root/radiance/ray/src/gen/gensurf.c
Revision: 2.33
Committed: Wed Apr 23 01:57:04 2025 UTC (6 weeks, 2 days ago) by greg
Changes since 2.32: +3 -2 lines
fix: Functio prototypes and other fixes to reduce compiler warnings
# User Rev Content
1 greg 1.1 #ifndef lint
2 greg 2.33 static const char RCSid[] = "$Id: gensurf.c,v 2.32 2025/04/18 23:02:53 greg Exp $";
3 greg 1.1 #endif
4 greg 1.2 /*
5 greg 1.1 * gensurf.c - program to generate functional surfaces
6     *
7     * Parametric functions x(s,t), y(s,t) and z(s,t)
8     * specify the surface, which is tesselated into an m by n
9     * array of paired triangles.
10     * The surface normal is defined by the right hand
11     * rule applied to (s,t).
12     *
13     * 4/3/87
14 greg 2.6 *
15     * 4/16/02 Added conditional vertex output
16 greg 1.1 */
17
18 greg 2.14 #include "standard.h"
19 schorsch 2.15
20     #include "paths.h"
21 greg 2.16 #include "resolu.h"
22     #include "rterror.h"
23 schorsch 2.13 #include "calcomp.h"
24 greg 1.1
25 greg 2.6 char XNAME[] = "X`SYS"; /* x function name */
26     char YNAME[] = "Y`SYS"; /* y function name */
27     char ZNAME[] = "Z`SYS"; /* z function name */
28
29     char VNAME[] = "valid"; /* valid vertex name */
30 greg 1.1
31 greg 1.4 #define ABS(x) ((x)>=0 ? (x) : -(x))
32
33 greg 2.9 #define ZEROVECT(v) (DOT(v,v) <= FTINY*FTINY)
34
35 greg 1.3 #define pvect(p) printf(vformat, (p)[0], (p)[1], (p)[2])
36 greg 1.1
37 greg 2.18 char vformat[] = "%18.12g %18.12g %18.12g\n";
38 greg 2.19 char tsargs[] = "4 surf_dx surf_dy surf_dz surf.cal";
39 greg 1.3 char texname[] = "Phong";
40 greg 1.1
41 greg 1.3 int smooth = 0; /* apply smoothing? */
42 greg 2.7 int objout = 0; /* output .OBJ format? */
43 greg 2.31 int rev = 0; /* invert normal directions? */
44 greg 1.1
45 greg 1.3 char *modname, *surfname;
46 greg 1.1
47 greg 2.2 /* recorded data flags */
48     #define HASBORDER 01
49     #define TRIPLETS 02
50     /* a data structure */
51     struct {
52     int flags; /* data type */
53     short m, n; /* number of s and t values */
54 schorsch 2.11 RREAL *data; /* the data itself, s major sort */
55 greg 2.2 } datarec; /* our recorded data */
56 greg 1.3
57 schorsch 2.13 /* XXX this is redundant with rt/noise3.c, should go to a library */
58 greg 2.33 double l_hermite(char *), l_bezier(char *),
59     l_bspline(char *), l_dataval(char *);
60 greg 2.2
61 greg 1.3 typedef struct {
62 greg 2.7 int valid; /* point is valid (vertex number) */
63 greg 2.29 int nvalid; /* normal is valid (normal number) */
64 greg 1.3 FVECT p; /* vertex position */
65     FVECT n; /* average normal */
66 schorsch 2.11 RREAL uv[2]; /* (u,v) position */
67 greg 1.3 } POINT;
68
69 greg 2.23 int nverts = 0; /* vertex output count */
70     int nnorms = 0; /* normal output count */
71 greg 1.3
72 schorsch 2.13 void loaddata(char *file, int m, int n, int pointsize);
