root/Development/ray/src/gen/gensurf.c
Revision: 2.16
Committed: Sat Aug 21 11:54:06 2004 UTC (21 years, 3 months ago) by greg
CVS Tags: rad3R8, rad3R7P2, rad3R7P1, rad3R6P1, rad3R6
Changes since 2.15: +5 -42 lines
2 static const char RCSid[] = "$Id: gensurf.c,v 2.15 2004/03/26 21:30:12 schorsch Exp $";
5 * gensurf.c - program to generate functional surfaces
6 *
7 * Parametric functions x(s,t), y(s,t) and z(s,t)
8 * specify the surface, which is tesselated into an m by n
9 * array of paired triangles.
10 * The surface normal is defined by the right hand
11 * rule applied to (s,t).
12 *
13 * 4/3/87
14 *
15 * 4/16/02 Added conditional vertex output
16 */
17
18 #include "standard.h"
19
20 #include "paths.h"
21 #include "resolu.h"
22 #include "rterror.h"
23 #include "calcomp.h"
24
25 char XNAME[] = "X`SYS"; /* x function name */
26 char YNAME[] = "Y`SYS"; /* y function name */
27 char ZNAME[] = "Z`SYS"; /* z function name */
28
29 char VNAME[] = "valid"; /* valid vertex name */
30
31 #define ABS(x) ((x)>=0 ? (x) : -(x))
32
33 #define ZEROVECT(v) (DOT(v,v) <= FTINY*FTINY)
34
35 #define pvect(p) printf(vformat, (p)[0], (p)[1], (p)[2])
36
37 char vformat[] = "%15.9g %15.9g %15.9g\n";
38 char tsargs[] = "4 surf_dx surf_dy surf_dz surf.cal\n";
39 char texname[] = "Phong";
40
41 int smooth = 0; /* apply smoothing? */
42 int objout = 0; /* output .OBJ format? */
43
44 char *modname, *surfname;
45
46 /* recorded data flags */
47 #define HASBORDER 01
48 #define TRIPLETS 02
49 /* a data structure */
50 struct {
51 int flags; /* data type */
52 short m, n; /* number of s and t values */
53 RREAL *data; /* the data itself, s major sort */
54 } datarec; /* our recorded data */
55
56 /* XXX this is redundant with rt/noise3.c, should go to a library */
57 double l_hermite(), l_bezier(), l_bspline(), l_dataval();
58
59 typedef struct {
60 int valid; /* point is valid (vertex number) */
61 FVECT p; /* vertex position */
62 FVECT n; /* average normal */
63 RREAL uv[2]; /* (u,v) position */
64 } POINT;
65
66
67 void loaddata(char *file, int m, int n, int pointsize);
68 double l_dataval(char *nam);
69 void putobjrow(POINT *rp, int n);
70 void putsquare(POINT *p0, POINT *p1, POINT *p2, POINT *p3);
71 void comprow(double s, POINT *row, int siz);
72 void compnorms(POINT *r0, POINT *r1, POINT *r2, int siz);
73 int norminterp(FVECT resmat[4], POINT *p0, POINT *p1, POINT *p2, POINT *p3);
74
75
76 int
77 main(argc, argv)
78 int argc;
79 char *argv[];
80 {
81 POINT *row0, *row1, *row2, *rp;
82 int i, j, m, n;
83 char stmp[256];
84
85 varset("PI", ':', PI);
86 funset("hermite", 5, ':', l_hermite);
87 funset("bezier", 5, ':', l_bezier);
88 funset("bspline", 5, ':', l_bspline);
89
90 if (argc < 8)
91 goto userror;
92
93 for (i = 8; i < argc; i++)
94 if (!strcmp(argv[i], "-e"))
95 scompile(argv[++i], NULL, 0);
96 else if (!strcmp(argv[i], "-f"))
97 fcompile(argv[++i]);
98 else if (!strcmp(argv[i], "-s"))
99 smooth++;
100 else if (!strcmp(argv[i], "-o"))
101 objout++;
102 else
103 goto userror;
104
105 modname = argv[1];
106 surfname = argv[2];
107 m = atoi(argv[6]);
108 n = atoi(argv[7]);
