root/Development/ray/src/gen/gensdaymtx.c
Revision: 1.7
Committed: Fri Jun 6 19:11:21 2025 UTC (5 months ago) by greg
refactor: Making use of printargs() more consistent with fixargv0()
2 static const char RCSid[] = "$Id: gensdaymtx.c,v 1.6 2025/04/15 20:15:50 greg Exp $";
4
5 #include <stdlib.h>
6 #include <ctype.h>
7 #ifdef _WIN32
8 #include <windows.h>
9 #else
10 #include <errno.h>
11 #include <sys/stat.h>
12 #include <sys/types.h>
13 #endif
14
15 #include "atmos.h"
16 #include "copyright.h"
17 #include "data.h"
18 #include "paths.h"
19 #include "platform.h"
20 #include "rtio.h"
21 #include "rtmath.h"
22 #include "sun.h"
23 #include "loadEPW.h"
24
25
26 const double SUN_ANG_DEG = 0.533; /* sun full-angle in degrees */
27 const double ARCTIC_LAT = 67.;
28 const double TROPIC_LAT = 23.;
29 const int SUMMER_START = 4;
30 const int SUMMER_END = 9;
31 const double GNORM = 0.777778;
32
33 /* Mean normalized relative daylight spectra where CCT = 6415K for overcast */
34 const double D6415[NSSAMP] = {
35 0.63231, 1.06171, 1.00779, 1.36423, 1.34133,
36 1.27258, 1.26276, 1.26352, 1.22201, 1.13246,
37 1.0434, 1.05547, 0.98212, 0.94445, 0.9722,
38 0.82387, 0.87853, 0.82559, 0.75111, 0.78925};
39
40 enum {
41 NSUNPATCH = 4 /* max. # patches to spread sun into */
42 };
43
44 double altitude; /* Solar altitude (radians) */
45 double azimuth; /* Solar azimuth (radians) */
46 int julian_date; /* Julian date */
47 double sun_zenith; /* Sun zenith angle (radians) */
48 int nskypatch; /* number of Reinhart patches */
49 float *rh_palt; /* sky patch altitudes (radians) */
50 float *rh_pazi; /* sky patch azimuths (radians) */
51 float *rh_dom; /* sky patch solid angle (sr) */
52 FVECT sundir;
53 double sun_ct; /* cos(theta) of sun altitude angle */
54
55 int input = 0; /* Input type */
56 int output = 0; /* Output type */
57 int nsuns = NSUNPATCH; /* number of sun patches to use */
58 double fixed_sun_sa = -1; /* fixed solid angle per sun? */
59 int verbose = 0; /* progress reports to stderr? */
60 int outfmt = 'a'; /* output format */
61 int rhsubdiv = 1; /* Reinhart sky subdivisions */
62 COLOR skycolor = {.96, 1.004, 1.118}; /* sky coloration */
63 COLOR suncolor = {1., 1., 1.}; /* sun color */
64 double grefl = .2; /* ground reflectance */
65
66
67 static inline double deg_to_rad(double deg)
68 {
69 return deg * (PI / 180.);
70 }
71
72 static inline double rad_to_deg(double rad)
73 {
74 return rad * (180. / PI);
75 }
76
77 static inline void vectorize(double altitude, double azimuth, FVECT v)
78 {
79 v[1] = cos(altitude);
80 v[0] = (v)[1] * sin(azimuth);
81 v[1] *= cos(azimuth);
82 v[2] = sin(altitude);
83 }
84
85 static inline double wmean2(const double a, const double b, const double x)
86 {
87 return a * (1 - x) + b * x;
88 }
89
90 static inline double wmean(
91 const double a, const double x,
92 const double b, const double y)
93 {
94 return (a * x + b * y) / (a + b);
95 }
96
97 static int make_directory(const char *path)
98 {
99 #ifdef _WIN32
100 if (CreateDirectory(path, NULL) || GetLastError() == ERROR_ALREADY_EXISTS) {
