root/radiance/ray/src/gen/gensky.c
Revision: 1.2
Committed: Fri Jul 21 21:17:42 1989 UTC (34 years, 11 months ago) by greg
added check for negative zenith brightness calculation
1 /* Copyright (c) 1986 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * gensky.c - program to generate sky functions.
9 * Our zenith is along the Z-axis, the X-axis
10 * points east, and the Y-axis points north.
11 * Radiance is in watts/steradian/sq. meter.
12 *
13 * 3/26/86
14 */
15
16 #include <stdio.h>
17
18 #include <math.h>
19
20
21 extern char *strcpy(), *strcat(), *malloc();
22 extern double stadj(), sdec(), sazi(), salt();
23
24 #define PI 3.141592654
25
26 #define DOT(v1,v2) (v1[0]*v2[0]+v1[1]*v2[1]+v1[2]*v2[2])
27
28 double normsc();
29 /* sun calculation constants */
30 extern double s_latitude;
31 extern double s_longitude;
32 extern double s_meridian;
33 /* required values */
34 int month, day;
35 double hour;
36 /* default values */
37 int cloudy = 0;
38 int dosun = 1;
39 double zenithbr = -1.0;
40 double turbidity = 2.75;
41 double gprefl = 0.2;
42 /* computed values */
43 double sundir[3];
44 double groundbr;
45 double F2;
46 double solarbr;
47
48 char *progname;
49 char errmsg[128];
50
51
52 main(argc, argv)
53 int argc;
54 char *argv[];
55 {
56 extern double atof();
57 int i;
58
59 progname = argv[0];
60 if (argc == 2 && !strcmp(argv[1], "-defaults")) {
61 printdefaults();
62 exit(0);
63 }
64 if (argc < 4)
65 userror("arg count");
66 month = atoi(argv[1]);
67 day = atoi(argv[2]);
68 hour = atof(argv[3]);
69 for (i = 4; i < argc; i++)
70 if (argv[i][0] == '-' || argv[i][0] == '+')
71 switch (argv[i][1]) {
72 case 's':
73 cloudy = 0;
74 dosun = argv[i][0] == '+';
75 break;
76 case 'c':
77 cloudy = 1;
78 dosun = 0;
79 break;
80 case 't':
81 turbidity = atof(argv[++i]);
82 break;
83 case 'b':
84 zenithbr = atof(argv[++i]);
85 break;
86 case 'g':
87 gprefl = atof(argv[++i]);
88 break;
89 case 'a':
90 s_latitude = atof(argv[++i]) * (PI/180);
91 break;
92 case 'o':
93 s_longitude = atof(argv[++i]) * (PI/180);
94 break;
95 case 'm':
96 s_meridian = atof(argv[++i]) * (PI/180);
97 break;
98 default:
99 sprintf(errmsg, "unknown option: %s", argv[i]);
100 userror(errmsg);
101 }
102 else
103 userror("bad option");
104
105 printhead(argc, argv);
106
107 computesky();
108 printsky();
109 }
110
111
112 computesky() /* compute sky parameters */
113 {
114 int jd;
115 double sd, st;
116 double altitude, azimuth;
117 /* compute solar direction */
118 jd = jdate(month, day); /* Julian date */
119 sd = sdec(jd); /* solar declination */
120 st = hour + stadj(jd); /* solar time */
121 altitude = salt(sd, st);
122 azimuth = sazi(sd, st);
123 sundir[0] = -sin(azimuth)*cos(altitude);
124 sundir[1] = -cos(azimuth)*cos(altitude);
125 sundir[2] = sin(altitude);
126
127 /* Compute zenith brightness */
128 if (zenithbr <= 0.0)
129 if (cloudy) {
130 zenithbr = 8.6*sundir[2] + .123;
131 zenithbr *= 1000.0/683.0;
132 } else {
