--- ray/src/gen/gensurf.c 2003/03/11 22:48:20 2.7 +++ ray/src/gen/gensurf.c 2003/04/23 00:52:33 2.10 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: gensurf.c,v 2.7 2003/03/11 22:48:20 greg Exp $"; +static const char RCSid[] = "$Id: gensurf.c,v 2.10 2003/04/23 00:52:33 greg Exp $"; #endif /* * gensurf.c - program to generate functional surfaces @@ -25,6 +25,8 @@ char VNAME[] = "valid"; /* valid vertex name */ #define ABS(x) ((x)>=0 ? (x) : -(x)) +#define ZEROVECT(v) (DOT(v,v) <= FTINY*FTINY) + #define pvect(p) printf(vformat, (p)[0], (p)[1], (p)[2]) char vformat[] = "%15.9g %15.9g %15.9g\n"; @@ -129,8 +131,10 @@ char *argv[]; comprow(0.0, row1, n); comprow(1.0/m, row2, n); compnorms(row0, row1, row2, n); - if (objout) + if (objout) { + printf("\nusemtl %s\n\n", modname); putobjrow(row1, n); + } /* for each row */ for (i = 0; i < m; i++) { /* compute next row */ @@ -207,7 +211,7 @@ int pointsize; size--; } if (size == (m+n+1)*pointsize) { /* no border after all */ - dp = (FLOAT *)realloc((char *)datarec.data, + dp = (FLOAT *)realloc((void *)datarec.data, m*n*pointsize*sizeof(FLOAT)); if (dp != NULL) datarec.data = dp; @@ -278,8 +282,8 @@ int n; if (!rp->valid) continue; fputs("v ", stdout); - printf(vformat, rp->p[0], rp->p[1], rp->p[2]); - if (smooth) + pvect(rp->p); + if (smooth && !ZEROVECT(rp->n)) printf("\tvn %.9g %.9g %.9g\n", rp->n[0], rp->n[1], rp->n[2]); printf("\tvt %.9g %.9g\n", rp->uv[0], rp->uv[1]); @@ -299,15 +303,15 @@ POINT *p0, *p1, *p2, *p3; /* compute exact normals */ ok1 = (p0->valid && p1->valid && p2->valid); if (ok1) { - fvsum(v1, p1->p, p0->p, -1.0); - fvsum(v2, p2->p, p0->p, -1.0); + VSUB(v1, p1->p, p0->p); + VSUB(v2, p2->p, p0->p); fcross(vc1, v1, v2); ok1 = (normalize(vc1) != 0.0); } ok2 = (p1->valid && p2->valid && p3->valid); if (ok2) { - fvsum(v1, p2->p, p3->p, -1.0); - fvsum(v2, p1->p, p3->p, -1.0); + VSUB(v1, p2->p, p3->p); + VSUB(v2, p1->p, p3->p); fcross(vc2, v1, v2); ok2 = (normalize(vc2) != 0.0); } @@ -316,29 +320,33 @@ POINT *p0, *p1, *p2, *p3; if (objout) { /* output .OBJ faces */ int p0n=0, p1n=0, p2n=0, p3n=0; if (smooth) { - p0n = p0->valid; - p1n = p1->valid; - p2n = p2->valid; - p3n = p3->valid; + if (!ZEROVECT(p0->n)) + p0n = p0->valid; + if (!ZEROVECT(p1->n)) + p1n = p1->valid; + if (!ZEROVECT(p2->n)) + p2n = p2->valid; + if (!ZEROVECT(p3->n)) + p3n = p3->valid; } if (ok1 & ok2 && fdot(vc1,vc2) >= 1.0-FTINY*FTINY) { printf("f %d/%d/%d %d/%d/%d %d/%d/%d %d/%d/%d\n", - p0->valid, p0n, p0->valid, - p1->valid, p1n, p1->valid, - p3->valid, p3n, p3->valid, - p2->valid, p2n, p2->valid); + p0->valid, p0->valid, p0n, + p1->valid, p1->valid, p1n, + p3->valid, p3->valid, p3n, + p2->valid, p2->valid, p2n); return; } if (ok1) printf("f %d/%d/%d %d/%d/%d %d/%d/%d\n", - p0->valid, p0n, p0->valid, - p1->valid, p1n, p1->valid, - p2->valid, p2n, p2->valid); + p0->valid, p0->valid, p0n, + p1->valid, p1->valid, p1n, + p2->valid, p2->valid, p2n); if (ok2) printf("f %d/%d/%d %d/%d/%d %d/%d/%d\n", - p2->valid, p2n, p2->valid, - p1->valid, p1n, p1->valid, - p3->valid, p3n, p3->valid); + p2->valid, p2->valid, p2n, + p1->valid, p1->valid, p1n, + p3->valid, p3->valid, p3n); return; } /* compute normal interpolation */
