root/radiance/ray/src/gen/gensurf.c
Revision: 2.33
Committed: Wed Apr 23 01:57:04 2025 UTC (2 months ago) by greg
Changes since 2.32: +3 -2 lines
fix: Functio prototypes and other fixes to reduce compiler warnings
2 static const char RCSid[] = "$Id: gensurf.c,v 2.32 2025/04/18 23:02:53 greg Exp $";
5 * gensurf.c - program to generate functional surfaces
6 *
7 * Parametric functions x(s,t), y(s,t) and z(s,t)
8 * specify the surface, which is tesselated into an m by n
9 * array of paired triangles.
10 * The surface normal is defined by the right hand
11 * rule applied to (s,t).
12 *
13 * 4/3/87
14 *
15 * 4/16/02 Added conditional vertex output
16 */
17
18 #include "standard.h"
19
20 #include "paths.h"
21 #include "resolu.h"
22 #include "rterror.h"
23 #include "calcomp.h"
24
25 char XNAME[] = "X`SYS"; /* x function name */
26 char YNAME[] = "Y`SYS"; /* y function name */
27 char ZNAME[] = "Z`SYS"; /* z function name */
28
29 char VNAME[] = "valid"; /* valid vertex name */
30
31 #define ABS(x) ((x)>=0 ? (x) : -(x))
32
33 #define ZEROVECT(v) (DOT(v,v) <= FTINY*FTINY)
34
35 #define pvect(p) printf(vformat, (p)[0], (p)[1], (p)[2])
36
37 char vformat[] = "%18.12g %18.12g %18.12g\n";
38 char tsargs[] = "4 surf_dx surf_dy surf_dz surf.cal";
39 char texname[] = "Phong";
40
41 int smooth = 0; /* apply smoothing? */
42 int objout = 0; /* output .OBJ format? */
43 int rev = 0; /* invert normal directions? */
44
45 char *modname, *surfname;
46
47 /* recorded data flags */
48 #define HASBORDER 01
49 #define TRIPLETS 02
50 /* a data structure */
51 struct {
52 int flags; /* data type */
53 short m, n; /* number of s and t values */
54 RREAL *data; /* the data itself, s major sort */
55 } datarec; /* our recorded data */
56
57 /* XXX this is redundant with rt/noise3.c, should go to a library */
58 double l_hermite(char *), l_bezier(char *),
59 l_bspline(char *), l_dataval(char *);
60
61 typedef struct {
62 int valid; /* point is valid (vertex number) */
63 int nvalid; /* normal is valid (normal number) */
64 FVECT p; /* vertex position */
65 FVECT n; /* average normal */
66 RREAL uv[2]; /* (u,v) position */
67 } POINT;
68
69 int nverts = 0; /* vertex output count */
70 int nnorms = 0; /* normal output count */
71
72 void loaddata(char *file, int m, int n, int pointsize);
73 double l_dataval(char *nam);
74 void putobjrow(POINT *rp, int n);
75 void putobjvert(POINT *p);
76 void putsquare(POINT *p0, POINT *p1, POINT *p2, POINT *p3);
77 void comprow(double s, POINT *row, int siz);
78 void compnorms(POINT *r0, POINT *r1, POINT *r2, int siz);
79 int norminterp(FVECT resmat[4], POINT *p0, POINT *p1, POINT *p2, POINT *p3);
80
81
82 int
83 main(int argc, char *argv[])
84 {
