| 1 |
#ifndef lint
| 2 |
static const char RCSid[] = "$Id$";
| 3 |
#endif
| 4 |
#include "atmos.h"
| 5 |
#include "copyright.h"
| 6 |
#include "data.h"
| 7 |
#include "platform.h"
| 8 |
#include "rtio.h"
| 9 |
#include <ctype.h>
| 10 |
#include <stdlib.h>
| 11 |
#ifdef _WIN32
| 12 |
#include <windows.h>
| 13 |
#else
| 14 |
#include <errno.h>
| 15 |
#include <sys/stat.h>
| 16 |
#include <sys/types.h>
| 17 |
#endif
| 18 |
| 19 |
char *progname;
| 20 |
| 21 |
double altitude; /* Solar altitude (radians) */
| 22 |
double azimuth; /* Solar azimuth (radians) */
| 23 |
int julian_date; /* Julian date */
| 24 |
double sun_zenith; /* Sun zenith angle (radians) */
| 25 |
int input = 0; /* Input type */
| 26 |
int output = 0; /* Output type */
| 27 |
FVECT sundir;
| 28 |
| 29 |
const double ARCTIC_LAT = 67.;
| 30 |
const double TROPIC_LAT = 23.;
| 31 |
const int SUMMER_START = 4;
| 32 |
const int SUMMER_END = 9;
| 33 |
const double GNORM = 0.777778;
| 34 |
| 35 |
const double D65EFF = 203.; /* standard illuminant D65 */
| 36 |
| 37 |
/* Mean normalized relative daylight spectra where CCT = 6415K for overcast */
| 38 |
const double D6415[NSSAMP] = {0.63231, 1.06171, 1.00779, 1.36423, 1.34133,
| 39 |
1.27258, 1.26276, 1.26352, 1.22201, 1.13246,
| 40 |
1.0434, 1.05547, 0.98212, 0.94445, 0.9722,
| 41 |
0.82387, 0.87853, 0.82559, 0.75111, 0.78925};
| 42 |
/* Degrees into radians */
| 43 |
#define DegToRad(deg) ((deg) * (PI / 180.))
| 44 |
| 45 |
/* Radiuans into degrees */
| 46 |
#define RadToDeg(rad) ((rad) * (180. / PI))
| 47 |
| 48 |
#ifndef NSUNPATCH
| 49 |
#define NSUNPATCH 4 /* max. # patches to spread sun into */
| 50 |
#endif
| 51 |
| 52 |
#define SUN_ANG_DEG 0.533 /* sun full-angle in degrees */
| 53 |
| 54 |
int nsuns = NSUNPATCH; /* number of sun patches to use */
| 55 |
double fixed_sun_sa = -1; /* fixed solid angle per sun? */
| 56 |
| 57 |
int verbose = 0; /* progress reports to stderr? */
| 58 |
| 59 |
int outfmt = 'a'; /* output format */
| 60 |
| 61 |
int rhsubdiv = 1; /* Reinhart sky subdivisions */
| 62 |
| 63 |
COLOR skycolor = {.96, 1.004, 1.118}; /* sky coloration */
| 64 |
COLOR suncolor = {1., 1., 1.}; /* sun color */
| 65 |
double grefl = .2; /* ground reflectance */
| 66 |
| 67 |
int nskypatch; /* number of Reinhart patches */
| 68 |
float *rh_palt; /* sky patch altitudes (radians) */
| 69 |
float *rh_pazi; /* sky patch azimuths (radians) */
| 70 |
float *rh_dom; /* sky patch solid angle (sr) */
| 71 |
| 72 |
double sun_ct;
| 73 |
| 74 |
#define vector(v, alt, azi) \
| 75 |
((v)[1] = cos(alt), (v)[0] = (v)[1] * sin(azi), (v)[1] *= cos(azi), \
| 76 |
(v)[2] = sin(alt))
| 77 |
| 78 |
#define rh_vector(v, i) vector(v, rh_palt[i], rh_pazi[i])
| 79 |
| 80 |
#define rh_cos(i) tsin(rh_palt[i])
| 81 |
| 82 |
#define solar_minute(jd, hr) ((24 * 60) * ((jd) - 1) + (int)((hr) * 60. + .5))
| 83 |
| 84 |
inline void vectorize(double altitude, double azimuth, FVECT v) {
| 85 |
v[1] = cos(altitude);
| 86 |
v[0] = (v)[1] * sin(azimuth);
