--- ray/src/gen/gensky.c 1991/11/12 17:05:02 2.1 +++ ray/src/gen/gensky.c 1992/03/20 15:29:10 2.5 @@ -19,6 +19,9 @@ static char SCCSid[] = "$SunId$ LBL"; #include "color.h" +#ifndef atof +extern double atof(); +#endif extern char *strcpy(), *strcat(), *malloc(); extern double stadj(), sdec(), sazi(), salt(); @@ -32,10 +35,12 @@ extern double s_latitude; extern double s_longitude; extern double s_meridian; /* required values */ -int month, day; -double hour; +int month, day; /* date */ +double hour; /* time */ +int tsolar; /* 0=standard, 1=solar */ +double altitude, azimuth; /* or solar angles */ /* default values */ -int cloudy = 0; +int cloudy = 0; /* 1=standard, 2=uniform */ int dosun = 1; double zenithbr = -1.0; double turbidity = 2.75; @@ -54,7 +59,7 @@ main(argc, argv) int argc; char *argv[]; { - extern double atof(), fabs(); + extern double fabs(); int i; progname = argv[0]; @@ -64,9 +69,16 @@ char *argv[]; } if (argc < 4) userror("arg count"); - month = atoi(argv[1]); - day = atoi(argv[2]); - hour = atof(argv[3]); + if (!strcmp(argv[1], "-ang")) { + altitude = atof(argv[2]) * (PI/180); + azimuth = atof(argv[3]) * (PI/180); + month = 0; + } else { + month = atoi(argv[1]); + day = atoi(argv[2]); + hour = atof(argv[3]); + tsolar = argv[3][0] == '+'; + } for (i = 4; i < argc; i++) if (argv[i][0] == '-' || argv[i][0] == '+') switch (argv[i][1]) { @@ -75,7 +87,7 @@ char *argv[]; dosun = argv[i][0] == '+'; break; case 'c': - cloudy = 1; + cloudy = argv[i][0] == '+' ? 2 : 1; dosun = 0; break; case 't': @@ -117,15 +129,20 @@ char *argv[]; computesky() /* compute sky parameters */ { - int jd; - double sd, st; - double altitude, azimuth; /* compute solar direction */ - jd = jdate(month, day); /* Julian date */ - sd = sdec(jd); /* solar declination */ - st = hour + stadj(jd); /* solar time */ - altitude = salt(sd, st); - azimuth = sazi(sd, st); + if (month) { /* from date and time */ + int jd; + double sd, st; + + jd = jdate(month, day); /* Julian date */ + sd = sdec(jd); /* solar declination */ + if (tsolar) /* solar time */ + st = hour; + else + st = hour + stadj(jd); + altitude = salt(sd, st); + azimuth = sazi(sd, st); + } sundir[0] = -sin(azimuth)*cos(altitude); sundir[1] = -cos(azimuth)*cos(altitude); sundir[2] = sin(altitude); @@ -143,7 +160,10 @@ computesky() /* compute sky parameters */ zenithbr = 0.0; /* Compute horizontal radiance */ if (cloudy) { - groundbr = zenithbr*0.777778; + if (cloudy == 2) + groundbr = zenithbr; + else + groundbr = zenithbr*0.777778; printf("# Ground ambient level: %f\n", groundbr); } else { F2 = 0.274*(0.91 + 10.0*exp(-3.0*(PI/2.0-altitude)) + @@ -179,7 +199,7 @@ printsky() /* print out sky */ printf("2 skybright skybright.cal\n"); printf("0\n"); if (cloudy) - printf("3 1 %.2e %.2e\n", zenithbr, groundbr); + printf("3 %d %.2e %.2e\n", cloudy, zenithbr, groundbr); else printf("7 -1 %.2e %.2e %.2e %f %f %f\n", zenithbr, groundbr, F2, sundir[0], sundir[1], sundir[2]); @@ -188,8 +208,10 @@ printsky() /* print out sky */ printdefaults() /* print default values */ { - if (cloudy) + if (cloudy == 1) printf("-c\t\t\t\t# Cloudy sky\n"); + else if (cloudy == 2) + printf("+c\t\t\t\t# Uniform cloudy sky\n"); else if (dosun) printf("+s\t\t\t\t# Sunny sky with sun\n"); else @@ -211,6 +233,7 @@ char *msg; if (msg != NULL) fprintf(stderr, "%s: Use error - %s\n", progname, msg); fprintf(stderr, "Usage: %s month day hour [options]\n", progname); + fprintf(stderr, " Or: %s -ang altitude azimuth [options]\n", progname); fprintf(stderr, " Or: %s -defaults\n", progname); exit(1); }