109 if (m <= 0 || n <= 0)
110 goto userror;
111 if (!strcmp(argv[5], "-") || access(argv[5], 4) == 0) { /* file? */
112 funset(ZNAME, 2, ':', l_dataval);
113 if (!strcmp(argv[5],argv[3]) && !strcmp(argv[5],argv[4])) {
114 loaddata(argv[5], m, n, 3);
115 funset(XNAME, 2, ':', l_dataval);
116 funset(YNAME, 2, ':', l_dataval);
117 } else {
118 loaddata(argv[5], m, n, 1);
119 sprintf(stmp, "%s(s,t)=%s;", XNAME, argv[3]);
120 scompile(stmp, NULL, 0);
121 sprintf(stmp, "%s(s,t)=%s;", YNAME, argv[4]);
122 scompile(stmp, NULL, 0);
123 }
124 } else {
125 sprintf(stmp, "%s(s,t)=%s;", XNAME, argv[3]);
126 scompile(stmp, NULL, 0);
127 sprintf(stmp, "%s(s,t)=%s;", YNAME, argv[4]);
128 scompile(stmp, NULL, 0);
129 sprintf(stmp, "%s(s,t)=%s;", ZNAME, argv[5]);
130 scompile(stmp, NULL, 0);
131 }
132 row0 = (POINT *)malloc((n+3)*sizeof(POINT));
133 row1 = (POINT *)malloc((n+3)*sizeof(POINT));
134 row2 = (POINT *)malloc((n+3)*sizeof(POINT));
135 if (row0 == NULL || row1 == NULL || row2 == NULL) {
136 fprintf(stderr, "%s: out of memory\n", argv[0]);
137 quit(1);
138 }
139 row0++; row1++; row2++;
140 /* print header */
141 fputs("# ", stdout);
142 printargs(argc, argv, stdout);
143 eclock = 0;
144 /* initialize */
145 comprow(-1.0/m, row0, n);
146 comprow(0.0, row1, n);
147 comprow(1.0/m, row2, n);
148 compnorms(row0, row1, row2, n);
149 if (objout) {
150 printf("\nusemtl %s\n\n", modname);
151 putobjrow(row1, n);
152 }
153 /* for each row */
154 for (i = 0; i < m; i++) {
155 /* compute next row */
156 rp = row0;
157 row0 = row1;
158 row1 = row2;
159 row2 = rp;
160 comprow((double)(i+2)/m, row2, n);
161 compnorms(row0, row1, row2, n);
162 if (objout)
163 putobjrow(row1, n);
164
165 for (j = 0; j < n; j++) {
166 int orient = (j & 1);
167 /* put polygons */
168 if (!(row0[j].valid && row1[j+1].valid))
169 orient = 1;
170 else if (!(row1[j].valid && row0[j+1].valid))
171 orient = 0;
172 if (orient)
173 putsquare(&row0[j], &row1[j],
174 &row0[j+1], &row1[j+1]);
175 else
176 putsquare(&row1[j], &row1[j+1],
177 &row0[j], &row0[j+1]);
178 }
179 }
180
181 return 0;
182
183 userror:
184 fprintf(stderr, "Usage: %s material name ", argv[0]);
185 fprintf(stderr, "x(s,t) y(s,t) z(s,t) m n [-s][-e expr][-f file]\n");
186 return 1;
187 }
188
189
190 void
191 loaddata( /* load point data from file */
192 char *file,
193 int m,
194 int n,
195 int pointsize
196 )
197 {
198 FILE *fp;
199 char word[64];
200 register int size;
201 register RREAL *dp;
202
203 datarec.flags = HASBORDER; /* assume border values */
204 datarec.m = m+1;
205 datarec.n = n+1;
206 size = datarec.m*datarec.n*pointsize;
207 if (pointsize == 3)
208 datarec.flags |= TRIPLETS;
209 dp = (RREAL *)malloc(size*sizeof(RREAL));
210 if ((datarec.data = dp) == NULL) {
211 fputs("Out of memory\n", stderr);
212 exit(1);
213 }
214 if (!strcmp(file, "-")) {
215 file = "<stdin>";
216 fp = stdin;
217 } else if ((fp = fopen(file, "r")) == NULL) {
218 fputs(file, stderr);
219 fputs(": cannot open\n", stderr);
220 exit(1);
221 }
222 while (size > 0 && fgetword(word, sizeof(word), fp) != NULL) {
223 if (!isflt(word)) {
224 fprintf(stderr, "%s: garbled data value: %s\n",