| 87 |
v[1] *= cos(azimuth);
| 88 |
v[2] = sin(altitude);
| 89 |
| 90 |
| 91 |
static int make_directory(const char *path) {
| 92 |
#ifdef _WIN32
| 93 |
if (CreateDirectory(path, NULL) || GetLastError() == ERROR_ALREADY_EXISTS) {
| 94 |
return 1;
| 95 |
| 96 |
return 0;
| 97 |
#else
| 98 |
if (mkdir(path, 0777) == 0 || errno == EEXIST) {
| 99 |
return 1;
| 100 |
| 101 |
return 0;
| 102 |
#endif
| 103 |
| 104 |
| 105 |
static const char *getfmtname(int fmt) {
| 106 |
switch (fmt) {
| 107 |
case 'a':
| 108 |
return ("ascii");
| 109 |
case 'f':
| 110 |
return ("float");
| 111 |
case 'd':
| 112 |
return ("double");
| 113 |
| 114 |
return ("unknown");
| 115 |
| 116 |
| 117 |
static inline double wmean2(const double a, const double b, const double x) {
| 118 |
return a * (1 - x) + b * x;
| 119 |
| 120 |
| 121 |
static inline double wmean(const double a, const double x, const double b,
| 122 |
const double y) {
| 123 |
return (a * x + b * y) / (a + b);
| 124 |
| 125 |
| 126 |
static double get_zenith_brightness(const double sundir[3]) {
| 127 |
double zenithbr;
| 128 |
if (sundir[2] < 0) {
| 129 |
zenithbr = 0;
| 130 |
} else {
| 131 |
zenithbr = (8.6 * sundir[2] + .123) * 1000.0 / D65EFF;
| 132 |
| 133 |
return zenithbr;
| 134 |
| 135 |
| 136 |
/* from gensky.c */
| 137 |
static double get_overcast_brightness(const double dz, const double zenithbr) {
| 138 |
double groundbr = zenithbr * GNORM;
| 139 |
return wmean(pow(dz + 1.01, 10), zenithbr * (1 + 2 * dz) / 3,
| 140 |
pow(dz + 1.01, -10), groundbr);
| 141 |
| 142 |
| 143 |
int rh_init(void) {
| 144 |
#define NROW 7
| 145 |
static const int tnaz[NROW] = {30, 30, 24, 24, 18, 12, 6};
| 146 |
const double alpha = (PI / 2.) / (NROW * rhsubdiv + .5);
| 147 |
int p, i, j;
| 148 |
/* allocate patch angle arrays */
| 149 |
nskypatch = 0;
| 150 |
for (p = 0; p < NROW; p++)
| 151 |
nskypatch += tnaz[p];
| 152 |
nskypatch *= rhsubdiv * rhsubdiv;
| 153 |
nskypatch += 2;
| 154 |
rh_palt = (float *)malloc(sizeof(float) * nskypatch);
| 155 |
rh_pazi = (float *)malloc(sizeof(float) * nskypatch);
| 156 |
rh_dom = (float *)malloc(sizeof(float) * nskypatch);
| 157 |
if ((rh_palt == NULL) | (rh_pazi == NULL) | (rh_dom == NULL)) {
| 158 |
fprintf(stderr, "%s: out of memory in rh_init()\n", progname);
| 159 |
exit(1);
| 160 |
| 161 |
rh_palt[0] = -PI / 2.; /* ground & zenith patches */
| 162 |
rh_pazi[0] = 0.;
| 163 |
rh_dom[0] = 2. * PI;
| 164 |
rh_palt[nskypatch - 1] = PI / 2.;
| 165 |
rh_pazi[nskypatch - 1] = 0.;
| 166 |
rh_dom[nskypatch - 1] = 2. * PI * (1. - cos(alpha * .5));
| 167 |
p = 1; /* "normal" patches */
| 168 |
for (i = 0; i < NROW * rhsubdiv; i++) {
| 169 |
const float ralt = alpha * (i + .5);
| 170 |
const int ninrow = tnaz[i / rhsubdiv] * rhsubdiv;
| 171 |
const float dom =
| 172 |
2. * PI * (sin(alpha * (i + 1)) - sin(alpha * i)) / (double)ninrow;
| 173 |
for (j = 0; j < ninrow; j++) {
| 174 |
rh_palt[p] = ralt;
| 175 |
rh_pazi[p] = 2. * PI * j / (double)ninrow;
| 176 |
rh_dom[p++] = dom;
