root/radiance/ray/src/gen/gensurf.c
Thu Oct 18 03:59:54 2007 UTC (16 years, 7 months ago) by greg
CVS Tags: rad3R9, rad4R0
Diff to previous 2.17 , to selected 1.14
Increased vertex output accuracy
Tue Oct 9 04:44:54 2007 UTC (16 years, 8 months ago) by greg
Diff to previous 2.16 , to selected 1.14
Added missing -o option from Usage
Sat Aug 21 11:54:06 2004 UTC (19 years, 9 months ago) by greg
Changes since 2.15: +5 -42 lines
Diff to previous 2.15 , to selected 1.14
Fri Mar 26 21:30:12 2004 UTC (20 years, 2 months ago) by schorsch
Diff to previous 2.14 , to selected 1.14
Added "paths.h" for access().
Tue Mar 23 15:18:09 2004 UTC (20 years, 2 months ago) by greg
Changes since 2.13: +2 -4 lines
Diff to previous 2.13 , to selected 1.14
Fixed missing declaration for atof()
Changes since 2.12: +66 -30 lines
Diff to previous 2.12 , to selected 1.14
Mon Aug 4 22:37:53 2003 UTC (20 years, 10 months ago) by greg
Diff to previous 2.11 , to selected 1.14
Diff to previous 2.10 , to selected 1.14
Wed Apr 23 00:52:33 2003 UTC (21 years, 1 month ago) by greg
Diff to previous 2.9 , to selected 1.14
Wed Mar 12 04:59:04 2003 UTC (21 years, 3 months ago) by greg
Changes since 2.8: +26 -20 lines
Diff to previous 2.8 , to selected 1.14
Tue Mar 11 22:57:45 2003 UTC (21 years, 3 months ago) by greg
Diff to previous 2.7 , to selected 1.14
Bug fix in output of .OBJ usemtl statement
Tue Mar 11 22:48:20 2003 UTC (21 years, 3 months ago) by greg
Changes since 2.6: +65 -6 lines
Diff to previous 2.6 , to selected 1.14
Changes since 2.5: +66 -23 lines
Diff to previous 2.5 , to selected 1.14
Tue Apr 12 15:16:15 1994 UTC (30 years, 2 months ago) by greg
Changes since 2.4: +1 -59 lines
Diff to previous 2.4 , to selected 1.14
moved 4x4 matrix inversion routine to library module
Thu Nov 18 09:33:04 1993 UTC (30 years, 6 months ago) by greg
Diff to previous 2.3 , to selected 1.14
minor compiler warning fixes
Wed Feb 5 21:05:00 1992 UTC (32 years, 4 months ago) by greg
Changes since 2.2: +18 -13 lines
Diff to previous 2.2 , to selected 1.14
bug fixes
Thu Jan 30 14:11:39 1992 UTC (32 years, 4 months ago) by greg
Changes since 2.1: +132 -11 lines
Diff to previous 2.1 , to selected 1.14
added ability to get point values from a file
Tue Nov 12 17:04:49 1991 UTC (32 years, 7 months ago) by greg
Diff to previous 1.15 , to selected 1.14
Tue Aug 13 16:07:14 1991 UTC (32 years, 10 months ago) by greg
Changes since 1.14: +3 -3 lines
Diff to previous 1.14
changed private variable names with `SYS` context
Revision 1.14 - (view) (download) (annotate) - [selected]
Tue Apr 23 15:51:11 1991 UTC (33 years, 1 month ago) by greg
Diff to previous 1.13
Tue Apr 23 13:04:58 1991 UTC (33 years, 1 month ago) by greg
Diff to previous 1.12 , to selected 1.14
changed arguments to varset()
Sat Dec 15 15:00:52 1990 UTC (33 years, 6 months ago) by greg
Changes since 1.11: +4 -4 lines
Diff to previous 1.11 , to selected 1.14
added MAT4 type
Thu Aug 2 13:42:56 1990 UTC (33 years, 10 months ago) by greg
Changes since 1.10: +5 -14 lines
Diff to previous 1.10 , to selected 1.14
simplified average normal calculation
Fri Jul 20 14:35:59 1990 UTC (33 years, 10 months ago) by greg
Changes since 1.9: +4 -4 lines
Diff to previous 1.9 , to selected 1.14
Mon Jul 9 09:55:47 1990 UTC (33 years, 11 months ago) by greg
Diff to previous 1.8 , to selected 1.14
set eclock variable for more efficient computations
Sat May 26 19:44:40 1990 UTC (34 years ago) by greg
Changes since 1.7: +13 -2 lines
Diff to previous 1.7 , to selected 1.14
eliminated computations outside [0,1] for unsmoothed surfaces
Wed Mar 7 11:14:36 1990 UTC (34 years, 3 months ago) by greg
Changes since 1.6: +17 -3 lines
Diff to previous 1.6 , to selected 1.14
added bezier and bspline functions
Fri Mar 2 17:24:02 1990 UTC (34 years, 3 months ago) by greg
Changes since 1.5: +15 -1 lines
Diff to previous 1.5 , to selected 1.14
Added Bezier cubic function
Fri Jan 19 00:03:08 1990 UTC (34 years, 4 months ago) by greg
Changes since 1.4: +2 -7 lines
Diff to previous 1.4 , to selected 1.14
Wed Oct 18 18:49:09 1989 UTC (34 years, 7 months ago) by greg
Changes since 1.3: +51 -79 lines
Diff to previous 1.3 , to selected 1.14
improved smoothing at edges, improved stability of invmat()
Wed Oct 18 15:01:23 1989 UTC (34 years, 7 months ago) by greg
Changes since 1.2: +307 -83 lines
Diff to previous 1.2 , to selected 1.14
added smoothing option
Sun Sep 10 16:45:16 1989 UTC (34 years, 9 months ago) by greg
Diff to previous 1.1 , to selected 1.14
fixed location of SCCSid
Thu Feb 2 11:16:30 1989 UTC (35 years, 4 months ago) by greg
Diff to selected 1.14
