--- ray/src/gen/gensky.c 2003/11/16 10:29:38 2.22 +++ ray/src/gen/gensky.c 2023/03/30 20:19:05 2.29 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: gensky.c,v 2.22 2003/11/16 10:29:38 schorsch Exp $"; +static const char RCSid[] = "$Id: gensky.c,v 2.29 2023/03/30 20:19:05 greg Exp $"; #endif /* * gensky.c - program to generate sky functions. @@ -10,20 +10,13 @@ static const char RCSid[] = "$Id: gensky.c,v 2.22 2003 * 3/26/86 */ -#include +#include "rtio.h" #include -#include #include #include - +#include "sun.h" #include "color.h" -extern int jdate(int month, int day); -extern double stadj(int jd); -extern double sdec(int jd); -extern double salt(double sd, double st); -extern double sazi(double sd, double st); - #ifndef PI #define PI 3.14159265358979323846 #endif @@ -38,10 +31,6 @@ extern double sazi(double sd, double st); #define overcast ((skytype==S_OVER)|(skytype==S_UNIF)) double normsc(); - /* sun calculation constants */ -extern double s_latitude; -extern double s_longitude; -extern double s_meridian; #undef toupper #define toupper(c) ((c) & ~0x20) /* ASCII trick to convert case */ @@ -69,6 +58,7 @@ struct { {"", 0} }; /* required values */ +int year = 0; /* year (optional) */ int month, day; /* date */ double hour; /* time */ int tsolar; /* 0=standard, 1=solar */ @@ -78,7 +68,7 @@ int skytype = S_CLEAR; /* sky type */ int dosun = 1; double zenithbr = 0.0; int u_zenith = 0; /* -1=irradiance, 1=radiance */ -double turbidity = 2.75; +double turbidity = 2.45; double gprefl = 0.2; /* computed values */ double sundir[3]; @@ -95,15 +85,16 @@ void printsky(void); void printdefaults(void); void userror(char *msg); double normsc(void); -void cvthour(char *hs); -void printhead(register int ac, register char **av); +int cvthour(char *hs); int -main(argc, argv) -int argc; -char *argv[]; +main( + int argc, + char *argv[] +) { + int got_meridian = 0; int i; progname = argv[0]; @@ -124,7 +115,7 @@ char *argv[]; day = atoi(argv[2]); if (day < 1 || day > 31) userror("bad day"); - cvthour(argv[3]); + got_meridian = cvthour(argv[3]); } for (i = 4; i < argc; i++) if (argv[i][0] == '-' || argv[i][0] == '+') @@ -133,6 +124,9 @@ char *argv[]; skytype = S_CLEAR; dosun = argv[i][0] == '+'; break; + case 'y': + year = atoi(argv[++i]); + break; case 'r': case 'R': u_solar = argv[i][1]=='R' ? -1 : 1; @@ -166,6 +160,10 @@ char *argv[]; s_longitude = atof(argv[++i]) * (PI/180); break; case 'm': + if (got_meridian) { + ++i; + break; /* time overrides */ + } s_meridian = atof(argv[++i]) * (PI/180); break; default: @@ -175,12 +173,17 @@ char *argv[]; else userror("bad option"); - if (fabs(s_meridian-s_longitude) > 45*PI/180) + if (year && (year < 1950) | (year > 2050)) fprintf(stderr, - "%s: warning: %.1f hours btwn. standard meridian and longitude\n", + "%s: warning - year should be in range 1950-2050\n", + progname); + if (month && !tsolar && fabs(s_meridian-s_longitude) > 45*PI/180) + fprintf(stderr, + "%s: warning - %.1f hours btwn. standard meridian and longitude\n", progname, (s_longitude-s_meridian)*12/PI); - printhead(argc, argv); + fputs("# ", stdout); + printargs(argc, argv, stdout); computesky(); printsky(); @@ -195,15 +198,20 @@ computesky(void) /* compute sky parameters */ double normfactor; /* compute solar direction */ if (month) { /* from date and time */ - int jd; - double sd, st; + double sd, st = hour; - jd = jdate(month, day); /* Julian date */ - sd = sdec(jd); /* solar declination */ - if (tsolar) /* solar time */ - st = hour; - else - st = hour + stadj(jd); + if (year) { /* Michalsky algorithm? */ + double mjd = mjdate(year, month, day, hour); + if (tsolar) + sd = msdec(mjd, NULL); + else + sd = msdec(mjd, &st); + } else { + int jd = jdate(month, day); /* Julian date */ + sd = sdec(jd); /* solar declination */ + if (!tsolar) /* get solar time? */ + st = hour + stadj(jd); + } altitude = salt(sd, st); azimuth = sazi(sd, st); printf("# Local solar time: %.2f\n", st); @@ -281,7 +289,7 @@ printsky(void) /* print out sky */ if (dosun) { printf("\nvoid light solar\n"); printf("0\n0\n"); - printf("3 %.2e %.2e %.2e\n", solarbr, solarbr, solarbr); + printf("3 %.3e %.3e %.3e\n", solarbr, solarbr, solarbr); printf("\nsolar source sun\n"); printf("0\n0\n"); printf("4 %f %f %f 0.5\n", sundir[0], sundir[1], sundir[2]); @@ -291,9 +299,9 @@ printsky(void) /* print out sky */ printf("2 skybr skybright.cal\n"); printf("0\n"); if (overcast) - printf("3 %d %.2e %.2e\n", skytype, zenithbr, groundbr); + printf("3 %d %.3e %.3e\n", skytype, zenithbr, groundbr); else - printf("7 %d %.2e %.2e %.2e %f %f %f\n", + printf("7 %d %.3e %.3e %.3e %f %f %f\n", skytype, zenithbr, groundbr, F2, sundir[0], sundir[1], sundir[2]); } @@ -356,9 +364,9 @@ normsc(void) /* compute normalization factor (E0*F2/ /* intermediate sky approx. */ {3.5556, -2.7152, -1.3081, 1.0660, 0.60227}, }; - register double *nf; + double *nf; double x, nsc; - register int i; + int i; /* polynomial approximation */ nf = nfc[skytype==S_INTER]; x = (altitude - PI/4.0)/(PI/4.0); @@ -370,13 +378,13 @@ normsc(void) /* compute normalization factor (E0*F2/ } -void +int cvthour( /* convert hour string */ char *hs ) { - register char *cp = hs; - register int i, j; + char *cp = hs; + int i, j; if ( (tsolar = *cp == '+') ) cp++; /* solar time? */ while (isdigit(*cp)) cp++; @@ -388,7 +396,7 @@ cvthour( /* convert hour string */ } while (isdigit(*cp)) cp++; if (!*cp) - return; + return(0); if (tsolar || !isalpha(*cp)) { fprintf(stderr, "%s: bad time format: %s\n", progname, hs); exit(1); @@ -400,7 +408,7 @@ cvthour( /* convert hour string */ break; if (!cp[j] && !tzone[i].zname[j]) { s_meridian = tzone[i].zmer * (PI/180); - return; + return(1); } } while (tzone[i++].zname[0]); @@ -410,19 +418,4 @@ cvthour( /* convert hour string */ fprintf(stderr, " %s", tzone[i].zname); putc('\n', stderr); exit(1); -} - - -void -printhead( /* print command header */ - register int ac, - register char **av -) -{ - putchar('#'); - while (ac--) { - putchar(' '); - fputs(*av++, stdout); - } - putchar('\n'); }