| 177 |
| 178 |
| 179 |
return nskypatch;
| 180 |
#undef NROW
| 181 |
| 182 |
| 183 |
/* Resize daylight matrix (GW) */
| 184 |
float *resize_dmatrix(float *mtx_data, int nsteps, int npatch) {
| 185 |
if (mtx_data == NULL)
| 186 |
mtx_data = (float *)malloc(sizeof(float) * NSSAMP * nsteps * npatch);
| 187 |
else
| 188 |
mtx_data =
| 189 |
(float *)realloc(mtx_data, sizeof(float) * NSSAMP * nsteps * npatch);
| 190 |
if (mtx_data == NULL) {
| 191 |
fprintf(stderr, "%s: out of memory in resize_dmatrix(%d,%d)\n", progname,
| 192 |
nsteps, npatch);
| 193 |
exit(1);
| 194 |
| 195 |
return (mtx_data);
| 196 |
| 197 |
| 198 |
static Atmosphere init_atmos(const double aod, const double grefl) {
| 199 |
Atmosphere atmos = {.ozone_density = {.layers =
| 200 |
| 201 |
{.width = 25000.0,
| 202 |
.exp_term = 0.0,
| 203 |
.exp_scale = 0.0,
| 204 |
.linear_term = 1.0 / 15000.0,
| 205 |
.constant_term = -2.0 / 3.0},
| 206 |
{.width = AH,
| 207 |
.exp_term = 0.0,
| 208 |
.exp_scale = 0.0,
| 209 |
.linear_term = -1.0 / 15000.0,
| 210 |
.constant_term = 8.0 / 3.0},
| 211 |
| 212 |
.rayleigh_density = {.layers =
| 213 |
| 214 |
{.width = AH,
| 215 |
.exp_term = 1.0,
| 216 |
.exp_scale = -1.0 / HR_MS,
| 217 |
.linear_term = 0.0,
| 218 |
.constant_term = 0.0},
| 219 |
| 220 |
.beta_r0 = BR0_MS,
| 221 |
.beta_scale = aod / AOD0_CA,
| 222 |
.beta_m = NULL,
| 223 |
.grefl = grefl};
| 224 |
return atmos;
| 225 |
| 226 |
| 227 |
static DpPaths get_dppaths(const char *dir, const double aod, const char *mname,
| 228 |
const char *tag) {
| 229 |
DpPaths paths;
| 230 |
| 231 |
snprintf(paths.tau, PATH_MAX, "%s%ctau_%s_%s_%.2f.dat", dir, DIRSEP, tag,
| 232 |
mname, aod);
| 233 |
snprintf(paths.scat, PATH_MAX, "%s%cscat_%s_%s_%.2f.dat", dir, DIRSEP, tag,
| 234 |
mname, aod);
| 235 |
snprintf(paths.scat1m, PATH_MAX, "%s%cscat1m_%s_%s_%.2f.dat", dir, DIRSEP,
| 236 |
tag, mname, aod);
| 237 |
snprintf(paths.irrad, PATH_MAX, "%s%cirrad_%s_%s_%.2f.dat", dir, DIRSEP, tag,
| 238 |
mname, aod);
| 239 |
| 240 |
return paths;
| 241 |
| 242 |
static void set_rayleigh_density_profile(Atmosphere *atmos, char *tag,
| 243 |
const int is_summer,
| 244 |
const double s_latitude) {
| 245 |
/* Set rayleigh density profile */
| 246 |
if (fabs(s_latitude * 180.0 / PI) > ARCTIC_LAT) {
| 247 |
tag[0] = 's';
| 248 |
if (is_summer) {
| 249 |
tag[1] = 's';
| 250 |
atmos->rayleigh_density.layers[0].exp_scale = -1.0 / HR_SS;
| 251 |
atmos->beta_r0 = BR0_SS;
| 252 |
} else {
| 253 |
tag[1] = 'w';
| 254 |
atmos->rayleigh_density.layers[0].exp_scale = -1.0 / HR_SW;
| 255 |
atmos->beta_r0 = BR0_SW;
| 256 |
| 257 |
} else if (fabs(s_latitude * 180.0 / PI) > TROPIC_LAT) {
| 258 |
tag[0] = 'm';
| 259 |
if (is_summer) {
| 260 |
tag[1] = 's';
| 261 |
atmos->rayleigh_density.layers[0].exp_scale = -1.0 / HR_MS;
| 262 |
atmos->beta_r0 = BR0_MS;
| 263 |
} else {
| 264 |
tag[1] = 'w';
| 265 |
atmos->rayleigh_density.layers[0].exp_scale = -1.0 / HR_MW;
| 266 |
atmos->beta_r0 = BR0_MW;
| 267 |
| 268 |
} else {
