--- ray/src/gen/gensdaymtx.c 2025/07/02 01:56:35 1.9 +++ ray/src/gen/gensdaymtx.c 2025/07/11 18:12:25 1.10 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: gensdaymtx.c,v 1.9 2025/07/02 01:56:35 greg Exp $"; +static const char RCSid[] = "$Id: gensdaymtx.c,v 1.10 2025/07/11 18:12:25 greg Exp $"; #endif #include @@ -22,58 +22,74 @@ static const char RCSid[] = "$Id: gensdaymtx.c,v 1.9 2 #include "loadEPW.h" -const double SUN_ANG_DEG = 0.533; /* sun full-angle in degrees */ -const double ARCTIC_LAT = 67.; -const double TROPIC_LAT = 23.; -const int SUMMER_START = 4; -const int SUMMER_END = 9; -const double GNORM = 0.777778; +const double SUN_ANG_DEG = 0.533; /* sun full-angle in degrees */ +const double ARCTIC_LAT = 67.; +const double TROPIC_LAT = 23.; +const int SUMMER_START = 4; +const int SUMMER_END = 9; +const double GNORM = 0.777778; +const double M_PER_KM = 1e3; /* Mean normalized relative daylight spectra where CCT = 6415K for overcast */ -const double D6415[NSSAMP] = { +const double D6415[NSSAMP] = { 0.63231, 1.06171, 1.00779, 1.36423, 1.34133, 1.27258, 1.26276, 1.26352, 1.22201, 1.13246, 1.0434, 1.05547, 0.98212, 0.94445, 0.9722, - 0.82387, 0.87853, 0.82559, 0.75111, 0.78925}; + 0.82387, 0.87853, 0.82559, 0.75111, 0.78925 +}; enum { - NSUNPATCH = 4 /* max. # patches to spread sun into */ + NSUNPATCH = 4 /* max. # patches to spread sun into */ }; -double altitude; /* Solar altitude (radians) */ -double azimuth; /* Solar azimuth (radians) */ -int julian_date; /* Julian date */ -double sun_zenith; /* Sun zenith angle (radians) */ -int nskypatch; /* number of Reinhart patches */ -float *rh_palt; /* sky patch altitudes (radians) */ -float *rh_pazi; /* sky patch azimuths (radians) */ -float *rh_dom; /* sky patch solid angle (sr) */ -FVECT sundir; -double sun_ct; /* cos(theta) of sun altitude angle */ +double altitude; /* Solar altitude (radians) */ +double azimuth; /* Solar azimuth (radians) */ +int julian_date; /* Julian date */ +double sun_zenith; /* Sun zenith angle (radians) */ +int nskypatch; /* number of Reinhart patches */ +float *rh_palt; /* sky patch altitudes (radians) */ +float *rh_pazi; /* sky patch azimuths (radians) */ +float *rh_dom; /* sky patch solid angle (sr) */ +FVECT sundir; +double sun_ct; /* cos(theta) of sun altitude angle */ -int input = 0; /* Input type */ -int output = 0; /* Output type */ -int nsuns = NSUNPATCH; /* number of sun patches to use */ -double fixed_sun_sa = -1; /* fixed solid angle per sun? */ -int verbose = 0; /* progress reports to stderr? */ -int outfmt = 'a'; /* output format */ -int rhsubdiv = 1; /* Reinhart sky subdivisions */ -COLOR skycolor = {.96, 1.004, 1.118}; /* sky coloration */ -COLOR suncolor = {1., 1., 1.}; /* sun color */ -double grefl = .2; /* ground reflectance */ +int input = 0; /* Input type */ +int output = 0; /* Output type */ +int nsuns = NSUNPATCH; /* number of sun patches to use */ +double fixed_sun_sa = -1; /* fixed solid angle per sun? */ +int verbose = 0; /* progress reports to stderr? */ +int outfmt = 'a'; /* output format */ +int rhsubdiv = 1; /* Reinhart sky subdivisions */ +COLOR skycolor = {.96, 1.004, 1.118}; /* sky coloration */ +COLOR suncolor = {1., 1., 1.