101 return 1;
102 }
103 return 0;
104 #else
105 if (mkdir(path, 0777) == 0 || errno == EEXIST) {
106 return 1;
107 }
108 return 0;
109 #endif
110 }
111
112 static const char *getfmtname(int fmt)
113 {
114 switch (fmt) {
115 case 'a':
116 return ("ascii");
117 case 'f':
118 return ("float");
119 case 'd':
120 return ("double");
121 }
122 return ("unknown");
123 }
124
125
126 static double get_overcast_zenith_brightness(const double sundir[3])
127 {
128 double zenithbr;
129 if (sundir[2] < 0) {
130 zenithbr = 0;
131 } else {
132 zenithbr = (8.6 * sundir[2] + .123) * 1000.0 / D65EFFICACY;
133 }
134 return zenithbr;
135 }
136
137
138 /* from gensky.c */
139 static double get_overcast_brightness(const double dz, const double zenithbr)
140 {
141 double groundbr = zenithbr * GNORM;
142 return wmean(pow(dz + 1.01, 10),
143 zenithbr * (1 + 2 * dz) / 3,
144 pow(dz + 1.01, -10), groundbr);
145 }
146
147 double solar_sunset(int month, int day)
148 {
149 float W;
150 W = -1 * (tan(s_latitude) * tan(sdec(jdate(month, day))));
151 return 12 + (PI / 2 - atan2(W, sqrt(1 - W * W))) * 180 / (PI * 15);
152 }
153
154
155 double solar_sunrise(int month, int day)
156 {
157 float W;
158 W = -1 * (tan(s_latitude) * tan(sdec(jdate(month, day))));
159 return 12 - (PI / 2 - atan2(W, sqrt(1 - W * W))) * 180 / (PI * 15);
160 }
161
162 int rh_init(void)
163 {
164 #define NROW 7
165 static const int tnaz[NROW] = {30, 30, 24, 24, 18, 12, 6};
166 const double alpha = (PI / 2.) / (NROW * rhsubdiv + .5);
167 int p, i, j;
168 /* allocate patch angle arrays */
169 nskypatch = 0;
170 for (p = 0; p < NROW; p++)
171 nskypatch += tnaz[p];
172 nskypatch *= rhsubdiv * rhsubdiv;
173 nskypatch += 2;
174 rh_palt = (float *)malloc(sizeof(float) * nskypatch);
175 rh_pazi = (float *)malloc(sizeof(float) * nskypatch);
176 rh_dom = (float *)malloc(sizeof(float) * nskypatch);
177 if ((rh_palt == NULL) | (rh_pazi == NULL) | (rh_dom == NULL)) {
178 fprintf(stderr, "%s: out of memory in rh_init()\n", progname);
179 exit(1);
180 }
181 rh_palt[0] = -PI / 2.; /* ground & zenith patches */
182 rh_pazi[0] = 0.;
183 rh_dom[0] = 2. * PI;
184 rh_palt[nskypatch - 1] = PI / 2.;
185 rh_pazi[nskypatch - 1] = 0.;
186 rh_dom[nskypatch - 1] = 2. * PI * (1. - cos(alpha * .5));
187 p = 1; /* "normal" patches */
188 for (i = 0; i < NROW * rhsubdiv; i++) {
189 const float ralt = alpha * (i + .5);
190 const int ninrow = tnaz[i / rhsubdiv] * rhsubdiv;
191 const float dom =
192 2. * PI * (sin(alpha * (i + 1)) - sin(alpha * i)) / (double)ninrow;
193 for (j = 0; j < ninrow; j++) {
194 rh_palt[p] = ralt;
195 rh_pazi[p] = 2. * PI * j / (double)ninrow;
196 rh_dom[p++] = dom;
197 }
198 }
199 return nskypatch;
200 #undef NROW
201 }
202
203 /* Resize daylight matrix (GW) */
204 float *resize_dmatrix(float *mtx_data, int nsteps, int npatch)
205 {
206 if (mtx_data == NULL)
207 mtx_data = (float * ) malloc(sizeof(float) * NSSAMP * nsteps * npatch);
208 else
209 mtx_data = (float * ) realloc(mtx_data,