| 269 |
tag[0] = 't';
| 270 |
tag[1] = 'r';
| 271 |
atmos->rayleigh_density.layers[0].exp_scale = -1.0 / HR_T;
| 272 |
atmos->beta_r0 = BR0_T;
| 273 |
| 274 |
tag[2] = '\0';
| 275 |
| 276 |
/* Add in solar direct to nearest sky patches (GW) */
| 277 |
void add_direct(DATARRAY *tau, DATARRAY *scat, DATARRAY *scat1m,
| 278 |
DATARRAY *irrad, double ccover, float *parr) {
| 279 |
FVECT svec;
| 280 |
double near_dprod[NSUNPATCH];
| 281 |
int near_patch[NSUNPATCH];
| 282 |
double wta[NSUNPATCH], wtot;
| 283 |
int i, j, p;
| 284 |
| 285 |
/* identify nsuns closest patches */
| 286 |
for (i = nsuns; i--;)
| 287 |
near_dprod[i] = -1.;
| 288 |
vectorize(altitude, azimuth, svec);
| 289 |
for (p = 1; p < nskypatch; p++) {
| 290 |
FVECT pvec;
| 291 |
double dprod;
| 292 |
vectorize(rh_palt[p], rh_pazi[p], pvec);
| 293 |
dprod = DOT(pvec, svec);
| 294 |
for (i = 0; i < nsuns; i++)
| 295 |
if (dprod > near_dprod[i]) {
| 296 |
for (j = nsuns; --j > i;) {
| 297 |
near_dprod[j] = near_dprod[j - 1];
| 298 |
near_patch[j] = near_patch[j - 1];
| 299 |
| 300 |
near_dprod[i] = dprod;
| 301 |
near_patch[i] = p;
| 302 |
break;
| 303 |
| 304 |
| 305 |
/* Get solar radiance */
| 306 |
double sun_radiance[NSSAMP] = {0};
| 307 |
get_solar_radiance(tau, scat, scat1m, sundir, ER, sun_ct, sun_radiance);
| 308 |
if (ccover > 0) {
| 309 |
double zenithbr = get_zenith_brightness(sundir);
| 310 |
double skybr = get_overcast_brightness(sundir[2], zenithbr);
| 311 |
int l;
| 312 |
for (l = 0; l < NSSAMP; ++l) {
| 313 |
sun_radiance[l] =
| 314 |
wmean2(sun_radiance[l], D6415[l] * skybr / WVLSPAN, ccover);
| 315 |
| 316 |
| 317 |
/* weight by proximity */
| 318 |
wtot = 0;
| 319 |
| 320 |
wtot += wta[i] = 1. / (1.002 - near_dprod[i]);
| 321 |
/* add to nearest patch radiances */
| 322 |
for (i = nsuns; i--;) {
| 323 |
float *pdest = parr + NSSAMP * near_patch[i];
| 324 |
int k;
| 325 |
for (k = 0; k < NSSAMP; k++) {
| 326 |
*pdest++ = sun_radiance[k] * wta[i] / wtot;
| 327 |
| 328 |
| 329 |
| 330 |
| 331 |
void calc_sky_patch_radiance(DATARRAY *scat, DATARRAY *scat1m, double ccover,
| 332 |
float *parr) {
| 333 |
int i;
| 334 |
double mu_sky; /* Sun-sky point azimuthal angle */
| 335 |
double sspa; /* Sun-sky point angle */
| 336 |
FVECT view_point = {0, 0, ER};
| 337 |
for (i = 1; i < nskypatch; i++) {
| 338 |
FVECT rdir_sky;
| 339 |
int k;
| 340 |
vectorize(rh_palt[i], rh_pazi[i], rdir_sky);
| 341 |
mu_sky = fdot(view_point, rdir_sky) / ER;
| 342 |
sspa = fdot(rdir_sky, sundir);
| 343 |
SCOLOR sky_radiance = {0};
| 344 |
| 345 |
get_sky_radiance(scat, scat1m, ER, mu_sky, sun_ct, sspa, sky_radiance);
| 346 |
for (k = 0; k < NSSAMP; ++k) {
| 347 |
sky_radiance[k] *= WVLSPAN;
| 348 |
| 349 |
| 350 |
if (ccover > 0) {
| 351 |
| 352 |
double grndbr = zenithbr * GNORM;
| 353 |
double skybr = get_overcast_brightness(rdir_sky[2], zenithbr);
| 354 |
int k;
| 355 |
| 356 |
sky_radiance[k] = wmean2(sky_radiance[k], skybr * D6415[k], ccover);
| 357 |
| 358 |
| 359 |
| 360 |
| 361 |
