1 |
/* Copyright (c) 1992 Regents of the University of California */ |
2 |
3 |
#ifndef lint |
4 |
static char SCCSid[] = "$SunId$ LBL"; |
5 |
#endif |
6 |
7 |
8 |
* gensky.c - program to generate sky functions. |
9 |
* Our zenith is along the Z-axis, the X-axis |
10 |
* points east, and the Y-axis points north. |
11 |
* Radiance is in watts/steradian/sq. meter. |
12 |
13 |
* 3/26/86 |
14 |
15 |
16 |
#include <stdio.h> |
17 |
18 |
#include <math.h> |
19 |
20 |
#include "color.h" |
21 |
22 |
#ifndef atof |
23 |
extern double atof(); |
24 |
#endif |
25 |
extern char *strcpy(), *strcat(), *malloc(); |
26 |
extern double stadj(), sdec(), sazi(), salt(); |
27 |
28 |
#define PI 3.141592654 |
29 |
30 |
#define DOT(v1,v2) (v1[0]*v2[0]+v1[1]*v2[1]+v1[2]*v2[2]) |
31 |
32 |
double normsc(); |
33 |
/* sun calculation constants */ |
34 |
extern double s_latitude; |
35 |
extern double s_longitude; |
36 |
extern double s_meridian; |
37 |
/* required values */ |
38 |
int month, day; /* date */ |
39 |
double hour; /* time */ |
40 |
int tsolar; /* 0=standard, 1=solar */ |
41 |
double altitude, azimuth; /* or solar angles */ |
42 |
/* default values */ |
43 |
int cloudy = 0; /* 1=standard, 2=uniform */ |
44 |
int dosun = 1; |
45 |
double zenithbr = -1.0; |
46 |
double turbidity = 2.75; |
47 |
double gprefl = 0.2; |
48 |
/* computed values */ |
49 |
double sundir[3]; |
50 |
double groundbr; |
51 |
double F2; |
52 |
double solarbr = -1.0; |
53 |
54 |
char *progname; |
55 |
char errmsg[128]; |
56 |
57 |
58 |
main(argc, argv) |
59 |
int argc; |
60 |
char *argv[]; |
61 |
62 |
int i; |
63 |
64 |
progname = argv[0]; |
65 |
if (argc == 2 && !strcmp(argv[1], "-defaults")) { |
66 |
printdefaults(); |
67 |
exit(0); |
68 |
69 |
if (argc < 4) |
70 |
userror("arg count"); |
71 |
if (!strcmp(argv[1], "-ang")) { |
72 |
altitude = atof(argv[2]) * (PI/180); |
73 |
azimuth = atof(argv[3]) * (PI/180); |
74 |
month = 0; |
75 |
} else { |
76 |
month = atoi(argv[1]); |
77 |
if (month < 1 || month > 12) |
78 |
userror("bad month"); |
79 |
day = atoi(argv[2]); |
80 |
if (day < 1 || day > 31) |
81 |
userror("bad day"); |
82 |
hour = atof(argv[3]); |
83 |
if (hour < 0 || hour >= 24) |
84 |
userror("bad hour"); |
85 |
tsolar = argv[3][0] == '+'; |
86 |
87 |
for (i = 4; i < argc; i++) |
88 |
if (argv[i][0] == '-' || argv[i][0] == '+') |
89 |
switch (argv[i][1]) { |
90 |
case 's': |
91 |
cloudy = 0; |
92 |
dosun = argv[i][0] == '+'; |
93 |
break; |
94 |
case 'r': |
95 |
solarbr = atof(argv[++i]); |
96 |
break; |
97 |
case 'c': |
98 |
cloudy = argv[i][0] == '+' ? 2 : 1; |
99 |
dosun = 0; |
100 |
break; |
101 |
case 't': |
102 |
turbidity = atof(argv[++i]); |
103 |
break; |
104 |
case 'b': |
105 |
zenithbr = atof(argv[++i]); |
