root/radiance/ray/src/gen/gensurf.c
Revision: 2.31
Committed: Tue Jan 21 01:56:27 2025 UTC (3 months, 2 weeks ago) by greg
Changes since 2.30: +12 -2 lines
feat(gensurf): Added gensurf -i option to reverse surface normals
2 static const char RCSid[] = "$Id: gensurf.c,v 2.30 2024/12/10 17:22:39 greg Exp $";
5 * gensurf.c - program to generate functional surfaces
6 *
7 * Parametric functions x(s,t), y(s,t) and z(s,t)
8 * specify the surface, which is tesselated into an m by n
9 * array of paired triangles.
10 * The surface normal is defined by the right hand
11 * rule applied to (s,t).
12 *
13 * 4/3/87
14 *
15 * 4/16/02 Added conditional vertex output
16 */
17
18 #include "standard.h"
19
20 #include "paths.h"
21 #include "resolu.h"
22 #include "rterror.h"
23 #include "calcomp.h"
24
25 char XNAME[] = "X`SYS"; /* x function name */
26 char YNAME[] = "Y`SYS"; /* y function name */
27 char ZNAME[] = "Z`SYS"; /* z function name */
28
29 char VNAME[] = "valid"; /* valid vertex name */
30
31 #define ABS(x) ((x)>=0 ? (x) : -(x))
32
33 #define ZEROVECT(v) (DOT(v,v) <= FTINY*FTINY)
34
35 #define pvect(p) printf(vformat, (p)[0], (p)[1], (p)[2])
36
37 char vformat[] = "%18.12g %18.12g %18.12g\n";
38 char tsargs[] = "4 surf_dx surf_dy surf_dz surf.cal";
39 char texname[] = "Phong";
40
41 int smooth = 0; /* apply smoothing? */
42 int objout = 0; /* output .OBJ format? */
43 int rev = 0; /* invert normal directions? */
44
45 char *modname, *surfname;
46
47 /* recorded data flags */
48 #define HASBORDER 01
49 #define TRIPLETS 02
50 /* a data structure */
51 struct {
52 int flags; /* data type */
53 short m, n; /* number of s and t values */
54 RREAL *data; /* the data itself, s major sort */
55 } datarec; /* our recorded data */
56
57 /* XXX this is redundant with rt/noise3.c, should go to a library */
58 double l_hermite(), l_bezier(), l_bspline(), l_dataval();
59
60 typedef struct {
61 int valid; /* point is valid (vertex number) */
62 int nvalid; /* normal is valid (normal number) */
63 FVECT p; /* vertex position */
64 FVECT n; /* average normal */
65 RREAL uv[2]; /* (u,v) position */
66 } POINT;
67
68 int nverts = 0; /* vertex output count */
69 int nnorms = 0; /* normal output count */
70
71 void loaddata(char *file, int m, int n, int pointsize);
72 double l_dataval(char *nam);
73 void putobjrow(POINT *rp, int n);
74 void putobjvert(POINT *p);
75 void putsquare(POINT *p0, POINT *p1, POINT *p2, POINT *p3);
76 void comprow(double s, POINT *row, int siz);
77 void compnorms(POINT *r0, POINT *r1, POINT *r2, int siz);
78 int norminterp(FVECT resmat[4], POINT *p0, POINT *p1, POINT *p2, POINT *p3);
79
80
81 int
82 main(int argc, char *argv[])
83 {
84 POINT *row0, *row1, *row2, *rp;
