root/radiance/ray/src/gen/gensky.c
Revision: 1.5
Committed: Tue Aug 6 08:22:06 1991 UTC (33 years, 10 months ago) by greg
Changes since 1.4: +6 -1 lines
added warning about mismatched standard meridians and longitudes
1 /* Copyright (c) 1986 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * gensky.c - program to generate sky functions.
9 * Our zenith is along the Z-axis, the X-axis
10 * points east, and the Y-axis points north.
11 * Radiance is in watts/steradian/sq. meter.
12 *
13 * 3/26/86
14 */
15
16 #include <stdio.h>
17
18 #include <math.h>
19
20
21 extern char *strcpy(), *strcat(), *malloc();
22 extern double stadj(), sdec(), sazi(), salt();
23
24 #define PI 3.141592654
25
26 #define DOT(v1,v2) (v1[0]*v2[0]+v1[1]*v2[1]+v1[2]*v2[2])
27
28 double normsc();
29 /* sun calculation constants */
30 extern double s_latitude;
31 extern double s_longitude;
32 extern double s_meridian;
33 /* required values */
34 int month, day;
35 double hour;
36 /* default values */
37 int cloudy = 0;
38 int dosun = 1;
39 double zenithbr = -1.0;
40 double turbidity = 2.75;
41 double gprefl = 0.2;
42 /* computed values */
43 double sundir[3];
44 double groundbr;
45 double F2;
46 double solarbr;
47
48 char *progname;
49 char errmsg[128];
50
51
52 main(argc, argv)
53 int argc;
54 char *argv[];
55 {
56 extern double atof(), fabs();
57 int i;
58
59 progname = argv[0];
60 if (argc == 2 && !strcmp(argv[1], "-defaults")) {
61 printdefaults();
62 exit(0);
63 }
64 if (argc < 4)
65 userror("arg count");
66 month = atoi(argv[1]);
67 day = atoi(argv[2]);
68 hour = atof(argv[3]);
69 for (i = 4; i < argc; i++)
70 if (argv[i][0] == '-' || argv[i][0] == '+')
71 switch (argv[i][1]) {
72 case 's':
73 cloudy = 0;
74 dosun = argv[i][0] == '+';
75 break;
76 case 'c':
77 cloudy = 1;
78 dosun = 0;
79 break;
80 case 't':
81 turbidity = atof(argv[++i]);
82 break;
83 case 'b':
84 zenithbr = atof(argv[++i]);
85 break;
86 case 'g':
87 gprefl = atof(argv[++i]);
88 break;
89 case 'a':
90 s_latitude = atof(argv[++i]) * (PI/180);
91 break;
92 case 'o':
93 s_longitude = atof(argv[++i]) * (PI/180);
94 break;
95 case 'm':
96 s_meridian = atof(argv[++i]) * (PI/180);
97 break;
98 default:
99 sprintf(errmsg, "unknown option: %s", argv[i]);
100 userror(errmsg);
101 }
102 else
103 userror("bad option");
104
105 if (fabs(s_meridian-s_longitude) > 30*PI/180)
106 fprintf(stderr,
107 "%s: warning: %.1f hours btwn. standard meridian and longitude\n",
108 progname, (s_longitude-s_meridian)*12/PI);
109
110 printhead(argc, argv);
111
112 computesky();
113 printsky();
114 }
115
116
117 computesky() /* compute sky parameters */
118 {
119 int jd;
120 double sd, st;
121 double altitude, azimuth;
122 /* compute solar direction */
123 jd = jdate(month, day); /* Julian date */
124 sd = sdec(jd); /* solar declination */
125 st = hour + stadj(jd); /* solar time */
126 altitude = salt(sd, st);
127 azimuth = sazi(sd, st);
128 sundir[0] = -sin(azimuth)*cos(altitude);
129 sundir[1] = -cos(azimuth)*cos(altitude);
130 sundir[2] = sin(altitude);
131
132 /* Compute zenith brightness */
