/%d/%d %d/%d/%d %d/%d/%d\n", + p0->valid, p0->valid, p0n, + p1->valid, p1->valid, p1n, + p2->valid, p2->valid, p2n); + if (ok2) + printf("f %d/%d/%d %d/%d/%d %d/%d/%d\n", + p2->valid, p2->valid, p2n, + p1->valid, p1->valid, p1n, + p3->valid, p3->valid, p3n); + return; + } + /* compute normal interpolation */ + axis = norminterp(norm, p0, p1, p2, p3); + + /* put out quadrilateral? */ + if (ok1 & ok2 && fdot(vc1,vc2) >= 1.0-FTINY*FTINY) { + printf("\n%s ", modname); + if (axis != -1) { + printf("texfunc %s\n", texname); + printf(tsargs); + printf("0\n13\t%d\n", axis); + pvect(norm[0]); + pvect(norm[1]); + pvect(norm[2]); + fvsum(v1, norm[3], vc1, -0.5); + fvsum(v1, v1, vc2, -0.5); + pvect(v1); + printf("\n%s ", texname); + } + printf("polygon %s.%d\n", surfname, ++nout); + printf("0\n0\n12\n"); + pvect(p0->p); + pvect(p1->p); + pvect(p3->p); + pvect(p2->p); + return; + } + /* put out triangles? */ + if (ok1) { + printf("\n%s ", modname); + if (axis != -1) { + printf("texfunc %s\n", texname); + printf(tsargs); + printf("0\n13\t%d\n", axis); + pvect(norm[0]); + pvect(norm[1]); + pvect(norm[2]); + fvsum(v1, norm[3], vc1, -1.0); + pvect(v1); + printf("\n%s ", texname); + } + printf("polygon %s.%d\n", surfname, ++nout); + printf("0\n0\n9\n"); + pvect(p0->p); + pvect(p1->p); + pvect(p2->p); + } + if (ok2) { + printf("\n%s ", modname); + if (axis != -1) { + printf("texfunc %s\n", texname); + printf(tsargs); + printf("0\n13\t%d\n", axis); + pvect(norm[0]); + pvect(norm[1]); + pvect(norm[2]); + fvsum(v2, norm[3], vc2, -1.0); + pvect(v2); + printf("\n%s ", texname); + } + printf("polygon %s.%d\n", surfname, ++nout); + printf("0\n0\n9\n"); + pvect(p2->p); + pvect(p1->p); + pvect(p3->p); + } +} + + comprow(s, row, siz) /* compute row of values */ double s; -register double *row; +register POINT *row; int siz; { - double st[2], step; - + double st[2]; + int end; + int checkvalid; + register int i; + + if (smooth) { + i = -1; /* compute one past each end */ + end = siz+1; + } else { + if (s < -FTINY || s > 1.0+FTINY) + return; + i = 0; + end = siz; + } st[0] = s; - st[1] = 0.0; - step = 1.0 / siz; + checkvalid = (fundefined(VNAME) == 2); + while (i <= end) { + st[1] = (double)i/siz; + if (checkvalid && funvalue(VNAME, 2, st) <= 0.0) { + row[i].valid = 0; + row[i].p[0] = row[i].p[1] = row[i].p[2] = 0.0; + row[i].uv[0] = row[i].uv[1] = 0.0; + } else { + row[i].valid = 1; + row[i].p[0] = funvalue(XNAME, 2, st); + row[i].p[1] = funvalue(YNAME, 2, st); + row[i].p[2] = funvalue(ZNAME, 2, st); + row[i].uv[0] = st[0]; + row[i].uv[1] = st[1]; + } + i++; + } +} + + +compnorms(r0, r1, r2, siz) /* compute row of averaged normals */ +register POINT *r0, *r1, *r2; +int siz; +{ + FVECT v1, v2; + + if (!smooth) /* not needed if no smoothing */ + return; + /* compute row 1 normals */ while (siz-- >= 0) { - *row++ = funvalue(XNAME, 2, st); - *row++ = funvalue(YNAME, 2, st); - *row++ = funvalue(ZNAME, 2, st); - st[1] += step; + if (!r1[0].valid) + continue; + if (!r0[0].valid) { + if (!r2[0].valid) { + r1[0].n[0] = r1[0].n[1] = r1[0].n[2] = 0.0; + continue; + } + fvsum(v1, r2[0].p, r1[0].p, -1.0); + } else if (!r2[0].valid) + fvsum(v1, r1[0].p, r0[0].p, -1.0); + else + fvsum(v1, r2[0].p, r0[0].p, -1.0); + if (!r1[-1].valid) { + if (!r1[1].valid) { + r1[0].n[0] = r1[0].n[1] = r1[0].n[2] = 0.0; + continue; + } + fvsum(v2, r1[1].p, r1[0].p, -1.0); + } else if (!r1[1].valid) + fvsum(v2, r1[0].p, r1[-1].p, -1.0); + else + fvsum(v2, r1[1].p, r1[-1].p, -1.0); + fcross(r1[0].n, v1, v2); + normalize(r1[0].n); + r0++; r1++; r2++; } } +int +norminterp(resmat, p0, p1, p2, p3) /* compute normal interpolation */ +register FVECT resmat[4]; +POINT *p0, *p1, *p2, *p3; +{ +#define u ((ax+1)%3) +#define v ((ax+2)%3) + + register int ax; + MAT4 eqnmat; + FVECT v1; + register int i, j; + + if (!smooth) /* no interpolation if no smoothing */ + return(-1); + /* find dominant axis */ + VCOPY(v1, p0->n); + fvsum(v1, v1, p1->n, 1.0); + fvsum(v1, v1, p2->n, 1.0); + fvsum(v1, v1, p3->n, 1.0); + ax = ABS(v1[0]) > ABS(v1[1]) ? 0 : 1; + ax = ABS(v1[ax]) > ABS(v1[2]) ? ax : 2; + /* assign equation matrix */ + eqnmat[0][0] = p0->p[u]*p0->p[v]; + eqnmat[0][1] = p0->p[u]; + eqnmat[0][2] = p0->p[v]; + eqnmat[0][3] = 1.0; + eqnmat[1][0] = p1->p[u]*p1->p[v]; + eqnmat[1][1] = p1->p[u]; + eqnmat[1][2] = p1->p[v]; + eqnmat[1][3] = 1.0; + eqnmat[2][0] = p2->p[u]*p2->p[v]; + eqnmat[2][1] = p2->p[u]; + eqnmat[2][2] = p2->p[v]; + eqnmat[2][3] = 1.0; + eqnmat[3][0] = p3->p[u]*p3->p[v]; + eqnmat[3][1] = p3->p[u]; + eqnmat[3][2] = p3->p[v]; + eqnmat[3][3] = 1.0; + /* invert matrix (solve system) */ + if (!invmat4(eqnmat, eqnmat)) + return(-1); /* no solution */ + /* compute result matrix */ + for (j = 0; j < 4; j++) + for (i = 0; i < 3; i++) + resmat[j][i] = eqnmat[j][0]*p0->n[i] + + eqnmat[j][1]*p1->n[i] + + eqnmat[j][2]*p2->n[i] + + eqnmat[j][3]*p3->n[i]; + return(ax); + +#undef u +#undef v +} + + +void eputs(msg) char *msg; { @@ -188,6 +560,7 @@ char *msg; } +void wputs(msg) char *msg; { @@ -195,7 +568,9 @@ char *msg; } +void quit(code) +int code; { exit(code); } @@ -224,4 +599,30 @@ l_hermite() argument(2)*(-2.0*t+3.0)*t*t + argument(3)*((t-2.0)*t+1.0)*t + argument(4)*(t-1.0)*t*t ); +} + + +double +l_bezier() +{ + double t; + + t = argument(5); + return( argument(1) * (1.+t*(-3.+t*(3.-t))) + + argument(2) * 3.*t*(1.+t*(-2.+t)) + + argument(3) * 3.*t*t*(1.-t) + + argument(4) * t*t*t ); +} + + +double +l_bspline() +{ + double t; + + t = argument(5); + return( argument(1) * (1./6.+t*(-1./2.+t*(1./2.-1./6.*t))) + + argument(2) * (2./3.+t*t*(-1.+1./2.*t)) + + argument(3) * (1./6.+t*(1./2.+t*(1./2.-1./2.*t))) + + argument(4) * (1./6.*t*t*t) ); }
