root/radiance/ray/src/gen/gensurf.c
Revision: 1.1
Committed: Thu Feb 2 11:16:30 1989 UTC (35 years, 4 months ago) by greg
1 /*
2
3 #ifndef lint
5 #endif
6 * gensurf.c - program to generate functional surfaces
7 *
8 * Parametric functions x(s,t), y(s,t) and z(s,t)
9 * specify the surface, which is tesselated into an m by n
10 * array of paired triangles.
11 * The surface normal is defined by the right hand
12 * rule applied to (s,t).
13 *
14 * 4/3/87
15 */
16
17 #include <stdio.h>
18
19 #define XNAME "X_" /* x function name */
20 #define YNAME "Y_" /* y function name */
21 #define ZNAME "Z_" /* z function name */
22
23 #define PI 3.14159265358979323846
24
25 #define FTINY 1e-7
26
27 #define vertex(p) printf(vformat, (p)[0], (p)[1], (p)[2])
28
29 char vformat[] = "%15.9g %15.9g %15.9g\n";
30
31 double funvalue(), dist2(), fdot(), l_hermite(), argument();
32
33
34 main(argc, argv)
35 int argc;
36 char *argv[];
37 {
38 static double *xyz[4];
39 double *row0, *row1, *dp;
40 double v1[3], v2[3], vc1[3], vc2[3];
41 double a1, a2;
42 int i, j, m, n;
43 char stmp[256];
44 double d;
45 register int k;
46
47 varset("PI", PI);
48 funset("hermite", 5, l_hermite);
49
50 if (argc < 8)
51 goto userror;
52
53 for (i = 8; i < argc; i++)
54 if (!strcmp(argv[i], "-e"))
55 scompile(NULL, argv[++i]);
56 else if (!strcmp(argv[i], "-f"))
57 fcompile(argv[++i]);
58 else
59 goto userror;
60
61 sprintf(stmp, "%s(s,t)=%s;", XNAME, argv[3]);
62 scompile(NULL, stmp);
63 sprintf(stmp, "%s(s,t)=%s;", YNAME, argv[4]);
64 scompile(NULL, stmp);
65 sprintf(stmp, "%s(s,t)=%s;", ZNAME, argv[5]);
66 scompile(NULL, stmp);
67 m = atoi(argv[6]);
68 n = atoi(argv[7]);
69 if (m <= 0 || n <= 0)
70 goto userror;
71
72 row0 = (double *)malloc((n+1)*3*sizeof(double));
73 row1 = (double *)malloc((n+1)*3*sizeof(double));
74 if (row0 == NULL || row1 == NULL) {
75 fprintf(stderr, "%s: out of memory\n", argv[0]);
76 quit(1);
77 }
78
79 printhead(argc, argv);
80
81 comprow(0.0, row1, n); /* compute zeroeth row */
82
83 for (i = 0; i < m; i++) {
84 /* compute next row */
85 dp = row0;
86 row0 = row1;
87 row1 = dp;
88 comprow((double)(i+1)/m, row1, n);
89
90 for (j = 0; j < n; j++) {
91 /* get vertices */
92 xyz[0] = row0 + 3*j;
93 xyz[1] = row1 + 3*j;
94 xyz[2] = xyz[0] + 3;
95 xyz[3] = xyz[1] + 3;
96 /* rotate vertices */
97 if (dist2(xyz[0],xyz[3]) < dist2(xyz[1],xyz[2])-FTINY) {
98 dp = xyz[0];
99 xyz[0] = xyz[1];
100 xyz[1] = xyz[3];
101 xyz[3] = xyz[2];
102 xyz[2] = dp;
103 }
104 /* get normals */
105 for (k = 0; k < 3; k++) {
106 v1[k] = xyz[1][k] - xyz[0][k];
107 v2[k] = xyz[2][k] - xyz[0][k];
108 }
109 fcross(vc1, v1, v2);
110 a1 = fdot(vc1, vc1);
111 for (k = 0; k < 3; k++) {
112 v1[k] = xyz[2][k] - xyz[3][k];
113 v2[k] = xyz[1][k] - xyz[3][k];
114 }
115 fcross(vc2, v1, v2);
116 a2 = fdot(vc2, vc2);
117 /* check coplanar */
118 if (a1 > FTINY*FTINY && a2 > FTINY*FTINY) {
119 d = fdot(vc1, vc2);
120 if (d*d/a1/a2 >= 1.0-FTINY*FTINY) {
121 if (d > 0.0) { /* coplanar */
122 printf(
123 "\n%s polygon %s.%d.%d\n",
124 argv[1], argv[2], i+1, j+1);
125 printf("0\n0\n12\n");
126 vertex(xyz[0]);
127 vertex(xyz[1]);
128 vertex(xyz[3]);
129 vertex(xyz[2]);
130 } /* else overlapped */
131 continue;
132 } /* else bent */
133 }
134 /* check triangles */
135 if (a1 > FTINY*FTINY) {
136 printf("\n%s polygon %s.%da%d\n",
137 argv[1], argv[2], i+1, j+1);
138 printf("0\n0\n9\n");
139 vertex(xyz[0]);
140 vertex(xyz[1]);
141 vertex(xyz[2]);
142 }
143 if (a2 > FTINY*FTINY) {
144 printf("\n%s polygon %s.%db%d\n",
145 argv[1], argv[2], i+1, j+1);
146 printf("0\n0\n9\n");
147 vertex(xyz[2]);
148 vertex(xyz[1]);
149 vertex(xyz[3]);
150 }
151 }
152 }
153
154 quit(0);
155
156 userror:
157 fprintf(stderr, "Usage: %s material name ", argv[0]);
158 fprintf(stderr, "x(s,t) y(s,t) z(s,t) m n [-e expr] [-f file]\n");
159 quit(1);
160 }
161
162
163 comprow(s, row, siz) /* compute row of values */
164 double s;
165 register double *row;
166 int siz;
167 {
168 double st[2], step;
169
170 st[0] = s;
171 st[1] = 0.0;
172 step = 1.0 / siz;
173 while (siz-- >= 0) {
174 *row++ = funvalue(XNAME, 2, st);
175 *row++ = funvalue(YNAME, 2, st);
176 *row++ = funvalue(ZNAME, 2, st);
177 st[1] += step;
178 }
179 }
180
181
182 eputs(msg)
183 char *msg;
184 {
185 fputs(msg, stderr);
186 }
187
188
189 wputs(msg)
190 char *msg;
191 {
192 eputs(msg);
193 }
194
195
196 quit(code)
197 {
198 exit(code);
199 }
200
201
202 printhead(ac, av) /* print command header */
203 register int ac;
204 register char **av;
205 {
206 putchar('#');
207 while (ac--) {
208 putchar(' ');
209 fputs(*av++, stdout);
210 }
211 putchar('\n');
212 }
213
214
215 double
216 l_hermite()
217 {
218 double t;
219
220 t = argument(5);
221 return( argument(1)*((2.0*t-3.0)*t*t+1.0) +
222 argument(2)*(-2.0*t+3.0)*t*t +
223 argument(3)*((t-2.0)*t+1.0)*t +
224 argument(4)*(t-1.0)*t*t );
225 }
