root/radiance/ray/src/gen/gensky.c
Revision: 2.3
Committed: Tue Mar 10 11:12:06 1992 UTC (32 years, 3 months ago) by greg
Changes since 2.2: +23 -13 lines
added -ang option for specifying solar angles explicitly
1 /* Copyright (c) 1986 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * gensky.c - program to generate sky functions.
9 * Our zenith is along the Z-axis, the X-axis
10 * points east, and the Y-axis points north.
11 * Radiance is in watts/steradian/sq. meter.
12 *
13 * 3/26/86
14 */
15
16 #include <stdio.h>
17
18 #include <math.h>
19
20 #include "color.h"
21
22 #ifndef atof
23 extern double atof();
24 #endif
25 extern char *strcpy(), *strcat(), *malloc();
26 extern double stadj(), sdec(), sazi(), salt();
27
28 #define PI 3.141592654
29
30 #define DOT(v1,v2) (v1[0]*v2[0]+v1[1]*v2[1]+v1[2]*v2[2])
31
32 double normsc();
33 /* sun calculation constants */
34 extern double s_latitude;
35 extern double s_longitude;
36 extern double s_meridian;
37 /* required values */
38 int month, day; /* date */
39 double hour; /* standard time */
40 double altitude, azimuth; /* or solar angles */
41 /* default values */
42 int cloudy = 0;
43 int dosun = 1;
44 double zenithbr = -1.0;
45 double turbidity = 2.75;
46 double gprefl = 0.2;
47 /* computed values */
48 double sundir[3];
49 double groundbr;
50 double F2;
51 double solarbr;
52
53 char *progname;
54 char errmsg[128];
55
56
57 main(argc, argv)
58 int argc;
59 char *argv[];
60 {
61 extern double fabs();
62 int i;
63
64 progname = argv[0];
65 if (argc == 2 && !strcmp(argv[1], "-defaults")) {
66 printdefaults();
67 exit(0);
68 }
69 if (argc < 4)
70 userror("arg count");
71 if (!strcmp(argv[1], "-ang")) {
72 altitude = atof(argv[2]) * (PI/180);
73 azimuth = atof(argv[3]) * (PI/180);
74 month = 0;
75 } else {
76 month = atoi(argv[1]);
77 day = atoi(argv[2]);
78 hour = atof(argv[3]);
79 }
80 for (i = 4; i < argc; i++)
81 if (argv[i][0] == '-' || argv[i][0] == '+')
82 switch (argv[i][1]) {
83 case 's':
84 cloudy = 0;
85 dosun = argv[i][0] == '+';
86 break;
87 case 'c':
88 cloudy = 1;
89 dosun = 0;
90 break;
91 case 't':
92 turbidity = atof(argv[++i]);
93 break;
94 case 'b':
95 zenithbr = atof(argv[++i]);
96 break;
97 case 'g':
98 gprefl = atof(argv[++i]);
99 break;
100 case 'a':
101 s_latitude = atof(argv[++i]) * (PI/180);
102 break;
103 case 'o':
104 s_longitude = atof(argv[++i]) * (PI/180);
105 break;
106 case 'm':
107 s_meridian = atof(argv[++i]) * (PI/180);
108 break;
109 default:
110 sprintf(errmsg, "unknown option: %s", argv[i]);
111 userror(errmsg);
112 }
113 else
114 userror("bad option");
115
116 if (fabs(s_meridian-s_longitude) > 30*PI/180)
117 fprintf(stderr,
118 "%s: warning: %.1f hours btwn. standard meridian and longitude\n",
119 progname, (s_longitude-s_meridian)*12/PI);
120
121 printhead(argc, argv);
122
123 computesky();
124 printsky();
125 }
126
127
128 computesky() /* compute sky parameters */
129 {
130 /* compute solar direction */
131 if (month) { /* from date and time */
132 int jd;
133 double sd, st;
134
135 jd = jdate(month, day); /* Julian date */
136 sd = sdec(jd); /* solar declination */
137 st = hour + stadj(jd); /* solar time */
138 altitude = salt(sd, st);
139 azimuth = sazi(sd, st);
140 }
141 sundir[0] = -sin(azimuth)*cos(altitude);
142 sundir[1] = -cos(azimuth)*cos(altitude);