85 POINT *row0, *row1, *row2, *rp;
86 int i, j, m, n;
87 char stmp[256];
88
89 esupport |= E_VARIABLE|E_FUNCTION|E_RCONST;
90 esupport &= ~(E_OUTCHAN|E_INCHAN);
91 varset("PI", ':', PI);
92 funset("hermite", 5, ':', l_hermite);
93 funset("bezier", 5, ':', l_bezier);
94 funset("bspline", 5, ':', l_bspline);
95
96 if (argc < 8)
97 goto userror;
98
99 for (i = 8; i < argc; i++)
100 if (!strcmp(argv[i], "-e"))
101 scompile(argv[++i], NULL, 0);
102 else if (!strcmp(argv[i], "-f")) {
103 char *fpath = getpath(argv[++i], getrlibpath(), 0);
104 if (fpath == NULL) {
105 fprintf(stderr, "%s: cannot find file '%s'\n",
106 argv[0], argv[i]);
107 quit(1);
108 }
109 fcompile(fpath);
110 } else if (!strcmp(argv[i], "-s"))
111 smooth++;
112 else if (!strcmp(argv[i], "-o"))
113 objout++;
114 else if (!strcmp(argv[i], "-i"))
115 rev = 1;
116 else
117 goto userror;
118
119 modname = argv[1];
120 surfname = argv[2];
121 m = eval(argv[6]) + .5;
122 n = eval(argv[7]) + .5;
123 if (m <= 0 || n <= 0)
124 goto userror;
125 if (!strcmp(argv[5], "-") || access(argv[5], 4) == 0) { /* file? */
126 funset(ZNAME, 2, ':', l_dataval);
127 if (!strcmp(argv[5],argv[3]) && !strcmp(argv[5],argv[4])) {
128 loaddata(argv[5], m, n, 3);
129 funset(XNAME, 2, ':', l_dataval);
130 funset(YNAME, 2, ':', l_dataval);
131 } else {
132 loaddata(argv[5], m, n, 1);
133 sprintf(stmp, "%s(s,t)=%s;", XNAME, argv[3]);
134 scompile(stmp, NULL, 0);
135 sprintf(stmp, "%s(s,t)=%s;", YNAME, argv[4]);
136 scompile(stmp, NULL, 0);
137 }
138 } else {
139 sprintf(stmp, "%s(s,t)=%s;", XNAME, argv[3]);
140 scompile(stmp, NULL, 0);
141 sprintf(stmp, "%s(s,t)=%s;", YNAME, argv[4]);
142 scompile(stmp, NULL, 0);
143 sprintf(stmp, "%s(s,t)=%s;", ZNAME, argv[5]);
144 scompile(stmp, NULL, 0);
145 }
146 row0 = (POINT *)malloc((n+3)*sizeof(POINT));
147 row1 = (POINT *)malloc((n+3)*sizeof(POINT));
148 row2 = (POINT *)malloc((n+3)*sizeof(POINT));
149 if (row0 == NULL || row1 == NULL || row2 == NULL) {
150 fprintf(stderr, "%s: out of memory\n", argv[0]);
151 quit(1);
152 }
153 row0++; row1++; row2++;
154 /* print header */
155 fputs("# ", stdout);
156 printargs(argc, argv, stdout);
157 doptimize(1);
158 eclock++;
159 /* initialize */
160 comprow(-1.0/m, row0, n);
161 comprow(0.0, row1, n);
162 comprow(1.0/m, row2, n);
163 compnorms(row0, row1, row2, n);
164 if (objout) {
165 printf("\nusemtl %s\n\n", modname);
166 printf("o %s\n\n", surfname);
167 putobjrow(row1, n);
168 }
169 /* for each row */
170 for (i = 0; i < m; i++) {
171 /* compute next row */
172 rp = row0;
173 row0 = row1;
174 row1 = row2;
175 row2 = rp;
176 comprow((double)(i+2)/m, row2, n);
177 compnorms(row0, row1, row2, n);
178 if (objout)
179 putobjrow(row1, n);
180
