1 |
#ifndef lint |
2 |
static const char RCSid[] = "$Id$"; |
3 |
#endif |
4 |
#include "atmos.h" |
5 |
#include "copyright.h" |
6 |
#include "data.h" |
7 |
#include "platform.h" |
8 |
#include "rtio.h" |
9 |
#include <ctype.h> |
10 |
#include <stdlib.h> |
11 |
#ifdef _WIN32 |
12 |
#include <windows.h> |
13 |
#else |
14 |
#include <errno.h> |
15 |
#include <sys/stat.h> |
16 |
#include <sys/types.h> |
17 |
#endif |
18 |
19 |
char *progname; |
20 |
21 |
double altitude; /* Solar altitude (radians) */ |
22 |
double azimuth; /* Solar azimuth (radians) */ |
23 |
int julian_date; /* Julian date */ |
24 |
double sun_zenith; /* Sun zenith angle (radians) */ |
25 |
int input = 0; /* Input type */ |
26 |
int output = 0; /* Output type */ |
27 |
FVECT sundir; |
28 |
29 |
const double ARCTIC_LAT = 67.; |
30 |
const double TROPIC_LAT = 23.; |
31 |
const int SUMMER_START = 4; |
32 |
const int SUMMER_END = 9; |
33 |
const double GNORM = 0.777778; |
34 |
35 |
const double D65EFF = 203.; /* standard illuminant D65 */ |
36 |
37 |
/* Mean normalized relative daylight spectra where CCT = 6415K for overcast */ |
38 |
const double D6415[NSSAMP] = {0.63231, 1.06171, 1.00779, 1.36423, 1.34133, |
39 |
1.27258, 1.26276, 1.26352, 1.22201, 1.13246, |
40 |
1.0434, 1.05547, 0.98212, 0.94445, 0.9722, |
41 |
0.82387, 0.87853, 0.82559, 0.75111, 0.78925}; |
42 |
/* Degrees into radians */ |
43 |
#define DegToRad(deg) ((deg) * (PI / 180.)) |
44 |
45 |
/* Radiuans into degrees */ |
46 |
#define RadToDeg(rad) ((rad) * (180. / PI)) |
47 |
48 |
#ifndef NSUNPATCH |
49 |
#define NSUNPATCH 4 /* max. # patches to spread sun into */ |
50 |
#endif |
51 |
52 |
#define SUN_ANG_DEG 0.533 /* sun full-angle in degrees */ |
53 |
54 |
int nsuns = NSUNPATCH; /* number of sun patches to use */ |
55 |
double fixed_sun_sa = -1; /* fixed solid angle per sun? */ |
56 |
57 |
int verbose = 0; /* progress reports to stderr? */ |
58 |
59 |
int outfmt = 'a'; /* output format */ |
60 |
61 |
int rhsubdiv = 1; /* Reinhart sky subdivisions */ |
62 |
63 |
COLOR skycolor = {.96, 1.004, 1.118}; /* sky coloration */ |
64 |
COLOR suncolor = {1., 1., 1.}; /* sun color */ |
65 |
double grefl = .2; /* ground reflectance */ |
66 |
67 |
int nskypatch; /* number of Reinhart patches */ |
68 |
float *rh_palt; /* sky patch altitudes (radians) */ |
69 |
float *rh_pazi; /* sky patch azimuths (radians) */ |
70 |
float *rh_dom; /* sky patch solid angle (sr) */ |
71 |
72 |
double sun_ct; |
73 |
74 |
#define vector(v, alt, azi) \ |
75 |
((v)[1] = cos(alt), (v)[0] = (v)[1] * sin(azi), (v)[1] *= cos(azi), \ |
76 |
(v)[2] = sin(alt)) |
77 |
78 |
#define rh_vector(v, i) vector(v, rh_palt[i], rh_pazi[i]) |
79 |
80 |
#define rh_cos(i) tsin(rh_palt[i]) |
81 |
82 |
#define solar_minute(jd, hr) ((24 * 60) * ((jd) - 1) + (int)((hr) * 60. + .5)) |
83 |
84 |
inline void vectorize(double altitude, double azimuth, FVECT v) { |
85 |
v[1] = cos(altitude); |
86 |
v[0] = (v)[1] * sin(azimuth); |
87 |
v[1] *= cos(azimuth); |
88 |
v[2] = sin(altitude); |
89 |
90 |
91 |
static int make_directory(const char *path) { |
92 |
#ifdef _WIN32 |
93 |
if (CreateDirectory(path, NULL) || GetLastError() == ERROR_ALREADY_EXISTS) { |
94 |
return 1; |
95 |
96 |
return 0; |
97 |
#else |
98 |
if (mkdir(path, 0777) == 0 || errno == EEXIST) { |
99 |
return 1; |
100 |
101 |
return 0; |
102 |