73     double l_dataval(char *nam);
74     void putobjrow(POINT *rp, int n);
75 greg 2.23 void putobjvert(POINT *p);
76 schorsch 2.13 void putsquare(POINT *p0, POINT *p1, POINT *p2, POINT *p3);
77     void comprow(double s, POINT *row, int siz);
78     void compnorms(POINT *r0, POINT *r1, POINT *r2, int siz);
79     int norminterp(FVECT resmat[4], POINT *p0, POINT *p1, POINT *p2, POINT *p3);
80
81
82     int
83 greg 2.28 main(int argc, char *argv[])
84 greg 1.1 {
85 greg 1.3 POINT *row0, *row1, *row2, *rp;
86 greg 1.1 int i, j, m, n;
87     char stmp[256];
88
89 greg 2.24 esupport |= E_VARIABLE|E_FUNCTION|E_RCONST;
90     esupport &= ~(E_OUTCHAN|E_INCHAN);
91 greg 1.13 varset("PI", ':', PI);
92 greg 1.14 funset("hermite", 5, ':', l_hermite);
93     funset("bezier", 5, ':', l_bezier);
94     funset("bspline", 5, ':', l_bspline);
95 greg 1.1
96     if (argc < 8)
97     goto userror;
98
99     for (i = 8; i < argc; i++)
100     if (!strcmp(argv[i], "-e"))
101 greg 1.10 scompile(argv[++i], NULL, 0);
102 greg 2.25 else if (!strcmp(argv[i], "-f")) {
103     char *fpath = getpath(argv[++i], getrlibpath(), 0);
104     if (fpath == NULL) {
105     fprintf(stderr, "%s: cannot find file '%s'\n",
106     argv[0], argv[i]);
107     quit(1);
108     }
109     fcompile(fpath);
110     } else if (!strcmp(argv[i], "-s"))
111 greg 1.3 smooth++;
112 greg 2.7 else if (!strcmp(argv[i], "-o"))
113     objout++;
114 greg 2.31 else if (!strcmp(argv[i], "-i"))
115     rev = 1;
116 greg 1.1 else
117     goto userror;
118
119 greg 1.3 modname = argv[1];
120     surfname = argv[2];
121 greg 2.26 m = eval(argv[6]) + .5;
122     n = eval(argv[7]) + .5;
123 greg 1.1 if (m <= 0 || n <= 0)
124     goto userror;
125 greg 2.2 if (!strcmp(argv[5], "-") || access(argv[5], 4) == 0) { /* file? */
126     funset(ZNAME, 2, ':', l_dataval);
127     if (!strcmp(argv[5],argv[3]) && !strcmp(argv[5],argv[4])) {
128     loaddata(argv[5], m, n, 3);
129     funset(XNAME, 2, ':', l_dataval);
130     funset(YNAME, 2, ':', l_dataval);
131     } else {
132     loaddata(argv[5], m, n, 1);
133     sprintf(stmp, "%s(s,t)=%s;", XNAME, argv[3]);
134     scompile(stmp, NULL, 0);
135     sprintf(stmp, "%s(s,t)=%s;", YNAME, argv[4]);
136     scompile(stmp, NULL, 0);
137     }
138     } else {
139     sprintf(stmp, "%s(s,t)=%s;", XNAME, argv[3]);
140     scompile(stmp, NULL, 0);
141     sprintf(stmp, "%s(s,t)=%s;", YNAME, argv[4]);
142     scompile(stmp, NULL, 0);
143     sprintf(stmp, "%s(s,t)=%s;", ZNAME, argv[5]);
144     scompile(stmp, NULL, 0);
145     }
146 greg 1.4 row0 = (POINT *)malloc((n+3)*sizeof(POINT));
147     row1 = (POINT *)malloc((n+3)*sizeof(POINT));
148     row2 = (POINT *)malloc((n+3)*sizeof(POINT));
149 greg 1.3 if (row0 == NULL || row1 == NULL || row2 == NULL) {
150 greg 1.1 fprintf(stderr, "%s: out of memory\n", argv[0]);
151     quit(1);
152     }