181 for (j = 0; j < n; j++) {
182 int orient = (j & 1);
183 /* put polygons */
184 if (!(row0[j].valid && row1[j+1].valid))
185 orient = 1;
186 else if (!(row1[j].valid && row0[j+1].valid))
187 orient = 0;
188 if (orient)
189 putsquare(&row0[j], &row1[j],
190 &row0[j+1], &row1[j+1]);
191 else
192 putsquare(&row1[j], &row1[j+1],
193 &row0[j], &row0[j+1]);
194 }
195 }
196
197 return 0;
198
199 userror:
200 fprintf(stderr, "Usage: %s material name ", argv[0]);
201 fprintf(stderr, "x(s,t) y(s,t) z(s,t) m n [-s][-o][-e expr][-f file]\n");
202 return 1;
203 }
204
205
206 void
207 loaddata( /* load point data from file */
208 char *file,
209 int m,
210 int n,
211 int pointsize
212 )
213 {
214 FILE *fp;
215 char word[64];
216 int size;
217 RREAL *dp;
218
219 datarec.flags = HASBORDER; /* assume border values */
220 datarec.m = m+1;
221 datarec.n = n+1;
222 size = datarec.m*datarec.n*pointsize;
223 if (pointsize == 3)
224 datarec.flags |= TRIPLETS;
225 dp = (RREAL *)malloc(size*sizeof(RREAL));
226 if ((datarec.data = dp) == NULL) {
227 fputs("Out of memory\n", stderr);
228 exit(1);
229 }
230 if (!strcmp(file, "-")) {
231 file = "<stdin>";
232 fp = stdin;
233 } else if ((fp = fopen(file, "r")) == NULL) {
234 fputs(file, stderr);
235 fputs(": cannot open\n", stderr);
236 exit(1);
237 }
238 while (size > 0 && fgetword(word, sizeof(word), fp) != NULL) {
239 if (!isflt(word)) {
240 fprintf(stderr, "%s: garbled data value: %s\n",
241 file, word);
242 exit(1);
243 }
244 *dp++ = atof(word);
245 size--;
246 }
247 if (size == (m+n+1)*pointsize) { /* no border after all */
248 dp = (RREAL *)realloc(datarec.data,
249 m*n*pointsize*sizeof(RREAL));
250 if (dp != NULL)
251 datarec.data = dp;
252 datarec.flags &= ~HASBORDER;
253 datarec.m = m;
254 datarec.n = n;
255 size = 0;
256 }
257 if (datarec.m < 2 || datarec.n < 2 || size != 0 ||
258 fgetword(word, sizeof(word), fp) != NULL) {
259 fputs(file, stderr);
260 fputs(": bad number of data points\n", stderr);
261 exit(1);
262 }
263 fclose(fp);
264 }
265
266
267 double
268 l_dataval( /* return recorded data value */
269 char *nam
270 )
271 {
272 double u, v;
273 int i, j;
274 RREAL *dp;
275 double d00, d01, d10, d11;
276 /* compute coordinates */
277 u = argument(1); v = argument(2);
278 if (datarec.flags & HASBORDER) {
279 i = u *= datarec.m-1;
280 j = v *= datarec.n-1;
281 } else {
282 i = u = u*datarec.m - .5;
283 j = v = v*datarec.n - .5;
284 }
285 if (i < 0) i = 0;
286 else if (i > datarec.m-2) i = datarec.m-2;
287 if (j < 0) j = 0;
288 else if (j > datarec.n-2) j = datarec.n-2;
289 /* compute value */
290 if (datarec.flags & TRIPLETS) {
291 dp = datarec.data + 3*(j*datarec.m + i);
292 if (nam == ZNAME)
293 dp += 2;
294 else if (nam == YNAME)