#endif |
103 |
104 |
105 |
static const char *getfmtname(int fmt) { |
106 |
switch (fmt) { |
107 |
case 'a': |
108 |
return ("ascii"); |
109 |
case 'f': |
110 |
return ("float"); |
111 |
case 'd': |
112 |
return ("double"); |
113 |
114 |
return ("unknown"); |
115 |
116 |
117 |
static inline double wmean2(const double a, const double b, const double x) { |
118 |
return a * (1 - x) + b * x; |
119 |
120 |
121 |
static inline double wmean(const double a, const double x, const double b, |
122 |
const double y) { |
123 |
return (a * x + b * y) / (a + b); |
124 |
125 |
126 |
static double get_zenith_brightness(const double sundir[3]) { |
127 |
double zenithbr; |
128 |
if (sundir[2] < 0) { |
129 |
zenithbr = 0; |
130 |
} else { |
131 |
zenithbr = (8.6 * sundir[2] + .123) * 1000.0 / D65EFF; |
132 |
133 |
return zenithbr; |
134 |
135 |
136 |
/* from gensky.c */ |
137 |
static double get_overcast_brightness(const double dz, const double zenithbr) { |
138 |
double groundbr = zenithbr * GNORM; |
139 |
return wmean(pow(dz + 1.01, 10), zenithbr * (1 + 2 * dz) / 3, |
140 |
pow(dz + 1.01, -10), groundbr); |
141 |
142 |
143 |
int rh_init(void) { |
144 |
#define NROW 7 |
145 |
static const int tnaz[NROW] = {30, 30, 24, 24, 18, 12, 6}; |
146 |
const double alpha = (PI / 2.) / (NROW * rhsubdiv + .5); |
147 |
int p, i, j; |
148 |
/* allocate patch angle arrays */ |
149 |
nskypatch = 0; |
150 |
for (p = 0; p < NROW; p++) |
151 |
nskypatch += tnaz[p]; |
152 |
nskypatch *= rhsubdiv * rhsubdiv; |
153 |
nskypatch += 2; |
154 |
rh_palt = (float *)malloc(sizeof(float) * nskypatch); |
155 |
rh_pazi = (float *)malloc(sizeof(float) * nskypatch); |
156 |
rh_dom = (float *)malloc(sizeof(float) * nskypatch); |
157 |
if ((rh_palt == NULL) | (rh_pazi == NULL) | (rh_dom == NULL)) { |
158 |
fprintf(stderr, "%s: out of memory in rh_init()\n", progname); |
159 |
exit(1); |
160 |
161 |
rh_palt[0] = -PI / 2.; /* ground & zenith patches */ |
162 |
rh_pazi[0] = 0.; |
163 |
rh_dom[0] = 2. * PI; |
164 |
rh_palt[nskypatch - 1] = PI / 2.; |
165 |
rh_pazi[nskypatch - 1] = 0.; |
166 |
rh_dom[nskypatch - 1] = 2. * PI * (1. - cos(alpha * .5)); |
167 |
p = 1; /* "normal" patches */ |
168 |
for (i = 0; i < NROW * rhsubdiv; i++) { |
169 |
const float ralt = alpha * (i + .5); |
170 |
const int ninrow = tnaz[i / rhsubdiv] * rhsubdiv; |
171 |
const float dom = |
172 |
2. * PI * (sin(alpha * (i + 1)) - sin(alpha * i)) / (double)ninrow; |
173 |
for (j = 0; j < ninrow; j++) { |
174 |
rh_palt[p] = ralt; |
175 |
rh_pazi[p] = 2. * PI * j / (double)ninrow; |
176 |
rh_dom[p++] = dom; |
177 |
178 |
179 |
return nskypatch; |
180 |
#undef NROW |
181 |
182 |
183 |
/* Resize daylight matrix (GW) */ |
184 |
float *resize_dmatrix(float *mtx_data, int nsteps, int npatch) { |
185 |
if (mtx_data == NULL) |
186 |
mtx_data = (float *)malloc(sizeof(float) * NSSAMP * nsteps * npatch); |
187 |
else |
188 |
mtx_data = |
189 |
(float *)realloc(mtx_data, sizeof(float) * NSSAMP * nsteps * npatch); |
190 |
if (mtx_data == NULL) { |
191 |
fprintf(stderr, "%s: out of memory in resize_dmatrix(%d,%d)\n", progname, |
192 |
nsteps, npatch); |
193 |
exit(1); |
194 |
195 |
return (mtx_data); |
196 |
197 |
198 |
static Atmosphere init_atmos(const double aod, const double grefl) { |
199 |
Atmosphere atmos = {.ozone_density = {.layers = |
200 |
201 |
