root/Development/ray/src/gen/gensky.c
Wed Dec 8 21:22:33 2010 UTC (14 years, 11 months ago) by greg
Changes since 2.24: +3 -3 lines
Diff to previous 2.24
Eliminated bogus warning for meridian offset when solar time is given
Wed Jul 26 17:15:11 2006 UTC (19 years, 3 months ago) by greg
Diff to previous 2.23
Changed default turbidity from 2.75 to 2.45
Fri Sep 10 18:19:24 2004 UTC (21 years, 2 months ago) by greg
Changes since 2.22: +11 -6 lines
Diff to previous 2.22
Sun Nov 16 10:29:38 2003 UTC (21 years, 11 months ago) by schorsch
Changes since 2.21: +51 -33 lines
Diff to previous 2.21
Sun Jul 27 22:12:02 2003 UTC (22 years, 3 months ago) by schorsch
Diff to previous 2.20
Sat Feb 22 02:07:23 2003 UTC (22 years, 8 months ago) by greg
Diff to previous 2.19
Thu Apr 23 16:27:05 1998 UTC (27 years, 6 months ago) by gwlarson
Changes since 2.18: +7 -3 lines
Diff to previous 2.18
fixed time zones and added new ones
Thu Jul 18 18:00:51 1996 UTC (29 years, 3 months ago) by greg
Diff to previous 2.17
changed panic at standard time difference from 2 to 3 hours
Tue Jul 16 14:14:50 1996 UTC (29 years, 3 months ago) by greg
Changes since 2.16: +61 -8 lines
Diff to previous 2.16
added time zone specifications
Tue Jun 25 20:48:17 1996 UTC (29 years, 4 months ago) by greg
Changes since 2.15: +16 -4 lines
Diff to previous 2.15
added ability to specify time as HH:MM
Mon May 2 15:17:25 1994 UTC (31 years, 6 months ago) by greg
Changes since 2.14: +2 -0 lines
Diff to previous 2.14
added exit(0) to end of main()
Mon Jan 31 12:53:49 1994 UTC (31 years, 9 months ago) by greg
Changes since 2.13: +1 -3 lines
Diff to previous 2.13
fixed bug in calculation of ground brightness for uniform and overcast skies
Fri Nov 5 17:25:34 1993 UTC (32 years ago) by greg
Changes since 2.12: +78 -31 lines
Diff to previous 2.12
added intermediate sky and changed +c option to -u
Mon Jun 14 13:54:26 1993 UTC (32 years, 5 months ago) by greg
Changes since 2.11: +39 -28 lines
added -B option for global irradiance and -R for solar irradiance
Mon Jun 7 14:51:22 1993 UTC (32 years, 5 months ago) by greg
Changes since 2.10: +2 -0 lines
added comment output regarding solar altitude and azimuth
Fri Jun 4 14:30:24 1993 UTC (32 years, 5 months ago) by greg
Changes since 2.9: +0 -3 lines
Removed unnecessary declaration of atof()
Wed Dec 9 08:32:52 1992 UTC (32 years, 11 months ago) by greg
Changes since 2.8: +9 -1 lines
Added protection against sun too close to zenith
Fri Oct 23 14:19:35 1992 UTC (33 years ago) by greg
Changes since 2.7: +8 -7 lines
added -r option to affect solar radiance
Fri Oct 2 16:11:53 1992 UTC (33 years, 1 month ago) by greg
Changes since 2.6: +0 -1 lines
Tue Apr 14 10:29:24 1992 UTC (33 years, 7 months ago) by greg
fixed bug in sky normalization calculation,
which resulted in incorrect ground ambient levels
Fri Mar 20 15:29:10 1992 UTC (33 years, 7 months ago) by greg
Changes since 2.4: +7 -2 lines
added ability to specify solar instead of standard time
Fri Mar 20 12:23:38 1992 UTC (33 years, 7 months ago) by greg
Changes since 2.3: +10 -5 lines
added +c option for uniform cloudy sky
Tue Mar 10 11:12:06 1992 UTC (33 years, 8 months ago) by greg
Changes since 2.2: +23 -13 lines
added -ang option for specifying solar angles explicitly
Thu Dec 19 15:09:28 1991 UTC (33 years, 10 months ago) by greg
Tue Nov 12 17:05:02 1991 UTC (34 years ago) by greg
Diff to previous 1.6
Thu Oct 24 13:43:22 1991 UTC (34 years ago) by greg
Changes since 1.5: +10 -8 lines
Diff to previous 1.5
changed factors for solar and sky luminance to radiance
Tue Aug 6 08:22:06 1991 UTC (34 years, 3 months ago) by greg
Changes since 1.4: +6 -1 lines
Diff to previous 1.4
added warning about mismatched standard meridians and longitudes
Tue Mar 19 12:09:27 1991 UTC (34 years, 7 months ago) by greg
Diff to previous 1.3
changed calculation of zenith brightness to use white light
Mon Mar 12 09:49:25 1990 UTC (35 years, 8 months ago) by greg
Changes since 1.2: +0 -2 lines
Diff to previous 1.2
removed unused variable
Fri Jul 21 21:17:42 1989 UTC (36 years, 3 months ago) by greg
Diff to previous 1.1
added check for negative zenith brightness calculation
Thu Feb 2 11:16:29 1989 UTC (36 years, 9 months ago) by greg