295 dp++;
296 d00 = dp[0]; d01 = dp[3];
297 dp += 3*datarec.m;
298 d10 = dp[0]; d11 = dp[3];
299 } else {
300 dp = datarec.data + j*datarec.m + i;
301 d00 = dp[0]; d01 = dp[1];
302 dp += datarec.m;
303 d10 = dp[0]; d11 = dp[1];
304 }
305 /* bilinear interpolation */
306 return((j+1-v)*((i+1-u)*d00+(u-i)*d01)+(v-j)*((i+1-u)*d10+(u-i)*d11));
307 }
308
309
310 void
311 putobjrow( /* output vertex row to .OBJ */
312 POINT *rp,
313 int n
314 )
315 {
316 static FVECT prevNorm;
317
318 for ( ; n-- >= 0; rp++) {
319 if (!rp->valid)
320 continue;
321 fputs("v ", stdout);
322 pvect(rp->p);
323 rp->valid = ++nverts;
324 printf("\tvt %.9g %.9g\n", rp->uv[0], rp->uv[1]);
325 if (!smooth || ZEROVECT(rp->n))
326 rp->nvalid = 0;
327 else if (VABSEQ(rp->n, prevNorm))
328 rp->nvalid = nnorms;
329 else {
330 printf("\tvn %.9g %.9g %.9g\n",
331 rp->n[0], rp->n[1], rp->n[2]);
332 rp->nvalid = ++nnorms;
333 VCOPY(prevNorm, rp->n);
334 }
335 }
336 }
337
338
339 void
340 putobjvert( /* put out OBJ vertex index triplet */
341 POINT *p
342 )
343 {
344 int pti = p->valid ? p->valid-nverts-1 : 0;
345 int ni = p->nvalid ? p->nvalid-nnorms-1 : 0;
346
347 printf(" %d/%d/%d", pti, pti, ni);
348 }
349
350
351 void
352 putsquare( /* put out a square */
353 POINT *p0,
354 POINT *p1,
355 POINT *p2,
356 POINT *p3
357 )
358 {
359 static int nout = 0;
360 FVECT norm[4];
361 int axis;
362 FVECT v1, v2, vc1, vc2;
363 int ok1, ok2;
364
365 if (rev) { /* reverse normals? */
366 POINT *pt = p1; p1 = p2; p2 = pt;
367 }
368 /* compute exact normals */
369 ok1 = (p0->valid && p1->valid && p2->valid);
370 if (ok1) {
371 VSUB(v1, p1->p, p0->p);
372 VSUB(v2, p2->p, p0->p);
373 fcross(vc1, v1, v2);
374 ok1 = (normalize(vc1) != 0.0);
375 }
376 ok2 = (p1->valid && p2->valid && p3->valid);
377 if (ok2) {
378 VSUB(v1, p2->p, p3->p);
379 VSUB(v2, p1->p, p3->p);
380 fcross(vc2, v1, v2);
381 ok2 = (normalize(vc2) != 0.0);
382 }
383 if (!(ok1 | ok2))
384 return;
385 if (objout) { /* output .OBJ faces */
386 if (ok1 & ok2 && fdot(vc1,vc2) >= 1.0-FTINY*FTINY) {
387 putc('f', stdout);
388 putobjvert(p0); putobjvert(p1);
389 putobjvert(p3); putobjvert(p2);
390 putc('\n', stdout);
391 return;
392 }
393 if (ok1) {
394 putc('f', stdout);
395 putobjvert(p0); putobjvert(p1); putobjvert(p2);
396 putc('\n', stdout);
397 }
398 if (ok2) {
399 putc('f', stdout);
400 putobjvert(p2); putobjvert(p1); putobjvert(p3);
401 putc('\n', stdout);
402 }
403 return;
404 }
405 /* compute normal interpolation */
406 axis = norminterp(norm, p0, p1, p2, p3);
407
408 /* put out quadrilateral? */
409 if (ok1 & ok2 && fdot(vc1,vc2) >= 1.0-FTINY*FTINY) {
410 printf("\n%s ", modname);
411 if (axis != -1) {
412 printf("texfunc %s\n%s\n", texname, tsargs);
