root/radiance/ray/src/gen/gensky.c
Revision: 1.6
Committed: Thu Oct 24 13:43:22 1991 UTC (33 years, 8 months ago) by greg
Changes since 1.5: +10 -8 lines
changed factors for solar and sky luminance to radiance
1 /* Copyright (c) 1986 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * gensky.c - program to generate sky functions.
9 * Our zenith is along the Z-axis, the X-axis
10 * points east, and the Y-axis points north.
11 * Radiance is in watts/steradian/sq. meter.
12 *
13 * 3/26/86
14 */
15
16 #include <stdio.h>
17
18 #include <math.h>
19
20 #include "color.h"
21
22 extern char *strcpy(), *strcat(), *malloc();
23 extern double stadj(), sdec(), sazi(), salt();
24
25 #define PI 3.141592654
26
27 #define DOT(v1,v2) (v1[0]*v2[0]+v1[1]*v2[1]+v1[2]*v2[2])
28
29 double normsc();
30 /* sun calculation constants */
31 extern double s_latitude;
32 extern double s_longitude;
33 extern double s_meridian;
34 /* required values */
35 int month, day;
36 double hour;
37 /* default values */
38 int cloudy = 0;
39 int dosun = 1;
40 double zenithbr = -1.0;
41 double turbidity = 2.75;
42 double gprefl = 0.2;
43 /* computed values */
44 double sundir[3];
45 double groundbr;
46 double F2;
47 double solarbr;
48
49 char *progname;
50 char errmsg[128];
51
52
53 main(argc, argv)
54 int argc;
55 char *argv[];
56 {
57 extern double atof(), fabs();
58 int i;
59
60 progname = argv[0];
61 if (argc == 2 && !strcmp(argv[1], "-defaults")) {
62 printdefaults();
63 exit(0);
64 }
65 if (argc < 4)
66 userror("arg count");
67 month = atoi(argv[1]);
68 day = atoi(argv[2]);
69 hour = atof(argv[3]);
70 for (i = 4; i < argc; i++)
71 if (argv[i][0] == '-' || argv[i][0] == '+')
72 switch (argv[i][1]) {
73 case 's':
74 cloudy = 0;
75 dosun = argv[i][0] == '+';
76 break;
77 case 'c':
78 cloudy = 1;
79 dosun = 0;
80 break;
81 case 't':
82 turbidity = atof(argv[++i]);
83 break;
84 case 'b':
85 zenithbr = atof(argv[++i]);
86 break;
87 case 'g':
88 gprefl = atof(argv[++i]);
89 break;
90 case 'a':
91 s_latitude = atof(argv[++i]) * (PI/180);
92 break;
93 case 'o':
94 s_longitude = atof(argv[++i]) * (PI/180);
95 break;
96 case 'm':
97 s_meridian = atof(argv[++i]) * (PI/180);
98 break;
99 default:
100 sprintf(errmsg, "unknown option: %s", argv[i]);
101 userror(errmsg);
102 }
103 else
104 userror("bad option");
105
106 if (fabs(s_meridian-s_longitude) > 30*PI/180)
107 fprintf(stderr,
108 "%s: warning: %.1f hours btwn. standard meridian and longitude\n",
109 progname, (s_longitude-s_meridian)*12/PI);
110
111 printhead(argc, argv);
112
113 computesky();
114 printsky();
115 }
116
117
118 computesky() /* compute sky parameters */
119 {
120 int jd;
121 double sd, st;
122 double altitude, azimuth;
123 /* compute solar direction */
124 jd = jdate(month, day); /* Julian date */
125 sd = sdec(jd); /* solar declination */
126 st = hour + stadj(jd); /* solar time */
127 altitude = salt(sd, st);
128 azimuth = sazi(sd, st);
129 sundir[0] = -sin(azimuth)*cos(altitude);
130 sundir[1] = -cos(azimuth)*cos(altitude);
131 sundir[2] = sin(altitude);
132
133 /* Compute zenith brightness */
134 if (zenithbr <= 0.0)
135 if (cloudy) {