153 greg 1.4 row0++; row1++; row2++;
154 greg 1.3 /* print header */
155 greg 2.16 fputs("# ", stdout);
156     printargs(argc, argv, stdout);
157 greg 2.32 doptimize(1);
158     eclock++;
159 greg 1.4 /* initialize */
160     comprow(-1.0/m, row0, n);
161 greg 1.3 comprow(0.0, row1, n);
162     comprow(1.0/m, row2, n);
163 greg 1.4 compnorms(row0, row1, row2, n);
164 greg 2.8 if (objout) {
165     printf("\nusemtl %s\n\n", modname);
166 greg 2.28 printf("o %s\n\n", surfname);
167 greg 2.7 putobjrow(row1, n);
168 greg 2.8 }
169 greg 1.3 /* for each row */
170 greg 1.1 for (i = 0; i < m; i++) {
171     /* compute next row */
172 greg 1.3 rp = row0;
173 greg 1.1 row0 = row1;
174 greg 1.3 row1 = row2;
175     row2 = rp;
176 greg 1.4 comprow((double)(i+2)/m, row2, n);
177     compnorms(row0, row1, row2, n);
178 greg 2.7 if (objout)
179     putobjrow(row1, n);
180 greg 1.1
181     for (j = 0; j < n; j++) {
182 greg 2.6 int orient = (j & 1);
183 greg 1.3 /* put polygons */
184 greg 2.7 if (!(row0[j].valid && row1[j+1].valid))
185 greg 2.6 orient = 1;
186 greg 2.7 else if (!(row1[j].valid && row0[j+1].valid))
187 greg 2.6 orient = 0;
188     if (orient)
189 greg 1.3 putsquare(&row0[j], &row1[j],
190     &row0[j+1], &row1[j+1]);
191     else
192     putsquare(&row1[j], &row1[j+1],
193     &row0[j], &row0[j+1]);
194 greg 1.1 }
195     }
196
197 schorsch 2.13 return 0;
198 greg 1.1
199     userror:
200     fprintf(stderr, "Usage: %s material name ", argv[0]);
201 greg 2.17 fprintf(stderr, "x(s,t) y(s,t) z(s,t) m n [-s][-o][-e expr][-f file]\n");
202 schorsch 2.13 return 1;
203 greg 2.2 }
204
205
206 schorsch 2.13 void
207     loaddata( /* load point data from file */
208     char *file,
209     int m,
210     int n,
211     int pointsize
212     )
213 greg 2.2 {
214     FILE *fp;
215     char word[64];
216 greg 2.22 int size;
217     RREAL *dp;
218 greg 2.2
219     datarec.flags = HASBORDER; /* assume border values */
220 greg 2.3 datarec.m = m+1;
221     datarec.n = n+1;
222     size = datarec.m*datarec.n*pointsize;
223 greg 2.2 if (pointsize == 3)
224     datarec.flags |= TRIPLETS;
225 schorsch 2.11 dp = (RREAL *)malloc(size*sizeof(RREAL));
226 greg 2.2 if ((datarec.data = dp) == NULL) {
227     fputs("Out of memory\n", stderr);
228     exit(1);
229     }
230     if (!strcmp(file, "-")) {
231     file = "<stdin>";
232     fp = stdin;
233     } else if ((fp = fopen(file, "r")) == NULL) {
234     fputs(file, stderr);
235     fputs(": cannot open\n", stderr);
236     exit(1);
237     }
238     while (size > 0 && fgetword(word, sizeof(word), fp) != NULL) {
239     if (!isflt(word)) {
240     fprintf(stderr, "%s: garbled data value: %s\n",
241     file, word);
242     exit(1);
243     }
244     *dp++ = atof(word);
245     size--;
246     }
247     if (size == (m+n+1)*pointsize) { /* no border after all */