133 zenithbr = (1.376*turbidity-1.81)*tan(altitude)+0.38;
134 zenithbr *= 1000.0/683.0;
135 }
136 if (zenithbr < 0.0)
137 zenithbr = 0.0;
138 /* Compute horizontal radiance */
139 if (cloudy) {
140 groundbr = zenithbr*0.777778;
141 printf("# Ground ambient level: %f\n", groundbr);
142 } else {
143 F2 = 0.274*(0.91 + 10.0*exp(-3.0*(PI/2.0-altitude)) +
144 0.45*sundir[2]*sundir[2]);
145 groundbr = zenithbr*normsc(PI/2.0-altitude)/F2/PI;
146 printf("# Ground ambient level: %f\n", groundbr);
147 if (sundir[2] > 0.0) {
148 if (sundir[2] > .16)
149 solarbr = 2.47e6 - 3.15e5/sundir[2];
150 else
151 solarbr = 5e5;
152 groundbr += solarbr*6e-5*sundir[2]/PI;
153 } else
154 dosun = 0;
155 }
156 groundbr *= gprefl;
157 }
158
159
160 printsky() /* print out sky */
161 {
162 register int i;
163
164 if (dosun) {
165 printf("\nvoid light solar\n");
166 printf("0\n0\n");
167 printf("3 %f %f %f\n", solarbr, solarbr, solarbr);
168 printf("\nsolar source sun\n");
169 printf("0\n0\n");
170 printf("4 %f %f %f 0.5\n", sundir[0], sundir[1], sundir[2]);
171 }
172
173 printf("\nvoid brightfunc skyfunc\n");
174 printf("2 skybright skybright.cal\n");
175 printf("0\n");
176 if (cloudy)
177 printf("3 1 %f %f\n", zenithbr, groundbr);
178 else
179 printf("7 -1 %f %f %f %f %f %f\n", zenithbr, groundbr, F2,
180 sundir[0], sundir[1], sundir[2]);
181 }
182
183
184 printdefaults() /* print default values */
185 {
186 if (cloudy)
187 printf("-c\t\t\t\t# Cloudy sky\n");
188 else if (dosun)
189 printf("+s\t\t\t\t# Sunny sky with sun\n");
190 else
191 printf("-s\t\t\t\t# Sunny sky without sun\n");
192 printf("-g %f\t\t\t# Ground plane reflectance\n", gprefl);
193 if (zenithbr > 0.0)
194 printf("-b %f\t\t\t# Zenith radiance (watts/ster/m2\n", zenithbr);
195 else
196 printf("-t %f\t\t\t# Atmospheric turbidity\n", turbidity);
197 printf("-a %f\t\t\t# Site latitude (degrees)\n", s_latitude*(180/PI));
198 printf("-o %f\t\t\t# Site longitude (degrees)\n", s_longitude*(180/PI));
199 printf("-m %f\t\t\t# Standard meridian (degrees)\n", s_meridian*(180/PI));
200 }
201
202
203 userror(msg) /* print usage error and quit */
204 char *msg;
205 {
206 if (msg != NULL)
207 fprintf(stderr, "%s: Use error - %s\n", progname, msg);
208 fprintf(stderr, "Usage: %s month day hour [options]\n", progname);
209 fprintf(stderr, " Or: %s -defaults\n", progname);
210 exit(1);
211 }
212
213
214 double
215 normsc(theta) /* compute normalization factor (E0*F2/L0) */
216 double theta;
217 {
218 static double nf[5] = {2.766521, 0.547665,
219 -0.369832, 0.009237, 0.059229};
220 double x, nsc;
221 register int i;
222 /* polynomial approximation */
223 x = (theta - PI/4.0)/(PI/4.0);
224 nsc = nf[4];
225 for (i = 3; i >= 0; i--)
226 nsc = nsc*x + nf[i];
227
228 return(nsc);
229 }
230
231
232 printhead(ac, av) /* print command header */
233 register int ac;
234 register char **av;
235 {
236 putchar('#');
237 while (ac--) {
238 putchar(' ');
239 fputs(*av++, stdout);
240 }
241 putchar('\n');
242 }
