root/radiance/ray/src/gen/gensky.c
Revision: 2.2
Committed: Thu Dec 19 15:09:28 1991 UTC (33 years, 6 months ago) by greg
1 /* Copyright (c) 1986 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * gensky.c - program to generate sky functions.
9 * Our zenith is along the Z-axis, the X-axis
10 * points east, and the Y-axis points north.
11 * Radiance is in watts/steradian/sq. meter.
12 *
13 * 3/26/86
14 */
15
16 #include <stdio.h>
17
18 #include <math.h>
19
20 #include "color.h"
21
22 #ifndef atof
23 extern double atof();
24 #endif
25 extern char *strcpy(), *strcat(), *malloc();
26 extern double stadj(), sdec(), sazi(), salt();
27
28 #define PI 3.141592654
29
30 #define DOT(v1,v2) (v1[0]*v2[0]+v1[1]*v2[1]+v1[2]*v2[2])
31
32 double normsc();
33 /* sun calculation constants */
34 extern double s_latitude;
35 extern double s_longitude;
36 extern double s_meridian;
37 /* required values */
38 int month, day;
39 double hour;
40 /* default values */
41 int cloudy = 0;
42 int dosun = 1;
43 double zenithbr = -1.0;
44 double turbidity = 2.75;
45 double gprefl = 0.2;
46 /* computed values */
47 double sundir[3];
48 double groundbr;
49 double F2;
50 double solarbr;
51
52 char *progname;
53 char errmsg[128];
54
55
56 main(argc, argv)
57 int argc;
58 char *argv[];
59 {
60 extern double fabs();
61 int i;
62
63 progname = argv[0];
64 if (argc == 2 && !strcmp(argv[1], "-defaults")) {
65 printdefaults();
66 exit(0);
67 }
68 if (argc < 4)
69 userror("arg count");
70 month = atoi(argv[1]);
71 day = atoi(argv[2]);
72 hour = atof(argv[3]);
73 for (i = 4; i < argc; i++)
74 if (argv[i][0] == '-' || argv[i][0] == '+')
75 switch (argv[i][1]) {
76 case 's':
77 cloudy = 0;
78 dosun = argv[i][0] == '+';
79 break;
80 case 'c':
81 cloudy = 1;
82 dosun = 0;
83 break;
84 case 't':
85 turbidity = atof(argv[++i]);
86 break;
87 case 'b':
88 zenithbr = atof(argv[++i]);
89 break;
90 case 'g':
91 gprefl = atof(argv[++i]);
92 break;
93 case 'a':
94 s_latitude = atof(argv[++i]) * (PI/180);
95 break;
96 case 'o':
97 s_longitude = atof(argv[++i]) * (PI/180);
98 break;
99 case 'm':
100 s_meridian = atof(argv[++i]) * (PI/180);
101 break;
102 default:
103 sprintf(errmsg, "unknown option: %s", argv[i]);
104 userror(errmsg);
105 }
106 else
107 userror("bad option");
108
109 if (fabs(s_meridian-s_longitude) > 30*PI/180)
110 fprintf(stderr,
111 "%s: warning: %.1f hours btwn. standard meridian and longitude\n",
112 progname, (s_longitude-s_meridian)*12/PI);
113
114 printhead(argc, argv);
115
116 computesky();
117 printsky();
118 }
119
120
121 computesky() /* compute sky parameters */
122 {
123 int jd;
124 double sd, st;
125 double altitude, azimuth;
126 /* compute solar direction */
127 jd = jdate(month, day); /* Julian date */
128 sd = sdec(jd); /* solar declination */
129 st = hour + stadj(jd); /* solar time */
130 altitude = salt(sd, st);
131 azimuth = sazi(sd, st);
132 sundir[0] = -sin(azimuth)*cos(altitude);
133 sundir[1] = -cos(azimuth)*cos(altitude);
134 sundir[2] = sin(altitude);
135
136 /* Compute zenith brightness */
137 if (zenithbr <= 0.0)
138 if (cloudy) {