210 sizeof(float) * NSSAMP * nsteps * npatch);
211 if (mtx_data == NULL) {
212 fprintf(stderr,
213 "%s: out of memory in resize_dmatrix(%d,%d)\n",
214 progname, nsteps, npatch);
215 exit(1);
216 }
217 return mtx_data;
218 }
219
220 static Atmosphere init_atmos(const double aod, const double grefl)
221 {
222 Atmosphere atmos = {
223 .ozone_density = {
224 .layers = {
225 {
226 .width = 25000.0,
227 .exp_term = 0.0,
228 .exp_scale = 0.0,
229 .linear_term = 1.0 / 15000.0,
230 .constant_term = -2.0 / 3.0
231 },
232 {
233 .width = AH,
234 .exp_term = 0.0,
235 .exp_scale = 0.0,
236 .linear_term = -1.0 / 15000.0,
237 .constant_term = 8.0 / 3.0
238 },
239 }
240 },
241 .rayleigh_density = {
242 .layers = {
243 {
244 .width = AH,
245 .exp_term = 1.0,
246 .exp_scale = -1.0 / HR_MS,
247 .linear_term = 0.0,
248 .constant_term = 0.0
249 },
250 }
251 },
252 .beta_r0 = BR0_MS,
253 .beta_scale = aod / AOD0_CA,
254 .beta_m = NULL,
255 .grefl = grefl
256 };
257 return atmos;
258 }
259
260 static DpPaths get_dppaths(const char *dir, const double aod,
261 const char *mname, const char *tag)
262 {
263 DpPaths paths;
264
265 snprintf(paths.tau, PATH_MAX, "%s%ctau_%s_%s_%.2f.dat",
266 dir, DIRSEP, tag, mname, aod);
267 snprintf(paths.scat, PATH_MAX, "%s%cscat_%s_%s_%.2f.dat",
268 dir, DIRSEP, tag, mname, aod);
269 snprintf(paths.scat1m, PATH_MAX, "%s%cscat1m_%s_%s_%.2f.dat",
270 dir, DIRSEP, tag, mname, aod);
271 snprintf(paths.irrad, PATH_MAX, "%s%cirrad_%s_%s_%.2f.dat",
272 dir, DIRSEP, tag, mname, aod);
273
274 return paths;
275 }
276
277
278 static void set_rayleigh_density_profile(Atmosphere *atmos,
279 char *tag, const int is_summer, const double s_latitude)
280 {
281 /* Set rayleigh density profile */
282 if (fabs(s_latitude * 180.0 / PI) > ARCTIC_LAT) {
283 tag[0] = 's';
284 if (is_summer) {
285 tag[1] = 's';
286 atmos->rayleigh_density.layers[0].exp_scale = -1.0 / HR_SS;
287 atmos->beta_r0 = BR0_SS;
288 } else {
289 tag[1] = 'w';
290 atmos->rayleigh_density.layers[0].exp_scale = -1.0 / HR_SW;
291 atmos->beta_r0 = BR0_SW;
292 }
293 } else if (fabs(s_latitude * 180.0 / PI) > TROPIC_LAT) {
294 tag[0] = 'm';
295 if (is_summer) {
296 tag[1] = 's';
297 atmos->rayleigh_density.layers[0].exp_scale = -1.0 / HR_MS;
298 atmos->beta_r0 = BR0_MS;
299 } else {
300 tag[1] = 'w';
301 atmos->rayleigh_density.layers[0].exp_scale = -1.0 / HR_MW;
302 atmos->beta_r0 = BR0_MW;
303 }
304 } else {
305 tag[0] = 't';
306 tag[1] = 'r';
307 atmos->rayleigh_density.layers[0].exp_scale = -1.0 / HR_T;
308 atmos->beta_r0 = BR0_T;
309 }
310 tag[2] = '\0';
311 }
312
313
314 /* Add in solar direct to nearest sky patches (GW) */
315 void add_direct(DATARRAY *tau, DATARRAY *scat, DATARRAY *scat1m, DATARRAY *irrad,
316 double ccover, double dirnorm, float *parr)
317 {
318 FVECT svec;
319 double near_dprod[NSUNPATCH];
320 int near_patch[NSUNPATCH];
321 double wta[NSUNPATCH], wtot;
322 int i, j, p;
323
324 /* identify nsuns closest patches */
325 for (i = nsuns; i--;)
326 near_dprod[i] = -1.;
327 vectorize(altitude, azimuth, svec);
