--- ray/src/gen/gensky.c 1992/12/09 08:32:52 2.9 +++ ray/src/gen/gensky.c 1993/06/14 13:54:26 2.12 @@ -19,9 +19,6 @@ static char SCCSid[] = "$SunId$ LBL"; #include "color.h" -#ifndef atof -extern double atof(); -#endif extern char *strcpy(), *strcat(), *malloc(); extern double stadj(), sdec(), sazi(), salt(); @@ -42,14 +39,16 @@ double altitude, azimuth; /* or solar angles */ /* default values */ int cloudy = 0; /* 1=standard, 2=uniform */ int dosun = 1; -double zenithbr = -1.0; +double zenithbr = 0.0; +int u_zenith = 0; /* -1=irradiance, 1=radiance */ double turbidity = 2.75; double gprefl = 0.2; /* computed values */ double sundir[3]; double groundbr; double F2; -double solarbr = -1.0; +double solarbr = 0.0; +int u_solar = 0; /* -1=irradiance, 1=radiance */ char *progname; char errmsg[128]; @@ -92,6 +91,8 @@ char *argv[]; dosun = argv[i][0] == '+'; break; case 'r': + case 'R': + u_solar = argv[i][1]=='R' ? -1 : 1; solarbr = atof(argv[++i]); break; case 'c': @@ -102,6 +103,8 @@ char *argv[]; turbidity = atof(argv[++i]); break; case 'b': + case 'B': + u_zenith = argv[i][1]=='B' ? -1 : 1; zenithbr = atof(argv[++i]); break; case 'g': @@ -137,6 +140,7 @@ char *argv[]; computesky() /* compute sky parameters */ { + double normfactor; /* compute solar direction */ if (month) { /* from date and time */ int jd; @@ -150,6 +154,8 @@ computesky() /* compute sky parameters */ st = hour + stadj(jd); altitude = salt(sd, st); azimuth = sazi(sd, st); + printf("# Solar altitude and azimuth: %f %f\n", + 180./PI*altitude, 180./PI*azimuth); } if (!cloudy && altitude > 87.*PI/180.) { fprintf(stderr, @@ -163,37 +169,41 @@ computesky() /* compute sky parameters */ sundir[1] = -cos(azimuth)*cos(altitude); sundir[2] = sin(altitude); + /* Compute normalization factor */ + if (cloudy == 2) + normfactor = 1.0; + else if (cloudy == 1) + normfactor = 0.777778; + else { + F2 = 0.274*(0.91 + 10.0*exp(-3.0*(PI/2.0-altitude)) + + 0.45*sundir[2]*sundir[2]); + normfactor = normsc(altitude)/F2/PI; + } /* Compute zenith brightness */ - if (zenithbr <= 0.0) - if (cloudy) { + if (u_zenith == -1) + zenithbr /= normfactor*PI; + else if (u_zenith == 0) { + if (cloudy) zenithbr = 8.6*sundir[2] + .123; - zenithbr *= 1000.0/WHTEFFICACY; - } else { + else zenithbr = (1.376*turbidity-1.81)*tan(altitude)+0.38; - zenithbr *= 1000.0/SKYEFFICACY; - } - if (zenithbr < 0.0) - zenithbr = 0.0; - /* Compute horizontal radiance */ - if (cloudy) { - if (cloudy == 2) - groundbr = zenithbr; + if (zenithbr < 0.0) + zenithbr = 0.0; else - groundbr = zenithbr*0.777778; - printf("# Ground ambient level: %f\n", groundbr); - } else { - F2 = 0.274*(0.91 + 10.0*exp(-3.0*(PI/2.0-altitude)) + - 0.45*sundir[2]*sundir[2]); - groundbr = zenithbr*normsc(altitude)/F2/PI; - printf("# Ground ambient level: %f\n", groundbr); - if (sundir[2] > 0.0 && solarbr != 0.0) { - if (solarbr < 0.0) - solarbr = 1.5e9/SUNEFFICACY * - (1.147 - .147/(sundir[2]>.16?sundir[2]:.16)); - groundbr += solarbr*6e-5*sundir[2]/PI; - } else - dosun = 0; + zenithbr *= 1000.0/SKYEFFICACY; } + /* Compute horizontal radiance */ + groundbr = zenithbr*normfactor; + printf("# Ground ambient level: %f\n", groundbr); + if (sundir[2] > 0.0 && (!u_solar || solarbr > 0.0)) { + if (u_solar == -1) + solarbr /= 6e-5*sundir[2]; + else if (u_solar == 0) + solarbr = 1.5e9/SUNEFFICACY * + (1.147 - .147/(sundir[2]>.16?sundir[2]:.16)); + groundbr += 6e-5/PI*solarbr*sundir[2]; + } else + dosun = 0; groundbr *= gprefl; }