parr[NSSAMP * i + k] = sky_radiance[k];
| 362 |
| 363 |
| 364 |
| 365 |
| 366 |
/* Return maximum of two doubles */
| 367 |
static inline double dmax(double a, double b) { return (a > b) ? a : b; }
| 368 |
| 369 |
/* Compute sky patch radiance values (modified by GW) */
| 370 |
void compute_sky(DATARRAY *tau, DATARRAY *scat, DATARRAY *scat1m,
| 371 |
| 372 |
int index; /* Category index */
| 373 |
int i;
| 374 |
float sun_zenith;
| 375 |
| 376 |
SCOLOR ground_radiance = {0};
| 377 |
SCOLR sky_sclr = {0};
| 378 |
SCOLR ground_sclr = {0};
| 379 |
| 380 |
const double radius = VLEN(view_point);
| 381 |
const double sun_ct = fdot(view_point, sundir) / radius;
| 382 |
const FVECT rdir_grnd = {0, 0, -1};
| 383 |
const double mu_grnd = fdot(view_point, rdir_grnd) / radius;
| 384 |
const double nu_grnd = fdot(rdir_grnd, sundir);
| 385 |
int j;
| 386 |
| 387 |
/* Calculate sun zenith angle (don't let it dip below horizon) */
| 388 |
/* Also limit minimum angle to keep circumsolar off zenith */
| 389 |
if (altitude <= 0.0)
| 390 |
sun_zenith = DegToRad(90.0);
| 391 |
else if (altitude >= DegToRad(87.0))
| 392 |
sun_zenith = DegToRad(3.0);
| 393 |
else
| 394 |
sun_zenith = DegToRad(90.0) - altitude;
| 395 |
| 396 |
/* Compute ground radiance (include solar contribution if any) */
| 397 |
get_ground_radiance(tau, scat, scat1m, irrad, view_point, rdir_grnd, radius,
| 398 |
mu_grnd, sun_ct, nu_grnd, grefl, sundir, parr);
| 399 |
for (j = 0; j < NSSAMP; j++) {
| 400 |
parr[j] *= WVLSPAN;
| 401 |
| 402 |
calc_sky_patch_radiance(scat, scat1m, ccover, parr);
| 403 |
| 404 |
| 405 |
int main(int argc, char *argv[]) {
| 406 |
| 407 |
char buf[256];
| 408 |
int doheader = 1; /* output header? */
| 409 |
double rotation = 0.0;
| 410 |
double elevation = 0;
| 411 |
int leap_day = 0; /* add leap day? */
| 412 |
int sun_hours_only = 0; /* only output sun hours? */
| 413 |
float *mtx_data = NULL;
| 414 |
int ntsteps = 0; /* number of time steps */
| 415 |
int tstorage = 0; /* number of allocated time steps */
| 416 |
int nstored = 0; /* number of time steps in matrix */
| 417 |
int last_monthly = 0; /* month of last report */
| 418 |
int mo, da;
| 419 |
double hr, aod, cc;
| 420 |
double dni, dhi;
| 421 |
int mtx_offset = 0;
| 422 |
int i, j;
| 423 |
char lstag[3];
| 424 |
char *mie_path = getpath("mie_ca.dat", getrlibpath(), R_OK);
| 425 |
char *ddir = ".";
| 426 |
char mie_name[20] = "mie_ca";
| 427 |
int num_threads = 1;
| 428 |
int sorder = 4;
| 429 |
int solar_only = 0;
| 430 |
int sky_only = 0;
| 431 |
| 432 |
| 433 |
progname = argv[0];
| 434 |
| 435 |
for (i = 1; i < argc && argv[i][0] == '-'; i++) {
| 436 |
switch (argv[i][1]) {
| 437 |
case 'd': /* solar (direct) only */
| 438 |
solar_only = 1;
| 439 |
break;
| 440 |
case 's': /* sky only (no direct) */
| 441 |
sky_only = 1;
| 442 |
break;
| 443 |
case 'g':
| 444 |
grefl = atof(argv[++i]);
| 445 |
break;
| 446 |
case 'm':
| 447 |
rhsubdiv = atoi(argv[++i]);
| 448 |
break;
| 449 |
case 'n':
| 450 |
