root/Development/ray/src/gen/gensurf.c
Revision: 2.8
Committed: Tue Mar 11 22:57:45 2003 UTC (22 years, 9 months ago) by greg
Bug fix in output of .OBJ usemtl statement
5 * gensurf.c - program to generate functional surfaces
6 *
7 * Parametric functions x(s,t), y(s,t) and z(s,t)
8 * specify the surface, which is tesselated into an m by n
9 * array of paired triangles.
10 * The surface normal is defined by the right hand
11 * rule applied to (s,t).
12 *
13 * 4/3/87
14 *
15 * 4/16/02 Added conditional vertex output
16 */
17
18 #include "standard.h"
19
20 char XNAME[] = "X`SYS"; /* x function name */
21 char YNAME[] = "Y`SYS"; /* y function name */
22 char ZNAME[] = "Z`SYS"; /* z function name */
23
24 char VNAME[] = "valid"; /* valid vertex name */
25
26 #define ABS(x) ((x)>=0 ? (x) : -(x))
27
28 #define pvect(p) printf(vformat, (p)[0], (p)[1], (p)[2])
29
30 char vformat[] = "%15.9g %15.9g %15.9g\n";
31 char tsargs[] = "4 surf_dx surf_dy surf_dz surf.cal\n";
32 char texname[] = "Phong";
33
34 int smooth = 0; /* apply smoothing? */
35 int objout = 0; /* output .OBJ format? */
36
37 char *modname, *surfname;
38
39 /* recorded data flags */
40 #define HASBORDER 01
41 #define TRIPLETS 02
42 /* a data structure */
43 struct {
44 int flags; /* data type */
45 short m, n; /* number of s and t values */
46 FLOAT *data; /* the data itself, s major sort */
47 } datarec; /* our recorded data */
48
49 double l_hermite(), l_bezier(), l_bspline(), l_dataval();
50 extern double funvalue(), argument();
51
52 typedef struct {
53 int valid; /* point is valid (vertex number) */
54 FVECT p; /* vertex position */
55 FVECT n; /* average normal */
56 FLOAT uv[2]; /* (u,v) position */
57 } POINT;
58
59
60 main(argc, argv)
61 int argc;
62 char *argv[];
63 {
64 extern long eclock;
65 POINT *row0, *row1, *row2, *rp;
66 int i, j, m, n;
67 char stmp[256];
68
69 varset("PI", ':', PI);
70 funset("hermite", 5, ':', l_hermite);
71 funset("bezier", 5, ':', l_bezier);
72 funset("bspline", 5, ':', l_bspline);
73
74 if (argc < 8)
75 goto userror;
76
77 for (i = 8; i < argc; i++)
78 if (!strcmp(argv[i], "-e"))
79 scompile(argv[++i], NULL, 0);
80 else if (!strcmp(argv[i], "-f"))
81 fcompile(argv[++i]);
82 else if (!strcmp(argv[i], "-s"))
83 smooth++;
84 else if (!strcmp(argv[i], "-o"))
85 objout++;
86 else
87 goto userror;
88
89 modname = argv[1];
90 surfname = argv[2];
91 m = atoi(argv[6]);
92 n = atoi(argv[7]);
93 if (m <= 0 || n <= 0)
94 goto userror;
95 if (!strcmp(argv[5], "-") || access(argv[5], 4) == 0) { /* file? */
96 funset(ZNAME, 2, ':', l_dataval);
97 if (!strcmp(argv[5],argv[3]) && !strcmp(argv[5],argv[4])) {
98 loaddata(argv[5], m, n, 3);
99 funset(XNAME, 2, ':', l_dataval);
100 funset(YNAME, 2, ':', l_dataval);
101 } else {
102 loaddata(argv[5], m, n, 1);
103 sprintf(stmp, "%s(s,t)=%s;", XNAME, argv[3]);
104 scompile(stmp, NULL, 0);
105 sprintf(stmp, "%s(s,t)=%s;", YNAME, argv[4]);
106 scompile(stmp, NULL, 0);
107 }
108 } else {
109 sprintf(stmp, "%s(s,t)=%s;", XNAME, argv[3]);
110 scompile(stmp, NULL, 0);