}; /* sun color */ +double grefl = .2; /* ground reflectance */ -static inline double deg_to_rad(double deg) +static inline double +deg_to_rad +( + double deg +) { return deg * (PI / 180.); } -static inline double rad_to_deg(double rad) +static inline double +rad_to_deg +( + double rad +) { return rad * (180. / PI); } -static inline void vectorize(double altitude, double azimuth, FVECT v) +static inline void +vectorize +( + double altitude, + double azimuth, + FVECT v +) { v[1] = cos(altitude); v[0] = (v)[1] * sin(azimuth); @@ -81,40 +97,63 @@ static inline void vectorize(double altitude, double a v[2] = sin(altitude); } -static inline double wmean2(const double a, const double b, const double x) +static inline double +wmean2 +( + const double a, + const double b, + const double x +) { return a * (1 - x) + b * x; } -static inline double wmean( - const double a, const double x, - const double b, const double y) +static inline double +wmean +( + const double a, + const double x, + const double b, + const double y +) { return (a * x + b * y) / (a + b); } -static int make_directory(const char *path) +static int +make_directory +( + const char *path +) { #ifdef _WIN32 if (CreateDirectory(path, NULL) || GetLastError() == ERROR_ALREADY_EXISTS) { return 1; } return 0; + #else if (mkdir(path, 0777) == 0 || errno == EEXIST) { return 1; } return 0; + #endif } -static const char *getfmtname(int fmt) +static const char * +getfmtname +( + int fmt +) { switch (fmt) { case 'a': return ("ascii"); + case 'f': return ("float"); + case 'd': return ("double"); } @@ -122,7 +161,11 @@ static const char *getfmtname(int fmt) } -static double get_overcast_zenith_brightness(const double sundir[3]) +static double +get_overcast_zenith_brightness +( + const double sundir[3] +) { double zenithbr; if (sundir[2] < 0) { @@ -135,15 +178,25 @@ static double get_overcast_zenith_brightness(const dou /* from gensky.c */ -static double get_overcast_brightness(const double dz, const double zenithbr) +static double +get_overcast_brightness +( + const double dz, + const double zenithbr +) { - double groundbr = zenithbr * GNORM; - return wmean(pow(dz + 1.01, 10), - zenithbr * (1 + 2 * dz) / 3, - pow(dz + 1.01, -10), groundbr); + double groundbr = zenithbr * GNORM; + return wmean(pow(dz + 1.01, 10), + zenithbr * (1 + 2 * dz) / 3, + pow(dz + 1.01, -10), groundbr); } -double solar_sunset(int month, int day) +double +solar_sunset +( + int month, + int day +) { float W; W = -1 * (tan(s_latitude) * tan(sdec(jdate(month, day)))); @@ -151,14 +204,23 @@ double solar_sunset(int month, int day) } -double solar_sunrise(int month, int day) +double +solar_sunrise +( + int month, + int day +) { float W; W = -1 * (tan(s_latitude) * tan(sdec(jdate(month, day)))); return 12 - (PI / 2 - atan2(W, sqrt(1 - W * W))) * 180 / (PI * 15); } -int rh_init(void) +int +rh_init +( + void +) { #define NROW 7 static const int tnaz[NROW] = {30, 30, 24, 24, 18, 12, 6}; @@ -166,8 +228,9 @@ int rh_init(void) int p, i, j; /* allocate patch angle arrays */ nskypatch = 0; - for (p = 0; p < NROW; p++) + for (p = 0; p < NROW; p++) { nskypatch += tnaz[p]; + } nskypatch *= rhsubdiv * rhsubdiv; nskypatch += 2; rh_palt = (float *)malloc(sizeof(float) * nskypatch); @@ -177,18 +240,18 @@ int rh_init(void) fprintf(stderr, "%s: out of memory in rh_init()\n", progname); exit(1); } - rh_palt[0] = -PI / 2.; /* ground & zenith patches */ + rh_palt[0] = -PI / 2.; /* ground & zenith patches */ rh_pazi[0] = 0.; rh_dom[0] = 2. * PI; rh_palt[nskypatch - 1] = PI / 2.; rh_pazi[nskypatch - 1] = 0.; rh_dom[nskypatch - 1] = 2. * PI * (1. - cos(alpha * .5)); - p = 1; /* "normal" patches */ + p = 1; /* "normal" patches */ for (i = 0; i < NROW * rhsubdiv; i++) { const float ralt = alpha * (i + .5); const int ninrow = tnaz[i / rhsubdiv] * rhsubdiv; const float dom = - 2. * PI * (sin(alpha * (i + 1)) - sin(alpha * i)) / (double)ninrow; + 2. * PI * (sin(alpha * (i + 1)) - sin(alpha * i)) / (double)ninrow; for (j = 0; j < ninrow; j++) { rh_palt[p] = ralt; rh_pazi[p] = 2. * PI * j / (double)ninrow; @@ -196,27 +259,40 @@ int rh_init(void) } } return nskypatch; + #undef NROW } /* Resize daylight matrix (GW) */ -float *resize_dmatrix(float *mtx_data, int nsteps, int npatch) +float * +resize_dmatrix +( + float *mtx_data, + int nsteps, + int npatch +) { - if (mtx_data == NULL) + if (mtx_data == NULL) { mtx_data = (float * ) malloc(sizeof(float) * NSSAMP * nsteps * npatch); - else + }else{ mtx_data = (float * ) realloc(mtx_data, - sizeof(float) * NSSAMP * nsteps * npatch); + sizeof(float) * NSSAMP * nsteps * npatch); + } if (mtx_data == NULL) { fprintf(stderr, "%s: out of memory in resize_dmatrix(%d,%d)\n", progname, nsteps, npatch); exit(1); - } - return mtx_data; + } + return mtx_data; } -static Atmosphere init_atmos(const double aod, const double grefl) +static Atmosphere +init_atmos +( + const double aod, + const double grefl +) { Atmosphere atmos = { .ozone_density = { @@ -256,26 +332,38 @@ static Atmosphere init_atmos(const double aod, const d return atmos; } -static DpPaths get_dppaths(const char *dir, const double aod, - const char *mname, const char *tag) +static DpPaths +get_dppaths +( + const char *dir, + const double aod, + const char *mname, + const char *tag +) { DpPaths paths; snprintf(paths.tau, PATH_MAX, "%s%ctau_%s_%s_%.2f.dat", - dir, DIRSEP, tag, mname, aod); + dir, DIRSEP, tag, mname, aod); snprintf(paths.scat, PATH_MAX, "%s%cscat_%s_%s_%.2f.dat", - dir, DIRSEP, tag, mname, aod); + dir, DIRSEP, tag, mname, aod); snprintf(paths.scat1m, PATH_MAX, "%s%cscat1m_%s_%s_%.2f.dat", - dir, DIRSEP, tag, mname, aod); + dir, DIRSEP, tag, mname, aod); snprintf(paths.irrad, PATH_MAX, "%s%cirrad_%s_%s_%.2f.dat", - dir, DIRSEP, tag, mname, aod); + dir, DIRSEP, tag, mname, aod); return paths; } -static void set_rayleigh_density_profile(Atmosphere *atmos, - char *tag, const int is_summer, const double s_latitude) +static void +set_rayleigh_density_profile +( + Atmosphere *atmos, + char *tag, + const int is_summer, + const double s_latitude +) { /* Set rayleigh density profile */ if (fabs(s_latitude * 180.0 / PI) > ARCTIC_LAT) { @@ -311,8 +399,17 @@ static void set_rayleigh_density_profile(Atmosphere *a /* Add in solar direct to nearest sky