--- ray/src/gen/gensurf.c 2007/10/09 04:44:54 2.17 +++ ray/src/gen/gensurf.c 2018/01/12 00:50:17 2.24 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: gensurf.c,v 2.17 2007/10/09 04:44:54 greg Exp $"; +static const char RCSid[] = "$Id: gensurf.c,v 2.24 2018/01/12 00:50:17 greg Exp $"; #endif /* * gensurf.c - program to generate functional surfaces @@ -34,8 +34,8 @@ char VNAME[] = "valid"; /* valid vertex name */ #define pvect(p) printf(vformat, (p)[0], (p)[1], (p)[2]) -char vformat[] = "%15.9g %15.9g %15.9g\n"; -char tsargs[] = "4 surf_dx surf_dy surf_dz surf.cal\n"; +char vformat[] = "%18.12g %18.12g %18.12g\n"; +char tsargs[] = "4 surf_dx surf_dy surf_dz surf.cal"; char texname[] = "Phong"; int smooth = 0; /* apply smoothing? */ @@ -58,15 +58,19 @@ double l_hermite(), l_bezier(), l_bspline(), l_datava typedef struct { int valid; /* point is valid (vertex number) */ + int nvalid; /* normal is valid */ FVECT p; /* vertex position */ FVECT n; /* average normal */ RREAL uv[2]; /* (u,v) position */ } POINT; +int nverts = 0; /* vertex output count */ +int nnorms = 0; /* normal output count */ void loaddata(char *file, int m, int n, int pointsize); double l_dataval(char *nam); void putobjrow(POINT *rp, int n); +void putobjvert(POINT *p); void putsquare(POINT *p0, POINT *p1, POINT *p2, POINT *p3); void comprow(double s, POINT *row, int siz); void compnorms(POINT *r0, POINT *r1, POINT *r2, int siz); @@ -82,6 +86,8 @@ char *argv[]; int i, j, m, n; char stmp[256]; + esupport |= E_VARIABLE|E_FUNCTION|E_RCONST; + esupport &= ~(E_OUTCHAN|E_INCHAN); varset("PI", ':', PI); funset("hermite", 5, ':', l_hermite); funset("bezier", 5, ':', l_bezier); @@ -197,8 +203,8 @@ loaddata( /* load point data from file */ { FILE *fp; char word[64]; - register int size; - register RREAL *dp; + int size; + RREAL *dp; datarec.flags = HASBORDER; /* assume border values */ datarec.m = m+1; @@ -229,7 +235,7 @@ loaddata( /* load point data from file */ size--; } if (size == (m+n+1)*pointsize) { /* no border after all */ - dp = (RREAL *)realloc((void *)datarec.data, + dp = (RREAL *)realloc(datarec.data, m*n*pointsize*sizeof(RREAL)); if (dp != NULL) datarec.data = dp; @@ -254,8 +260,8 @@ l_dataval( /* return recorded data value */ ) { double u, v; - register int i, j; - register RREAL *dp; + int i, j; + RREAL *dp; double d00, d01, d10, d11; /* compute coordinates */ u = argument(1); v = argument(2); @@ -293,20 +299,21 @@ l_dataval( /* return recorded data value */ void putobjrow( /* output vertex row to .OBJ */ - register POINT *rp, + POINT *rp, int n ) { - static int nverts = 0; - for ( ; n-- >= 0; rp++) { if (!rp->valid) continue; fputs("v ", stdout); pvect(rp->p); - if (smooth && !ZEROVECT(rp->n)) + if (smooth && !ZEROVECT(rp->n)) { printf("\tvn %.9g %.9g %.9g\n", rp->n[0], rp->n[1], rp->n[2]); + rp->nvalid = ++nnorms; + } else + rp->nvalid = 0; printf("\tvt %.9g %.9g\n", rp->uv[0], rp->uv[1]); rp->valid = ++nverts; } @@ -314,6 +321,18 @@ putobjrow( /* output vertex row to .OBJ */ void +putobjvert( /* put out OBJ vertex index triplet */ + POINT *p +) +{ + int pti = p->valid ? p->valid-nverts-1 : 0; + int ni = p->nvalid ? p->nvalid-nnorms-1 : 0; + + printf(" %d/%d/%d", pti, pti, ni); +} + + +void putsquare( /* put out a square */ POINT *p0, POINT *p1, @@ -344,35 +363,23 @@ putsquare( /* put out a square */ if (!