85 int i, j, m, n;
86 char stmp[256];
87
88 esupport |= E_VARIABLE|E_FUNCTION|E_RCONST;
89 esupport &= ~(E_OUTCHAN|E_INCHAN);
90 varset("PI", ':', PI);
91 funset("hermite", 5, ':', l_hermite);
92 funset("bezier", 5, ':', l_bezier);
93 funset("bspline", 5, ':', l_bspline);
94
95 if (argc < 8)
96 goto userror;
97
98 for (i = 8; i < argc; i++)
99 if (!strcmp(argv[i], "-e"))
100 scompile(argv[++i], NULL, 0);
101 else if (!strcmp(argv[i], "-f")) {
102 char *fpath = getpath(argv[++i], getrlibpath(), 0);
103 if (fpath == NULL) {
104 fprintf(stderr, "%s: cannot find file '%s'\n",
105 argv[0], argv[i]);
106 quit(1);
107 }
108 fcompile(fpath);
109 } else if (!strcmp(argv[i], "-s"))
110 smooth++;
111 else if (!strcmp(argv[i], "-o"))
112 objout++;
113 else if (!strcmp(argv[i], "-i"))
114 rev = 1;
115 else
116 goto userror;
117
118 modname = argv[1];
119 surfname = argv[2];
120 m = eval(argv[6]) + .5;
121 n = eval(argv[7]) + .5;
122 if (m <= 0 || n <= 0)
123 goto userror;
124 if (!strcmp(argv[5], "-") || access(argv[5], 4) == 0) { /* file? */
125 funset(ZNAME, 2, ':', l_dataval);
126 if (!strcmp(argv[5],argv[3]) && !strcmp(argv[5],argv[4])) {
127 loaddata(argv[5], m, n, 3);
128 funset(XNAME, 2, ':', l_dataval);
129 funset(YNAME, 2, ':', l_dataval);
130 } else {
131 loaddata(argv[5], m, n, 1);
132 sprintf(stmp, "%s(s,t)=%s;", XNAME, argv[3]);
133 scompile(stmp, NULL, 0);
134 sprintf(stmp, "%s(s,t)=%s;", YNAME, argv[4]);
135 scompile(stmp, NULL, 0);
136 }
137 } else {
138 sprintf(stmp, "%s(s,t)=%s;", XNAME, argv[3]);
139 scompile(stmp, NULL, 0);
140 sprintf(stmp, "%s(s,t)=%s;", YNAME, argv[4]);
141 scompile(stmp, NULL, 0);
142 sprintf(stmp, "%s(s,t)=%s;", ZNAME, argv[5]);
143 scompile(stmp, NULL, 0);
144 }
145 row0 = (POINT *)malloc((n+3)*sizeof(POINT));
146 row1 = (POINT *)malloc((n+3)*sizeof(POINT));
147 row2 = (POINT *)malloc((n+3)*sizeof(POINT));
148 if (row0 == NULL || row1 == NULL || row2 == NULL) {
149 fprintf(stderr, "%s: out of memory\n", argv[0]);
150 quit(1);
151 }
152 row0++; row1++; row2++;
153 /* print header */
154 fputs("# ", stdout);
155 printargs(argc, argv, stdout);
156 eclock = 1;
157 /* initialize */
158 comprow(-1.0/m, row0, n);
159 comprow(0.0, row1, n);
160 comprow(1.0/m, row2, n);
161 compnorms(row0, row1, row2, n);
162 if (objout) {
163 printf("\nusemtl %s\n\n", modname);
164 printf("o %s\n\n", surfname);
165 putobjrow(row1, n);
166 }
167 /* for each row */
168 for (i = 0; i < m; i++) {
169 /* compute next row */
170 rp = row0;
171 row0 = row1;
172 row1 = row2;
173 row2 = rp;
174 comprow((double)(i+2)/m, row2, n);
175 compnorms(row0, row1, row2, n);
176 if (objout)
177 putobjrow(row1, n);
178
179 for (j = 0; j < n; j++) {