patches (GW) */ -void add_direct(DATARRAY *tau, DATARRAY *scat, DATARRAY *scat1m, DATARRAY *irrad, - double ccover, double dirnorm, float *parr) +void +add_direct +( + DATARRAY *tau, + DATARRAY *scat, + DATARRAY *scat1m, + DATARRAY *irrad, + double ccover, + double dirnorm, + float *parr +) { FVECT svec; double near_dprod[NSUNPATCH]; @@ -321,15 +418,16 @@ void add_direct(DATARRAY *tau, DATARRAY *scat, DATARRA int i, j, p; /* identify nsuns closest patches */ - for (i = nsuns; i--;) + for (i = nsuns; i--;) { near_dprod[i] = -1.; + } vectorize(altitude, azimuth, svec); for (p = 1; p < nskypatch; p++) { FVECT pvec; double dprod; vectorize(rh_palt[p], rh_pazi[p], pvec); dprod = DOT(pvec, svec); - for (i = 0; i < nsuns; i++) + for (i = 0; i < nsuns; i++) { if (dprod > near_dprod[i]) { for (j = nsuns; --j > i;) { near_dprod[j] = near_dprod[j - 1]; @@ -339,6 +437,7 @@ void add_direct(DATARRAY *tau, DATARRAY *scat, DATARRA near_patch[i] = p; break; } + } } /* Get solar radiance */ double sun_radiance[NSSAMP] = {0}; @@ -363,16 +462,18 @@ void add_direct(DATARRAY *tau, DATARRAY *scat, DATARRA intensity = dirnorm / SOLOMG / WHTEFFICACY; } double dir_ratio = 1.; - if (mean > 0) + if (mean > 0) { dir_ratio = intensity / mean; + } for (i = 0; i < NSSAMP; ++i) { sun_radiance[i] *= dir_ratio; } /* weight by proximity */ wtot = 0; - for (i = nsuns; i--;) + for (i = nsuns; i--;) { wtot += wta[i] = 1. / (1.002 - near_dprod[i]); + } /* add to nearest patch radiances */ for (i = nsuns; i--;) { float *pdest = parr + NSSAMP * near_patch[i]; @@ -384,22 +485,31 @@ void add_direct(DATARRAY *tau, DATARRAY *scat, DATARRA } -void calc_sky_patch_radiance(DATARRAY *scat, DATARRAY *scat1m, - DATARRAY *irrad_clear, double ccover, double dif_ratio, - double overcast_zenithbr, FVECT view_point, float *parr) +void +calc_sky_patch_radiance +( + DATARRAY *scat, + DATARRAY *scat1m, + DATARRAY *irrad_clear, + double ccover, + double dif_ratio, + double overcast_zenithbr, + FVECT view_point, + float *parr +) { - double mu_sky; /* Sun-sky point azimuthal angle */ - double sspa; /* Sun-sky point angle */ - int i; + double mu_sky; /* Sun-sky point azimuthal angle */ + double sspa; /* Sun-sky point angle */ + int i; for (i = 1; i < nskypatch; i++) { - FVECT rdir_sky; + FVECT rdir_sky; vectorize(rh_palt[i], rh_pazi[i], rdir_sky); mu_sky = fdot(view_point, rdir_sky) / ER; sspa = fdot(rdir_sky, sundir); - SCOLOR sky_radiance = {0}; + SCOLOR sky_radiance = {0}; get_sky_radiance(scat, scat1m, ER, mu_sky, sun_ct, sspa, sky_radiance); - int k; + int k; for (k = 0; k < NSSAMP; ++k) { sky_radiance[k] *= WVLSPAN; } @@ -424,8 +534,18 @@ void calc_sky_patch_radiance(DATARRAY *scat, DATARRAY /* Compute sky patch radiance values (modified by GW) */ -void compute_sky(DATARRAY *tau, DATARRAY *scat, DATARRAY *scat1m, - DATARRAY *irrad, double ccover, double difhor, FVECT view_point, float *parr) +void +compute_sky +( + DATARRAY *tau, + DATARRAY *scat, + DATARRAY *scat1m, + DATARRAY *irrad, + double ccover, + double difhor, + FVECT view_point, + float *parr +) { float sun_zenith; SCOLOR sky_radiance = {0}; @@ -440,12 +560,13 @@ void compute_sky(DATARRAY *tau, DATARRAY *scat, DATARR /* Calculate sun zenith angle (don't let it dip below horizon) */ /* Also limit minimum angle to keep circumsolar off zenith */ - if (altitude <= 0.0) + if (altitude <= 0.0) { sun_zenith = deg_to_rad(90.0); - else if (altitude >= deg_to_rad(87.0)) + }else if (altitude >= deg_to_rad(87.0)) { sun_zenith = deg_to_rad(3.0); - else + }else{ sun_zenith = deg_to_rad(90.0) - altitude; + } double overcast_zenithbr = get_overcast_zenith_brightness(sundir); @@ -457,12 +578,12 @@ void compute_sky(DATARRAY *tau, DATARRAY *scat, DATARR double diffuse_irradiance = 0; int l; for (l = 0; l < NSSAMP; ++l) { - diffuse_irradiance += indirect_irradiance_clear->arr.d[l] * 20; /* 20nm interval */ + diffuse_irradiance += indirect_irradiance_clear->arr.d[l] * 20; /* 20nm interval */ } /* free(indirect_irradiance_clear); */ diffuse_irradiance = wmean2(diffuse_irradiance, overcast_ghi, ccover); if (diffuse_irradiance > 0) { - dif_ratio = difhor / WHTEFFICACY / diffuse_irradiance / 1.15; /* fudge */ + dif_ratio = difhor / WHTEFFICACY / diffuse_irradiance / 1.15; /* fudge */ } } @@ -476,45 +597,50 @@ void compute_sky(DATARRAY *tau, DATARRAY *scat, DATARR calc_sky_patch_radiance(scat, scat1m, irrad, ccover, dif_ratio, overcast_zenithbr, view_point, parr); } -int main(int argc, char *argv[]) +int +main +( + int argc, + char *argv[] +) { - EPWheader *epw = NULL; /* EPW/WEA input file */ - EPWrecord erec; /* current EPW/WEA input record */ - int doheader = 1; /* output header? */ - double rotation = 0.0; /* site rotation (degrees) */ - double elevation = 0; /* site elevation (meters) */ - int leap_day = 0; /* add leap day? */ - int sun_hours_only = 0; /* only output sun hours? */ - int dir_is_horiz; /* direct is meas. on horizontal? */ - int ntsteps = 0; /* number of time steps */ - int tstorage = 0; /* number of allocated time steps */ - int nstored = 0; /* number of time steps in matrix */ - int last_monthly = 0; /* month of last report */ - double dni; /* direct normal illuminance */ - double dhi; /* diffuse horizontal illuminance */ + EPWheader *epw = NULL; /* EPW/WEA input file */ + EPWrecord erec; /* current EPW/WEA input record */ + int doheader = 1; /* output header? */ + double rotation = 0.0; /* site rotation (degrees) */ + double elevation = 0; /* site elevation (meters) */ + int leap_day = 0; /* add leap day? */ + int sun_hours_only = 0; /* only output sun hours? */ + int dir_is_horiz; /* direct is meas. on horizontal? */ + int ntsteps = 0; /* number of time steps */ + int tstorage = 0; /* number of allocated time steps */ + int nstored = 0; /* number of time steps in matrix */ + int last_monthly = 0; /* month of last report */ + double dni; /* direct normal illuminance */ + double dhi; /* diffuse horizontal illuminance */ - float *mtx_data = NULL; - int mtx_offset = 0; - double timeinterval = 0; - char lstag[3]; - char *mie_path = getpath("mie_ca.dat", getrlibpath(), R_OK); - char *ddir = "."; - char mie_name[20] = "mie_ca"; - int num_threads = 1; - int sorder = 4; - int solar_only = 0; - int sky_only = 0; - int i, j; - FVECT view_point = {0, 0, ER}; + float *mtx_data = NULL; + int