--- ray/src/gen/gensky.c 1992/03/10 11:12:06 2.3 +++ ray/src/gen/gensky.c 1992/10/02 16:11:53 2.7 @@ -36,10 +36,11 @@ extern double s_longitude; extern double s_meridian; /* required values */ int month, day; /* date */ -double hour; /* standard time */ +double hour; /* time */ +int tsolar; /* 0=standard, 1=solar */ double altitude, azimuth; /* or solar angles */ /* default values */ -int cloudy = 0; +int cloudy = 0; /* 1=standard, 2=uniform */ int dosun = 1; double zenithbr = -1.0; double turbidity = 2.75; @@ -58,7 +59,6 @@ main(argc, argv) int argc; char *argv[]; { - extern double fabs(); int i; progname = argv[0]; @@ -74,8 +74,15 @@ char *argv[]; month = 0; } else { month = atoi(argv[1]); + if (month < 1 || month > 12) + userror("bad month"); day = atoi(argv[2]); + if (day < 1 || day > 31) + userror("bad day"); hour = atof(argv[3]); + if (hour < 0 || hour >= 24) + userror("bad hour"); + tsolar = argv[3][0] == '+'; } for (i = 4; i < argc; i++) if (argv[i][0] == '-' || argv[i][0] == '+') @@ -85,7 +92,7 @@ char *argv[]; dosun = argv[i][0] == '+'; break; case 'c': - cloudy = 1; + cloudy = argv[i][0] == '+' ? 2 : 1; dosun = 0; break; case 't': @@ -134,7 +141,10 @@ computesky() /* compute sky parameters */ jd = jdate(month, day); /* Julian date */ sd = sdec(jd); /* solar declination */ - st = hour + stadj(jd); /* solar time */ + if (tsolar) /* solar time */ + st = hour; + else + st = hour + stadj(jd); altitude = salt(sd, st); azimuth = sazi(sd, st); } @@ -146,7 +156,7 @@ computesky() /* compute sky parameters */ if (zenithbr <= 0.0) if (cloudy) { zenithbr = 8.6*sundir[2] + .123; - zenithbr *= 1000.0/SKYEFFICACY; + zenithbr *= 1000.0/WHTEFFICACY; } else { zenithbr = (1.376*turbidity-1.81)*tan(altitude)+0.38; zenithbr *= 1000.0/SKYEFFICACY; @@ -155,12 +165,15 @@ computesky() /* compute sky parameters */ zenithbr = 0.0; /* Compute horizontal radiance */ if (cloudy) { - groundbr = zenithbr*0.777778; + if (cloudy == 2) + groundbr = zenithbr; + else + groundbr = zenithbr*0.777778; printf("# Ground ambient level: %f\n", groundbr); } else { F2 = 0.274*(0.91 + 10.0*exp(-3.0*(PI/2.0-altitude)) + 0.45*sundir[2]*sundir[2]); - groundbr = zenithbr*normsc(PI/2.0-altitude)/F2/PI; + groundbr = zenithbr*normsc(altitude)/F2/PI; printf("# Ground ambient level: %f\n", groundbr); if (sundir[2] > 0.0) { if (sundir[2] > .16) @@ -191,7 +204,7 @@ printsky() /* print out sky */ printf("2 skybright skybright.cal\n"); printf("0\n"); if (cloudy) - printf("3 1 %.2e %.2e\n", zenithbr, groundbr); + printf("3 %d %.2e %.2e\n", cloudy, zenithbr, groundbr); else printf("7 -1 %.2e %.2e %.2e %f %f %f\n", zenithbr, groundbr, F2, sundir[0], sundir[1], sundir[2]); @@ -200,8 +213,10 @@ printsky() /* print out sky */ printdefaults() /* print default values */ { - if (cloudy) + if (cloudy == 1) printf("-c\t\t\t\t# Cloudy sky\n"); + else if (cloudy == 2) + printf("+c\t\t\t\t# Uniform cloudy sky\n"); else if (dosun) printf("+s\t\t\t\t# Sunny sky with sun\n"); else