180 int orient = (j & 1);
181 /* put polygons */
182 if (!(row0[j].valid && row1[j+1].valid))
183 orient = 1;
184 else if (!(row1[j].valid && row0[j+1].valid))
185 orient = 0;
186 if (orient)
187 putsquare(&row0[j], &row1[j],
188 &row0[j+1], &row1[j+1]);
189 else
190 putsquare(&row1[j], &row1[j+1],
191 &row0[j], &row0[j+1]);
192 }
193 }
194
195 return 0;
196
197 userror:
198 fprintf(stderr, "Usage: %s material name ", argv[0]);
199 fprintf(stderr, "x(s,t) y(s,t) z(s,t) m n [-s][-o][-e expr][-f file]\n");
200 return 1;
201 }
202
203
204 void
205 loaddata( /* load point data from file */
206 char *file,
207 int m,
208 int n,
209 int pointsize
210 )
211 {
212 FILE *fp;
213 char word[64];
214 int size;
215 RREAL *dp;
216
217 datarec.flags = HASBORDER; /* assume border values */
218 datarec.m = m+1;
219 datarec.n = n+1;
220 size = datarec.m*datarec.n*pointsize;
221 if (pointsize == 3)
222 datarec.flags |= TRIPLETS;
223 dp = (RREAL *)malloc(size*sizeof(RREAL));
224 if ((datarec.data = dp) == NULL) {
225 fputs("Out of memory\n", stderr);
226 exit(1);
227 }
228 if (!strcmp(file, "-")) {
229 file = "<stdin>";
230 fp = stdin;
231 } else if ((fp = fopen(file, "r")) == NULL) {
232 fputs(file, stderr);
233 fputs(": cannot open\n", stderr);
234 exit(1);
235 }
236 while (size > 0 && fgetword(word, sizeof(word), fp) != NULL) {
237 if (!isflt(word)) {
238 fprintf(stderr, "%s: garbled data value: %s\n",
239 file, word);
240 exit(1);
241 }
242 *dp++ = atof(word);
243 size--;
244 }
245 if (size == (m+n+1)*pointsize) { /* no border after all */
246 dp = (RREAL *)realloc(datarec.data,
247 m*n*pointsize*sizeof(RREAL));
248 if (dp != NULL)
249 datarec.data = dp;
250 datarec.flags &= ~HASBORDER;
251 datarec.m = m;
252 datarec.n = n;
253 size = 0;
254 }
255 if (datarec.m < 2 || datarec.n < 2 || size != 0 ||
256 fgetword(word, sizeof(word), fp) != NULL) {
257 fputs(file, stderr);
258 fputs(": bad number of data points\n", stderr);
259 exit(1);
260 }
261 fclose(fp);
262 }
263
264
265 double
266 l_dataval( /* return recorded data value */
267 char *nam
268 )
269 {
270 double u, v;
271 int i, j;
272 RREAL *dp;
273 double d00, d01, d10, d11;
274 /* compute coordinates */
275 u = argument(1); v = argument(2);
276 if (datarec.flags & HASBORDER) {
277 i = u *= datarec.m-1;
278 j = v *= datarec.n-1;
279 } else {
280 i = u = u*datarec.m - .5;
281 j = v = v*datarec.n - .5;
282 }
283 if (i < 0) i = 0;
284 else if (i > datarec.m-2) i = datarec.m-2;
285 if (j < 0) j = 0;
286 else if (j > datarec.n-2) j = datarec.n-2;
287 /* compute value */
288 if (datarec.flags & TRIPLETS) {
289 dp = datarec.data + 3*(j*datarec.m + i);
290 if (nam == ZNAME)
291 dp += 2;
292 else if (nam == YNAME)
293 dp++;
