root/Development/ray/src/gen/gensurf.c
Revision: 2.7
Committed: Tue Mar 11 22:48:20 2003 UTC (22 years, 7 months ago) by greg
Changes since 2.6: +65 -6 lines
5 * gensurf.c - program to generate functional surfaces
6 *
7 * Parametric functions x(s,t), y(s,t) and z(s,t)
8 * specify the surface, which is tesselated into an m by n
9 * array of paired triangles.
10 * The surface normal is defined by the right hand
11 * rule applied to (s,t).
12 *
13 * 4/3/87
14 *
15 * 4/16/02 Added conditional vertex output
16 */
17
18 #include "standard.h"
19
20 char XNAME[] = "X`SYS"; /* x function name */
21 char YNAME[] = "Y`SYS"; /* y function name */
22 char ZNAME[] = "Z`SYS"; /* z function name */
23
24 char VNAME[] = "valid"; /* valid vertex name */
25
26 #define ABS(x) ((x)>=0 ? (x) : -(x))
27
28 #define pvect(p) printf(vformat, (p)[0], (p)[1], (p)[2])
29
30 char vformat[] = "%15.9g %15.9g %15.9g\n";
31 char tsargs[] = "4 surf_dx surf_dy surf_dz surf.cal\n";
32 char texname[] = "Phong";
33
34 int smooth = 0; /* apply smoothing? */
35 int objout = 0; /* output .OBJ format? */
36
37 char *modname, *surfname;
38
39 /* recorded data flags */
40 #define HASBORDER 01
41 #define TRIPLETS 02
42 /* a data structure */
43 struct {
44 int flags; /* data type */
45 short m, n; /* number of s and t values */
46 FLOAT *data; /* the data itself, s major sort */
47 } datarec; /* our recorded data */
48
49 double l_hermite(), l_bezier(), l_bspline(), l_dataval();
50 extern double funvalue(), argument();
51
52 typedef struct {
53 int valid; /* point is valid (vertex number) */
54 FVECT p; /* vertex position */
55 FVECT n; /* average normal */
56 FLOAT uv[2]; /* (u,v) position */
57 } POINT;
58
59
60 main(argc, argv)
61 int argc;
62 char *argv[];
63 {
64 extern long eclock;
65 POINT *row0, *row1, *row2, *rp;
66 int i, j, m, n;
67 char stmp[256];
68
69 varset("PI", ':', PI);
70 funset("hermite", 5, ':', l_hermite);
71 funset("bezier", 5, ':', l_bezier);
72 funset("bspline", 5, ':', l_bspline);
73
74 if (argc < 8)
75 goto userror;
76
77 for (i = 8; i < argc; i++)
78 if (!strcmp(argv[i], "-e"))
79 scompile(argv[++i], NULL, 0);
80 else if (!strcmp(argv[i], "-f"))
81 fcompile(argv[++i]);
82 else if (!strcmp(argv[i], "-s"))
83 smooth++;
84 else if (!strcmp(argv[i], "-o"))
85 objout++;
86 else
87 goto userror;
88
89 modname = argv[1];
90 surfname = argv[2];
91 m = atoi(argv[6]);
92 n = atoi(argv[7]);
93 if (m <= 0 || n <= 0)
94 goto userror;
95 if (!strcmp(argv[5], "-") || access(argv[5], 4) == 0) { /* file? */
96 funset(ZNAME, 2, ':', l_dataval);
97 if (!strcmp(argv[5],argv[3]) && !strcmp(argv[5],argv[4])) {
98 loaddata(argv[5], m, n, 3);
99 funset(XNAME, 2, ':', l_dataval);
100 funset(YNAME, 2, ':', l_dataval);
101 } else {
102 loaddata(argv[5], m, n, 1);
103 sprintf(stmp, "%s(s,t)=%s;", XNAME, argv[3]);
104 scompile(stmp, NULL, 0);
105 sprintf(stmp, "%s(s,t)=%s;", YNAME, argv[4]);
106 scompile(stmp, NULL, 0);
107 }
108 } else {
109 sprintf(stmp, "%s(s,t)=%s;", XNAME, argv[3]);
110 scompile(stmp, NULL, 0);