mtx_offset = 0; + double timeinterval = 0; + char lstag[3]; + char *mie_path = getpath("mie_ca.dat", getrlibpath(), R_OK); + char *ddir = "."; + char mie_name[20] = "mie_ca"; + int num_threads = 1; + int sorder = 4; + int solar_only = 0; + int sky_only = 0; + int i, j, k; + FVECT view_point = {0, 0, ER}; fixargv0(argv[0]); for (i = 1; i < argc && argv[i][0] == '-'; i++) { switch (argv[i][1]) { - case 'd': /* solar (direct) only */ + case 'd': /* solar (direct) only */ solar_only = 1; break; - case 's': /* sky only (no direct) */ + case 's': /* sky only (no direct) */ sky_only = 1; break; case 'g': @@ -526,29 +652,30 @@ int main(int argc, char *argv[]) case 'n': num_threads = atoi(argv[++i]); break; - case 'r': /* rotate distribution */ - if (argv[i][2] && argv[i][2] != 'z') + case 'r': /* rotate distribution */ + if (argv[i][2] && argv[i][2] != 'z') { goto userr; + } rotation = atof(argv[++i]); break; - case 'u': /* solar hours only */ + case 'u': /* solar hours only */ sun_hours_only = 1; break; case 'p': ddir = argv[++i]; break; - case 'v': /* verbose progress reports */ + case 'v': /* verbose progress reports */ verbose++; break; - case 'h': /* turn off header */ + case 'h': /* turn off header */ doheader = 0; break; - case '5': /* 5-phase calculation */ + case '5': /* 5-phase calculation */ nsuns = 1; fixed_sun_sa = PI / 360. * atof(argv[++i]); if (fixed_sun_sa <= 0) { fprintf( - stderr, + stderr, "%s: missing solar disk size argument for '-5' option\n", progname); exit(1); @@ -558,7 +685,7 @@ int main(int argc, char *argv[]) case 'i': timeinterval = atof(argv[++i]); break; - case 'o': /* output format */ + case 'o': /* output format */ switch (argv[i][2]) { case 'f': case 'd': @@ -573,39 +700,42 @@ int main(int argc, char *argv[]) goto userr; } } - if (i < argc - 1) + if (i < argc - 1) { goto userr; + } epw = EPWopen(argv[i]); - if (epw == NULL) + if (epw == NULL) { exit(1); + } if (i == argc - 1 && freopen(argv[i], "r", stdin) == NULL) { fprintf(stderr, "%s: cannot open '%s' for input\n", progname, argv[i]); exit(1); } if (verbose) { - if (i == argc - 1) + if (i == argc - 1) { fprintf(stderr, "%s: reading weather tape '%s'\n", progname, argv[i]); - else + }else{ fprintf(stderr, "%s: reading weather tape from \n", progname); + } } s_latitude = epw->loc.latitude; s_longitude = -epw->loc.longitude; s_meridian = -15.*epw->loc.timezone; elevation = epw->loc.elevation; - switch (epw->isWEA) { /* translate units */ + switch (epw->isWEA) { /* translate units */ case WEAnot: case WEAradnorm: - input = 1; /* radiometric quantities */ - dir_is_horiz = 0; /* direct is perpendicular meas. */ + input = 1; /* radiometric quantities */ + dir_is_horiz = 0; /* direct is perpendicular meas. */ break; case WEAradhoriz: - input = 1; /* radiometric quantities */ - dir_is_horiz = 1; /* solar measured horizontally */ + input = 1; /* radiometric quantities */ + dir_is_horiz = 1; /* solar measured horizontally */ break; case WEAphotnorm: - input = 2; /* photometric quantities */ - dir_is_horiz = 0; /* direct is perpendicular meas. */ + input = 2; /* photometric quantities */ + dir_is_horiz = 0; /* direct