--- ray/src/gen/gensky.c 1991/12/19 15:09:28 2.2 +++ ray/src/gen/gensky.c 1992/03/10 11:12:06 2.3 @@ -35,8 +35,9 @@ extern double s_latitude; extern double s_longitude; extern double s_meridian; /* required values */ -int month, day; -double hour; +int month, day; /* date */ +double hour; /* standard time */ +double altitude, azimuth; /* or solar angles */ /* default values */ int cloudy = 0; int dosun = 1; @@ -67,9 +68,15 @@ char *argv[]; } if (argc < 4) userror("arg count"); - month = atoi(argv[1]); - day = atoi(argv[2]); - hour = atof(argv[3]); + if (!strcmp(argv[1], "-ang")) { + altitude = atof(argv[2]) * (PI/180); + azimuth = atof(argv[3]) * (PI/180); + month = 0; + } else { + month = atoi(argv[1]); + day = atoi(argv[2]); + hour = atof(argv[3]); + } for (i = 4; i < argc; i++) if (argv[i][0] == '-' || argv[i][0] == '+') switch (argv[i][1]) { @@ -120,15 +127,17 @@ char *argv[]; computesky() /* compute sky parameters */ { - int jd; - double sd, st; - double altitude, azimuth; /* compute solar direction */ - jd = jdate(month, day); /* Julian date */ - sd = sdec(jd); /* solar declination */ - st = hour + stadj(jd); /* solar time */ - altitude = salt(sd, st); - azimuth = sazi(sd, st); + if (month) { /* from date and time */ + int jd; + double sd, st; + + jd = jdate(month, day); /* Julian date */ + sd = sdec(jd); /* solar declination */ + st = hour + stadj(jd); /* solar time */ + altitude = salt(sd, st); + azimuth = sazi(sd, st); + } sundir[0] = -sin(azimuth)*cos(altitude); sundir[1] = -cos(azimuth)*cos(altitude); sundir[2] = sin(altitude); @@ -214,6 +223,7 @@ char *msg; if (msg != NULL) fprintf(stderr, "%s: Use error - %s\n", progname, msg); fprintf(stderr, "Usage: %s month day hour [options]\n", progname); + fprintf(stderr, " Or: %s -ang altitude azimuth [options]\n", progname); fprintf(stderr, " Or: %s -defaults\n", progname); exit(1); }