133 if (zenithbr <= 0.0)
134 if (cloudy) {
135 zenithbr = 8.6*sundir[2] + .123;
136 zenithbr *= 1000.0*.0064/3.;
137 } else {
138 zenithbr = (1.376*turbidity-1.81)*tan(altitude)+0.38;
139 zenithbr *= 1000.0*.0064/3.;
140 }
141 if (zenithbr < 0.0)
142 zenithbr = 0.0;
143 /* Compute horizontal radiance */
144 if (cloudy) {
145 groundbr = zenithbr*0.777778;
146 printf("# Ground ambient level: %f\n", groundbr);
147 } else {
148 F2 = 0.274*(0.91 + 10.0*exp(-3.0*(PI/2.0-altitude)) +
149 0.45*sundir[2]*sundir[2]);
150 groundbr = zenithbr*normsc(PI/2.0-altitude)/F2/PI;
151 printf("# Ground ambient level: %f\n", groundbr);
152 if (sundir[2] > 0.0) {
153 if (sundir[2] > .16)
154 solarbr = 2.47e6 - 3.15e5/sundir[2];
155 else
156 solarbr = 5e5;
157 groundbr += solarbr*6e-5*sundir[2]/PI;
158 } else
159 dosun = 0;
160 }
161 groundbr *= gprefl;
162 }
163
164
165 printsky() /* print out sky */
166 {
167 if (dosun) {
168 printf("\nvoid light solar\n");
169 printf("0\n0\n");
170 printf("3 %f %f %f\n", solarbr, solarbr, solarbr);
171 printf("\nsolar source sun\n");
172 printf("0\n0\n");
173 printf("4 %f %f %f 0.5\n", sundir[0], sundir[1], sundir[2]);
174 }
175
176 printf("\nvoid brightfunc skyfunc\n");
177 printf("2 skybright skybright.cal\n");
178 printf("0\n");
179 if (cloudy)
180 printf("3 1 %f %f\n", zenithbr, groundbr);
181 else
182 printf("7 -1 %f %f %f %f %f %f\n", zenithbr, groundbr, F2,
183 sundir[0], sundir[1], sundir[2]);
184 }
185
186
187 printdefaults() /* print default values */
188 {
189 if (cloudy)
190 printf("-c\t\t\t\t# Cloudy sky\n");
191 else if (dosun)
192 printf("+s\t\t\t\t# Sunny sky with sun\n");
193 else
194 printf("-s\t\t\t\t# Sunny sky without sun\n");
195 printf("-g %f\t\t\t# Ground plane reflectance\n", gprefl);
196 if (zenithbr > 0.0)
197 printf("-b %f\t\t\t# Zenith radiance (watts/ster/m2\n", zenithbr);
198 else
199 printf("-t %f\t\t\t# Atmospheric turbidity\n", turbidity);
200 printf("-a %f\t\t\t# Site latitude (degrees)\n", s_latitude*(180/PI));
201 printf("-o %f\t\t\t# Site longitude (degrees)\n", s_longitude*(180/PI));
202 printf("-m %f\t\t\t# Standard meridian (degrees)\n", s_meridian*(180/PI));
203 }
204
205
206 userror(msg) /* print usage error and quit */
207 char *msg;
208 {
209 if (msg != NULL)
210 fprintf(stderr, "%s: Use error - %s\n", progname, msg);
211 fprintf(stderr, "Usage: %s month day hour [options]\n", progname);
212 fprintf(stderr, " Or: %s -defaults\n", progname);
213 exit(1);
214 }
215
216
217 double
218 normsc(theta) /* compute normalization factor (E0*F2/L0) */
219 double theta;
220 {
221 static double nf[5] = {2.766521, 0.547665,
222 -0.369832, 0.009237, 0.059229};
223 double x, nsc;
224 register int i;
225 /* polynomial approximation */
226 x = (theta - PI/4.0)/(PI/4.0);
227 nsc = nf[4];
228 for (i = 3; i >= 0; i--)
229 nsc = nsc*x + nf[i];
230
231 return(nsc);
232 }
233
234
235 printhead(ac, av) /* print command header */
236 register int ac;
237 register char **av;
238 {
239 putchar('#');
240 while (ac--) {
241 putchar(' ');
242 fputs(*av++, stdout);
243 }
244 putchar('\n');
245 }
