Changes and check-in for 3.5 release Includes new source files and modifications not recorded for many years See ray/doc/notes/ReleaseNotes for notes between 3.1 and 3.5 release
fixed time zones and added new ones
changed panic at standard time difference from 2 to 3 hours
added time zone specifications
added ability to specify time as HH:MM
added exit(0) to end of main()
fixed bug in calculation of ground brightness for uniform and overcast skies
added intermediate sky and changed +c option to -u
added -B option for global irradiance and -R for solar irradiance
added comment output regarding solar altitude and azimuth
Removed unnecessary declaration of atof()
Added protection against sun too close to zenith
added -r option to affect solar radiance
fixed bug in sky normalization calculation, which resulted in incorrect ground ambient levels
added ability to specify solar instead of standard time
added +c option for uniform cloudy sky
added -ang option for specifying solar angles explicitly
changed factors for solar and sky luminance to radiance
added warning about mismatched standard meridians and longitudes
changed calculation of zenith brightness to use white light
removed unused variable
added check for negative zenith brightness calculation