111 sprintf(stmp, "%s(s,t)=%s;", YNAME, argv[4]);
112 scompile(stmp, NULL, 0);
113 sprintf(stmp, "%s(s,t)=%s;", ZNAME, argv[5]);
114 scompile(stmp, NULL, 0);
115 }
116 row0 = (POINT *)malloc((n+3)*sizeof(POINT));
117 row1 = (POINT *)malloc((n+3)*sizeof(POINT));
118 row2 = (POINT *)malloc((n+3)*sizeof(POINT));
119 if (row0 == NULL || row1 == NULL || row2 == NULL) {
120 fprintf(stderr, "%s: out of memory\n", argv[0]);
121 quit(1);
122 }
123 row0++; row1++; row2++;
124 /* print header */
125 printhead(argc, argv);
126 eclock = 0;
127 /* initialize */
128 comprow(-1.0/m, row0, n);
129 comprow(0.0, row1, n);
130 comprow(1.0/m, row2, n);
131 compnorms(row0, row1, row2, n);
132 if (objout) {
133 printf("\nusemtl %s\n\n", modname);
134 putobjrow(row1, n);
135 }
136 /* for each row */
137 for (i = 0; i < m; i++) {
138 /* compute next row */
139 rp = row0;
140 row0 = row1;
141 row1 = row2;
142 row2 = rp;
143 comprow((double)(i+2)/m, row2, n);
144 compnorms(row0, row1, row2, n);
145 if (objout)
146 putobjrow(row1, n);
147
148 for (j = 0; j < n; j++) {
149 int orient = (j & 1);
150 /* put polygons */
151 if (!(row0[j].valid && row1[j+1].valid))
152 orient = 1;
153 else if (!(row1[j].valid && row0[j+1].valid))
154 orient = 0;
155 if (orient)
156 putsquare(&row0[j], &row1[j],
157 &row0[j+1], &row1[j+1]);
158 else
159 putsquare(&row1[j], &row1[j+1],
160 &row0[j], &row0[j+1]);
161 }
162 }
163
164 quit(0);
165
166 userror:
167 fprintf(stderr, "Usage: %s material name ", argv[0]);
168 fprintf(stderr, "x(s,t) y(s,t) z(s,t) m n [-s][-e expr][-f file]\n");
169 quit(1);
170 }
171
172
173 loaddata(file, m, n, pointsize) /* load point data from file */
174 char *file;
175 int m, n;
176 int pointsize;
177 {
178 FILE *fp;
179 char word[64];
180 register int size;
181 register FLOAT *dp;
182
183 datarec.flags = HASBORDER; /* assume border values */
184 datarec.m = m+1;
185 datarec.n = n+1;
186 size = datarec.m*datarec.n*pointsize;
187 if (pointsize == 3)
188 datarec.flags |= TRIPLETS;
189 dp = (FLOAT *)malloc(size*sizeof(FLOAT));
190 if ((datarec.data = dp) == NULL) {
191 fputs("Out of memory\n", stderr);
192 exit(1);
193 }
194 if (!strcmp(file, "-")) {
195 file = "<stdin>";
196 fp = stdin;
197 } else if ((fp = fopen(file, "r")) == NULL) {
198 fputs(file, stderr);
199 fputs(": cannot open\n", stderr);
200 exit(1);
201 }
202 while (size > 0 && fgetword(word, sizeof(word), fp) != NULL) {
203 if (!isflt(word)) {
204 fprintf(stderr, "%s: garbled data value: %s\n",
205 file, word);
206 exit(1);
207 }
208 *dp++ = atof(word);
209 size--;
210 }
211 if (size == (m+n+1)*pointsize) { /* no border after all */
212 dp = (FLOAT *)realloc((char *)datarec.data,
213 m*n*pointsize*sizeof(FLOAT));
214 if (dp != NULL)
215 datarec.data = dp;
216 datarec.flags &= ~HASBORDER;
217 datarec.m = m;
218 datarec.n = n;
219 size = 0;
220 }
221 if (datarec.m < 2 || datarec.n < 2 || size != 0 ||
222 fgetword(word, sizeof(word), fp) != NULL) {
223 fputs(file, stderr);
224 fputs(": bad number of data points\n", stderr);
