--- ray/src/gen/gensky.c 1992/03/10 11:12:06 2.3 +++ ray/src/gen/gensky.c 1992/03/20 15:29:10 2.5 @@ -36,10 +36,11 @@ extern double s_longitude; extern double s_meridian; /* required values */ int month, day; /* date */ -double hour; /* standard time */ +double hour; /* time */ +int tsolar; /* 0=standard, 1=solar */ double altitude, azimuth; /* or solar angles */ /* default values */ -int cloudy = 0; +int cloudy = 0; /* 1=standard, 2=uniform */ int dosun = 1; double zenithbr = -1.0; double turbidity = 2.75; @@ -76,6 +77,7 @@ char *argv[]; month = atoi(argv[1]); day = atoi(argv[2]); hour = atof(argv[3]); + tsolar = argv[3][0] == '+'; } for (i = 4; i < argc; i++) if (argv[i][0] == '-' || argv[i][0] == '+') @@ -85,7 +87,7 @@ char *argv[]; dosun = argv[i][0] == '+'; break; case 'c': - cloudy = 1; + cloudy = argv[i][0] == '+' ? 2 : 1; dosun = 0; break; case 't': @@ -134,7 +136,10 @@ computesky() /* compute sky parameters */ jd = jdate(month, day); /* Julian date */ sd = sdec(jd); /* solar declination */ - st = hour + stadj(jd); /* solar time */ + if (tsolar) /* solar time */ + st = hour; + else + st = hour + stadj(jd); altitude = salt(sd, st); azimuth = sazi(sd, st); } @@ -155,7 +160,10 @@ computesky() /* compute sky parameters */ zenithbr = 0.0; /* Compute horizontal radiance */ if (cloudy) { - groundbr = zenithbr*0.777778; + if (cloudy == 2) + groundbr = zenithbr; + else + groundbr = zenithbr*0.777778; printf("# Ground ambient level: %f\n", groundbr); } else { F2 = 0.274*(0.91 + 10.0*exp(-3.0*(PI/2.0-altitude)) + @@ -191,7 +199,7 @@ printsky() /* print out sky */ printf("2 skybright skybright.cal\n"); printf("0\n"); if (cloudy) - printf("3 1 %.2e %.2e\n", zenithbr, groundbr); + printf("3 %d %.2e %.2e\n", cloudy, zenithbr, groundbr); else printf("7 -1 %.2e %.2e %.2e %f %f %f\n", zenithbr, groundbr, F2, sundir[0], sundir[1], sundir[2]); @@ -200,8 +208,10 @@ printsky() /* print out sky */ printdefaults() /* print default values */ { - if (cloudy) + if (cloudy == 1) printf("-c\t\t\t\t# Cloudy sky\n"); + else if (cloudy == 2) + printf("+c\t\t\t\t# Uniform cloudy sky\n"); else if (dosun) printf("+s\t\t\t\t# Sunny sky with sun\n"); else