111 sprintf(stmp, "%s(s,t)=%s;", YNAME, argv[4]);
112 scompile(stmp, NULL, 0);
113 sprintf(stmp, "%s(s,t)=%s;", ZNAME, argv[5]);
114 scompile(stmp, NULL, 0);
115 }
116 row0 = (POINT *)malloc((n+3)*sizeof(POINT));
117 row1 = (POINT *)malloc((n+3)*sizeof(POINT));
118 row2 = (POINT *)malloc((n+3)*sizeof(POINT));
119 if (row0 == NULL || row1 == NULL || row2 == NULL) {
120 fprintf(stderr, "%s: out of memory\n", argv[0]);
121 quit(1);
122 }
123 row0++; row1++; row2++;
124 /* print header */
125 printhead(argc, argv);
126 eclock = 0;
127 /* initialize */
128 comprow(-1.0/m, row0, n);
129 comprow(0.0, row1, n);
130 comprow(1.0/m, row2, n);
131 compnorms(row0, row1, row2, n);
132 if (objout)
133 putobjrow(row1, n);
134 /* for each row */
135 for (i = 0; i < m; i++) {
136 /* compute next row */
137 rp = row0;
138 row0 = row1;
139 row1 = row2;
140 row2 = rp;
141 comprow((double)(i+2)/m, row2, n);
142 compnorms(row0, row1, row2, n);
143 if (objout)
144 putobjrow(row1, n);
145
146 for (j = 0; j < n; j++) {
147 int orient = (j & 1);
148 /* put polygons */
149 if (!(row0[j].valid && row1[j+1].valid))
150 orient = 1;
151 else if (!(row1[j].valid && row0[j+1].valid))
152 orient = 0;
153 if (orient)
154 putsquare(&row0[j], &row1[j],
155 &row0[j+1], &row1[j+1]);
156 else
157 putsquare(&row1[j], &row1[j+1],
158 &row0[j], &row0[j+1]);
159 }
160 }
161
162 quit(0);
163
164 userror:
165 fprintf(stderr, "Usage: %s material name ", argv[0]);
166 fprintf(stderr, "x(s,t) y(s,t) z(s,t) m n [-s][-e expr][-f file]\n");
167 quit(1);
168 }
169
170
171 loaddata(file, m, n, pointsize) /* load point data from file */
172 char *file;
173 int m, n;
174 int pointsize;
175 {
176 FILE *fp;
177 char word[64];
178 register int size;
179 register FLOAT *dp;
180
181 datarec.flags = HASBORDER; /* assume border values */
182 datarec.m = m+1;
183 datarec.n = n+1;
184 size = datarec.m*datarec.n*pointsize;
185 if (pointsize == 3)
186 datarec.flags |= TRIPLETS;
187 dp = (FLOAT *)malloc(size*sizeof(FLOAT));
188 if ((datarec.data = dp) == NULL) {
189 fputs("Out of memory\n", stderr);
190 exit(1);
191 }
192 if (!strcmp(file, "-")) {
193 file = "<stdin>";
194 fp = stdin;
195 } else if ((fp = fopen(file, "r")) == NULL) {
196 fputs(file, stderr);
197 fputs(": cannot open\n", stderr);
198 exit(1);
199 }
200 while (size > 0 && fgetword(word, sizeof(word), fp) != NULL) {
201 if (!isflt(word)) {
202 fprintf(stderr, "%s: garbled data value: %s\n",
203 file, word);
204 exit(1);
205 }
206 *dp++ = atof(word);
207 size--;
208 }
209 if (size == (m+n+1)*pointsize) { /* no border after all */
210 dp = (FLOAT *)realloc((char *)datarec.data,
211 m*n*pointsize*sizeof(FLOAT));
212 if (dp != NULL)
213 datarec.data = dp;
214 datarec.flags &= ~HASBORDER;
215 datarec.m = m;
216 datarec.n = n;
217 size = 0;
218 }
219 if (datarec.m < 2 || datarec.n < 2 || size != 0 ||
220 fgetword(word, sizeof(word), fp) != NULL) {
221 fputs(file, stderr);
222 fputs(": bad number of data points\n", stderr);
223 exit(1);
224 }
225 fclose(fp);