(ok1 | ok2)) return; if (objout) { /* output .OBJ faces */ - int p0n=0, p1n=0, p2n=0, p3n=0; - if (smooth) { - if (!ZEROVECT(p0->n)) - p0n = p0->valid; - if (!ZEROVECT(p1->n)) - p1n = p1->valid; - if (!ZEROVECT(p2->n)) - p2n = p2->valid; - if (!ZEROVECT(p3->n)) - p3n = p3->valid; - } if (ok1 & ok2 && fdot(vc1,vc2) >= 1.0-FTINY*FTINY) { - printf("f %d/%d/%d %d/%d/%d %d/%d/%d %d/%d/%d\n", - p0->valid, p0->valid, p0n, - p1->valid, p1->valid, p1n, - p3->valid, p3->valid, p3n, - p2->valid, p2->valid, p2n); + putc('f', stdout); + putobjvert(p0); putobjvert(p1); + putobjvert(p3); putobjvert(p2); + putc('\n', stdout); return; } - if (ok1) - printf("f %d/%d/%d %d/%d/%d %d/%d/%d\n", - p0->valid, p0->valid, p0n, - p1->valid, p1->valid, p1n, - p2->valid, p2->valid, p2n); - if (ok2) - printf("f %d/%d/%d %d/%d/%d %d/%d/%d\n", - p2->valid, p2->valid, p2n, - p1->valid, p1->valid, p1n, - p3->valid, p3->valid, p3n); + if (ok1) { + putc('f', stdout); + putobjvert(p0); putobjvert(p1); putobjvert(p2); + putc('\n', stdout); + } + if (ok2) { + putc('f', stdout); + putobjvert(p2); putobjvert(p1); putobjvert(p3); + putc('\n', stdout); + } return; } /* compute normal interpolation */ @@ -382,8 +389,7 @@ putsquare( /* put out a square */ if (ok1 & ok2 && fdot(vc1,vc2) >= 1.0-FTINY*FTINY) { printf("\n%s ", modname); if (axis != -1) { - printf("texfunc %s\n", texname); - printf(tsargs); + printf("texfunc %s\n%s\n", texname, tsargs); printf("0\n13\t%d\n", axis); pvect(norm[0]); pvect(norm[1]); @@ -405,8 +411,7 @@ putsquare( /* put out a square */ if (ok1) { printf("\n%s ", modname); if (axis != -1) { - printf("texfunc %s\n", texname); - printf(tsargs); + printf("texfunc %s\n%s\n", texname, tsargs); printf("0\n13\t%d\n", axis); pvect(norm[0]); pvect(norm[1]); @@ -424,8 +429,7 @@ putsquare( /* put out a square */ if (ok2) { printf("\n%s ", modname); if (axis != -1) { - printf("texfunc %s\n", texname); - printf(tsargs); + printf("texfunc %s\n%s\n", texname, tsargs); printf("0\n13\t%d\n", axis); pvect(norm[0]); pvect(norm[1]); @@ -446,14 +450,14 @@ putsquare( /* put out a square */ void comprow( /* compute row of values */ double s, - register POINT *row, + POINT *row, int siz ) { double st[2]; int end; int checkvalid; - register int i; + int i; if (smooth) { i = -1; /* compute one past each end */ @@ -487,9 +491,9 @@ comprow( /* compute row of values */ void compnorms( /* compute row of averaged normals */ - register POINT *r0, - register POINT *r1, - register POINT *r2, + POINT *r0, + POINT *r1, + POINT *r2, int siz ) { @@ -530,7 +534,7 @@ compnorms( /* compute row of averaged normals */ int norminterp( /* compute normal interpolation */ - register FVECT resmat[4], + FVECT resmat[4], POINT *p0, POINT *p1, POINT *p2, @@ -540,10 +544,10 @@ norminterp( /* compute normal interpolation */ #define u ((ax+1)%3) #define v ((ax+2)%3) - register int ax; + int ax; MAT4 eqnmat; FVECT v1; - register int i, j; + int i, j; if (!smooth) /* no interpolation if no smoothing */ return(-1);