num_threads = atoi(argv[++i]);
| 451 |
break;
| 452 |
case 'r': /* rotate distribution */
| 453 |
if (argv[i][2] && argv[i][2] != 'z')
| 454 |
goto userr;
| 455 |
rotation = atof(argv[++i]);
| 456 |
break;
| 457 |
case 'u': /* solar hours only */
| 458 |
sun_hours_only = 1;
| 459 |
break;
| 460 |
case 'p':
| 461 |
ddir = argv[++i];
| 462 |
break;
| 463 |
case 'v': /* verbose progress reports */
| 464 |
verbose++;
| 465 |
break;
| 466 |
case 'h': /* turn off header */
| 467 |
doheader = 0;
| 468 |
break;
| 469 |
case '5': /* 5-phase calculation */
| 470 |
nsuns = 1;
| 471 |
fixed_sun_sa = PI / 360. * atof(argv[++i]);
| 472 |
if (fixed_sun_sa <= 0) {
| 473 |
fprintf(stderr,
| 474 |
"%s: missing solar disk size argument for '-5' option\n",
| 475 |
progname);
| 476 |
exit(1);
| 477 |
| 478 |
fixed_sun_sa *= fixed_sun_sa * PI;
| 479 |
break;
| 480 |
case 'o': /* output format */
| 481 |
switch (argv[i][2]) {
| 482 |
case 'f':
| 483 |
case 'd':
| 484 |
case 'a':
| 485 |
outfmt = argv[i][2];
| 486 |
break;
| 487 |
default:
| 488 |
goto userr;
| 489 |
| 490 |
break;
| 491 |
default:
| 492 |
goto userr;
| 493 |
| 494 |
| 495 |
if (i < argc - 1)
| 496 |
goto userr;
| 497 |
if (i == argc - 1 && freopen(argv[i], "r", stdin) == NULL) {
| 498 |
fprintf(stderr, "%s: cannot open '%s' for input\n", progname, argv[i]);
| 499 |
exit(1);
| 500 |
| 501 |
if (verbose) {
| 502 |
if (i == argc - 1)
| 503 |
fprintf(stderr, "%s: reading weather tape '%s'\n", progname, argv[i]);
| 504 |
else
| 505 |
fprintf(stderr, "%s: reading weather tape from <stdin>\n", progname);
| 506 |
| 507 |
/* read weather tape header */
| 508 |
if (scanf("place %[^\r\n] ", buf) != 1)
| 509 |
goto fmterr;
| 510 |
if (scanf("latitude %lf\n", &s_latitude) != 1)
| 511 |
goto fmterr;
| 512 |
if (scanf("longitude %lf\n", &s_longitude) != 1)
| 513 |
goto fmterr;
| 514 |
if (scanf("time_zone %lf\n", &s_meridian) != 1)
| 515 |
goto fmterr;
| 516 |
if (scanf("site_elevation %lf\n", &elevation) != 1)
| 517 |
goto fmterr;
| 518 |
if (scanf("weather_data_file_units %d\n", &input) != 1)
| 519 |
goto fmterr;
| 520 |
| 521 |
rh_init();
| 522 |
if (verbose) {
| 523 |
fprintf(stderr, "%s: location '%s'\n", progname, buf);
| 524 |
fprintf(stderr, "%s: (lat,long)=(%.1f,%.1f) degrees north, west\n",
| 525 |
progname, s_latitude, s_longitude);
| 526 |
if (rotation != 0)
| 527 |
fprintf(stderr, "%s: rotating output %.0f degrees\n", progname, rotation);
| 528 |
| 529 |
| 530 |
s_latitude = DegToRad(s_latitude);
| 531 |
s_longitude = DegToRad(s_longitude);
| 532 |
s_meridian = DegToRad(s_meridian);
| 533 |
/* initial allocation */
| 534 |
mtx_data = resize_dmatrix(mtx_data, tstorage = 2, nskypatch);
| 535 |
| 536 |
/* Load mie density data */
| 537 |
DATARRAY *mie_dp = getdata(mie_path);
| 538 |
if (mie_dp == NULL) {
| 539 |
fprintf(stderr, "Error reading mie data\n");
| 540 |
return 0;
| 541 |
| 542 |
| 543 |
while (scanf("%d %d %lf %lf %lf %lf %lf\n", &mo, &da, &hr, &dni, &dhi, &aod,
| 544 |
&cc) == 7) {
