--- ray/src/gen/genssky.c 2024/07/05 18:04:36 2.1 +++ ray/src/gen/genssky.c 2024/07/19 23:38:28 2.2 @@ -1,12 +1,23 @@ -// Main function for generating spectral sky -// Cloudy sky computed as weight average of clear and cie overcast sky +#ifndef lint +static const char RCSid[] = "$Id: genssky.c,v 2.2 2024/07/19 23:38:28 greg Exp $"; +#endif +/* Main function for generating spectral sky */ +/* Cloudy sky computed as weight average of clear and cie overcast sky */ -#include "copyright.h" #include "atmos.h" +#include "copyright.h" #include "resolu.h" +#include "rtio.h" #include "view.h" +#include +#ifdef _WIN32 +#include +#else +#include +#include +#include +#endif - char *progname; const double ARCTIC_LAT = 67.; @@ -17,12 +28,128 @@ const double GNORM = 0.777778; const double D65EFF = 203.; /* standard illuminant D65 */ -// Mean normalized relative daylight spectra where CCT = 6415K for overcast; +/* Mean normalized relative daylight spectra where CCT = 6415K for overcast; */ const double D6415[NSSAMP] = {0.63231, 1.06171, 1.00779, 1.36423, 1.34133, 1.27258, 1.26276, 1.26352, 1.22201, 1.13246, 1.0434, 1.05547, 0.98212, 0.94445, 0.9722, 0.82387, 0.87853, 0.82559, 0.75111, 0.78925}; +/* European and North American zones */ +struct { + char zname[8]; /* time zone name (all caps) */ + float zmer; /* standard meridian */ +} tzone[] = {{"YST", 135}, {"YDT", 120}, {"PST", 120}, {"PDT", 105}, + {"MST", 105}, {"MDT", 90}, {"CST", 90}, {"CDT", 75}, + {"EST", 75}, {"EDT", 60}, {"AST", 60}, {"ADT", 45}, + {"NST", 52.5}, {"NDT", 37.5}, {"GMT", 0}, {"BST", -15}, + {"CET", -15}, {"CEST", -30}, {"EET", -30}, {"EEST", -45}, + {"AST", -45}, {"ADT", -60}, {"GST", -60}, {"GDT", -75}, + {"IST", -82.5}, {"IDT", -97.5}, {"JST", -135}, {"NDT", -150}, + {"NZST", -180}, {"NZDT", -195}, {"", 0}}; + +static int make_directory(const char *path) { +#ifdef _WIN32 + if (CreateDirectory(path, NULL) || GetLastError() == ERROR_ALREADY_EXISTS) { + return 1; + } + return 0; +#else + if (mkdir(path, 0777) == 0 || errno == EEXIST) { + return 1; + } + return 0; +#endif +} + +static int cvthour(char *hs, int *tsolar, double *hour) { + char *cp = hs; + int i, j; + + if ((*tsolar = *cp == '+')) + cp++; /* solar time? */ + while (isdigit(*cp)) + cp++; + if (*cp == ':') + *hour = atoi(hs) + atoi(++cp) / 60.0; + else { + *hour = atof(hs); + if (*cp == '.') + cp++; + } + while (isdigit(*cp)) + cp++; + if (!*cp) + return (0); + if (*tsolar || !isalpha(*cp)) { + fprintf(stderr, "%s: bad time format: %s\n", progname, hs); + exit(1); + } + i = 0; + do { + for (j = 0; cp[j]; j++) + if (toupper(cp[j]) != tzone[i].zname[j]) + break; + if (!cp[j] && !tzone[i].zname[j]) { + s_meridian = tzone[i].zmer * (PI / 180); + return (1); + } + } while (tzone[i++].zname[0]); + + fprintf(stderr, "%s: unknown time zone: %s\n", progname, cp); + fprintf(stderr, "Known time zones:\n\t%s", tzone[0].zname); + for (i = 1; tzone[i].zname[0]; i++) + fprintf(stderr, " %s", tzone[i].zname); + putc('\n', stderr); + exit(1); +} + +static void basename(const char *path, char *output, size_t outsize) { + const char *last_slash = strrchr(path, '/'); + const