328 for (p = 1; p < nskypatch; p++) {
329 FVECT pvec;
330 double dprod;
331 vectorize(rh_palt[p], rh_pazi[p], pvec);
332 dprod = DOT(pvec, svec);
333 for (i = 0; i < nsuns; i++)
334 if (dprod > near_dprod[i]) {
335 for (j = nsuns; --j > i;) {
336 near_dprod[j] = near_dprod[j - 1];
337 near_patch[j] = near_patch[j - 1];
338 }
339 near_dprod[i] = dprod;
340 near_patch[i] = p;
341 break;
342 }
343 }
344 /* Get solar radiance */
345 double sun_radiance[NSSAMP] = {0};
346 get_solar_radiance(tau, scat, scat1m, sundir, ER, sun_ct, sun_radiance);
347 if (ccover > 0) {
348 double zenithbr = get_overcast_zenith_brightness(sundir);
349 double skybr = get_overcast_brightness(sundir[2], zenithbr);
350 int l;
351 for (l = 0; l < NSSAMP; ++l) {
352 sun_radiance[l] = wmean2(sun_radiance[l], D6415[l] * skybr / WVLSPAN, ccover);
353 }
354 }
355 /* Normalize */
356 double sum = 0.0;
357 for (i = 0; i < NSSAMP; ++i) {
358 sum += sun_radiance[i];
359 }
360 double mean = sum / NSSAMP;
361
362 double intensity = mean * WVLSPAN;
363 if (dirnorm > 0) {
364 intensity = dirnorm / SOLOMG / WHTEFFICACY;
365 }
366 double dir_ratio = 1.;
367 if (mean > 0)
368 dir_ratio = intensity / mean;
369 for (i = 0; i < NSSAMP; ++i) {
370 sun_radiance[i] *= dir_ratio;
371 }
372
373 /* weight by proximity */
374 wtot = 0;
375 for (i = nsuns; i--;)
376 wtot += wta[i] = 1. / (1.002 - near_dprod[i]);
377 /* add to nearest patch radiances */
378 for (i = nsuns; i--;) {
379 float *pdest = parr + NSSAMP * near_patch[i];
380 int k;
381 for (k = 0; k < NSSAMP; k++) {
382 *pdest++ = sun_radiance[k] * wta[i] / wtot;
383 }
384 }
385 }
386
387
388 void calc_sky_patch_radiance(DATARRAY *scat, DATARRAY *scat1m,
389 DATARRAY *irrad_clear, double ccover, double dif_ratio,
390 double overcast_zenithbr, FVECT view_point, float *parr)
391 {
392 double mu_sky; /* Sun-sky point azimuthal angle */
393 double sspa; /* Sun-sky point angle */
394 int i;
395 for (i = 1; i < nskypatch; i++) {
396 FVECT rdir_sky;
397 vectorize(rh_palt[i], rh_pazi[i], rdir_sky);
398 mu_sky = fdot(view_point, rdir_sky) / ER;
399 sspa = fdot(rdir_sky, sundir);
400
401 SCOLOR sky_radiance = {0};
402 get_sky_radiance(scat, scat1m, ER, mu_sky, sun_ct, sspa, sky_radiance);
403 int k;
404 for (k = 0; k < NSSAMP; ++k) {
405 sky_radiance[k] *= WVLSPAN;
406 }
407
408 if (ccover > 0) {
409 double skybr = get_overcast_brightness(rdir_sky[2], overcast_zenithbr);
410 for (k = 0; k < NSSAMP; ++k) {
411 sky_radiance[k] = wmean2(sky_radiance[k], skybr * D6415[k], ccover);
412 }
413 }
414
415 /* calibration */
416 for (k = 0; k < NSSAMP; ++k) {
417 sky_radiance[k] *= dif_ratio;
418 }
419
420 for (k = 0; k < NSSAMP; ++k) {
421 parr[NSSAMP * i + k] = sky_radiance[k];
422 }
423 }
424 }
425
426
427 /* Compute sky patch radiance values (modified by GW) */
428 void compute_sky(DATARRAY *tau, DATARRAY *scat, DATARRAY *scat1m,
429 DATARRAY *irrad, double ccover, double difhor, FVECT view_point, float *parr)
430 {
431 float sun_zenith;
432 SCOLOR sky_radiance = {0};
433 SCOLOR ground_radiance = {0};