106 |
break; |
107 |
case 'g': |
108 |
gprefl = atof(argv[++i]); |
109 |
break; |
110 |
case 'a': |
111 |
s_latitude = atof(argv[++i]) * (PI/180); |
112 |
break; |
113 |
case 'o': |
114 |
s_longitude = atof(argv[++i]) * (PI/180); |
115 |
break; |
116 |
case 'm': |
117 |
s_meridian = atof(argv[++i]) * (PI/180); |
118 |
break; |
119 |
default: |
120 |
sprintf(errmsg, "unknown option: %s", argv[i]); |
121 |
userror(errmsg); |
122 |
123 |
else |
124 |
userror("bad option"); |
125 |
126 |
if (fabs(s_meridian-s_longitude) > 30*PI/180) |
127 |
fprintf(stderr, |
128 |
"%s: warning: %.1f hours btwn. standard meridian and longitude\n", |
129 |
progname, (s_longitude-s_meridian)*12/PI); |
130 |
131 |
printhead(argc, argv); |
132 |
133 |
computesky(); |
134 |
printsky(); |
135 |
136 |
137 |
138 |
computesky() /* compute sky parameters */ |
139 |
140 |
/* compute solar direction */ |
141 |
if (month) { /* from date and time */ |
142 |
int jd; |
143 |
double sd, st; |
144 |
145 |
jd = jdate(month, day); /* Julian date */ |
146 |
sd = sdec(jd); /* solar declination */ |
147 |
if (tsolar) /* solar time */ |
148 |
st = hour; |
149 |
else |
150 |
st = hour + stadj(jd); |
151 |
altitude = salt(sd, st); |
152 |
azimuth = sazi(sd, st); |
153 |
154 |
if (!cloudy && altitude > 87.*PI/180.) { |
155 |
fprintf(stderr, |
156 |
"%s: warning - sun too close to zenith, reducing altitude to 87 degrees\n", |
157 |
progname); |
158 |
printf( |
159 |
"# warning - sun too close to zenith, reducing altitude to 87 degrees\n"); |
160 |
altitude = 87.*PI/180.; |
161 |
162 |
sundir[0] = -sin(azimuth)*cos(altitude); |
163 |
sundir[1] = -cos(azimuth)*cos(altitude); |
164 |
sundir[2] = sin(altitude); |
165 |
166 |
/* Compute zenith brightness */ |
167 |
if (zenithbr <= 0.0) |
168 |
if (cloudy) { |
169 |
zenithbr = 8.6*sundir[2] + .123; |
170 |
zenithbr *= 1000.0/WHTEFFICACY; |
171 |
} else { |
172 |
zenithbr = (1.376*turbidity-1.81)*tan(altitude)+0.38; |
173 |
zenithbr *= 1000.0/SKYEFFICACY; |
174 |
175 |
if (zenithbr < 0.0) |
176 |
zenithbr = 0.0; |
177 |
/* Compute horizontal radiance */ |
178 |
if (cloudy) { |
179 |
if (cloudy == 2) |
180 |
groundbr = zenithbr; |
181 |
else |
182 |
groundbr = zenithbr*0.777778; |
183 |
printf("# Ground ambient level: %f\n", groundbr); |
184 |
} else { |
185 |
F2 = 0.274*(0.91 + 10.0*exp(-3.0*(PI/2.0-altitude)) + |
186 |
0.45*sundir[2]*sundir[2]); |
187 |
groundbr = zenithbr*normsc(altitude)/F2/PI; |
188 |
189 |
if (sundir[2] > 0.0 && solarbr != 0.0) { |
190 |
if (solarbr < 0.0) |
191 |
solarbr = 1.5e9/SUNEFFICACY * |
192 |
(1.147 - .147/(sundir[2]>.16?sundir[2]:.16)); |
193 |
groundbr += solarbr*6e-5*sundir[2]/PI; |
194 |
} else |
195 |
dosun = 0; |
196 |