294 d00 = dp[0]; d01 = dp[3];
295 dp += 3*datarec.m;
296 d10 = dp[0]; d11 = dp[3];
297 } else {
298 dp = datarec.data + j*datarec.m + i;
299 d00 = dp[0]; d01 = dp[1];
300 dp += datarec.m;
301 d10 = dp[0]; d11 = dp[1];
302 }
303 /* bilinear interpolation */
304 return((j+1-v)*((i+1-u)*d00+(u-i)*d01)+(v-j)*((i+1-u)*d10+(u-i)*d11));
305 }
306
307
308 void
309 putobjrow( /* output vertex row to .OBJ */
310 POINT *rp,
311 int n
312 )
313 {
314 static FVECT prevNorm;
315
316 for ( ; n-- >= 0; rp++) {
317 if (!rp->valid)
318 continue;
319 fputs("v ", stdout);
320 pvect(rp->p);
321 rp->valid = ++nverts;
322 printf("\tvt %.9g %.9g\n", rp->uv[0], rp->uv[1]);
323 if (!smooth || ZEROVECT(rp->n))
324 rp->nvalid = 0;
325 else if (VABSEQ(rp->n, prevNorm))
326 rp->nvalid = nnorms;
327 else {
328 printf("\tvn %.9g %.9g %.9g\n",
329 rp->n[0], rp->n[1], rp->n[2]);
330 rp->nvalid = ++nnorms;
331 VCOPY(prevNorm, rp->n);
332 }
333 }
334 }
335
336
337 void
338 putobjvert( /* put out OBJ vertex index triplet */
339 POINT *p
340 )
341 {
342 int pti = p->valid ? p->valid-nverts-1 : 0;
343 int ni = p->nvalid ? p->nvalid-nnorms-1 : 0;
344
345 printf(" %d/%d/%d", pti, pti, ni);
346 }
347
348
349 void
350 putsquare( /* put out a square */
351 POINT *p0,
352 POINT *p1,
353 POINT *p2,
354 POINT *p3
355 )
356 {
357 static int nout = 0;
358 FVECT norm[4];
359 int axis;
360 FVECT v1, v2, vc1, vc2;
361 int ok1, ok2;
362
363 if (rev) { /* reverse normals? */
364 POINT *pt = p1; p1 = p2; p2 = pt;
365 }
366 /* compute exact normals */
367 ok1 = (p0->valid && p1->valid && p2->valid);
368 if (ok1) {
369 VSUB(v1, p1->p, p0->p);
370 VSUB(v2, p2->p, p0->p);
371 fcross(vc1, v1, v2);
372 ok1 = (normalize(vc1) != 0.0);
373 }
374 ok2 = (p1->valid && p2->valid && p3->valid);
375 if (ok2) {
376 VSUB(v1, p2->p, p3->p);
377 VSUB(v2, p1->p, p3->p);
378 fcross(vc2, v1, v2);
379 ok2 = (normalize(vc2) != 0.0);
380 }
381 if (!(ok1 | ok2))
382 return;
383 if (objout) { /* output .OBJ faces */
384 if (ok1 & ok2 && fdot(vc1,vc2) >= 1.0-FTINY*FTINY) {
385 putc('f', stdout);
386 putobjvert(p0); putobjvert(p1);
387 putobjvert(p3); putobjvert(p2);
388 putc('\n', stdout);
389 return;
390 }
391 if (ok1) {
392 putc('f', stdout);
393 putobjvert(p0); putobjvert(p1); putobjvert(p2);
394 putc('\n', stdout);
395 }
396 if (ok2) {
397 putc('f', stdout);
398 putobjvert(p2); putobjvert(p1); putobjvert(p3);
399 putc('\n', stdout);
400 }
401 return;
402 }
403 /* compute normal interpolation */
404 axis = norminterp(norm, p0, p1, p2, p3);
405
406 /* put out quadrilateral? */
407 if (ok1 & ok2 && fdot(vc1,vc2) >= 1.0-FTINY*FTINY) {
408 printf("\n%s ", modname);
409 if (axis != -1) {
410 printf("texfunc %s\n%s\n", texname, tsargs);