226 }
227
228
229 double
230 l_dataval(nam) /* return recorded data value */
231 char *nam;
232 {
233 double u, v;
234 register int i, j;
235 register FLOAT *dp;
236 double d00, d01, d10, d11;
237 /* compute coordinates */
238 u = argument(1); v = argument(2);
239 if (datarec.flags & HASBORDER) {
240 i = u *= datarec.m-1;
241 j = v *= datarec.n-1;
242 } else {
243 i = u = u*datarec.m - .5;
244 j = v = v*datarec.n - .5;
245 }
246 if (i < 0) i = 0;
247 else if (i > datarec.m-2) i = datarec.m-2;
248 if (j < 0) j = 0;
249 else if (j > datarec.n-2) j = datarec.n-2;
250 /* compute value */
251 if (datarec.flags & TRIPLETS) {
252 dp = datarec.data + 3*(j*datarec.m + i);
253 if (nam == ZNAME)
254 dp += 2;
255 else if (nam == YNAME)
256 dp++;
257 d00 = dp[0]; d01 = dp[3];
258 dp += 3*datarec.m;
259 d10 = dp[0]; d11 = dp[3];
260 } else {
261 dp = datarec.data + j*datarec.m + i;
262 d00 = dp[0]; d01 = dp[1];
263 dp += datarec.m;
264 d10 = dp[0]; d11 = dp[1];
265 }
266 /* bilinear interpolation */
267 return((j+1-v)*((i+1-u)*d00+(u-i)*d01)+(v-j)*((i+1-u)*d10+(u-i)*d11));
268 }
269
270
271 putobjrow(rp, n) /* output vertex row to .OBJ */
272 register POINT *rp;
273 int n;
274 {
275 static int nverts = 0;
276
277 for ( ; n-- >= 0; rp++) {
278 if (!rp->valid)
279 continue;
280 fputs("v ", stdout);
281 printf(vformat, rp->p[0], rp->p[1], rp->p[2]);
282 if (smooth)
283 printf("\tvn %.9g %.9g %.9g\n",
284 rp->n[0], rp->n[1], rp->n[2]);
285 printf("\tvt %.9g %.9g\n", rp->uv[0], rp->uv[1]);
286 rp->valid = ++nverts;
287 }
288 }
289
290
291 putsquare(p0, p1, p2, p3) /* put out a square */
292 POINT *p0, *p1, *p2, *p3;
293 {
294 static int nout = 0;
295 FVECT norm[4];
296 int axis;
297 FVECT v1, v2, vc1, vc2;
298 int ok1, ok2;
299 /* compute exact normals */
300 ok1 = (p0->valid && p1->valid && p2->valid);
301 if (ok1) {
302 fvsum(v1, p1->p, p0->p, -1.0);
303 fvsum(v2, p2->p, p0->p, -1.0);
304 fcross(vc1, v1, v2);
305 ok1 = (normalize(vc1) != 0.0);
306 }
307 ok2 = (p1->valid && p2->valid && p3->valid);
308 if (ok2) {
309 fvsum(v1, p2->p, p3->p, -1.0);
310 fvsum(v2, p1->p, p3->p, -1.0);
311 fcross(vc2, v1, v2);
312 ok2 = (normalize(vc2) != 0.0);
313 }
314 if (!(ok1 | ok2))
315 return;
316 if (objout) { /* output .OBJ faces */
317 int p0n=0, p1n=0, p2n=0, p3n=0;
318 if (smooth) {
319 p0n = p0->valid;
320 p1n = p1->valid;
321 p2n = p2->valid;
322 p3n = p3->valid;
323 }
324 if (ok1 & ok2 && fdot(vc1,vc2) >= 1.0-FTINY*FTINY) {
325 printf("f %d/%d/%d %d/%d/%d %d/%d/%d %d/%d/%d\n",
326 p0->valid, p0n, p0->valid,
327 p1->valid, p1n, p1->valid,
328 p3->valid, p3n, p3->valid,
329 p2->valid, p2n, p2->valid);
330 return;
331 }
332 if (ok1)
333 printf("f %d/%d/%d %d/%d/%d %d/%d/%d\n",
334 p0->valid, p0n, p0->valid,
335 p1->valid, p1n, p1->valid,
336 p2->valid, p2n, p2->valid);
337 if (ok2)
338 printf("f %d/%d/%d %d/%d/%d %d/%d/%d\n",
339 p2->valid, p2n, p2->valid,
340 p1->valid, p1n, p1->valid,
341 p3->valid, p3n, p3->valid);
342 return;
343 }
344 /* compute normal interpolation */