197 |
groundbr *= gprefl; |
198 |
199 |
200 |
201 |
printsky() /* print out sky */ |
202 |
203 |
if (dosun) { |
204 |
printf("\nvoid light solar\n"); |
205 |
printf("0\n0\n"); |
206 |
printf("3 %.2e %.2e %.2e\n", solarbr, solarbr, solarbr); |
207 |
printf("\nsolar source sun\n"); |
208 |
printf("0\n0\n"); |
209 |
printf("4 %f %f %f 0.5\n", sundir[0], sundir[1], sundir[2]); |
210 |
211 |
212 |
printf("\nvoid brightfunc skyfunc\n"); |
213 |
printf("2 skybright skybright.cal\n"); |
214 |
printf("0\n"); |
215 |
if (cloudy) |
216 |
printf("3 %d %.2e %.2e\n", cloudy, zenithbr, groundbr); |
217 |
else |
218 |
printf("7 -1 %.2e %.2e %.2e %f %f %f\n", zenithbr, groundbr, |
219 |
F2, sundir[0], sundir[1], sundir[2]); |
220 |
221 |
222 |
223 |
printdefaults() /* print default values */ |
224 |
225 |
if (cloudy == 1) |
226 |
printf("-c\t\t\t\t# Cloudy sky\n"); |
227 |
else if (cloudy == 2) |
228 |
printf("+c\t\t\t\t# Uniform cloudy sky\n"); |
229 |
else if (dosun) |
230 |
printf("+s\t\t\t\t# Sunny sky with sun\n"); |
231 |
else |
232 |
printf("-s\t\t\t\t# Sunny sky without sun\n"); |
233 |
printf("-g %f\t\t\t# Ground plane reflectance\n", gprefl); |
234 |
if (zenithbr > 0.0) |
235 |
printf("-b %f\t\t\t# Zenith radiance (watts/ster/m2\n", zenithbr); |
236 |
else |
237 |
printf("-t %f\t\t\t# Atmospheric turbidity\n", turbidity); |
238 |
printf("-a %f\t\t\t# Site latitude (degrees)\n", s_latitude*(180/PI)); |
239 |
printf("-o %f\t\t\t# Site longitude (degrees)\n", s_longitude*(180/PI)); |
240 |
printf("-m %f\t\t\t# Standard meridian (degrees)\n", s_meridian*(180/PI)); |
241 |
242 |
243 |
244 |
userror(msg) /* print usage error and quit */ |
245 |
char *msg; |
246 |
247 |
if (msg != NULL) |
248 |
fprintf(stderr, "%s: Use error - %s\n", progname, msg); |
249 |
fprintf(stderr, "Usage: %s month day hour [options]\n", progname); |
250 |
fprintf(stderr, " Or: %s -ang altitude azimuth [options]\n", progname); |
251 |
fprintf(stderr, " Or: %s -defaults\n", progname); |
252 |
exit(1); |
253 |
254 |
255 |
256 |
double |
257 |
normsc(theta) /* compute normalization factor (E0*F2/L0) */ |
258 |
double theta; |
259 |
260 |
static double nf[5] = {2.766521, 0.547665, |
261 |
-0.369832, 0.009237, 0.059229}; |
262 |
double x, nsc; |
263 |
register int i; |
264 |
/* polynomial approximation */ |
265 |
x = (theta - PI/4.0)/(PI/4.0); |
266 |
nsc = nf[4]; |
267 |
for (i = 3; i >= 0; i--) |
268 |
nsc = nsc*x + nf[i]; |
269 |
270 |
return(nsc); |
271 |
272 |
273 |
274 |
printhead(ac, av) /* print command header */ |
275 |
register int ac; |
276 |
register char **av; |
277 |
278 |
putchar('#'); |
279 |
while (ac--) { |
280 |
putchar(' '); |
281 |
fputs(*av++, stdout); |
282 |
283 |
putchar('\n'); |
284 |