139 zenithbr = 8.6*sundir[2] + .123;
140 zenithbr *= 1000.0/SKYEFFICACY;
141 } else {
142 zenithbr = (1.376*turbidity-1.81)*tan(altitude)+0.38;
143 zenithbr *= 1000.0/SKYEFFICACY;
144 }
145 if (zenithbr < 0.0)
146 zenithbr = 0.0;
147 /* Compute horizontal radiance */
148 if (cloudy) {
149 groundbr = zenithbr*0.777778;
150 printf("# Ground ambient level: %f\n", groundbr);
151 } else {
152 F2 = 0.274*(0.91 + 10.0*exp(-3.0*(PI/2.0-altitude)) +
153 0.45*sundir[2]*sundir[2]);
154 groundbr = zenithbr*normsc(PI/2.0-altitude)/F2/PI;
155 printf("# Ground ambient level: %f\n", groundbr);
156 if (sundir[2] > 0.0) {
157 if (sundir[2] > .16)
158 solarbr = (1.5e9/SUNEFFICACY) *
159 (1.147 - .147/sundir[2]);
160 else
161 solarbr = 1.5e9/SUNEFFICACY*(1.147-.147/.16);
162 groundbr += solarbr*6e-5*sundir[2]/PI;
163 } else
164 dosun = 0;
165 }
166 groundbr *= gprefl;
167 }
168
169
170 printsky() /* print out sky */
171 {
172 if (dosun) {
173 printf("\nvoid light solar\n");
174 printf("0\n0\n");
175 printf("3 %.2e %.2e %.2e\n", solarbr, solarbr, solarbr);
176 printf("\nsolar source sun\n");
177 printf("0\n0\n");
178 printf("4 %f %f %f 0.5\n", sundir[0], sundir[1], sundir[2]);
179 }
180
181 printf("\nvoid brightfunc skyfunc\n");
182 printf("2 skybright skybright.cal\n");
183 printf("0\n");
184 if (cloudy)
185 printf("3 1 %.2e %.2e\n", zenithbr, groundbr);
186 else
187 printf("7 -1 %.2e %.2e %.2e %f %f %f\n", zenithbr, groundbr,
188 F2, sundir[0], sundir[1], sundir[2]);
189 }
190
191
192 printdefaults() /* print default values */
193 {
194 if (cloudy)
195 printf("-c\t\t\t\t# Cloudy sky\n");
196 else if (dosun)
197 printf("+s\t\t\t\t# Sunny sky with sun\n");
198 else
199 printf("-s\t\t\t\t# Sunny sky without sun\n");
200 printf("-g %f\t\t\t# Ground plane reflectance\n", gprefl);
201 if (zenithbr > 0.0)
202 printf("-b %f\t\t\t# Zenith radiance (watts/ster/m2\n", zenithbr);
203 else
204 printf("-t %f\t\t\t# Atmospheric turbidity\n", turbidity);
205 printf("-a %f\t\t\t# Site latitude (degrees)\n", s_latitude*(180/PI));
206 printf("-o %f\t\t\t# Site longitude (degrees)\n", s_longitude*(180/PI));
207 printf("-m %f\t\t\t# Standard meridian (degrees)\n", s_meridian*(180/PI));
208 }
209
210
211 userror(msg) /* print usage error and quit */
212 char *msg;
213 {
214 if (msg != NULL)
215 fprintf(stderr, "%s: Use error - %s\n", progname, msg);
216 fprintf(stderr, "Usage: %s month day hour [options]\n", progname);
217 fprintf(stderr, " Or: %s -defaults\n", progname);
218 exit(1);
219 }
220
221
222 double
223 normsc(theta) /* compute normalization factor (E0*F2/L0) */
224 double theta;
225 {
226 static double nf[5] = {2.766521, 0.547665,
227 -0.369832, 0.009237, 0.059229};
228 double x, nsc;
229 register int i;
230 /* polynomial approximation */
231 x = (theta - PI/4.0)/(PI/4.0);
232 nsc = nf[4];
233 for (i = 3; i >= 0; i--)
234 nsc = nsc*x + nf[i];
235
236 return(nsc);
237 }
238
239
240 printhead(ac, av) /* print command header */
241 register int ac;
242 register char **av;
243 {
244 putchar('#');
245 while (ac--) {
246 putchar(' ');
247 fputs(*av++, stdout);
248 }
249 putchar('\n');
250 }