| 545 |
if (aod == 0.0) {
| 546 |
aod = AOD0_CA;
| 547 |
fprintf(stderr, "aod is zero, using default value %.3f\n", AOD0_CA);
| 548 |
| 549 |
double sda, sta;
| 550 |
int sun_in_sky;
| 551 |
/* compute solar position */
| 552 |
if ((mo == 2) & (da == 29)) {
| 553 |
julian_date = 60;
| 554 |
leap_day = 1;
| 555 |
} else
| 556 |
julian_date = jdate(mo, da) + leap_day;
| 557 |
sda = sdec(julian_date);
| 558 |
sta = stadj(julian_date);
| 559 |
altitude = salt(sda, hr + sta);
| 560 |
sun_in_sky = (altitude > -DegToRad(SUN_ANG_DEG / 2.));
| 561 |
| 562 |
azimuth = sazi(sda, hr + sta) + PI - DegToRad(rotation);
| 563 |
| 564 |
vectorize(altitude, azimuth, sundir);
| 565 |
if (sun_hours_only && sundir[2] <= 0.) {
| 566 |
continue; /* skipping nighttime points */
| 567 |
| 568 |
sun_ct = fdot(view_point, sundir) / ER;
| 569 |
| 570 |
mtx_offset = NSSAMP * nskypatch * nstored;
| 571 |
nstored += 1;
| 572 |
printf("mtx_offset = %d nstored = %d nskypatch = %d\n", mtx_offset, nstored,
| 573 |
nskypatch);
| 574 |
/* make space for next row */
| 575 |
if (nstored > tstorage) {
| 576 |
printf("make space for next row nstored = %d tstorage = %d\n", nstored,
| 577 |
tstorage);
| 578 |
tstorage += (tstorage >> 1) + nstored + 7;
| 579 |
mtx_data = resize_dmatrix(mtx_data, tstorage, nskypatch);
| 580 |
| 581 |
ntsteps++; /* keep count of time steps */
| 582 |
/* compute sky patch values */
| 583 |
Atmosphere clear_atmos = init_atmos(aod, grefl);
| 584 |
int is_summer = (mo >= SUMMER_START && mo <= SUMMER_END);
| 585 |
if (s_latitude < 0) {
| 586 |
is_summer = !is_summer;
| 587 |
| 588 |
set_rayleigh_density_profile(&clear_atmos, lstag, is_summer, s_latitude);
| 589 |
| 590 |
clear_atmos.beta_m = mie_dp;
| 591 |
| 592 |
char gsdir[PATH_MAX];
| 593 |
size_t siz = strlen(ddir);
| 594 |
if (ISDIRSEP(ddir[siz - 1]))
| 595 |
ddir[siz - 1] = '\0';
| 596 |
snprintf(gsdir, PATH_MAX, "%s%catmos_data", ddir, DIRSEP);
| 597 |
if (!make_directory(gsdir)) {
| 598 |
fprintf(stderr, "Failed creating atmos_data directory");
| 599 |
exit(1);
| 600 |
| 601 |
DpPaths clear_paths = get_dppaths(gsdir, aod, mie_name, lstag);
| 602 |
| 603 |
if (getpath(clear_paths.tau, ".", R_OK) == NULL ||
| 604 |
getpath(clear_paths.scat, ".", R_OK) == NULL ||
| 605 |
getpath(clear_paths.scat1m, ".", R_OK) == NULL ||
| 606 |
getpath(clear_paths.irrad, ".", R_OK) == NULL) {
| 607 |
printf("# Pre-computing...\n");
| 608 |
if (!precompute(sorder, clear_paths, &clear_atmos, num_threads)) {
| 609 |
fprintf(stderr, "Pre-compute failed\n");
| 610 |
return 0;
| 611 |
| 612 |
| 613 |
| 614 |
DATARRAY *tau_clear_dp = getdata(clear_paths.tau);
| 615 |
DATARRAY *irrad_clear_dp = getdata(clear_paths.irrad);
| 616 |
DATARRAY *scat_clear_dp = getdata(clear_paths.scat);
| 617 |
DATARRAY *scat1m_clear_dp = getdata(clear_paths.scat1m);
| 618 |
| 619 |
if (!solar_only)
| 620 |
compute_sky(tau_clear_dp, scat_clear_dp, scat1m_clear_dp, irrad_clear_dp,
| 621 |
cc, mtx_data + mtx_offset);
| 622 |
if (!sky_only)