248 greg 2.20 dp = (RREAL *)realloc(datarec.data,
249 schorsch 2.11 m*n*pointsize*sizeof(RREAL));
250 greg 2.2 if (dp != NULL)
251     datarec.data = dp;
252     datarec.flags &= ~HASBORDER;
253 greg 2.3 datarec.m = m;
254     datarec.n = n;
255 greg 2.2 size = 0;
256     }
257 greg 2.3 if (datarec.m < 2 || datarec.n < 2 || size != 0 ||
258     fgetword(word, sizeof(word), fp) != NULL) {
259 greg 2.2 fputs(file, stderr);
260     fputs(": bad number of data points\n", stderr);
261     exit(1);
262     }
263     fclose(fp);
264     }
265
266
267     double
268 schorsch 2.13 l_dataval( /* return recorded data value */
269     char *nam
270     )
271 greg 2.2 {
272     double u, v;
273 greg 2.22 int i, j;
274     RREAL *dp;
275 greg 2.2 double d00, d01, d10, d11;
276     /* compute coordinates */
277     u = argument(1); v = argument(2);
278     if (datarec.flags & HASBORDER) {
279 greg 2.3 i = u *= datarec.m-1;
280     j = v *= datarec.n-1;
281 greg 2.2 } else {
282 greg 2.3 i = u = u*datarec.m - .5;
283     j = v = v*datarec.n - .5;
284 greg 2.2 }
285     if (i < 0) i = 0;
286     else if (i > datarec.m-2) i = datarec.m-2;
287     if (j < 0) j = 0;
288     else if (j > datarec.n-2) j = datarec.n-2;
289     /* compute value */
290     if (datarec.flags & TRIPLETS) {
291 greg 2.3 dp = datarec.data + 3*(j*datarec.m + i);
292     if (nam == ZNAME)
293     dp += 2;
294     else if (nam == YNAME)
295 greg 2.2 dp++;
296     d00 = dp[0]; d01 = dp[3];
297 greg 2.3 dp += 3*datarec.m;
298 greg 2.2 d10 = dp[0]; d11 = dp[3];
299     } else {
300 greg 2.3 dp = datarec.data + j*datarec.m + i;
301 greg 2.2 d00 = dp[0]; d01 = dp[1];
302 greg 2.3 dp += datarec.m;
303 greg 2.2 d10 = dp[0]; d11 = dp[1];
304     }
305     /* bilinear interpolation */
306     return((j+1-v)*((i+1-u)*d00+(u-i)*d01)+(v-j)*((i+1-u)*d10+(u-i)*d11));
307 greg 1.1 }
308
309
310 schorsch 2.13 void
311     putobjrow( /* output vertex row to .OBJ */
312 greg 2.22 POINT *rp,
313 schorsch 2.13 int n
314     )
315 greg 2.7 {
316 greg 2.29 static FVECT prevNorm;
317
318 greg 2.7 for ( ; n-- >= 0; rp++) {
319     if (!rp->valid)
320     continue;
321     fputs("v ", stdout);
322 greg 2.9 pvect(rp->p);
323 greg 2.29 rp->valid = ++nverts;
324     printf("\tvt %.9g %.9g\n", rp->uv[0], rp->uv[1]);
325     if (!smooth || ZEROVECT(rp->n))
326     rp->nvalid = 0;
327     else if (VABSEQ(rp->n, prevNorm))
328     rp->nvalid = nnorms;
329     else {
330 greg 2.7 printf("\tvn %.9g %.9g %.9g\n",
331     rp->n[0], rp->n[1], rp->n[2]);
332 greg 2.21 rp->nvalid = ++nnorms;
333 greg 2.29 VCOPY(prevNorm, rp->n);
334     }
335 greg 2.7 }
336     }
337
338
339 schorsch 2.13 void
340 greg 2.23 putobjvert( /* put out OBJ vertex index triplet */
341     POINT *p
342     )
343     {
344     int pti = p->valid ? p->valid-nverts-1 : 0;
345     int ni = p->nvalid ? p->nvalid-nnorms-1 : 0;
346
347     printf(" %d/%d/%d", pti, pti, ni);