434 SCOLR sky_sclr = {0};
435 SCOLR ground_sclr = {0};
436 const double radius = VLEN(view_point);
437 const double sun_ct = fdot(view_point, sundir) / radius;
438 const FVECT rdir_grnd = {0, 0, -1};
439 const double mu_grnd = fdot(view_point, rdir_grnd) / radius;
440 const double nu_grnd = fdot(rdir_grnd, sundir);
441
442 /* Calculate sun zenith angle (don't let it dip below horizon) */
443 /* Also limit minimum angle to keep circumsolar off zenith */
444 if (altitude <= 0.0)
445 sun_zenith = deg_to_rad(90.0);
446 else if (altitude >= deg_to_rad(87.0))
447 sun_zenith = deg_to_rad(3.0);
448 else
449 sun_zenith = deg_to_rad(90.0) - altitude;
450
451 double overcast_zenithbr = get_overcast_zenith_brightness(sundir);
452
453 /* diffuse calibration factor */
454 double dif_ratio = 1;
455 if (difhor > 0) {
456 DATARRAY *indirect_irradiance_clear = get_indirect_irradiance(irrad, radius, sun_ct);
457 double overcast_ghi = overcast_zenithbr * 7.0 * PI / 9.0;
458 double diffuse_irradiance = 0;
459 int l;
460 for (l = 0; l < NSSAMP; ++l) {
461 diffuse_irradiance += indirect_irradiance_clear->arr.d[l] * 20; /* 20nm interval */
462 }
463 /* free(indirect_irradiance_clear); */
464 diffuse_irradiance = wmean2(diffuse_irradiance, overcast_ghi, ccover);
465 if (diffuse_irradiance > 0) {
466 dif_ratio = difhor / WHTEFFICACY / diffuse_irradiance / 1.15; /* fudge */
467 }
468 }
469
470 /* Compute ground radiance (include solar contribution if any) */
471 get_ground_radiance(tau, scat, scat1m, irrad, view_point, rdir_grnd, radius,
472 mu_grnd, sun_ct, nu_grnd, grefl, sundir, parr);
473 int j;
474 for (j = 0; j < NSSAMP; j++) {
475 parr[j] *= WVLSPAN;
476 }
477 calc_sky_patch_radiance(scat, scat1m, irrad, ccover, dif_ratio, overcast_zenithbr, view_point, parr);
478 }
479
480 int main(int argc, char *argv[])
481 {
482 EPWheader *epw = NULL; /* EPW/WEA input file */
483 EPWrecord erec; /* current EPW/WEA input record */
484 int doheader = 1; /* output header? */
485 double rotation = 0.0; /* site rotation (degrees) */
486 double elevation = 0; /* site elevation (meters) */
487 int leap_day = 0; /* add leap day? */
488 int sun_hours_only = 0; /* only output sun hours? */
489 int dir_is_horiz; /* direct is meas. on horizontal? */
490 int ntsteps = 0; /* number of time steps */
491 int tstorage = 0; /* number of allocated time steps */
492 int nstored = 0; /* number of time steps in matrix */
493 int last_monthly = 0; /* month of last report */
494 double dni; /* direct normal illuminance */
495 double dhi; /* diffuse horizontal illuminance */
496
497 float *mtx_data = NULL;
498 int mtx_offset = 0;
499 double timeinterval = 0;
500 char lstag[3];
501 char *mie_path = getpath("mie_ca.dat", getrlibpath(), R_OK);
502 char *ddir = ".";
503 char mie_name[20] = "mie_ca";
504 int num_threads = 1;
505 int sorder = 4;
506 int solar_only = 0;
507 int sky_only = 0;
508 int i, j;
509 FVECT view_point = {0, 0, ER};
510
511 fixargv0(argv[0]);
512
513 for (i = 1; i < argc && argv[i][0] == '-'; i++) {
514 switch (argv[i][1]) {