char *last_backslash = strrchr(path, '\\'); + const char *filename = path; + const char *last_dot; + + if (last_slash && last_backslash) { + filename = + (last_slash > last_backslash) ? last_slash + 1 : last_backslash + 1; + } else if (last_slash) { + filename = last_slash + 1; + } else if (last_backslash) { + filename = last_backslash + 1; + } + + last_dot = strrchr(filename, '.'); + if (last_dot) { + size_t length = last_dot - filename; + if (length < outsize) { + strncpy(output, filename, length); + output[length] = '\0'; + } else { + strncpy(output, filename, outsize - 1); + output[outsize - 1] = '\0'; + } + } +} + +char *join_paths(const char *path1, const char *path2) { + size_t len1 = strlen(path1); + size_t len2 = strlen(path2); + int need_separator = (path1[len1 - 1] != DIRSEP); + + char *result = malloc(len1 + len2 + (need_separator ? 2 : 1)); + if (!result) + return NULL; + + strcpy(result, path1); + if (need_separator) { + result[len1] = DIRSEP; + len1++; + } + strcpy(result + len1, path2); + + return result; +} + static inline double wmean2(const double a, const double b, const double x) { return a * (1 - x) + b * x; } @@ -42,43 +169,57 @@ static double get_zenith_brightness(const double sundi return zenithbr; } -// from gensky.c +/* from gensky.c */ static double get_overcast_brightness(const double dz, const double zenithbr) { double groundbr = zenithbr * GNORM; return wmean(pow(dz + 1.01, 10), zenithbr * (1 + 2 * dz) / 3, pow(dz + 1.01, -10), groundbr); } -static void write_rad_file(FILE *fp, const double *sun_radiance, - const FVECT sundir, const char skyfile[PATH_MAX], - const char grndfile[PATH_MAX]) { +static void write_header(const int argc, char **argv, const double cloud_cover, + const double grefl, const int res) { + printf("# "); + for (int i = 0; i < argc; i++) { + printf("%s ", argv[i]); + } + printf("\n"); + printf("#Cloud cover: %g\n#Ground reflectance: %g\n#Sky map resolution: %d\n\n", + cloud_cover, grefl, res); +} + +static void write_rad(const double *sun_radiance, const FVECT sundir, + const char skyfile[PATH_MAX], + const char grndfile[PATH_MAX]) { if (sundir[2] > 0) { - fprintf(fp, "void spectrum sunrad\n0\n0\n22 380 780 "); + printf("void spectrum sunrad\n0\n0\n22 380 780 "); + /* Normalize to one */ + double sum = 0.0; for (int i = 0; i < NSSAMP; ++i) { - fprintf(fp, "%.1f ", sun_radiance[i] * WVLSPAN); + sum += sun_radiance[i]; } - fprintf(fp, "\n\nsunrad light solar\n0\n0\n3 1 1 1\n\n"); - fprintf(fp, "solar source sun\n0\n0\n4 %f %f %f 0.533\n\n", sundir[0], - sundir[1], sundir[2]); + double mean = sum / NSSAMP; + for (int i = 0; i < NSSAMP; ++i) { + printf("%.3f ", sun_radiance[i] / mean); + } + double intensity = mean * WVLSPAN; + printf("\n\nsunrad light solar\n0\n0\n3 %.1f %.1f %.1f\n\n", intensity, + intensity, intensity); + printf("solar source sun\n0\n0\n4 %f %f %f 0.533\n\n", sundir[0], sundir[1], + sundir[2]); } - fprintf(fp, - "void specpict skyfunc\n8 noop %s fisheye.cal fish_u fish_v -rx 90 " - "-mx\n0\n0\n\n", - skyfile); - fprintf(fp, "skyfunc glow sky_glow\n0\n0\n4 1 1 1 0\n\n"); - fprintf(fp, "sky_glow