348     }
349
350
351     void
352 schorsch 2.13 putsquare( /* put out a square */
353     POINT *p0,
354     POINT *p1,
355     POINT *p2,
356     POINT *p3
357     )
358 greg 1.3 {
359     static int nout = 0;
360     FVECT norm[4];
361     int axis;
362     FVECT v1, v2, vc1, vc2;
363     int ok1, ok2;
364 greg 2.31
365     if (rev) { /* reverse normals? */
366     POINT *pt = p1; p1 = p2; p2 = pt;
367     }
368 greg 1.3 /* compute exact normals */
369 greg 2.7 ok1 = (p0->valid && p1->valid && p2->valid);
370 greg 2.6 if (ok1) {
371 greg 2.9 VSUB(v1, p1->p, p0->p);
372     VSUB(v2, p2->p, p0->p);
373 greg 2.6 fcross(vc1, v1, v2);
374     ok1 = (normalize(vc1) != 0.0);
375     }
376 greg 2.7 ok2 = (p1->valid && p2->valid && p3->valid);
377 greg 2.6 if (ok2) {
378 greg 2.9 VSUB(v1, p2->p, p3->p);
379     VSUB(v2, p1->p, p3->p);
380 greg 2.6 fcross(vc2, v1, v2);
381     ok2 = (normalize(vc2) != 0.0);
382     }
383 greg 1.3 if (!(ok1 | ok2))
384     return;
385 greg 2.7 if (objout) { /* output .OBJ faces */
386     if (ok1 & ok2 && fdot(vc1,vc2) >= 1.0-FTINY*FTINY) {
387 greg 2.23 putc('f', stdout);
388     putobjvert(p0); putobjvert(p1);
389     putobjvert(p3); putobjvert(p2);
390     putc('\n', stdout);
391 greg 2.7 return;
392     }
393 greg 2.23 if (ok1) {
394     putc('f', stdout);
395     putobjvert(p0); putobjvert(p1); putobjvert(p2);
396     putc('\n', stdout);
397     }
398     if (ok2) {
399     putc('f', stdout);
400     putobjvert(p2); putobjvert(p1); putobjvert(p3);
401     putc('\n', stdout);
402     }
403 greg 2.7 return;
404     }
405 greg 1.3 /* compute normal interpolation */
406     axis = norminterp(norm, p0, p1, p2, p3);
407
408     /* put out quadrilateral? */
409     if (ok1 & ok2 && fdot(vc1,vc2) >= 1.0-FTINY*FTINY) {
410     printf("\n%s ", modname);
411     if (axis != -1) {
412 greg 2.19 printf("texfunc %s\n%s\n", texname, tsargs);
413 greg 1.3 printf("0\n13\t%d\n", axis);
414     pvect(norm[0]);
415     pvect(norm[1]);
416     pvect(norm[2]);
417     fvsum(v1, norm[3], vc1, -0.5);
418     fvsum(v1, v1, vc2, -0.5);
419     pvect(v1);
420     printf("\n%s ", texname);
421     }
422     printf("polygon %s.%d\n", surfname, ++nout);
423     printf("0\n0\n12\n");
424     pvect(p0->p);
425     pvect(p1->p);
426     pvect(p3->p);
427     pvect(p2->p);
428     return;
429     }
430     /* put out triangles? */
431     if (ok1) {
432     printf("\n%s ", modname);
433     if (axis != -1) {
434 greg 2.19 printf("texfunc %s\n%s\n", texname, tsargs);
435 greg 1.3 printf("0\n13\t%d\n", axis);
436     pvect(norm[0]);
437     pvect(norm[1]);
438     pvect(norm[2]);
439     fvsum(v1, norm[3], vc1, -1.0);
440     pvect(v1);
441     printf("\n%s ", texname);
442     }
443     printf("polygon %s.%d\n", surfname, ++nout);
444     printf("0\n0\n9\n");
445     pvect(p0->p);
446     pvect(p1->p);