515 case 'd': /* solar (direct) only */
516 solar_only = 1;
517 break;
518 case 's': /* sky only (no direct) */
519 sky_only = 1;
520 break;
521 case 'g':
522 grefl = atof(argv[++i]);
523 break;
524 case 'm':
525 rhsubdiv = atoi(argv[++i]);
526 break;
527 case 'n':
528 num_threads = atoi(argv[++i]);
529 break;
530 case 'r': /* rotate distribution */
531 if (argv[i][2] && argv[i][2] != 'z')
532 goto userr;
533 rotation = atof(argv[++i]);
534 break;
535 case 'u': /* solar hours only */
536 sun_hours_only = 1;
537 break;
538 case 'p':
539 ddir = argv[++i];
540 break;
541 case 'v': /* verbose progress reports */
542 verbose++;
543 break;
544 case 'h': /* turn off header */
545 doheader = 0;
546 break;
547 case '5': /* 5-phase calculation */
548 nsuns = 1;
549 fixed_sun_sa = PI / 360. * atof(argv[++i]);
550 if (fixed_sun_sa <= 0) {
551 fprintf(
552 stderr,
553 "%s: missing solar disk size argument for '-5' option\n",
554 progname);
555 exit(1);
556 }
557 fixed_sun_sa *= fixed_sun_sa * PI;
558 break;
559 case 'i':
560 timeinterval = atof(argv[++i]);
561 break;
562 case 'o': /* output format */
563 switch (argv[i][2]) {
564 case 'f':
565 case 'd':
566 case 'a':
567 outfmt = argv[i][2];
568 break;
569 default:
570 goto userr;
571 }
572 break;
573 default:
574 goto userr;
575 }
576 }
577 if (i < argc - 1)
578 goto userr;
579
580 epw = EPWopen(argv[i]);
581 if (epw == NULL)
582 exit(1);
583 if (i == argc - 1 && freopen(argv[i], "r", stdin) == NULL) {
584 fprintf(stderr, "%s: cannot open '%s' for input\n", progname, argv[i]);
585 exit(1);
586 }
587 if (verbose) {
588 if (i == argc - 1)
589 fprintf(stderr, "%s: reading weather tape '%s'\n", progname, argv[i]);
590 else
591 fprintf(stderr, "%s: reading weather tape from <stdin>\n", progname);
592 }
593 s_latitude = epw->loc.latitude;
594 s_longitude = -epw->loc.longitude;
595 s_meridian = -15.*epw->loc.timezone;
596 elevation = epw->loc.elevation;
597 switch (epw->isWEA) { /* translate units */
598 case WEAnot:
599 case WEAradnorm:
600 input = 1; /* radiometric quantities */
601 dir_is_horiz = 0; /* direct is perpendicular meas. */
602 break;
603 case WEAradhoriz:
604 input = 1; /* radiometric quantities */
605 dir_is_horiz = 1; /* solar measured horizontally */
606 break;
607 case WEAphotnorm:
608 input = 2; /* photometric quantities */
609 dir_is_horiz = 0; /* direct is perpendicular meas. */
610 break;
611 default:
612 goto fmterr;
613 }
614
615 rh_init();
616
617 if (verbose) {
618 fprintf(stderr, "%s: location '%s %s'\n", progname, epw->loc.city, epw->loc.country);
619 fprintf(
620 stderr,
621 "%s: (lat,long)=(%.1f,%.1f) degrees north, west\n",
622 progname, s_latitude, s_longitude);
623 if (rotation != 0)
624 fprintf(stderr, "%s: rotating output %.0f degrees\n", progname, rotation);
625 }
626
627 s_latitude = deg_to_rad(s_latitude);
628 s_longitude = deg_to_rad(s_longitude);
629 s_meridian = deg_to_rad(s_meridian);
630 /* initial allocation */
631 mtx_data = resize_dmatrix(mtx_data, tstorage = 2, nskypatch);
632