source sky\n0\n0\n4 0 0 1 180\n\n"); + printf("void specpict skymap\n8 noop %s fisheye.cal fish_u fish_v -rx 90 " + "-mx\n0\n0\n\n", + skyfile); - fprintf(fp, - "void specpict grndmap\n8 noop %s fisheye.cal fish_u fish_v -rx -90 " - "-my\n0\n0\n\n", - grndfile); - fprintf(fp, "grndmap glow ground_glow\n0\n0\n4 1 1 1 0\n\n"); - fprintf(fp, "ground_glow source ground_source\n0\n0\n4 0 0 -1 180\n\n"); + printf("void specpict grndmap\n8 noop %s fisheye.cal fish_u fish_v -rx -90 " + "-my\n0\n0\n\n", + grndfile); + printf("void mixfunc skyfunc\n4 skymap grndmap if(Dz,1,0) .\n0\n0\n"); } static void write_hsr_header(FILE *fp, RESOLU *res) { float wvsplit[4] = {380, 480, 588, - 780}; // RGB wavelength limits+partitions (nm) + 780}; /* RGB wavelength limits+partitions (nm) */ newheader("RADIANCE", fp); fputncomp(NSSAMP, fp); fputwlsplit(wvsplit, fp); @@ -91,14 +232,8 @@ int gen_spect_sky(DATARRAY *tau_clear, DATARRAY *scat_ DATARRAY *scat1m_clear, DATARRAY *irrad_clear, const double cloud_cover, const FVECT sundir, const double grefl, const int res, const char *outname) { - - char radfile[PATH_MAX]; char skyfile[PATH_MAX]; char grndfile[PATH_MAX]; - if (!snprintf(radfile, sizeof(radfile), "%s.rad", outname)) { - fprintf(stderr, "Error setting rad file name\n"); - return 0; - }; if (!snprintf(skyfile, sizeof(skyfile), "%s_sky.hsr", outname)) { fprintf(stderr, "Error setting sky file name\n"); return 0; @@ -180,7 +315,7 @@ int gen_spect_sky(DATARRAY *tau_clear, DATARRAY *scat_ fclose(skyfp); fclose(grndfp); - // Get solar radiance + /* Get solar radiance */ double sun_radiance[NSSAMP] = {0}; get_solar_radiance(tau_clear, scat_clear, scat1m_clear, sundir, radius, sun_ct, sun_radiance); @@ -193,27 +328,31 @@ int gen_spect_sky(DATARRAY *tau_clear, DATARRAY *scat_ } } - FILE *rfp = fopen(radfile, "w"); - write_rad_file(rfp, sun_radiance, sundir, skyfile, grndfile); - fclose(rfp); + write_rad(sun_radiance, sundir, skyfile, grndfile); return 1; } -static DpPaths get_dppaths(const double aod, const char *tag) { +static DpPaths get_dppaths(const char *dir, const double aod, const char *mname, + const char *tag) { DpPaths paths; - snprintf(paths.tau, PATH_MAX, "tau_%s_%.2f.dat", tag, aod); - snprintf(paths.scat, PATH_MAX, "scat_%s_%.2f.dat", tag, aod); - snprintf(paths.scat1m, PATH_MAX, "scat1m_%s_%.2f.dat", tag, aod); - snprintf(paths.irrad, PATH_MAX, "irrad_%s_%.2f.dat", tag, aod); + snprintf(paths.tau, PATH_MAX, "%s%ctau_%s_%s_%.2f.dat", dir, DIRSEP, tag, + mname, aod); + snprintf(paths.scat, PATH_MAX, "%s%cscat_%s_%s_%.2f.dat", dir, DIRSEP, tag, + mname, aod); + snprintf(paths.scat1m, PATH_MAX, "%s%cscat1m_%s_%s_%.2f.dat", dir, DIRSEP, + tag, mname, aod); + snprintf(paths.irrad, PATH_MAX, "%s%cirrad_%s_%s_%.2f.dat", dir, DIRSEP, tag, + mname, aod); return paths; } -static void set_rayleigh_density_profile(Atmosphere *atmos, char *tag, const int is_summer, +static void set_rayleigh_density_profile(Atmosphere *atmos, char *tag, + const int is_summer, const double s_latitude) { - // Set rayleigh density profile - if (fabs(s_latitude*180.0 / PI) > ARCTIC_LAT) { + /* Set rayleigh