225 file, word);
226 exit(1);
227 }
228 *dp++ = atof(word);
229 size--;
230 }
231 if (size == (m+n+1)*pointsize) { /* no border after all */
232 dp = (RREAL *)realloc((void *)datarec.data,
233 m*n*pointsize*sizeof(RREAL));
234 if (dp != NULL)
235 datarec.data = dp;
236 datarec.flags &= ~HASBORDER;
237 datarec.m = m;
238 datarec.n = n;
239 size = 0;
240 }
241 if (datarec.m < 2 || datarec.n < 2 || size != 0 ||
242 fgetword(word, sizeof(word), fp) != NULL) {
243 fputs(file, stderr);
244 fputs(": bad number of data points\n", stderr);
245 exit(1);
246 }
247 fclose(fp);
248 }
249
250
251 double
252 l_dataval( /* return recorded data value */
253 char *nam
254 )
255 {
256 double u, v;
257 register int i, j;
258 register RREAL *dp;
259 double d00, d01, d10, d11;
260 /* compute coordinates */
261 u = argument(1); v = argument(2);
262 if (datarec.flags & HASBORDER) {
263 i = u *= datarec.m-1;
264 j = v *= datarec.n-1;
265 } else {
266 i = u = u*datarec.m - .5;
267 j = v = v*datarec.n - .5;
268 }
269 if (i < 0) i = 0;
270 else if (i > datarec.m-2) i = datarec.m-2;
271 if (j < 0) j = 0;
272 else if (j > datarec.n-2) j = datarec.n-2;
273 /* compute value */
274 if (datarec.flags & TRIPLETS) {
275 dp = datarec.data + 3*(j*datarec.m + i);
276 if (nam == ZNAME)
277 dp += 2;
278 else if (nam == YNAME)
279 dp++;
280 d00 = dp[0]; d01 = dp[3];
281 dp += 3*datarec.m;
282 d10 = dp[0]; d11 = dp[3];
283 } else {
284 dp = datarec.data + j*datarec.m + i;
285 d00 = dp[0]; d01 = dp[1];
286 dp += datarec.m;
287 d10 = dp[0]; d11 = dp[1];
288 }
289 /* bilinear interpolation */
290 return((j+1-v)*((i+1-u)*d00+(u-i)*d01)+(v-j)*((i+1-u)*d10+(u-i)*d11));
291 }
292
293
294 void
295 putobjrow( /* output vertex row to .OBJ */
296 register POINT *rp,
297 int n
298 )
299 {
300 static int nverts = 0;
301
302 for ( ; n-- >= 0; rp++) {
303 if (!rp->valid)
304 continue;
305 fputs("v ", stdout);
306 pvect(rp->p);
307 if (smooth && !ZEROVECT(rp->n))
308 printf("\tvn %.9g %.9g %.9g\n",
309 rp->n[0], rp->n[1], rp->n[2]);
310 printf("\tvt %.9g %.9g\n", rp->uv[0], rp->uv[1]);
311 rp->valid = ++nverts;
312 }
313 }
314
315
316 void
317 putsquare( /* put out a square */
318 POINT *p0,
319 POINT *p1,
320 POINT *p2,
321 POINT *p3
322 )
323 {
324 static int nout = 0;
325 FVECT norm[4];
326 int axis;
327 FVECT v1, v2, vc1, vc2;
328 int ok1, ok2;
329 /* compute exact normals */
330 ok1 = (p0->valid && p1->valid && p2->valid);
331 if (ok1) {
332 VSUB(v1, p1->p, p0->p);
333 VSUB(v2, p2->p, p0->p);
334 fcross(vc1, v1, v2);
335 ok1 = (normalize(vc1) != 0.0);
336 }
337 ok2 = (p1->valid && p2->valid && p3->valid);
338 if (ok2) {
339 VSUB(v1, p2->p, p3->p);
340 VSUB(v2, p1->p, p3->p);
341 fcross(vc2, v1, v2);
342 ok2 = (normalize(vc2) != 0.0);
343 }
344 if (!(ok1 | ok2))
345 return;
346 if (objout) { /* output .OBJ faces */
347 int p0n=0, p1n=0, p2n=0, p3n=0;
348 if (smooth) {
349 if (!ZEROVECT(p0->n))
350 p0n = p0->valid;
351 if (!ZEROVECT(p1->n))
352 p1n = p1->valid;
353 if (!ZEROVECT(p2->n))
354 p2n = p2->valid;
355 if (!ZEROVECT(p3->n))
356 p3n = p3->valid;
357 }
358 if (ok1 & ok2 && fdot(vc1,vc2) >= 1.0-FTINY*FTINY) {