413 printf("0\n13\t%d\n", axis);
414 pvect(norm[0]);
415 pvect(norm[1]);
416 pvect(norm[2]);
417 fvsum(v1, norm[3], vc1, -0.5);
418 fvsum(v1, v1, vc2, -0.5);
419 pvect(v1);
420 printf("\n%s ", texname);
421 }
422 printf("polygon %s.%d\n", surfname, ++nout);
423 printf("0\n0\n12\n");
424 pvect(p0->p);
425 pvect(p1->p);
426 pvect(p3->p);
427 pvect(p2->p);
428 return;
429 }
430 /* put out triangles? */
431 if (ok1) {
432 printf("\n%s ", modname);
433 if (axis != -1) {
434 printf("texfunc %s\n%s\n", texname, tsargs);
435 printf("0\n13\t%d\n", axis);
436 pvect(norm[0]);
437 pvect(norm[1]);
438 pvect(norm[2]);
439 fvsum(v1, norm[3], vc1, -1.0);
440 pvect(v1);
441 printf("\n%s ", texname);
442 }
443 printf("polygon %s.%d\n", surfname, ++nout);
444 printf("0\n0\n9\n");
445 pvect(p0->p);
446 pvect(p1->p);
447 pvect(p2->p);
448 }
449 if (ok2) {
450 printf("\n%s ", modname);
451 if (axis != -1) {
452 printf("texfunc %s\n%s\n", texname, tsargs);
453 printf("0\n13\t%d\n", axis);
454 pvect(norm[0]);
455 pvect(norm[1]);
456 pvect(norm[2]);
457 fvsum(v2, norm[3], vc2, -1.0);
458 pvect(v2);
459 printf("\n%s ", texname);
460 }
461 printf("polygon %s.%d\n", surfname, ++nout);
462 printf("0\n0\n9\n");
463 pvect(p2->p);
464 pvect(p1->p);
465 pvect(p3->p);
466 }
467 }
468
469
470 void
471 comprow( /* compute row of values */
472 double s,
473 POINT *row,
474 int siz
475 )
476 {
477 double st[2];
478 int end;
479 int checkvalid;
480 int i;
481
482 if (smooth) {
483 i = -1; /* compute one past each end */
484 end = siz+1;
485 } else {
486 if (s < -FTINY || s > 1.0+FTINY)
487 return;
488 i = 0;
489 end = siz;
490 }
491 st[0] = s;
492 checkvalid = (fundefined(VNAME) == 2);
493 while (i <= end) {
494 st[1] = (double)i/siz;
495 if (checkvalid && funvalue(VNAME, 2, st) <= 0.0) {
496 row[i].valid = 0;
497 row[i].p[0] = row[i].p[1] = row[i].p[2] = 0.0;
498 row[i].uv[0] = row[i].uv[1] = 0.0;
499 } else {
500 row[i].valid = 1;
501 row[i].p[0] = funvalue(XNAME, 2, st);
502 row[i].p[1] = funvalue(YNAME, 2, st);
503 row[i].p[2] = funvalue(ZNAME, 2, st);
504 row[i].uv[0] = st[0];
505 row[i].uv[1] = st[1];
506 }
507 i++;
508 }
509 }
510
511
512 void
513 compnorms( /* compute row of averaged normals */
514 POINT *r0,
515 POINT *r1,
516 POINT *r2,
517 int siz
518 )
519 {
520 FVECT v1, v2;
521
522 if (!smooth) /* not needed if no smoothing */
523 return;
524 /* compute row 1 normals */
525 while (siz-- >= 0) {
526 if (!r1[0].valid)
527 goto skip;
528 if (!r0[0].valid) {
529 if (!r2[0].valid) {
530 r1[0].n[0] = r1[0].n[1] = r1[0].n[2] = 0.0;
531 goto skip;
532 }
533 fvsum(v1, r2[0].p, r1[0].p, -1.0);
534 } else if (!r2[0].valid)
535 fvsum(v1, r1[0].p, r0[0].p, -1.0);
536 else
