root/radiance/ray/src/gen/gensky.c
Diff to previous 2.19 , to selected 1.5
Thu Apr 23 16:27:05 1998 UTC (26 years ago) by gwlarson
Changes since 2.18: +7 -3 lines
Diff to previous 2.18 , to selected 1.5
fixed time zones and added new ones
Thu Jul 18 18:00:51 1996 UTC (27 years, 9 months ago) by greg
Diff to previous 2.17 , to selected 1.5
changed panic at standard time difference from 2 to 3 hours
Tue Jul 16 14:14:50 1996 UTC (27 years, 9 months ago) by greg
Changes since 2.16: +61 -8 lines
Diff to previous 2.16 , to selected 1.5
added time zone specifications
Tue Jun 25 20:48:17 1996 UTC (27 years, 10 months ago) by greg
Changes since 2.15: +16 -4 lines
Diff to previous 2.15 , to selected 1.5
added ability to specify time as HH:MM
Mon May 2 15:17:25 1994 UTC (30 years ago) by greg
Changes since 2.14: +2 -0 lines
Diff to previous 2.14 , to selected 1.5
added exit(0) to end of main()
Mon Jan 31 12:53:49 1994 UTC (30 years, 3 months ago) by greg
Changes since 2.13: +1 -3 lines
Diff to previous 2.13 , to selected 1.5
fixed bug in calculation of ground brightness for uniform and overcast skies
Fri Nov 5 17:25:34 1993 UTC (30 years, 6 months ago) by greg
Changes since 2.12: +78 -31 lines
Diff to previous 2.12 , to selected 1.5
added intermediate sky and changed +c option to -u
Mon Jun 14 13:54:26 1993 UTC (30 years, 10 months ago) by greg
Changes since 2.11: +39 -28 lines
Diff to previous 2.11 , to selected 1.5
added -B option for global irradiance and -R for solar irradiance
Mon Jun 7 14:51:22 1993 UTC (30 years, 11 months ago) by greg
Changes since 2.10: +2 -0 lines
Diff to previous 2.10 , to selected 1.5
added comment output regarding solar altitude and azimuth
Fri Jun 4 14:30:24 1993 UTC (30 years, 11 months ago) by greg
Changes since 2.9: +0 -3 lines
Diff to previous 2.9 , to selected 1.5
Removed unnecessary declaration of atof()
Wed Dec 9 08:32:52 1992 UTC (31 years, 5 months ago) by greg
Changes since 2.8: +9 -1 lines
Diff to previous 2.8 , to selected 1.5
Added protection against sun too close to zenith
Fri Oct 23 14:19:35 1992 UTC (31 years, 6 months ago) by greg
Changes since 2.7: +8 -7 lines
Diff to previous 2.7 , to selected 1.5
added -r option to affect solar radiance
Fri Oct 2 16:11:53 1992 UTC (31 years, 7 months ago) by greg
Changes since 2.6: +0 -1 lines
Diff to previous 2.6 , to selected 1.5
Tue Apr 14 10:29:24 1992 UTC (32 years, 1 month ago) by greg
Diff to previous 2.5 , to selected 1.5
fixed bug in sky normalization calculation,
which resulted in incorrect ground ambient levels
Fri Mar 20 15:29:10 1992 UTC (32 years, 1 month ago) by greg
Changes since 2.4: +7 -2 lines
Diff to previous 2.4 , to selected 1.5
added ability to specify solar instead of standard time
Fri Mar 20 12:23:38 1992 UTC (32 years, 1 month ago) by greg
Changes since 2.3: +10 -5 lines
Diff to previous 2.3 , to selected 1.5
added +c option for uniform cloudy sky
Tue Mar 10 11:12:06 1992 UTC (32 years, 2 months ago) by greg
Changes since 2.2: +23 -13 lines
Diff to previous 2.2 , to selected 1.5
added -ang option for specifying solar angles explicitly
Thu Dec 19 15:09:28 1991 UTC (32 years, 4 months ago) by greg
Diff to previous 2.1 , to selected 1.5
Tue Nov 12 17:05:02 1991 UTC (32 years, 6 months ago) by greg
Diff to previous 1.6 , to selected 1.5
Thu Oct 24 13:43:22 1991 UTC (32 years, 6 months ago) by greg
Changes since 1.5: +10 -8 lines
Diff to previous 1.5
changed factors for solar and sky luminance to radiance
Tue Aug 6 08:22:06 1991 UTC (32 years, 9 months ago) by greg
Changes since 1.4: +6 -1 lines
Diff to previous 1.4
added warning about mismatched standard meridians and longitudes
Tue Mar 19 12:09:27 1991 UTC (33 years, 1 month ago) by greg
changed calculation of zenith brightness to use white light
Mon Mar 12 09:49:25 1990 UTC (34 years, 2 months ago) by greg
Changes since 1.2: +0 -2 lines
removed unused variable
Fri Jul 21 21:17:42 1989 UTC (34 years, 9 months ago) by greg
added check for negative zenith brightness calculation
Thu Feb 2 11:16:29 1989 UTC (35 years, 3 months ago) by greg
Diff to selected 1.5