359 printf("f %d/%d/%d %d/%d/%d %d/%d/%d %d/%d/%d\n",
360 p0->valid, p0->valid, p0n,
361 p1->valid, p1->valid, p1n,
362 p3->valid, p3->valid, p3n,
363 p2->valid, p2->valid, p2n);
364 return;
365 }
366 if (ok1)
367 printf("f %d/%d/%d %d/%d/%d %d/%d/%d\n",
368 p0->valid, p0->valid, p0n,
369 p1->valid, p1->valid, p1n,
370 p2->valid, p2->valid, p2n);
371 if (ok2)
372 printf("f %d/%d/%d %d/%d/%d %d/%d/%d\n",
373 p2->valid, p2->valid, p2n,
374 p1->valid, p1->valid, p1n,
375 p3->valid, p3->valid, p3n);
376 return;
377 }
378 /* compute normal interpolation */
379 axis = norminterp(norm, p0, p1, p2, p3);
380
381 /* put out quadrilateral? */
382 if (ok1 & ok2 && fdot(vc1,vc2) >= 1.0-FTINY*FTINY) {
383 printf("\n%s ", modname);
384 if (axis != -1) {
385 printf("texfunc %s\n", texname);
386 printf(tsargs);
387 printf("0\n13\t%d\n", axis);
388 pvect(norm[0]);
389 pvect(norm[1]);
390 pvect(norm[2]);
391 fvsum(v1, norm[3], vc1, -0.5);
392 fvsum(v1, v1, vc2, -0.5);
393 pvect(v1);
394 printf("\n%s ", texname);
395 }
396 printf("polygon %s.%d\n", surfname, ++nout);
397 printf("0\n0\n12\n");
398 pvect(p0->p);
399 pvect(p1->p);
400 pvect(p3->p);
401 pvect(p2->p);
402 return;
403 }
404 /* put out triangles? */
405 if (ok1) {
406 printf("\n%s ", modname);
407 if (axis != -1) {
408 printf("texfunc %s\n", texname);
409 printf(tsargs);
410 printf("0\n13\t%d\n", axis);
411 pvect(norm[0]);
412 pvect(norm[1]);
413 pvect(norm[2]);
414 fvsum(v1, norm[3], vc1, -1.0);
415 pvect(v1);
416 printf("\n%s ", texname);
417 }
418 printf("polygon %s.%d\n", surfname, ++nout);
419 printf("0\n0\n9\n");
420 pvect(p0->p);
421 pvect(p1->p);
422 pvect(p2->p);
423 }
424 if (ok2) {
425 printf("\n%s ", modname);
426 if (axis != -1) {
427 printf("texfunc %s\n", texname);
428 printf(tsargs);
429 printf("0\n13\t%d\n", axis);
430 pvect(norm[0]);
431 pvect(norm[1]);
432 pvect(norm[2]);
433 fvsum(v2, norm[3], vc2, -1.0);
434 pvect(v2);
435 printf("\n%s ", texname);
436 }
437 printf("polygon %s.%d\n", surfname, ++nout);
438 printf("0\n0\n9\n");
439 pvect(p2->p);
440 pvect(p1->p);
441 pvect(p3->p);
442 }
443 }
444
445
446 void
447 comprow( /* compute row of values */
448 double s,
449 register POINT *row,
450 int siz
451 )
452 {
453 double st[2];
454 int end;
455 int checkvalid;
456 register int i;
457
458 if (smooth) {
459 i = -1; /* compute one past each end */
460 end = siz+1;
461 } else {
462 if (s < -FTINY || s > 1.0+FTINY)
463 return;
464 i = 0;
465 end = siz;
466 }
467 st[0] = s;
468 checkvalid = (fundefined(VNAME) == 2);
469 while (i <= end) {
470 st[1] = (double)i/siz;
471 if (checkvalid && funvalue(VNAME, 2, st) <= 0.0) {
472 row[i].valid = 0;
473 row[i].p[0] = row[i].p[1] = row[i].p[2] = 0.0;
474 row[i].uv[0] = row[i].uv[1] = 0.0;
475 } else {
476 row[i].valid = 1;
477 row[i].p[0] = funvalue(XNAME, 2, st);
478 row[i].p[1] = funvalue(YNAME, 2, st);
479 row[i].p[2] = funvalue(ZNAME, 2, st);
480 row[i].uv[0] = st[0];
481 row[i].uv[1] = st[1];
482 }
483 i++;
484 }
485 }
486
487
488 void
489 compnorms( /* compute row of averaged normals */
490 register POINT *r0,
491 register POINT *r1,
492 register POINT *r2,