411 printf("0\n13\t%d\n", axis);
412 pvect(norm[0]);
413 pvect(norm[1]);
414 pvect(norm[2]);
415 fvsum(v1, norm[3], vc1, -0.5);
416 fvsum(v1, v1, vc2, -0.5);
417 pvect(v1);
418 printf("\n%s ", texname);
419 }
420 printf("polygon %s.%d\n", surfname, ++nout);
421 printf("0\n0\n12\n");
422 pvect(p0->p);
423 pvect(p1->p);
424 pvect(p3->p);
425 pvect(p2->p);
426 return;
427 }
428 /* put out triangles? */
429 if (ok1) {
430 printf("\n%s ", modname);
431 if (axis != -1) {
432 printf("texfunc %s\n%s\n", texname, tsargs);
433 printf("0\n13\t%d\n", axis);
434 pvect(norm[0]);
435 pvect(norm[1]);
436 pvect(norm[2]);
437 fvsum(v1, norm[3], vc1, -1.0);
438 pvect(v1);
439 printf("\n%s ", texname);
440 }
441 printf("polygon %s.%d\n", surfname, ++nout);
442 printf("0\n0\n9\n");
443 pvect(p0->p);
444 pvect(p1->p);
445 pvect(p2->p);
446 }
447 if (ok2) {
448 printf("\n%s ", modname);
449 if (axis != -1) {
450 printf("texfunc %s\n%s\n", texname, tsargs);
451 printf("0\n13\t%d\n", axis);
452 pvect(norm[0]);
453 pvect(norm[1]);
454 pvect(norm[2]);
455 fvsum(v2, norm[3], vc2, -1.0);
456 pvect(v2);
457 printf("\n%s ", texname);
458 }
459 printf("polygon %s.%d\n", surfname, ++nout);
460 printf("0\n0\n9\n");
461 pvect(p2->p);
462 pvect(p1->p);
463 pvect(p3->p);
464 }
465 }
466
467
468 void
469 comprow( /* compute row of values */
470 double s,
471 POINT *row,
472 int siz
473 )
474 {
475 double st[2];
476 int end;
477 int checkvalid;
478 int i;
479
480 if (smooth) {
481 i = -1; /* compute one past each end */
482 end = siz+1;
483 } else {
484 if (s < -FTINY || s > 1.0+FTINY)
485 return;
486 i = 0;
487 end = siz;
488 }
489 st[0] = s;
490 checkvalid = (fundefined(VNAME) == 2);
491 while (i <= end) {
492 st[1] = (double)i/siz;
493 if (checkvalid && funvalue(VNAME, 2, st) <= 0.0) {
494 row[i].valid = 0;
495 row[i].p[0] = row[i].p[1] = row[i].p[2] = 0.0;
496 row[i].uv[0] = row[i].uv[1] = 0.0;
497 } else {
498 row[i].valid = 1;
499 row[i].p[0] = funvalue(XNAME, 2, st);
500 row[i].p[1] = funvalue(YNAME, 2, st);
501 row[i].p[2] = funvalue(ZNAME, 2, st);
502 row[i].uv[0] = st[0];
503 row[i].uv[1] = st[1];
504 }
505 i++;
506 }
507 }
508
509
510 void
511 compnorms( /* compute row of averaged normals */
512 POINT *r0,
513 POINT *r1,
514 POINT *r2,
515 int siz
516 )
517 {
518 FVECT v1, v2;
519
520 if (!smooth) /* not needed if no smoothing */
521 return;
522 /* compute row 1 normals */
523 while (siz-- >= 0) {
524 if (!r1[0].valid)
525 goto skip;
526 if (!r0[0].valid) {
527 if (!r2[0].valid) {
528 r1[0].n[0] = r1[0].n[1] = r1[0].n[2] = 0.0;
529 goto skip;
530 }
531 fvsum(v1, r2[0].p, r1[0].p, -1.0);
532 } else if (!r2[0].valid)
533 fvsum(v1, r1[0].p, r0[0].p, -1.0);
534 else
