--- ray/src/gen/gensky.c 2003/11/16 10:29:38 2.22 +++ ray/src/gen/gensky.c 2004/09/10 18:19:24 2.23 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: gensky.c,v 2.22 2003/11/16 10:29:38 schorsch Exp $"; +static const char RCSid[] = "$Id: gensky.c,v 2.23 2004/09/10 18:19:24 greg Exp $"; #endif /* * gensky.c - program to generate sky functions. @@ -95,7 +95,7 @@ void printsky(void); void printdefaults(void); void userror(char *msg); double normsc(void); -void cvthour(char *hs); +int cvthour(char *hs); void printhead(register int ac, register char **av); @@ -104,6 +104,7 @@ main(argc, argv) int argc; char *argv[]; { + int got_meridian = 0; int i; progname = argv[0]; @@ -124,7 +125,7 @@ char *argv[]; day = atoi(argv[2]); if (day < 1 || day > 31) userror("bad day"); - cvthour(argv[3]); + got_meridian = cvthour(argv[3]); } for (i = 4; i < argc; i++) if (argv[i][0] == '-' || argv[i][0] == '+') @@ -166,6 +167,10 @@ char *argv[]; s_longitude = atof(argv[++i]) * (PI/180); break; case 'm': + if (got_meridian) { + ++i; + break; /* time overrides */ + } s_meridian = atof(argv[++i]) * (PI/180); break; default: @@ -370,7 +375,7 @@ normsc(void) /* compute normalization factor (E0*F2/ } -void +int cvthour( /* convert hour string */ char *hs ) @@ -388,7 +393,7 @@ cvthour( /* convert hour string */ } while (isdigit(*cp)) cp++; if (!*cp) - return; + return(0); if (tsolar || !isalpha(*cp)) { fprintf(stderr, "%s: bad time format: %s\n", progname, hs); exit(1); @@ -400,7 +405,7 @@ cvthour( /* convert hour string */ break; if (!cp[j] && !tzone[i].zname[j]) { s_meridian = tzone[i].zmer * (PI/180); - return; + return(1); } } while (tzone[i++].zname[0]);
