--- ray/src/gen/gensky.c 1989/07/21 21:17:42 1.2 +++ ray/src/gen/gensky.c 1993/06/07 14:51:22 2.11 @@ -1,4 +1,4 @@ -/* Copyright (c) 1986 Regents of the University of California */ +/* Copyright (c) 1992 Regents of the University of California */ #ifndef lint static char SCCSid[] = "$SunId$ LBL"; @@ -17,6 +17,7 @@ static char SCCSid[] = "$SunId$ LBL"; #include +#include "color.h" extern char *strcpy(), *strcat(), *malloc(); extern double stadj(), sdec(), sazi(), salt(); @@ -31,10 +32,12 @@ extern double s_latitude; extern double s_longitude; extern double s_meridian; /* required values */ -int month, day; -double hour; +int month, day; /* date */ +double hour; /* time */ +int tsolar; /* 0=standard, 1=solar */ +double altitude, azimuth; /* or solar angles */ /* default values */ -int cloudy = 0; +int cloudy = 0; /* 1=standard, 2=uniform */ int dosun = 1; double zenithbr = -1.0; double turbidity = 2.75; @@ -43,7 +46,7 @@ double gprefl = 0.2; double sundir[3]; double groundbr; double F2; -double solarbr; +double solarbr = -1.0; char *progname; char errmsg[128]; @@ -53,7 +56,6 @@ main(argc, argv) int argc; char *argv[]; { - extern double atof(); int i; progname = argv[0]; @@ -63,9 +65,22 @@ char *argv[]; } if (argc < 4) userror("arg count"); - month = atoi(argv[1]); - day = atoi(argv[2]); - hour = atof(argv[3]); + if (!strcmp(argv[1], "-ang")) { + altitude = atof(argv[2]) * (PI/180); + azimuth = atof(argv[3]) * (PI/180); + month = 0; + } else { + month = atoi(argv[1]); + if (month < 1 || month > 12) + userror("bad month"); + day = atoi(argv[2]); + if (day < 1 || day > 31) + userror("bad day"); + hour = atof(argv[3]); + if (hour < 0 || hour >= 24) + userror("bad hour"); + tsolar = argv[3][0] == '+'; + } for (i = 4; i < argc; i++) if (argv[i][0] == '-' || argv[i][0] == '+') switch (argv[i][1]) { @@ -73,8 +88,11 @@ char *argv[]; cloudy = 0; dosun = argv[i][0] == '+'; break; + case 'r': + solarbr = atof(argv[++i]); + break; case 'c': - cloudy = 1; + cloudy = argv[i][0] == '+' ? 2 : 1; dosun = 0; break; case 't': @@ -102,6 +120,11 @@ char *argv[]; else userror("bad option"); + if (fabs(s_meridian-s_longitude) > 30*PI/180) + fprintf(stderr, + "%s: warning: %.1f hours btwn. standard meridian and longitude\n", + progname, (s_longitude-s_meridian)*12/PI); + printhead(argc, argv); computesky(); @@ -111,15 +134,30 @@ char *argv[]; computesky() /* compute sky parameters */ { - int jd; - double sd, st; - double altitude, azimuth; /* compute solar direction */ - jd = jdate(month, day); /* Julian date */ - sd = sdec(jd); /* solar declination */ - st = hour + stadj(jd); /* solar time */ - altitude = salt(sd, st); - azimuth = sazi(sd, st); + if (month) { /* from date and time */ + int jd; + double sd, st; + + jd = jdate(month, day); /* Julian date */ + sd = sdec(jd); /* solar declination */ + if (tsolar) /* solar time */ + st = hour; + else + st = hour + stadj(jd); + altitude = salt(sd, st); + azimuth = sazi(sd, st); + printf("# Solar altitude and azimuth: %f %f\n", + 180./PI*altitude, 180./PI*azimuth); + } + if (!cloudy && altitude > 87.