225 exit(1);
226 }
227 fclose(fp);
228 }
229
230
231 double
232 l_dataval(nam) /* return recorded data value */
233 char *nam;
234 {
235 double u, v;
236 register int i, j;
237 register FLOAT *dp;
238 double d00, d01, d10, d11;
239 /* compute coordinates */
240 u = argument(1); v = argument(2);
241 if (datarec.flags & HASBORDER) {
242 i = u *= datarec.m-1;
243 j = v *= datarec.n-1;
244 } else {
245 i = u = u*datarec.m - .5;
246 j = v = v*datarec.n - .5;
247 }
248 if (i < 0) i = 0;
249 else if (i > datarec.m-2) i = datarec.m-2;
250 if (j < 0) j = 0;
251 else if (j > datarec.n-2) j = datarec.n-2;
252 /* compute value */
253 if (datarec.flags & TRIPLETS) {
254 dp = datarec.data + 3*(j*datarec.m + i);
255 if (nam == ZNAME)
256 dp += 2;
257 else if (nam == YNAME)
258 dp++;
259 d00 = dp[0]; d01 = dp[3];
260 dp += 3*datarec.m;
261 d10 = dp[0]; d11 = dp[3];
262 } else {
263 dp = datarec.data + j*datarec.m + i;
264 d00 = dp[0]; d01 = dp[1];
265 dp += datarec.m;
266 d10 = dp[0]; d11 = dp[1];
267 }
268 /* bilinear interpolation */
269 return((j+1-v)*((i+1-u)*d00+(u-i)*d01)+(v-j)*((i+1-u)*d10+(u-i)*d11));
270 }
271
272
273 putobjrow(rp, n) /* output vertex row to .OBJ */
274 register POINT *rp;
275 int n;
276 {
277 static int nverts = 0;
278
279 for ( ; n-- >= 0; rp++) {
280 if (!rp->valid)
281 continue;
282 fputs("v ", stdout);
283 printf(vformat, rp->p[0], rp->p[1], rp->p[2]);
284 if (smooth)
285 printf("\tvn %.9g %.9g %.9g\n",
286 rp->n[0], rp->n[1], rp->n[2]);
287 printf("\tvt %.9g %.9g\n", rp->uv[0], rp->uv[1]);
288 rp->valid = ++nverts;
289 }
290 }
291
292
293 putsquare(p0, p1, p2, p3) /* put out a square */
294 POINT *p0, *p1, *p2, *p3;
295 {
296 static int nout = 0;
297 FVECT norm[4];
298 int axis;
299 FVECT v1, v2, vc1, vc2;
300 int ok1, ok2;
301 /* compute exact normals */
302 ok1 = (p0->valid && p1->valid && p2->valid);
303 if (ok1) {
304 fvsum(v1, p1->p, p0->p, -1.0);
305 fvsum(v2, p2->p, p0->p, -1.0);
306 fcross(vc1, v1, v2);
307 ok1 = (normalize(vc1) != 0.0);
308 }
309 ok2 = (p1->valid && p2->valid && p3->valid);
310 if (ok2) {
311 fvsum(v1, p2->p, p3->p, -1.0);
312 fvsum(v2, p1->p, p3->p, -1.0);
313 fcross(vc2, v1, v2);
314 ok2 = (normalize(vc2) != 0.0);
315 }
316 if (!(ok1 | ok2))
317 return;
318 if (objout) { /* output .OBJ faces */
319 int p0n=0, p1n=0, p2n=0, p3n=0;
320 if (smooth) {
321 p0n = p0->valid;
322 p1n = p1->valid;
323 p2n = p2->valid;
324 p3n = p3->valid;
325 }
326 if (ok1 & ok2 && fdot(vc1,vc2) >= 1.0-FTINY*FTINY) {
327 printf("f %d/%d/%d %d/%d/%d %d/%d/%d %d/%d/%d\n",
328 p0->valid, p0n, p0->valid,
329 p1->valid, p1n, p1->valid,
330 p3->valid, p3n, p3->valid,
331 p2->valid, p2n, p2->valid);
332 return;
333 }
334 if (ok1)
335 printf("f %d/%d/%d %d/%d/%d %d/%d/%d\n",
336 p0->valid, p0n, p0->valid,
337 p1->valid, p1n, p1->valid,
338 p2->valid, p2n, p2->valid);
339 if (ok2)
340 printf("f %d/%d/%d %d/%d/%d %d/%d/%d\n",
341 p2->valid, p2n, p2->valid,
342 p1->valid, p1n, p1->valid,
343 p3->valid, p3n, p3->valid);
344 return;
345 }
346 /* compute normal interpolation */