| 623 |
add_direct(tau_clear_dp, scat_clear_dp, scat1m_clear_dp, irrad_clear_dp,
| 624 |
| 625 |
/* monthly reporting */
| 626 |
if (verbose && mo != last_monthly)
| 627 |
fprintf(stderr, "%s: stepping through month %d...\n", progname,
| 628 |
last_monthly = mo);
| 629 |
| 630 |
freedata(mie_dp);
| 631 |
if (!ntsteps) {
| 632 |
fprintf(stderr, "%s: no valid time steps on input\n", progname);
| 633 |
exit(1);
| 634 |
| 635 |
/* check for junk at end */
| 636 |
while ((i = fgetc(stdin)) != EOF)
| 637 |
if (!isspace(i)) {
| 638 |
fprintf(stderr, "%s: warning - unexpected data past EOT: ", progname);
| 639 |
buf[0] = i;
| 640 |
buf[1] = '\0';
| 641 |
fgets(buf + 1, sizeof(buf) - 1, stdin);
| 642 |
fputs(buf, stderr);
| 643 |
fputc('\n', stderr);
| 644 |
break;
| 645 |
| 646 |
/* write out matrix */
| 647 |
if (outfmt != 'a')
| 648 |
SET_FILE_BINARY(stdout);
| 649 |
#ifdef getc_unlocked
| 650 |
flockfile(stdout);
| 651 |
#endif
| 652 |
if (verbose)
| 653 |
fprintf(stderr, "%s: writing %smatrix with %d time steps...\n", progname,
| 654 |
outfmt == 'a' ? "" : "binary ", nstored);
| 655 |
if (doheader) {
| 656 |
newheader("RADIANCE", stdout);
| 657 |
printargs(argc, argv, stdout);
| 658 |
printf("LATLONG= %.8f %.8f\n", RadToDeg(s_latitude),
| 659 |
-RadToDeg(s_longitude));
| 660 |
printf("NROWS=%d\n", nskypatch);
| 661 |
printf("NCOLS=%d\n", nstored);
| 662 |
printf("NCOMP=%d\n", NSSAMP);
| 663 |
if ((outfmt == 'f') | (outfmt == 'd'))
| 664 |
fputendian(stdout);
| 665 |
fputformat((char *)getfmtname(outfmt), stdout);
| 666 |
putchar('\n');
| 667 |
| 668 |
/* patches are rows (outer sort) */
| 669 |
for (i = 0; i < nskypatch; i++) {
| 670 |
mtx_offset = NSSAMP * i;
| 671 |
switch (outfmt) {
| 672 |
case 'a':
| 673 |
for (j = 0; j < nstored; j++) {
| 674 |
int k;
| 675 |
| 676 |
printf("%.3g ", mtx_data[mtx_offset + k]);
| 677 |
| 678 |
printf("\n");
| 679 |
mtx_offset += NSSAMP * nskypatch;
| 680 |
| 681 |
if (nstored > 1)
| 682 |
fputc('\n', stdout);
| 683 |
break;
| 684 |
case 'f':
| 685 |
| 686 |
putbinary(mtx_data + mtx_offset, sizeof(float), NSSAMP, stdout);
| 687 |
| 688 |
| 689 |
break;
| 690 |
case 'd':
| 691 |
| 692 |
double ment[NSSAMP];
| 693 |
| 694 |
ment[j] = mtx_data[mtx_offset + j];
| 695 |
putbinary(ment, sizeof(double), NSSAMP, stdout);
| 696 |
| 697 |
| 698 |
break;
| 699 |
| 700 |
if (ferror(stdout))
| 701 |
goto writerr;
| 702 |
| 703 |
alldone:
| 704 |
if (fflush(NULL) == EOF)
| 705 |
goto writerr;
| 706 |
if (verbose)
| 707 |
fprintf(stderr, "%s: done.\n", progname);
| 708 |
exit(0);
| 709 |
userr:
| 710 |
fprintf(stderr,
| 711 |
"Usage: %s [-v][-h][-A][-d|-s|-n][-u][-D file [-M modfile]][-r "
| 712 |
"deg][-m N][-g r g b][-c r g b][-o{f|d}][-O{0|1}] [tape.wea]\n",
| 713 |
progname);
| 714 |
exit(1);
| 715 |
fmterr:
| 716 |
fprintf(stderr, "%s: weather tape format error in header\n", progname);
| 717 |
exit(1);
| 718 |
writerr:
| 719 |
fprintf(stderr, "%s: write error on output\n", progname);
| 720 |
exit(1);
| 721 |