447     pvect(p2->p);
448     }
449     if (ok2) {
450     printf("\n%s ", modname);
451     if (axis != -1) {
452 greg 2.19 printf("texfunc %s\n%s\n", texname, tsargs);
453 greg 1.3 printf("0\n13\t%d\n", axis);
454     pvect(norm[0]);
455     pvect(norm[1]);
456     pvect(norm[2]);
457     fvsum(v2, norm[3], vc2, -1.0);
458     pvect(v2);
459     printf("\n%s ", texname);
460     }
461     printf("polygon %s.%d\n", surfname, ++nout);
462     printf("0\n0\n9\n");
463     pvect(p2->p);
464     pvect(p1->p);
465     pvect(p3->p);
466     }
467     }
468
469
470 schorsch 2.13 void
471     comprow( /* compute row of values */
472     double s,
473 greg 2.22 POINT *row,
474 schorsch 2.13 int siz
475     )
476 greg 1.1 {
477 greg 1.4 double st[2];
478 greg 1.8 int end;
479 greg 2.6 int checkvalid;
480 greg 2.22 int i;
481 greg 1.8
482     if (smooth) {
483     i = -1; /* compute one past each end */
484     end = siz+1;
485     } else {
486     if (s < -FTINY || s > 1.0+FTINY)
487     return;
488     i = 0;
489     end = siz;
490     }
491 greg 1.1 st[0] = s;
492 greg 2.6 checkvalid = (fundefined(VNAME) == 2);
493 greg 1.8 while (i <= end) {
494 greg 1.4 st[1] = (double)i/siz;
495 greg 2.6 if (checkvalid && funvalue(VNAME, 2, st) <= 0.0) {
496     row[i].valid = 0;
497     row[i].p[0] = row[i].p[1] = row[i].p[2] = 0.0;
498 greg 2.7 row[i].uv[0] = row[i].uv[1] = 0.0;
499 greg 2.6 } else {
500     row[i].valid = 1;
501     row[i].p[0] = funvalue(XNAME, 2, st);
502     row[i].p[1] = funvalue(YNAME, 2, st);
503     row[i].p[2] = funvalue(ZNAME, 2, st);
504 greg 2.7 row[i].uv[0] = st[0];
505     row[i].uv[1] = st[1];
506 greg 2.6 }
507 greg 1.8 i++;
508 greg 1.1 }
509 greg 1.3 }
510
511
512 schorsch 2.13 void
513     compnorms( /* compute row of averaged normals */
514 greg 2.22 POINT *r0,
515     POINT *r1,
516     POINT *r2,
517 schorsch 2.13 int siz
518     )
519 greg 1.3 {
520 greg 1.11 FVECT v1, v2;
521 greg 1.3
522     if (!smooth) /* not needed if no smoothing */
523     return;
524 greg 2.6 /* compute row 1 normals */
525 greg 1.4 while (siz-- >= 0) {
526 greg 2.6 if (!r1[0].valid)
527 greg 2.27 goto skip;
528 greg 2.6 if (!r0[0].valid) {
529     if (!r2[0].valid) {
530     r1[0].n[0] = r1[0].n[1] = r1[0].n[2] = 0.0;
531 greg 2.27 goto skip;
532 greg 2.6 }
533     fvsum(v1, r2[0].p, r1[0].p, -1.0);
534     } else if (!r2[0].valid)
535     fvsum(v1, r1[0].p, r0[0].p, -1.0);
536     else
537     fvsum(v1, r2[0].p, r0[0].p, -1.0);
538     if (!r1[-1].valid) {
539     if (!r1[1].valid) {
540     r1[0].n[0] = r1[0].n[1] = r1[0].n[2] = 0.0;
541 greg 2.27 goto skip;
542 greg 2.6 }
543     fvsum(v2, r1[1].p, r1[0].p, -1.0);
544     } else if (!r1[1].valid)
545     fvsum(v2, r1[0].p, r1[-1].p, -1.0);
546     else
547     fvsum(v2, r1[1].p, r1[-1].p, -1.0);
548 greg 2.31 if (rev)
549     fcross(r1[0].n, v2, v1);
550     else