535 fvsum(v1, r2[0].p, r0[0].p, -1.0);
536 if (!r1[-1].valid) {
537 if (!r1[1].valid) {
538 r1[0].n[0] = r1[0].n[1] = r1[0].n[2] = 0.0;
539 goto skip;
540 }
541 fvsum(v2, r1[1].p, r1[0].p, -1.0);
542 } else if (!r1[1].valid)
543 fvsum(v2, r1[0].p, r1[-1].p, -1.0);
544 else
545 fvsum(v2, r1[1].p, r1[-1].p, -1.0);
546 if (rev)
547 fcross(r1[0].n, v2, v1);
548 else
549 fcross(r1[0].n, v1, v2);
550 normalize(r1[0].n);
551 skip:
552 r0++; r1++; r2++;
553 }
554 }
555
556
557 int
558 norminterp( /* compute normal interpolation */
559 FVECT resmat[4],
560 POINT *p0,
561 POINT *p1,
562 POINT *p2,
563 POINT *p3
564 )
565 {
566 #define u ((ax+1)%3)
567 #define v ((ax+2)%3)
568
569 int ax;
570 MAT4 eqnmat;
571 FVECT v1;
572 int i, j;
573
574 if (!smooth) /* no interpolation if no smoothing */
575 return(-1);
576 /* find dominant axis */
577 VCOPY(v1, p0->n);
578 fvsum(v1, v1, p1->n, 1.0);
579 fvsum(v1, v1, p2->n, 1.0);
580 fvsum(v1, v1, p3->n, 1.0);
581 ax = ABS(v1[0]) > ABS(v1[1]) ? 0 : 1;
582 ax = ABS(v1[ax]) > ABS(v1[2]) ? ax : 2;
583 /* assign equation matrix */
584 eqnmat[0][0] = p0->p[u]*p0->p[v];
585 eqnmat[0][1] = p0->p[u];
586 eqnmat[0][2] = p0->p[v];
587 eqnmat[0][3] = 1.0;
588 eqnmat[1][0] = p1->p[u]*p1->p[v];
589 eqnmat[1][1] = p1->p[u];
590 eqnmat[1][2] = p1->p[v];
591 eqnmat[1][3] = 1.0;
592 eqnmat[2][0] = p2->p[u]*p2->p[v];
593 eqnmat[2][1] = p2->p[u];
594 eqnmat[2][2] = p2->p[v];
595 eqnmat[2][3] = 1.0;
596 eqnmat[3][0] = p3->p[u]*p3->p[v];
597 eqnmat[3][1] = p3->p[u];
598 eqnmat[3][2] = p3->p[v];
599 eqnmat[3][3] = 1.0;
600 /* invert matrix (solve system) */
601 if (!invmat4(eqnmat, eqnmat))
602 return(-1); /* no solution */
603 /* compute result matrix */
604 for (j = 0; j < 4; j++)
605 for (i = 0; i < 3; i++)
606 resmat[j][i] = eqnmat[j][0]*p0->n[i] +
607 eqnmat[j][1]*p1->n[i] +
608 eqnmat[j][2]*p2->n[i] +
609 eqnmat[j][3]*p3->n[i];
610 return(ax);
611
612 #undef u
613 #undef v
614 }
615
616
617 double
618 l_hermite(char *nm)
619 {
620 double t;
621
622 t = argument(5);
623 return( argument(1)*((2.0*t-3.0)*t*t+1.0) +
624 argument(2)*(-2.0*t+3.0)*t*t +
625 argument(3)*((t-2.0)*t+1.0)*t +
626 argument(4)*(t-1.0)*t*t );
627 }
628
629
630 double
631 l_bezier(char *nm)
632 {
633 double t;
634
635 t = argument(5);
636 return( argument(1) * (1.+t*(-3.+t*(3.-t))) +
637 argument(2) * 3.*t*(1.+t*(-2.+t)) +
638 argument(3) * 3.*t*t*(1.-t) +
639 argument(4) * t*t*t );
640 }
641
642
643 double
644 l_bspline(char *nm)
645 {
646 double t;
647
648 t = argument(5);
649 return( argument(1) * (1./6.+t*(-1./2.+t*(1./2.-1./6.*t))) +
650 argument(2) * (2./3.+t*t*(-1.+1./2.*t)) +
651 argument(3) * (1./6.+t*(1./2.+t*(1./2.-1./2.*t))) +
652 argument(4) * (1./6.*t*t*t) );
653 }