493 int siz
494 )
495 {
496 FVECT v1, v2;
497
498 if (!smooth) /* not needed if no smoothing */
499 return;
500 /* compute row 1 normals */
501 while (siz-- >= 0) {
502 if (!r1[0].valid)
503 continue;
504 if (!r0[0].valid) {
505 if (!r2[0].valid) {
506 r1[0].n[0] = r1[0].n[1] = r1[0].n[2] = 0.0;
507 continue;
508 }
509 fvsum(v1, r2[0].p, r1[0].p, -1.0);
510 } else if (!r2[0].valid)
511 fvsum(v1, r1[0].p, r0[0].p, -1.0);
512 else
513 fvsum(v1, r2[0].p, r0[0].p, -1.0);
514 if (!r1[-1].valid) {
515 if (!r1[1].valid) {
516 r1[0].n[0] = r1[0].n[1] = r1[0].n[2] = 0.0;
517 continue;
518 }
519 fvsum(v2, r1[1].p, r1[0].p, -1.0);
520 } else if (!r1[1].valid)
521 fvsum(v2, r1[0].p, r1[-1].p, -1.0);
522 else
523 fvsum(v2, r1[1].p, r1[-1].p, -1.0);
524 fcross(r1[0].n, v1, v2);
525 normalize(r1[0].n);
526 r0++; r1++; r2++;
527 }
528 }
529
530
531 int
532 norminterp( /* compute normal interpolation */
533 register FVECT resmat[4],
534 POINT *p0,
535 POINT *p1,
536 POINT *p2,
537 POINT *p3
538 )
539 {
540 #define u ((ax+1)%3)
541 #define v ((ax+2)%3)
542
543 register int ax;
544 MAT4 eqnmat;
545 FVECT v1;
546 register int i, j;
547
548 if (!smooth) /* no interpolation if no smoothing */
549 return(-1);
550 /* find dominant axis */
551 VCOPY(v1, p0->n);
552 fvsum(v1, v1, p1->n, 1.0);
553 fvsum(v1, v1, p2->n, 1.0);
554 fvsum(v1, v1, p3->n, 1.0);
555 ax = ABS(v1[0]) > ABS(v1[1]) ? 0 : 1;
556 ax = ABS(v1[ax]) > ABS(v1[2]) ? ax : 2;
557 /* assign equation matrix */
558 eqnmat[0][0] = p0->p[u]*p0->p[v];
559 eqnmat[0][1] = p0->p[u];
560 eqnmat[0][2] = p0->p[v];
561 eqnmat[0][3] = 1.0;
562 eqnmat[1][0] = p1->p[u]*p1->p[v];
563 eqnmat[1][1] = p1->p[u];
564 eqnmat[1][2] = p1->p[v];
565 eqnmat[1][3] = 1.0;
566 eqnmat[2][0] = p2->p[u]*p2->p[v];
567 eqnmat[2][1] = p2->p[u];
568 eqnmat[2][2] = p2->p[v];
569 eqnmat[2][3] = 1.0;
570 eqnmat[3][0] = p3->p[u]*p3->p[v];
571 eqnmat[3][1] = p3->p[u];
572 eqnmat[3][2] = p3->p[v];
573 eqnmat[3][3] = 1.0;
574 /* invert matrix (solve system) */
575 if (!invmat4(eqnmat, eqnmat))
576 return(-1); /* no solution */
577 /* compute result matrix */
578 for (j = 0; j < 4; j++)
579 for (i = 0; i < 3; i++)
580 resmat[j][i] = eqnmat[j][0]*p0->n[i] +
581 eqnmat[j][1]*p1->n[i] +
582 eqnmat[j][2]*p2->n[i] +
583 eqnmat[j][3]*p3->n[i];
584 return(ax);
585
586 #undef u
587 #undef v
588 }
589
590
591 double
592 l_hermite(char *nm)
593 {
594 double t;
595
596 t = argument(5);
597 return( argument(1)*((2.0*t-3.0)*t*t+1.0) +
598 argument(2)*(-2.0*t+3.0)*t*t +
599 argument(3)*((t-2.0)*t+1.0)*t +
600 argument(4)*(t-1.0)*t*t );
601 }
602
603
604 double
605 l_bezier(char *nm)
606 {
607 double t;
608
609 t = argument(5);
610 return( argument(1) * (1.+t*(-3.+t*(3.-t))) +
611 argument(2) * 3.*t*(1.+t*(-2.+t)) +
612 argument(3) * 3.*t*t*(1.-t) +
613 argument(4) * t*t*t );
614 }
615
616
617 double
618 l_bspline(char *nm)
619 {
620 double t;
621
622 t = argument(5);
623 return( argument(1) * (1./6.+t*(-1./2.+t*(1./2.-1./6.*t))) +
624 argument(2) * (2./3.+t*t*(-1.+1./2.*t)) +
625 argument(3) * (1./6.+t*(1./2.+t*(1./2.-1./2.*t))) +
626 argument(4) * (1./6.*t*t*t) );
627 }