density profile */ + if (fabs(s_latitude * 180.0 / PI) > ARCTIC_LAT) { tag[0] = 's'; if (is_summer) { tag[1] = 's'; @@ -224,7 +363,7 @@ static void set_rayleigh_density_profile(Atmosphere *a atmos->rayleigh_density.layers[0].exp_scale = -1.0 / HR_SW; atmos->beta_r0 = BR0_SW; } - } else if (fabs(s_latitude*180.0/PI) > TROPIC_LAT) { + } else if (fabs(s_latitude * 180.0 / PI) > TROPIC_LAT) { tag[0] = 'm'; if (is_summer) { tag[1] = 's'; @@ -245,33 +384,31 @@ static void set_rayleigh_density_profile(Atmosphere *a } static Atmosphere init_atmos(const double aod, const double grefl) { - Atmosphere atmos = { - .ozone_density = {.layers = - { - {.width = 25000.0, - .exp_term = 0.0, - .exp_scale = 0.0, - .linear_term = 1.0 / 15000.0, - .constant_term = -2.0 / 3.0}, - {.width = AH, - .exp_term = 0.0, - .exp_scale = 0.0, - .linear_term = -1.0 / 15000.0, - .constant_term = 8.0 / 3.0}, - }}, - .rayleigh_density = {.layers = - { - {.width = AH, - .exp_term = 1.0, - .exp_scale = -1.0 / HR_MS, - .linear_term = 0.0, - .constant_term = 0.0}, - }}, - .beta_r0 = BR0_MS, - .beta_scale = aod / AOD0_CA, - .beta_m = NULL, - .grefl = grefl - }; + Atmosphere atmos = {.ozone_density = {.layers = + { + {.width = 25000.0, + .exp_term = 0.0, + .exp_scale = 0.0, + .linear_term = 1.0 / 15000.0, + .constant_term = -2.0 / 3.0}, + {.width = AH, + .exp_term = 0.0, + .exp_scale = 0.0, + .linear_term = -1.0 / 15000.0, + .constant_term = 8.0 / 3.0}, + }}, + .rayleigh_density = {.layers = + { + {.width = AH, + .exp_term = 1.0, + .exp_scale = -1.0 / HR_MS, + .linear_term = 0.0, + .constant_term = 0.0}, + }}, + .beta_r0 = BR0_MS, + .beta_scale = aod / AOD0_CA, + .beta_m = NULL, + .grefl = grefl}; return atmos; } @@ -284,23 +421,47 @@ int main(int argc, char *argv[]) { int sorder = 4; int year = 0; int tsolar = 0; + int got_meridian = 0; double grefl = 0.2; double ccover = 0.0; int res = 128; double aod = AOD0_CA; char *outname = "out"; char *mie_path = getpath("mie_ca.dat", getrlibpath(), R_OK); + char mie_name[20] = "mie_ca"; char lstag[3]; + char *ddir = "."; + if (!strcmp(argv[1], "-defaults")) { + printf("-i %d\t\t\t\t#scattering order\n", sorder); + printf("-g %f\t\t\t#ground reflectance\n", grefl); + printf("-c %f\t\t\t#cloud cover\n", ccover); + printf("-r %d\t\t\t\t#image resolution\n", res); + printf("-d %f\t\t\t#broadband aerosol optical depth\n", AOD0_CA); + printf("-f %s\t\t\t\t#output name (-f)\n", outname); + printf("-p %s\t\t\t\t#atmos data directory\n", ddir); + exit(1); + } + if (argc < 4) { - fprintf(stderr, "Usage: %s month day hour -y year -a lat -o lon -m tz -d aod -r res -n nproc -c ccover -l mie -g grefl -f outpath\n", + fprintf(stderr, + "Usage: %s month day hour -y year -a lat -o lon -m tz -d aod -r " + "res -n nproc -c ccover -l mie -g grefl -f outpath\n", argv[0]); return 0; } month = atoi(argv[1]); + if (month < 1 || month > 12) { + fprintf(stderr, "bad month"); + exit(1); + } day = atoi(argv[2]); - hour = atof(argv[3]); + if (day < 1 || day > 31) { + fprintf(stderr, "bad month"); + exit(1); + } + got_meridian = cvthour(argv[3], &tsolar, &hour); if (!compute_sundir(year, month, day, hour, tsolar, sundir)) { fprintf(stderr, "Cannot compute solar angle\n"); @@ -313,45 +474,60 @@ int main(int argc, char *argv[]) { case 'a': s_latitude = atof(argv[++i]) * (PI / 180.0); break; - case 'g': - grefl = atof(argv[++i]); - break; case 'c': ccover = atof(argv[++i]); break; case 'd': aod = atof(argv[++i]); break; + case 'f': + outname = argv[++i]; + break; + case 'g': + grefl = atof(argv[++i]); + break; case 'i': sorder = atoi(argv[++i]); break; case 'l': mie_path = argv[++i]; + basename(mie_path, mie_name, sizeof(mie_name)); break; case 'm': + if (got_meridian) { + ++i; + break; + } s_meridian = atof(argv[++i]) * (PI / 180.0); break; - case 'o': - s_longitude = atof(argv[++i]) * (PI / 180.0); - break; case 'n': num_threads = atoi(argv[++i]); break; - case 'y': - year = atoi(argv[++i]); + case 'o': + s_longitude = atof(argv[++i]) * (PI / 180.0); break; - case 'f': - outname = argv[++i]; + case 'p': + ddir = argv[++i]; break; case 'r': res = atoi(argv[++i]); break; + case 'y': + year = atoi(argv[++i]); + break; default: fprintf(stderr, "Unknown option %s\n", argv[i]); exit(1); } } } + if (year && (year < 1950) | (year > 2050)) + fprintf(stderr, "%s: warning - year should be in range 1950-2050\n", + progname); + if (month && !tsolar && fabs(s_meridian - s_longitude) > 45 * PI / 180) + fprintf(stderr, + "%s: warning - %.1f hours btwn. standard meridian and longitude\n", + progname, (s_longitude - s_meridian) * 12 / PI); Atmosphere clear_atmos = init_atmos(aod, grefl); @@ -361,7 +537,7 @@ int main(int argc, char *argv[]) { } set_rayleigh_density_profile(&clear_atmos, lstag, is_summer, s_latitude); - // Load mie density data + /* Load mie density data */ DATARRAY *mie_dp = getdata(mie_path); if (mie_dp == NULL) { fprintf(stderr, "Error reading mie data\n"); @@ -369,15 +545,25 @@ int main(int argc, char *argv[]) { } clear_atmos.beta_m = mie_dp; - DpPaths clear_paths = get_dppaths(aod, lstag); + char gsdir[PATH_MAX]; + size_t siz = strlen(ddir); + if (ISDIRSEP(ddir[siz-1])) + ddir[siz-1] = '\0'; + snprintf(gsdir, PATH_MAX, "%s%catmos_data", ddir, DIRSEP); + printf("gsdir: %s\n", gsdir); + if (!make_directory(gsdir)) { + fprintf(stderr, "Failed creating atmos_data directory"); + exit(1); + } + DpPaths clear_paths = get_dppaths(gsdir, aod, mie_name, lstag); if (getpath(clear_paths.tau, ".", R_OK) == NULL || getpath(clear_paths.scat, ".", R_OK) == NULL || getpath(clear_paths.scat1m, ".", R_OK) == NULL || getpath(clear_paths.irrad, ".", R_OK) == NULL) { - printf("# Precomputing...\n"); + printf("# Pre-computing...\n"); if (!precompute(sorder, clear_paths, &clear_atmos, num_threads)) { - fprintf(stderr, "Precompute failed\n"); + fprintf(stderr, "Pre-compute failed\n"); return 0; } } @@ -386,6 +572,8 @@ int main(int argc, char *argv[]) { DATARRAY *irrad_clear_dp = getdata(clear_paths.irrad); DATARRAY *scat_clear_dp = getdata(clear_paths.scat); DATARRAY *scat1m_clear_dp = getdata(clear_paths.scat1m); + + write_header(argc, argv, ccover, grefl, res); if (!gen_spect_sky(tau_clear_dp, scat_clear_dp, scat1m_clear_dp, irrad_clear_dp, ccover, sundir, grefl, res, outname)) {