633 /* Load mie density data */
634 DATARRAY *mie_dp = getdata(mie_path);
635 if (mie_dp == NULL) {
636 fprintf(stderr, "Error reading mie data\n");
637 return 0;
638 }
639
640 if (epw->isWEA == WEAnot) {
641 fprintf(stderr, "EPW input\n");
642 } else if (epw->isWEA != WEAphotnorm) {
643 fprintf(stderr, "need WEA in photopic unit\n");
644 exit(1);
645 }
646
647 while ((j = EPWread(epw, &erec)) > 0) {
648 const int mo = erec.date.month+1;
649 const int da = erec.date.day;
650 const double hr = erec.date.hour;
651 double aod = erec.optdepth;
652 double cc = erec.skycover;
653 double sda, sta, st;
654 int sun_in_sky;
655
656 if (aod == 0.0) {
657 aod = AOD0_CA;
658 fprintf(stderr, "aod is zero, using default value %.3f\n", AOD0_CA);
659 }
660 /* compute solar position */
661 if ((mo == 2) & (da == 29)) {
662 julian_date = 60;
663 leap_day = 1;
664 } else
665 julian_date = jdate(mo, da) + leap_day;
666 sda = sdec(julian_date);
667 sta = stadj(julian_date);
668 st = hr + sta;
669 if (timeinterval > 0) {
670 if (fabs(solar_sunrise(mo, da) - st) <= timeinterval/120)
671 st = (st + timeinterval/120 + solar_sunrise(mo, da))/2;
672 else if (fabs(solar_sunset(mo, da) - st) < timeinterval/120)
673 st = (st - timeinterval/120 + solar_sunset(mo, da))/2;
674 }
675 altitude = salt(sda, st);
676 sun_in_sky = (altitude > -deg_to_rad(SUN_ANG_DEG / 2.));
677
678 azimuth = sazi(sda, st) + PI - deg_to_rad(rotation);
679
680 vectorize(altitude, azimuth, sundir);
681 if (sun_hours_only && !sun_in_sky) {
682 continue; /* skipping nighttime points */
683 }
684 sun_ct = fdot(view_point, sundir) / ER;
685
686 dni = erec.dirillum;
687 dhi = erec.diffillum;
688
689 mtx_offset = NSSAMP * nskypatch * nstored;
690 nstored += 1;
691
692 /* make space for next row */
693 if (nstored > tstorage) {
694 tstorage += (tstorage >> 1) + nstored + 7;
695 mtx_data = resize_dmatrix(mtx_data, tstorage, nskypatch);
696 }
697 ntsteps++; /* keep count of time steps */
698
699 /* compute sky patch values */
700 Atmosphere clear_atmos = init_atmos(aod, grefl);
701 int is_summer = (mo >= SUMMER_START && mo <= SUMMER_END);
702 if (s_latitude < 0) {
703 is_summer = !is_summer;
704 }
705 set_rayleigh_density_profile(&clear_atmos, lstag, is_summer, s_latitude);
706
707 clear_atmos.beta_m = mie_dp;
708
709 char gsdir[PATH_MAX];
710 size_t siz = strlen(ddir);
711 if (ISDIRSEP(ddir[siz - 1]))
712 ddir[siz - 1] = '\0';
713 snprintf(gsdir, PATH_MAX, "%s%catmos_data", ddir, DIRSEP);
714 if (!make_directory(gsdir)) {
715 fprintf(stderr, "Failed creating atmos_data directory");
716 exit(1);
717 }
718 DpPaths clear_paths = get_dppaths(gsdir, aod, mie_name, lstag);
719
720 if (getpath(clear_paths.tau, ".", R_OK) == NULL ||
721 getpath(clear_paths.scat, ".", R_OK) == NULL ||
722 getpath(clear_paths.scat1m, ".", R_OK) == NULL ||
723 getpath(clear_paths.irrad, ".", R_OK) == NULL) {
724 fprintf(stderr, "# Pre-computing...\n");
725 if (!precompute(sorder, clear_paths, &clear_atmos, num_threads)) {
726 fprintf(stderr, "Pre-compute failed\n");
727 return 0;