347 axis = norminterp(norm, p0, p1, p2, p3);
348
349 /* put out quadrilateral? */
350 if (ok1 & ok2 && fdot(vc1,vc2) >= 1.0-FTINY*FTINY) {
351 printf("\n%s ", modname);
352 if (axis != -1) {
353 printf("texfunc %s\n", texname);
354 printf(tsargs);
355 printf("0\n13\t%d\n", axis);
356 pvect(norm[0]);
357 pvect(norm[1]);
358 pvect(norm[2]);
359 fvsum(v1, norm[3], vc1, -0.5);
360 fvsum(v1, v1, vc2, -0.5);
361 pvect(v1);
362 printf("\n%s ", texname);
363 }
364 printf("polygon %s.%d\n", surfname, ++nout);
365 printf("0\n0\n12\n");
366 pvect(p0->p);
367 pvect(p1->p);
368 pvect(p3->p);
369 pvect(p2->p);
370 return;
371 }
372 /* put out triangles? */
373 if (ok1) {
374 printf("\n%s ", modname);
375 if (axis != -1) {
376 printf("texfunc %s\n", texname);
377 printf(tsargs);
378 printf("0\n13\t%d\n", axis);
379 pvect(norm[0]);
380 pvect(norm[1]);
381 pvect(norm[2]);
382 fvsum(v1, norm[3], vc1, -1.0);
383 pvect(v1);
384 printf("\n%s ", texname);
385 }
386 printf("polygon %s.%d\n", surfname, ++nout);
387 printf("0\n0\n9\n");
388 pvect(p0->p);
389 pvect(p1->p);
390 pvect(p2->p);
391 }
392 if (ok2) {
393 printf("\n%s ", modname);
394 if (axis != -1) {
395 printf("texfunc %s\n", texname);
396 printf(tsargs);
397 printf("0\n13\t%d\n", axis);
398 pvect(norm[0]);
399 pvect(norm[1]);
400 pvect(norm[2]);
401 fvsum(v2, norm[3], vc2, -1.0);
402 pvect(v2);
403 printf("\n%s ", texname);
404 }
405 printf("polygon %s.%d\n", surfname, ++nout);
406 printf("0\n0\n9\n");
407 pvect(p2->p);
408 pvect(p1->p);
409 pvect(p3->p);
410 }
411 }
412
413
414 comprow(s, row, siz) /* compute row of values */
415 double s;
416 register POINT *row;
417 int siz;
418 {
419 double st[2];
420 int end;
421 int checkvalid;
422 register int i;
423
424 if (smooth) {
425 i = -1; /* compute one past each end */
426 end = siz+1;
427 } else {
428 if (s < -FTINY || s > 1.0+FTINY)
429 return;
430 i = 0;
431 end = siz;
432 }
433 st[0] = s;
434 checkvalid = (fundefined(VNAME) == 2);
435 while (i <= end) {
436 st[1] = (double)i/siz;
437 if (checkvalid && funvalue(VNAME, 2, st) <= 0.0) {
438 row[i].valid = 0;
439 row[i].p[0] = row[i].p[1] = row[i].p[2] = 0.0;
440 row[i].uv[0] = row[i].uv[1] = 0.0;
441 } else {
442 row[i].valid = 1;
443 row[i].p[0] = funvalue(XNAME, 2, st);
444 row[i].p[1] = funvalue(YNAME, 2, st);
445 row[i].p[2] = funvalue(ZNAME, 2, st);
446 row[i].uv[0] = st[0];
447 row[i].uv[1] = st[1];
448 }
449 i++;
450 }
451 }
452
453
454 compnorms(r0, r1, r2, siz) /* compute row of averaged normals */
455 register POINT *r0, *r1, *r2;
456 int siz;
457 {
458 FVECT v1, v2;
459
460 if (!smooth) /* not needed if no smoothing */
461 return;
462 /* compute row 1 normals */
463 while (siz-- >= 0) {
464 if (!r1[0].valid)
465 continue;
466 if (!r0[0].valid) {
467 if (!r2[0].valid) {
468 r1[0].n[0] = r1[0].n[1] = r1[0].n[2] = 0.0;
469 continue;
470 }
471 fvsum(v1, r2[0].p, r1[0].p, -1.0);
472 } else if (!r2[0].valid)
473 fvsum(v1, r1[0].p, r0[0].p, -1.0);
474 else
475 fvsum(v1, r2[0].p, r0[0].p, -1.0);
476 if (!r1[-1].valid) {