is perpendicular meas. */ break; default: goto fmterr; @@ -616,11 +746,12 @@ int main(int argc, char *argv[]) if (verbose) { fprintf(stderr, "%s: location '%s %s'\n", progname, epw->loc.city, epw->loc.country); fprintf( - stderr, + stderr, "%s: (lat,long)=(%.1f,%.1f) degrees north, west\n", progname, s_latitude, s_longitude); - if (rotation != 0) + if (rotation != 0) { fprintf(stderr, "%s: rotating output %.0f degrees\n", progname, rotation); + } } s_latitude = deg_to_rad(s_latitude); @@ -644,36 +775,38 @@ int main(int argc, char *argv[]) } while ((j = EPWread(epw, &erec)) > 0) { - const int mo = erec.date.month+1; - const int da = erec.date.day; - const double hr = erec.date.hour; - double aod = erec.optdepth * 1e3; + const int mo = erec.date.month+1; + const int da = erec.date.day; + const double hr = erec.date.hour; + double aod = erec.optdepth * M_PER_KM; if (aod >= 999.0) { - fprintf(stderr, "aod not set, using default value %.3f\n", AOD0_CA); aod = AOD0_CA; + fprintf(stderr, "aod is not set, using default value %.3f\n", AOD0_CA); } double cc = erec.skycover; if (cc >= 99.0) { - fprintf(stderr, "skycover not set, using default value 0.0\n"); cc = 0.0; + fprintf(stderr, "skycover is not set, using default value %.3f\n", 0.0); } - double sda, sta, st; - int sun_in_sky; + double sda, sta, st; + int sun_in_sky; /* compute solar position */ if ((mo == 2) & (da == 29)) { julian_date = 60; leap_day = 1; - } else + } else{ julian_date = jdate(mo, da) + leap_day; + } sda = sdec(julian_date); sta = stadj(julian_date); st = hr + sta; if (timeinterval > 0) { - if (fabs(solar_sunrise(mo, da) - st) <= timeinterval/120) + if (fabs(solar_sunrise(mo, da) - st) <= timeinterval/120) { st = (st + timeinterval/120 + solar_sunrise(mo, da))/2; - else if (fabs(solar_sunset(mo, da) - st) < timeinterval/120) + }else if (fabs(solar_sunset(mo, da) - st) < timeinterval/120) { st = (st - timeinterval/120 + solar_sunset(mo, da))/2; + } } altitude = salt(sda, st); sun_in_sky = (altitude > -deg_to_rad(SUN_ANG_DEG / 2.)); @@ -682,7 +815,7 @@ int main(int argc, char *argv[]) vectorize(altitude, azimuth, sundir); if (sun_hours_only && !sun_in_sky) { - continue; /* skipping nighttime points */ + continue; /* skipping nighttime points */ } sun_ct = fdot(view_point, sundir) / ER; @@ -697,7 +830,7 @@ int main(int argc, char *argv[]) tstorage += (tstorage >> 1) + nstored + 7; mtx_data = resize_dmatrix(mtx_data, tstorage, nskypatch); } - ntsteps++; /* keep count of time steps */ + ntsteps++; /* keep count of time steps */ /* compute sky patch values */ Atmosphere clear_atmos = init_atmos(aod, grefl); @@ -711,9 +844,10 @@ int main(int argc, char *argv[]) char gsdir[PATH_MAX]; size_t siz = strlen(ddir); - if (ISDIRSEP(ddir[siz - 1])) + if (ISDIRSEP(ddir[siz - 1])) { ddir[siz - 1] = '\0'; - snprintf(gsdir, PATH_MAX, "%s%catmos_data", ddir, DIRSEP); + } + snprintf(gsdir, PATH_MAX, "%s%catmos_data", ddir, DIRSEP); if (!make_directory(gsdir)) { fprintf(stderr, "Failed creating atmos_data directory"); exit(1); @@ -736,16 +870,19 @@ int main(int argc, char *argv[]) DATARRAY *scat_clear_dp = getdata(clear_paths.scat); DATARRAY *scat1m_clear_dp = getdata(clear_paths.scat1m); - if (!solar_only) + if (!solar_only) { compute_sky(tau_clear_dp, scat_clear_dp, scat1m_clear_dp, irrad_clear_dp, - cc, dhi, view_point, mtx_data + mtx_offset); - if (!sky_only) + cc, dhi, view_point, mtx_data + mtx_offset); + } + if (!sky_only) { add_direct(tau_clear_dp, scat_clear_dp, scat1m_clear_dp, irrad_clear_dp, - cc, dni, mtx_data + mtx_offset); + cc, dni, mtx_data + mtx_offset); + } /* monthly reporting */ - if (verbose && mo != last_monthly) + if (verbose && mo != last_monthly) { fprintf(stderr, "%s: stepping through month %d...\n", progname, - last_monthly = mo); + last_monthly = mo); + } } if (j != EOF) { fprintf(stderr, "%s: error on input\n", progname); @@ -758,26 +895,28 @@ int main(int argc, char *argv[]) exit(1); } /* write out matrix */ - if (outfmt != 'a') + if (outfmt != 'a') { SET_FILE_BINARY(stdout); + } #ifdef getc_unlocked flockfile(stdout); #endif - if (verbose) + if (verbose) { fprintf(stderr, "%s: writing %smatrix with %d time steps...\n", progname, - outfmt == 'a' ? "" : "binary ", nstored); + outfmt == 'a' ? "" : "binary ", nstored); + } if (doheader) { newheader("RADIANCE", stdout); printargs(argc, argv, stdout); printf("LATLONG= %.8f %.8f\n", rad_to_deg(s_latitude), - -rad_to_deg(s_longitude)); + -rad_to_deg(s_longitude)); printf("NROWS=%d\n", nskypatch); printf("NCOLS=%d\n", nstored); printf("NCOMP=%d\n", NSSAMP); - float wvsplit[4] = {380, 480, 588, 780}; - fputwlsplit(wvsplit, stdout); - if ((outfmt == 'f') | (outfmt == 'd')) + fputwlsplit(WLPART, stdout); + if ((outfmt == 'f') | (outfmt == 'd')) { fputendian(stdout); + } fputformat((char *)getfmtname(outfmt), stdout); putchar('\n'); } @@ -787,41 +926,48 @@ int main(int argc, char *argv[]) switch (outfmt) { case 'a': for (j = 0; j < nstored; j++) { - int k; - for (k = 0; k < NSSAMP; k++) { + for (k = NSSAMP - 1; k >= 0; k--) { printf("%.3g ", mtx_data[mtx_offset + k]); } printf("\n"); mtx_offset += NSSAMP * nskypatch; } - if (nstored > 1) + if (nstored > 1) { fputc('\n', stdout); + } break; case 'f': for (j = 0; j < nstored; j++) { - putbinary(mtx_data + mtx_offset, sizeof(float), NSSAMP, stdout); + float ment[NSSAMP]; + for (k = NSSAMP - 1; k >= 0; k--) { + ment[k] = mtx_data[mtx_offset + k]; + } + putbinary(ment, sizeof(float), NSSAMP, stdout); mtx_offset += NSSAMP * nskypatch; } break; case 'd': for (j = 0; j < nstored; j++) { double ment[NSSAMP]; - for (j = 0; j < NSSAMP; j++) - ment[j] = mtx_data[mtx_offset + j]; + for (k = NSSAMP - 1; k >= 0; k--) { + ment[j] = mtx_data[mtx_offset + k]; + } putbinary(ment, sizeof(double), NSSAMP, stdout); mtx_offset += NSSAMP * nskypatch; } break; } - if (ferror(stdout)) + if (ferror(stdout)) { goto writerr; + } } return 0; + userr: fprintf(stderr, - "Usage: %s [-v][-h][-A][-d|-s|-n][-u][-D file [-M modfile]][-r " - "deg][-m N][-g r g b][-c r g b][-o{f|d}][-O{0|1}] [tape.wea]\n", - progname); + "Usage: %s [-v][-h][-A][-d|-s|-n][-u][-D file [-M modfile]][-r " + "deg][-m N][-g r g b][-c r g b][-o{f|d}][-O{0|1}] [tape.wea]\n", + progname); exit(1); fmterr: fprintf(stderr, "%s: weather tape format error in header\n", progname);
