root/Development/ray/src/gen/gensdaymtx.c
Fri Aug 22 01:04:30 2025 UTC (2 months, 2 weeks ago) by greg
Changes since 1.12: +6 -6 lines
Diff to previous 1.12 , to selected 1.3
fix(gensdaymtx): Corrected handling of zero values
Mon Aug 4 23:45:20 2025 UTC (3 months ago) by greg
Changes since 1.11: +5 -5 lines
Diff to previous 1.11 , to selected 1.3
fix(gensdaymtx): Fixed spectral ordering for -of and -od output
Mon Aug 4 20:50:41 2025 UTC (3 months ago) by greg
Changes since 1.10: +3 -3 lines
Diff to previous 1.10 , to selected 1.3
fix(genssky,gensdaymtx): Fixed return status from main()
Fri Jul 11 18:12:25 2025 UTC (3 months, 3 weeks ago) by greg
CVS Tags: rad6R0
Changes since 1.9: +332 -186 lines
Diff to previous 1.9 , to selected 1.3
fix(genssky,gensdaymtx): Spectral data ordering was reversed in output HSR's (TW)
Wed Jul 2 01:56:35 2025 UTC (4 months ago) by greg
Changes since 1.8: +10 -6 lines
Diff to previous 1.8 , to selected 1.3
fix(gensdaymtx): Set optical depth and sy cover default values correctly (TW)
Sat Jun 7 05:09:45 2025 UTC (4 months, 4 weeks ago) by greg
Changes since 1.7: +1 -2 lines
Diff to previous 1.7 , to selected 1.3
Fri Jun 6 19:11:21 2025 UTC (4 months, 4 weeks ago) by greg
Diff to previous 1.6 , to selected 1.3
refactor: Making use of printargs() more consistent with fixargv0()
Tue Apr 15 20:15:50 2025 UTC (6 months, 3 weeks ago) by greg
Changes since 1.5: +739 -727 lines
Diff to previous 1.5 , to selected 1.3
fix(gensdaymtx): Added WAVELENGTH_SPLITS= to header output and code cleanup by TW
Thu Apr 10 23:30:58 2025 UTC (6 months, 3 weeks ago) by greg
Changes since 1.4: +550 -454 lines
Diff to previous 1.4 , to selected 1.3
feat(gensdaymtx,genssky): TW fixed bug in genssky and added absolute calibration
Thu Aug 8 02:00:20 2024 UTC (14 months, 4 weeks ago) by greg
Changes since 1.3: +23 -13 lines
Diff to previous 1.3
fix(gensdaymtx): Fixed sky value accumulation in first column/timestep
Revision 1.3 - (view) (download) (annotate) - [selected]
Fri Aug 2 23:13:54 2024 UTC (15 months ago) by greg
Changes since 1.2: +1 -7 lines
Diff to previous 1.2
perf(gensdaymtx): Removed calls to freedata(), which were re-loading files unnecessarily
Fri Aug 2 19:01:13 2024 UTC (15 months ago) by greg
Changes since 1.1: +3 -0 lines
Diff to previous 1.1 , to selected 1.3
chore: Added missing RCSID and dependencies in Rmakefile
Fri Aug 2 18:59:26 2024 UTC (15 months ago) by greg
Diff to selected 1.3
feat(gensdaymtx,epw2wea,genssky): Taoning added new gensdaymtx and updated others