728 }
729 }
730
731 DATARRAY *tau_clear_dp = getdata(clear_paths.tau);
732 DATARRAY *irrad_clear_dp = getdata(clear_paths.irrad);
733 DATARRAY *scat_clear_dp = getdata(clear_paths.scat);
734 DATARRAY *scat1m_clear_dp = getdata(clear_paths.scat1m);
735
736 if (!solar_only)
737 compute_sky(tau_clear_dp, scat_clear_dp, scat1m_clear_dp, irrad_clear_dp,
738 cc, dhi, view_point, mtx_data + mtx_offset);
739 if (!sky_only)
740 add_direct(tau_clear_dp, scat_clear_dp, scat1m_clear_dp, irrad_clear_dp,
741 cc, dni, mtx_data + mtx_offset);
742 /* monthly reporting */
743 if (verbose && mo != last_monthly)
744 fprintf(stderr, "%s: stepping through month %d...\n", progname,
745 last_monthly = mo);
746 }
747 if (j != EOF) {
748 fprintf(stderr, "%s: error on input\n", progname);
749 exit(1);
750 }
751 EPWclose(epw); epw = NULL;
752 freedata(mie_dp);
753 if (!ntsteps) {
754 fprintf(stderr, "%s: no valid time steps on input\n", progname);
755 exit(1);
756 }
757 /* write out matrix */
758 if (outfmt != 'a')
759 SET_FILE_BINARY(stdout);
760 #ifdef getc_unlocked
761 flockfile(stdout);
762 #endif
763 if (verbose)
764 fprintf(stderr, "%s: writing %smatrix with %d time steps...\n", progname,
765 outfmt == 'a' ? "" : "binary ", nstored);
766 if (doheader) {
767 newheader("RADIANCE", stdout);
768 printargs(argc, argv, stdout);
769 printf("LATLONG= %.8f %.8f\n", rad_to_deg(s_latitude),
770 -rad_to_deg(s_longitude));
771 printf("NROWS=%d\n", nskypatch);
772 printf("NCOLS=%d\n", nstored);
773 printf("NCOMP=%d\n", NSSAMP);
774 float wvsplit[4] = {380, 480, 588, 780};
775 fputwlsplit(wvsplit, stdout);
776 if ((outfmt == 'f') | (outfmt == 'd'))
777 fputendian(stdout);
778 fputformat((char *)getfmtname(outfmt), stdout);
779 putchar('\n');
780 }
781 /* patches are rows (outer sort) */
782 for (i = 0; i < nskypatch; i++) {
783 mtx_offset = NSSAMP * i;
784 switch (outfmt) {
785 case 'a':
786 for (j = 0; j < nstored; j++) {
787 int k;
788 for (k = 0; k < NSSAMP; k++) {
789 printf("%.3g ", mtx_data[mtx_offset + k]);
790 }
791 printf("\n");
792 mtx_offset += NSSAMP * nskypatch;
793 }
794 if (nstored > 1)
795 fputc('\n', stdout);
796 break;
797 case 'f':
798 for (j = 0; j < nstored; j++) {
799 putbinary(mtx_data + mtx_offset, sizeof(float), NSSAMP, stdout);
800 mtx_offset += NSSAMP * nskypatch;
801 }
802 break;
803 case 'd':
804 for (j = 0; j < nstored; j++) {
805 double ment[NSSAMP];
806 for (j = 0; j < NSSAMP; j++)
807 ment[j] = mtx_data[mtx_offset + j];
808 putbinary(ment, sizeof(double), NSSAMP, stdout);
809 mtx_offset += NSSAMP * nskypatch;
810 }
811 break;
812 }
813 if (ferror(stdout))
814 goto writerr;
815 }
816 return 0;
817 userr:
818 fprintf(stderr,
819 "Usage: %s [-v][-h][-A][-d|-s|-n][-u][-D file [-M modfile]][-r "
820 "deg][-m N][-g r g b][-c r g b][-o{f|d}][-O{0|1}] [tape.wea]\n",
821 progname);
822 exit(1);
823 fmterr:
824 fprintf(stderr, "%s: weather tape format error in header\n", progname);
825 exit(1);
826 writerr:
827 fprintf(stderr, "%s: write error on output\n", progname);
828 exit(1);
829 }