*PI/180.) { + fprintf(stderr, +"%s: warning - sun too close to zenith, reducing altitude to 87 degrees\n", + progname); + printf( +"# warning - sun too close to zenith, reducing altitude to 87 degrees\n"); + altitude = 87.*PI/180.; + } sundir[0] = -sin(azimuth)*cos(altitude); sundir[1] = -cos(azimuth)*cos(altitude); sundir[2] = sin(altitude); @@ -128,27 +166,29 @@ computesky() /* compute sky parameters */ if (zenithbr <= 0.0) if (cloudy) { zenithbr = 8.6*sundir[2] + .123; - zenithbr *= 1000.0/683.0; + zenithbr *= 1000.0/WHTEFFICACY; } else { zenithbr = (1.376*turbidity-1.81)*tan(altitude)+0.38; - zenithbr *= 1000.0/683.0; + zenithbr *= 1000.0/SKYEFFICACY; } if (zenithbr < 0.0) zenithbr = 0.0; /* Compute horizontal radiance */ if (cloudy) { - groundbr = zenithbr*0.777778; + if (cloudy == 2) + groundbr = zenithbr; + else + groundbr = zenithbr*0.777778; printf("# Ground ambient level: %f\n", groundbr); } else { F2 = 0.274*(0.91 + 10.0*exp(-3.0*(PI/2.0-altitude)) + 0.45*sundir[2]*sundir[2]); - groundbr = zenithbr*normsc(PI/2.0-altitude)/F2/PI; + groundbr = zenithbr*normsc(altitude)/F2/PI; printf("# Ground ambient level: %f\n", groundbr); - if (sundir[2] > 0.0) { - if (sundir[2] > .16) - solarbr = 2.47e6 - 3.15e5/sundir[2]; - else - solarbr = 5e5; + if (sundir[2] > 0.0 && solarbr != 0.0) { + if (solarbr < 0.0) + solarbr = 1.5e9/SUNEFFICACY * + (1.147 - .147/(sundir[2]>.16?sundir[2]:.16)); groundbr += solarbr*6e-5*sundir[2]/PI; } else dosun = 0; @@ -159,12 +199,10 @@ computesky() /* compute sky parameters */ printsky() /* print out sky */ { - register int i; - if (dosun) { printf("\nvoid light solar\n"); printf("0\n0\n"); - printf("3 %f %f %f\n", solarbr, solarbr, solarbr); + printf("3 %.2e %.2e %.2e\n", solarbr, solarbr, solarbr); printf("\nsolar source sun\n"); printf("0\n0\n"); printf("4 %f %f %f 0.5\n", sundir[0], sundir[1], sundir[2]); @@ -174,17 +212,19 @@ printsky() /* print out sky */ printf("2 skybright skybright.cal\n"); printf("0\n"); if (cloudy) - printf("3 1 %f %f\n", zenithbr, groundbr); + printf("3 %d %.2e %.2e\n", cloudy, zenithbr, groundbr); else - printf("7 -1 %f %f %f %f %f %f\n", zenithbr, groundbr, F2, - sundir[0], sundir[1], sundir[2]); + printf("7 -1 %.2e %.2e %.2e %f %f %f\n", zenithbr, groundbr, + F2, sundir[0], sundir[1], sundir[2]); } printdefaults() /* print default values */ { - if (cloudy) + if (cloudy == 1) printf("-c\t\t\t\t# Cloudy sky\n"); + else if (cloudy == 2) + printf("+c\t\t\t\t# Uniform cloudy sky\n"); else if (dosun) printf("+s\t\t\t\t# Sunny sky with sun\n"); else @@ -206,6 +246,7 @@ char *msg; if (msg != NULL) fprintf(stderr, "%s: Use error - %s\n", progname, msg); fprintf(stderr, "Usage: %s month day hour [options]\n", progname); + fprintf(stderr, " Or: %s -ang altitude azimuth [options]\n", progname); fprintf(stderr, " Or: %s -defaults\n", progname); exit(1); }