345 axis = norminterp(norm, p0, p1, p2, p3);
346
347 /* put out quadrilateral? */
348 if (ok1 & ok2 && fdot(vc1,vc2) >= 1.0-FTINY*FTINY) {
349 printf("\n%s ", modname);
350 if (axis != -1) {
351 printf("texfunc %s\n", texname);
352 printf(tsargs);
353 printf("0\n13\t%d\n", axis);
354 pvect(norm[0]);
355 pvect(norm[1]);
356 pvect(norm[2]);
357 fvsum(v1, norm[3], vc1, -0.5);
358 fvsum(v1, v1, vc2, -0.5);
359 pvect(v1);
360 printf("\n%s ", texname);
361 }
362 printf("polygon %s.%d\n", surfname, ++nout);
363 printf("0\n0\n12\n");
364 pvect(p0->p);
365 pvect(p1->p);
366 pvect(p3->p);
367 pvect(p2->p);
368 return;
369 }
370 /* put out triangles? */
371 if (ok1) {
372 printf("\n%s ", modname);
373 if (axis != -1) {
374 printf("texfunc %s\n", texname);
375 printf(tsargs);
376 printf("0\n13\t%d\n", axis);
377 pvect(norm[0]);
378 pvect(norm[1]);
379 pvect(norm[2]);
380 fvsum(v1, norm[3], vc1, -1.0);
381 pvect(v1);
382 printf("\n%s ", texname);
383 }
384 printf("polygon %s.%d\n", surfname, ++nout);
385 printf("0\n0\n9\n");
386 pvect(p0->p);
387 pvect(p1->p);
388 pvect(p2->p);
389 }
390 if (ok2) {
391 printf("\n%s ", modname);
392 if (axis != -1) {
393 printf("texfunc %s\n", texname);
394 printf(tsargs);
395 printf("0\n13\t%d\n", axis);
396 pvect(norm[0]);
397 pvect(norm[1]);
398 pvect(norm[2]);
399 fvsum(v2, norm[3], vc2, -1.0);
400 pvect(v2);
401 printf("\n%s ", texname);
402 }
403 printf("polygon %s.%d\n", surfname, ++nout);
404 printf("0\n0\n9\n");
405 pvect(p2->p);
406 pvect(p1->p);
407 pvect(p3->p);
408 }
409 }
410
411
412 comprow(s, row, siz) /* compute row of values */
413 double s;
414 register POINT *row;
415 int siz;
416 {
417 double st[2];
418 int end;
419 int checkvalid;
420 register int i;
421
422 if (smooth) {
423 i = -1; /* compute one past each end */
424 end = siz+1;
425 } else {
426 if (s < -FTINY || s > 1.0+FTINY)
427 return;
428 i = 0;
429 end = siz;
430 }
431 st[0] = s;
432 checkvalid = (fundefined(VNAME) == 2);
433 while (i <= end) {
434 st[1] = (double)i/siz;
435 if (checkvalid && funvalue(VNAME, 2, st) <= 0.0) {
436 row[i].valid = 0;
437 row[i].p[0] = row[i].p[1] = row[i].p[2] = 0.0;
438 row[i].uv[0] = row[i].uv[1] = 0.0;
439 } else {
440 row[i].valid = 1;
441 row[i].p[0] = funvalue(XNAME, 2, st);
442 row[i].p[1] = funvalue(YNAME, 2, st);
443 row[i].p[2] = funvalue(ZNAME, 2, st);
444 row[i].uv[0] = st[0];
445 row[i].uv[1] = st[1];
446 }
447 i++;
448 }
449 }
450
451
452 compnorms(r0, r1, r2, siz) /* compute row of averaged normals */
453 register POINT *r0, *r1, *r2;
454 int siz;
455 {
456 FVECT v1, v2;
457
458 if (!smooth) /* not needed if no smoothing */
459 return;
460 /* compute row 1 normals */
461 while (siz-- >= 0) {
462 if (!r1[0].valid)
463 continue;
464 if (!r0[0].valid) {
465 if (!r2[0].valid) {
466 r1[0].n[0] = r1[0].n[1] = r1[0].n[2] = 0.0;
467 continue;
468 }
469 fvsum(v1, r2[0].p, r1[0].p, -1.0);
470 } else if (!r2[0].valid)
471 fvsum(v1, r1[0].p, r0[0].p, -1.0);
472 else
473 fvsum(v1, r2[0].p, r0[0].p, -1.0);
474 if (!r1[-1].valid) {