143 sundir[2] = sin(altitude);
144
145 /* Compute zenith brightness */
146 if (zenithbr <= 0.0)
147 if (cloudy) {
148 zenithbr = 8.6*sundir[2] + .123;
149 zenithbr *= 1000.0/SKYEFFICACY;
150 } else {
151 zenithbr = (1.376*turbidity-1.81)*tan(altitude)+0.38;
152 zenithbr *= 1000.0/SKYEFFICACY;
153 }
154 if (zenithbr < 0.0)
155 zenithbr = 0.0;
156 /* Compute horizontal radiance */
157 if (cloudy) {
158 groundbr = zenithbr*0.777778;
159 printf("# Ground ambient level: %f\n", groundbr);
160 } else {
161 F2 = 0.274*(0.91 + 10.0*exp(-3.0*(PI/2.0-altitude)) +
162 0.45*sundir[2]*sundir[2]);
163 groundbr = zenithbr*normsc(PI/2.0-altitude)/F2/PI;
164 printf("# Ground ambient level: %f\n", groundbr);
165 if (sundir[2] > 0.0) {
166 if (sundir[2] > .16)
167 solarbr = (1.5e9/SUNEFFICACY) *
168 (1.147 - .147/sundir[2]);
169 else
170 solarbr = 1.5e9/SUNEFFICACY*(1.147-.147/.16);
171 groundbr += solarbr*6e-5*sundir[2]/PI;
172 } else
173 dosun = 0;
174 }
175 groundbr *= gprefl;
176 }
177
178
179 printsky() /* print out sky */
180 {
181 if (dosun) {
182 printf("\nvoid light solar\n");
183 printf("0\n0\n");
184 printf("3 %.2e %.2e %.2e\n", solarbr, solarbr, solarbr);
185 printf("\nsolar source sun\n");
186 printf("0\n0\n");
187 printf("4 %f %f %f 0.5\n", sundir[0], sundir[1], sundir[2]);
188 }
189
190 printf("\nvoid brightfunc skyfunc\n");
191 printf("2 skybright skybright.cal\n");
192 printf("0\n");
193 if (cloudy)
194 printf("3 1 %.2e %.2e\n", zenithbr, groundbr);
195 else
196 printf("7 -1 %.2e %.2e %.2e %f %f %f\n", zenithbr, groundbr,
197 F2, sundir[0], sundir[1], sundir[2]);
198 }
199
200
201 printdefaults() /* print default values */
202 {
203 if (cloudy)
204 printf("-c\t\t\t\t# Cloudy sky\n");
205 else if (dosun)
206 printf("+s\t\t\t\t# Sunny sky with sun\n");
207 else
208 printf("-s\t\t\t\t# Sunny sky without sun\n");
209 printf("-g %f\t\t\t# Ground plane reflectance\n", gprefl);
210 if (zenithbr > 0.0)
211 printf("-b %f\t\t\t# Zenith radiance (watts/ster/m2\n", zenithbr);
212 else
213 printf("-t %f\t\t\t# Atmospheric turbidity\n", turbidity);
214 printf("-a %f\t\t\t# Site latitude (degrees)\n", s_latitude*(180/PI));
215 printf("-o %f\t\t\t# Site longitude (degrees)\n", s_longitude*(180/PI));
216 printf("-m %f\t\t\t# Standard meridian (degrees)\n", s_meridian*(180/PI));
217 }
218
219
220 userror(msg) /* print usage error and quit */
221 char *msg;
222 {
223 if (msg != NULL)
224 fprintf(stderr, "%s: Use error - %s\n", progname, msg);
225 fprintf(stderr, "Usage: %s month day hour [options]\n", progname);
226 fprintf(stderr, " Or: %s -ang altitude azimuth [options]\n", progname);
227 fprintf(stderr, " Or: %s -defaults\n", progname);
228 exit(1);
229 }
230
231
232 double
233 normsc(theta) /* compute normalization factor (E0*F2/L0) */
234 double theta;
235 {
236 static double nf[5] = {2.766521, 0.547665,
237 -0.369832, 0.009237, 0.059229};
238 double x, nsc;
239 register int i;
240 /* polynomial approximation */
241 x = (theta - PI/4.0)/(PI/4.0);
242 nsc = nf[4];
243 for (i = 3; i >= 0; i--)
244 nsc = nsc*x + nf[i];
245
246 return(nsc);
247 }
248
249
250 printhead(ac, av) /* print command header */
251 register int ac;
252 register char **av;
253 {
254 putchar('#');
255 while (ac--) {
256 putchar(' ');
257 fputs(*av++, stdout);
258 }
259 putchar('\n');
260 }