136 zenithbr = 8.6*sundir[2] + .123;
137 zenithbr *= 1000.0/SKYEFFICACY;
138 } else {
139 zenithbr = (1.376*turbidity-1.81)*tan(altitude)+0.38;
140 zenithbr *= 1000.0/SKYEFFICACY;
141 }
142 if (zenithbr < 0.0)
143 zenithbr = 0.0;
144 /* Compute horizontal radiance */
145 if (cloudy) {
146 groundbr = zenithbr*0.777778;
147 printf("# Ground ambient level: %f\n", groundbr);
148 } else {
149 F2 = 0.274*(0.91 + 10.0*exp(-3.0*(PI/2.0-altitude)) +
150 0.45*sundir[2]*sundir[2]);
151 groundbr = zenithbr*normsc(PI/2.0-altitude)/F2/PI;
152 printf("# Ground ambient level: %f\n", groundbr);
153 if (sundir[2] > 0.0) {
154 if (sundir[2] > .16)
155 solarbr = (1.5e9/SUNEFFICACY) *
156 (1.147 - .147/sundir[2]);
157 else
158 solarbr = 1.5e9/SUNEFFICACY*(1.147-.147/.16);
159 groundbr += solarbr*6e-5*sundir[2]/PI;
160 } else
161 dosun = 0;
162 }
163 groundbr *= gprefl;
164 }
165
166
167 printsky() /* print out sky */
168 {
169 if (dosun) {
170 printf("\nvoid light solar\n");
171 printf("0\n0\n");
172 printf("3 %.2e %.2e %.2e\n", solarbr, solarbr, solarbr);
173 printf("\nsolar source sun\n");
174 printf("0\n0\n");
175 printf("4 %f %f %f 0.5\n", sundir[0], sundir[1], sundir[2]);
176 }
177
178 printf("\nvoid brightfunc skyfunc\n");
179 printf("2 skybright skybright.cal\n");
180 printf("0\n");
181 if (cloudy)
182 printf("3 1 %.2e %.2e\n", zenithbr, groundbr);
183 else
184 printf("7 -1 %.2e %.2e %.2e %f %f %f\n", zenithbr, groundbr,
185 F2, sundir[0], sundir[1], sundir[2]);
186 }
187
188
189 printdefaults() /* print default values */
190 {
191 if (cloudy)
192 printf("-c\t\t\t\t# Cloudy sky\n");
193 else if (dosun)
194 printf("+s\t\t\t\t# Sunny sky with sun\n");
195 else
196 printf("-s\t\t\t\t# Sunny sky without sun\n");
197 printf("-g %f\t\t\t# Ground plane reflectance\n", gprefl);
198 if (zenithbr > 0.0)
199 printf("-b %f\t\t\t# Zenith radiance (watts/ster/m2\n", zenithbr);
200 else
201 printf("-t %f\t\t\t# Atmospheric turbidity\n", turbidity);
202 printf("-a %f\t\t\t# Site latitude (degrees)\n", s_latitude*(180/PI));
203 printf("-o %f\t\t\t# Site longitude (degrees)\n", s_longitude*(180/PI));
204 printf("-m %f\t\t\t# Standard meridian (degrees)\n", s_meridian*(180/PI));
205 }
206
207
208 userror(msg) /* print usage error and quit */
209 char *msg;
210 {
211 if (msg != NULL)
212 fprintf(stderr, "%s: Use error - %s\n", progname, msg);
213 fprintf(stderr, "Usage: %s month day hour [options]\n", progname);
214 fprintf(stderr, " Or: %s -defaults\n", progname);
215 exit(1);
216 }
217
218
219 double
220 normsc(theta) /* compute normalization factor (E0*F2/L0) */
221 double theta;
222 {
223 static double nf[5] = {2.766521, 0.547665,
224 -0.369832, 0.009237, 0.059229};
225 double x, nsc;
226 register int i;
227 /* polynomial approximation */
228 x = (theta - PI/4.0)/(PI/4.0);
229 nsc = nf[4];
230 for (i = 3; i >= 0; i--)
231 nsc = nsc*x + nf[i];
232
233 return(nsc);
234 }
235
236
237 printhead(ac, av) /* print command header */
238 register int ac;
239 register char **av;
240 {
241 putchar('#');
242 while (ac--) {
243 putchar(' ');
244 fputs(*av++, stdout);
245 }
246 putchar('\n');
247 }