477 if (!r1[1].valid) {
478 r1[0].n[0] = r1[0].n[1] = r1[0].n[2] = 0.0;
479 continue;
480 }
481 fvsum(v2, r1[1].p, r1[0].p, -1.0);
482 } else if (!r1[1].valid)
483 fvsum(v2, r1[0].p, r1[-1].p, -1.0);
484 else
485 fvsum(v2, r1[1].p, r1[-1].p, -1.0);
486 fcross(r1[0].n, v1, v2);
487 normalize(r1[0].n);
488 r0++; r1++; r2++;
489 }
490 }
491
492
493 int
494 norminterp(resmat, p0, p1, p2, p3) /* compute normal interpolation */
495 register FVECT resmat[4];
496 POINT *p0, *p1, *p2, *p3;
497 {
498 #define u ((ax+1)%3)
499 #define v ((ax+2)%3)
500
501 register int ax;
502 MAT4 eqnmat;
503 FVECT v1;
504 register int i, j;
505
506 if (!smooth) /* no interpolation if no smoothing */
507 return(-1);
508 /* find dominant axis */
509 VCOPY(v1, p0->n);
510 fvsum(v1, v1, p1->n, 1.0);
511 fvsum(v1, v1, p2->n, 1.0);
512 fvsum(v1, v1, p3->n, 1.0);
513 ax = ABS(v1[0]) > ABS(v1[1]) ? 0 : 1;
514 ax = ABS(v1[ax]) > ABS(v1[2]) ? ax : 2;
515 /* assign equation matrix */
516 eqnmat[0][0] = p0->p[u]*p0->p[v];
517 eqnmat[0][1] = p0->p[u];
518 eqnmat[0][2] = p0->p[v];
519 eqnmat[0][3] = 1.0;
520 eqnmat[1][0] = p1->p[u]*p1->p[v];
521 eqnmat[1][1] = p1->p[u];
522 eqnmat[1][2] = p1->p[v];
523 eqnmat[1][3] = 1.0;
524 eqnmat[2][0] = p2->p[u]*p2->p[v];
525 eqnmat[2][1] = p2->p[u];
526 eqnmat[2][2] = p2->p[v];
527 eqnmat[2][3] = 1.0;
528 eqnmat[3][0] = p3->p[u]*p3->p[v];
529 eqnmat[3][1] = p3->p[u];
530 eqnmat[3][2] = p3->p[v];
531 eqnmat[3][3] = 1.0;
532 /* invert matrix (solve system) */
533 if (!invmat4(eqnmat, eqnmat))
534 return(-1); /* no solution */
535 /* compute result matrix */
536 for (j = 0; j < 4; j++)
537 for (i = 0; i < 3; i++)
538 resmat[j][i] = eqnmat[j][0]*p0->n[i] +
539 eqnmat[j][1]*p1->n[i] +
540 eqnmat[j][2]*p2->n[i] +
541 eqnmat[j][3]*p3->n[i];
542 return(ax);
543
544 #undef u
545 #undef v
546 }
547
548
549 void
550 eputs(msg)
551 char *msg;
552 {
553 fputs(msg, stderr);
554 }
555
556
557 void
558 wputs(msg)
559 char *msg;
560 {
561 eputs(msg);
562 }
563
564
565 void
566 quit(code)
567 int code;
568 {
569 exit(code);
570 }
571
572
573 printhead(ac, av) /* print command header */
574 register int ac;
575 register char **av;
576 {
577 putchar('#');
578 while (ac--) {
579 putchar(' ');
580 fputs(*av++, stdout);
581 }
582 putchar('\n');
583 }
584
585
586 double
587 l_hermite()
588 {
589 double t;
590
591 t = argument(5);
592 return( argument(1)*((2.0*t-3.0)*t*t+1.0) +
593 argument(2)*(-2.0*t+3.0)*t*t +
594 argument(3)*((t-2.0)*t+1.0)*t +
595 argument(4)*(t-1.0)*t*t );
596 }
597
598
599 double
600 l_bezier()
601 {
602 double t;
603
604 t = argument(5);
605 return( argument(1) * (1.+t*(-3.+t*(3.-t))) +
606 argument(2) * 3.*t*(1.+t*(-2.+t)) +
607 argument(3) * 3.*t*t*(1.-t) +
608 argument(4) * t*t*t );
609 }
610
611
612 double
613 l_bspline()
614 {
615 double t;
616
617 t = argument(5);
618 return( argument(1) * (1./6.+t*(-1./2.+t*(1./2.-1./6.*t))) +
619 argument(2) * (2./3.+t*t*(-1.+1./2.*t)) +
620 argument(3) * (1./6.+t*(1./2.+t*(1./2.-1./2.*t))) +
621 argument(4) * (1./6.*t*t*t) );
622 }