475 if (!r1[1].valid) {
476 r1[0].n[0] = r1[0].n[1] = r1[0].n[2] = 0.0;
477 continue;
478 }
479 fvsum(v2, r1[1].p, r1[0].p, -1.0);
480 } else if (!r1[1].valid)
481 fvsum(v2, r1[0].p, r1[-1].p, -1.0);
482 else
483 fvsum(v2, r1[1].p, r1[-1].p, -1.0);
484 fcross(r1[0].n, v1, v2);
485 normalize(r1[0].n);
486 r0++; r1++; r2++;
487 }
488 }
489
490
491 int
492 norminterp(resmat, p0, p1, p2, p3) /* compute normal interpolation */
493 register FVECT resmat[4];
494 POINT *p0, *p1, *p2, *p3;
495 {
496 #define u ((ax+1)%3)
497 #define v ((ax+2)%3)
498
499 register int ax;
500 MAT4 eqnmat;
501 FVECT v1;
502 register int i, j;
503
504 if (!smooth) /* no interpolation if no smoothing */
505 return(-1);
506 /* find dominant axis */
507 VCOPY(v1, p0->n);
508 fvsum(v1, v1, p1->n, 1.0);
509 fvsum(v1, v1, p2->n, 1.0);
510 fvsum(v1, v1, p3->n, 1.0);
511 ax = ABS(v1[0]) > ABS(v1[1]) ? 0 : 1;
512 ax = ABS(v1[ax]) > ABS(v1[2]) ? ax : 2;
513 /* assign equation matrix */
514 eqnmat[0][0] = p0->p[u]*p0->p[v];
515 eqnmat[0][1] = p0->p[u];
516 eqnmat[0][2] = p0->p[v];
517 eqnmat[0][3] = 1.0;
518 eqnmat[1][0] = p1->p[u]*p1->p[v];
519 eqnmat[1][1] = p1->p[u];
520 eqnmat[1][2] = p1->p[v];
521 eqnmat[1][3] = 1.0;
522 eqnmat[2][0] = p2->p[u]*p2->p[v];
523 eqnmat[2][1] = p2->p[u];
524 eqnmat[2][2] = p2->p[v];
525 eqnmat[2][3] = 1.0;
526 eqnmat[3][0] = p3->p[u]*p3->p[v];
527 eqnmat[3][1] = p3->p[u];
528 eqnmat[3][2] = p3->p[v];
529 eqnmat[3][3] = 1.0;
530 /* invert matrix (solve system) */
531 if (!invmat4(eqnmat, eqnmat))
532 return(-1); /* no solution */
533 /* compute result matrix */
534 for (j = 0; j < 4; j++)
535 for (i = 0; i < 3; i++)
536 resmat[j][i] = eqnmat[j][0]*p0->n[i] +
537 eqnmat[j][1]*p1->n[i] +
538 eqnmat[j][2]*p2->n[i] +
539 eqnmat[j][3]*p3->n[i];
540 return(ax);
541
542 #undef u
543 #undef v
544 }
545
546
547 void
548 eputs(msg)
549 char *msg;
550 {
551 fputs(msg, stderr);
552 }
553
554
555 void
556 wputs(msg)
557 char *msg;
558 {
559 eputs(msg);
560 }
561
562
563 void
564 quit(code)
565 int code;
566 {
567 exit(code);
568 }
569
570
571 printhead(ac, av) /* print command header */
572 register int ac;
573 register char **av;
574 {
575 putchar('#');
576 while (ac--) {
577 putchar(' ');
578 fputs(*av++, stdout);
579 }
580 putchar('\n');
581 }
582
583
584 double
585 l_hermite()
586 {
587 double t;
588
589 t = argument(5);
590 return( argument(1)*((2.0*t-3.0)*t*t+1.0) +
591 argument(2)*(-2.0*t+3.0)*t*t +
592 argument(3)*((t-2.0)*t+1.0)*t +
593 argument(4)*(t-1.0)*t*t );
594 }
595
596
597 double
598 l_bezier()
599 {
600 double t;
601
602 t = argument(5);
603 return( argument(1) * (1.+t*(-3.+t*(3.-t))) +
604 argument(2) * 3.*t*(1.+t*(-2.+t)) +
605 argument(3) * 3.*t*t*(1.-t) +
606 argument(4) * t*t*t );
607 }
608
609
610 double
611 l_bspline()
612 {
613 double t;
614
615 t = argument(5);
616 return( argument(1) * (1./6.+t*(-1./2.+t*(1./2.-1./6.*t))) +
617 argument(2) * (2./3.+t*t*(-1.+1./2.*t)) +
618 argument(3) * (1./6.+t*(1./2.+t*(1./2.-1./2.*t))) +
619 argument(4) * (1./6.*t*t*t) );
620 }