537 fvsum(v1, r2[0].p, r0[0].p, -1.0);
538 if (!r1[-1].valid) {
539 if (!r1[1].valid) {
540 r1[0].n[0] = r1[0].n[1] = r1[0].n[2] = 0.0;
541 goto skip;
542 }
543 fvsum(v2, r1[1].p, r1[0].p, -1.0);
544 } else if (!r1[1].valid)
545 fvsum(v2, r1[0].p, r1[-1].p, -1.0);
546 else
547 fvsum(v2, r1[1].p, r1[-1].p, -1.0);
548 if (rev)
549 fcross(r1[0].n, v2, v1);
550 else
551 fcross(r1[0].n, v1, v2);
552 normalize(r1[0].n);
553 skip:
554 r0++; r1++; r2++;
555 }
556 }
557
558
559 int
560 norminterp( /* compute normal interpolation */
561 FVECT resmat[4],
562 POINT *p0,
563 POINT *p1,
564 POINT *p2,
565 POINT *p3
566 )
567 {
568 #define u ((ax+1)%3)
569 #define v ((ax+2)%3)
570
571 int ax;
572 MAT4 eqnmat;
573 FVECT v1;
574 int i, j;
575
576 if (!smooth) /* no interpolation if no smoothing */
577 return(-1);
578 /* find dominant axis */
579 VCOPY(v1, p0->n);
580 fvsum(v1, v1, p1->n, 1.0);
581 fvsum(v1, v1, p2->n, 1.0);
582 fvsum(v1, v1, p3->n, 1.0);
583 ax = ABS(v1[0]) > ABS(v1[1]) ? 0 : 1;
584 ax = ABS(v1[ax]) > ABS(v1[2]) ? ax : 2;
585 /* assign equation matrix */
586 eqnmat[0][0] = p0->p[u]*p0->p[v];
587 eqnmat[0][1] = p0->p[u];
588 eqnmat[0][2] = p0->p[v];
589 eqnmat[0][3] = 1.0;
590 eqnmat[1][0] = p1->p[u]*p1->p[v];
591 eqnmat[1][1] = p1->p[u];
592 eqnmat[1][2] = p1->p[v];
593 eqnmat[1][3] = 1.0;
594 eqnmat[2][0] = p2->p[u]*p2->p[v];
595 eqnmat[2][1] = p2->p[u];
596 eqnmat[2][2] = p2->p[v];
597 eqnmat[2][3] = 1.0;
598 eqnmat[3][0] = p3->p[u]*p3->p[v];
599 eqnmat[3][1] = p3->p[u];
600 eqnmat[3][2] = p3->p[v];
601 eqnmat[3][3] = 1.0;
602 /* invert matrix (solve system) */
603 if (!invmat4(eqnmat, eqnmat))
604 return(-1); /* no solution */
605 /* compute result matrix */
606 for (j = 0; j < 4; j++)
607 for (i = 0; i < 3; i++)
608 resmat[j][i] = eqnmat[j][0]*p0->n[i] +
609 eqnmat[j][1]*p1->n[i] +
610 eqnmat[j][2]*p2->n[i] +
611 eqnmat[j][3]*p3->n[i];
612 return(ax);
613
614 #undef u
615 #undef v
616 }
617
618
619 double
620 l_hermite(char *nm)
621 {
622 double t;
623
624 t = argument(5);
625 return( argument(1)*((2.0*t-3.0)*t*t+1.0) +
626 argument(2)*(-2.0*t+3.0)*t*t +
627 argument(3)*((t-2.0)*t+1.0)*t +
628 argument(4)*(t-1.0)*t*t );
629 }
630
631
632 double
633 l_bezier(char *nm)
634 {
635 double t;
636
637 t = argument(5);
638 return( argument(1) * (1.+t*(-3.+t*(3.-t))) +
639 argument(2) * 3.*t*(1.+t*(-2.+t)) +
640 argument(3) * 3.*t*t*(1.-t) +
641 argument(4) * t*t*t );
642 }
643
644
645 double
646 l_bspline(char *nm)
647 {
648 double t;
649
650 t = argument(5);
651 return( argument(1) * (1./6.+t*(-1./2.+t*(1./2.-1./6.*t))) +
652 argument(2) * (2./3.+t*t*(-1.+1./2.*t)) +
653 argument(3) * (1./6.+t*(1./2.+t*(1./2.-1./2.*t))) +
654 argument(4) * (1./6.*t*t*t) );
655 }