551     fcross(r1[0].n, v1, v2);
552 greg 1.3 normalize(r1[0].n);
553 greg 2.27 skip:
554 greg 1.3 r0++; r1++; r2++;
555     }
556     }
557
558
559     int
560 schorsch 2.13 norminterp( /* compute normal interpolation */
561 greg 2.22 FVECT resmat[4],
562 schorsch 2.13 POINT *p0,
563     POINT *p1,
564     POINT *p2,
565     POINT *p3
566     )
567 greg 1.3 {
568     #define u ((ax+1)%3)
569     #define v ((ax+2)%3)
570
571 greg 2.22 int ax;
572 greg 1.12 MAT4 eqnmat;
573 greg 1.3 FVECT v1;
574 greg 2.22 int i, j;
575 greg 1.3
576     if (!smooth) /* no interpolation if no smoothing */
577     return(-1);
578     /* find dominant axis */
579     VCOPY(v1, p0->n);
580     fvsum(v1, v1, p1->n, 1.0);
581     fvsum(v1, v1, p2->n, 1.0);
582     fvsum(v1, v1, p3->n, 1.0);
583 greg 1.4 ax = ABS(v1[0]) > ABS(v1[1]) ? 0 : 1;
584     ax = ABS(v1[ax]) > ABS(v1[2]) ? ax : 2;
585 greg 1.3 /* assign equation matrix */
586     eqnmat[0][0] = p0->p[u]*p0->p[v];
587     eqnmat[0][1] = p0->p[u];
588     eqnmat[0][2] = p0->p[v];
589     eqnmat[0][3] = 1.0;
590     eqnmat[1][0] = p1->p[u]*p1->p[v];
591     eqnmat[1][1] = p1->p[u];
592     eqnmat[1][2] = p1->p[v];
593     eqnmat[1][3] = 1.0;
594     eqnmat[2][0] = p2->p[u]*p2->p[v];
595     eqnmat[2][1] = p2->p[u];
596     eqnmat[2][2] = p2->p[v];
597     eqnmat[2][3] = 1.0;
598     eqnmat[3][0] = p3->p[u]*p3->p[v];
599     eqnmat[3][1] = p3->p[u];
600     eqnmat[3][2] = p3->p[v];
601     eqnmat[3][3] = 1.0;
602     /* invert matrix (solve system) */
603 greg 2.5 if (!invmat4(eqnmat, eqnmat))
604 greg 1.3 return(-1); /* no solution */
605     /* compute result matrix */
606     for (j = 0; j < 4; j++)
607     for (i = 0; i < 3; i++)
608 greg 1.4 resmat[j][i] = eqnmat[j][0]*p0->n[i] +
609     eqnmat[j][1]*p1->n[i] +
610     eqnmat[j][2]*p2->n[i] +
611     eqnmat[j][3]*p3->n[i];
612 greg 1.3 return(ax);
613
614     #undef u
615     #undef v
616 greg 1.1 }
617
618
619     double
620 greg 2.12 l_hermite(char *nm)
621 greg 1.1 {
622     double t;
623
624     t = argument(5);
625     return( argument(1)*((2.0*t-3.0)*t*t+1.0) +
626     argument(2)*(-2.0*t+3.0)*t*t +
627     argument(3)*((t-2.0)*t+1.0)*t +
628     argument(4)*(t-1.0)*t*t );
629 greg 1.6 }
630
631
632     double
633 greg 2.12 l_bezier(char *nm)
634 greg 1.6 {
635     double t;
636
637     t = argument(5);
638     return( argument(1) * (1.+t*(-3.+t*(3.-t))) +
639     argument(2) * 3.*t*(1.+t*(-2.+t)) +
640     argument(3) * 3.*t*t*(1.-t) +
641     argument(4) * t*t*t );
642 greg 1.7 }
643
644
645     double
646 greg 2.12 l_bspline(char *nm)
647 greg 1.7 {
648     double t;
649
650     t = argument(5);
651     return( argument(1) * (1./6.+t*(-1./2.+t*(1./2.-1./6.*t))) +
652     argument(2) * (2./3.+t*t*(-1.+1./2.*t)) +
653     argument(3) * (1./6.+t*(1./2.+t*(1./2.-1./2.*t))) +
654     argument(4) * (1./6.*t*t*t) );
655 greg 1.1 }