{.width = 25000.0, |
202 |
.exp_term = 0.0, |
203 |
.exp_scale = 0.0, |
204 |
.linear_term = 1.0 / 15000.0, |
205 |
.constant_term = -2.0 / 3.0}, |
206 |
{.width = AH, |
207 |
.exp_term = 0.0, |
208 |
.exp_scale = 0.0, |
209 |
.linear_term = -1.0 / 15000.0, |
210 |
.constant_term = 8.0 / 3.0}, |
211 |
212 |
.rayleigh_density = {.layers = |
213 |
214 |
{.width = AH, |
215 |
.exp_term = 1.0, |
216 |
.exp_scale = -1.0 / HR_MS, |
217 |
.linear_term = 0.0, |
218 |
.constant_term = 0.0}, |
219 |
220 |
.beta_r0 = BR0_MS, |
221 |
.beta_scale = aod / AOD0_CA, |
222 |
.beta_m = NULL, |
223 |
.grefl = grefl}; |
224 |
return atmos; |
225 |
226 |
227 |
static DpPaths get_dppaths(const char *dir, const double aod, const char *mname, |
228 |
const char *tag) { |
229 |
DpPaths paths; |
230 |
231 |
snprintf(paths.tau, PATH_MAX, "%s%ctau_%s_%s_%.2f.dat", dir, DIRSEP, tag, |
232 |
mname, aod); |
233 |
snprintf(paths.scat, PATH_MAX, "%s%cscat_%s_%s_%.2f.dat", dir, DIRSEP, tag, |
234 |
mname, aod); |
235 |
snprintf(paths.scat1m, PATH_MAX, "%s%cscat1m_%s_%s_%.2f.dat", dir, DIRSEP, |
236 |
tag, mname, aod); |
237 |
snprintf(paths.irrad, PATH_MAX, "%s%cirrad_%s_%s_%.2f.dat", dir, DIRSEP, tag, |
238 |
mname, aod); |
239 |
240 |
return paths; |
241 |
242 |
static void set_rayleigh_density_profile(Atmosphere *atmos, char *tag, |
243 |
const int is_summer, |
244 |
const double s_latitude) { |
245 |
/* Set rayleigh density profile */ |
246 |
if (fabs(s_latitude * 180.0 / PI) > ARCTIC_LAT) { |
247 |
tag[0] = 's'; |
248 |
if (is_summer) { |
249 |
tag[1] = 's'; |
250 |
atmos->rayleigh_density.layers[0].exp_scale = -1.0 / HR_SS; |
251 |
atmos->beta_r0 = BR0_SS; |
252 |
} else { |
253 |
tag[1] = 'w'; |
254 |
atmos->rayleigh_density.layers[0].exp_scale = -1.0 / HR_SW; |
255 |
atmos->beta_r0 = BR0_SW; |
256 |
257 |
} else if (fabs(s_latitude * 180.0 / PI) > TROPIC_LAT) { |
258 |
tag[0] = 'm'; |
259 |
if (is_summer) { |
260 |
tag[1] = 's'; |
261 |
atmos->rayleigh_density.layers[0].exp_scale = -1.0 / HR_MS; |
262 |
atmos->beta_r0 = BR0_MS; |
263 |
} else { |
264 |
tag[1] = 'w'; |
265 |
atmos->rayleigh_density.layers[0].exp_scale = -1.0 / HR_MW; |
266 |
atmos->beta_r0 = BR0_MW; |
267 |
268 |
} else { |
269 |
tag[0] = 't'; |
270 |
tag[1] = 'r'; |
271 |
atmos->rayleigh_density.layers[0].exp_scale = -1.0 / HR_T; |
272 |
atmos->beta_r0 = BR0_T; |
273 |
274 |
tag[2] = '\0'; |
275 |
276 |
/* Add in solar direct to nearest sky patches (GW) */ |
277 |
void add_direct(DATARRAY *tau, DATARRAY *scat, DATARRAY *scat1m, |
278 |
DATARRAY *irrad, double ccover, float *parr) { |
279 |
FVECT svec; |
280 |
double near_dprod[NSUNPATCH]; |
281 |
int near_patch[NSUNPATCH]; |
282 |
double wta[NSUNPATCH], wtot; |
283 |
int i, j, p; |
284 |
285 |
/* identify nsuns closest patches */ |
286 |
for (i = nsuns; i--;) |
287 |
near_dprod[i] = -1.; |
288 |
vectorize(altitude, azimuth, svec); |
289 |
for (p = 1; p < nskypatch; p++) { |
290 |
FVECT pvec; |
291 |
double dprod; |
292 |
vectorize(rh_palt[p], rh_pazi[p], pvec); |
293 |
dprod = DOT(pvec, svec); |
294 |
for (i = 0; i < nsuns; i++) |
295 |
if (dprod > near_dprod[i]) { |
296 |
for (j = nsuns; --j > i;) { |
297 |
near_dprod[j] = near_dprod[j - 1]; |
298 |
near_patch[j] = near_patch[j - 1]; |
299 |
300 |
near_dprod[i] = dprod; |
301 |
near_patch[i] = p; |
302 |
break; |
303 |
304 |
305 |
/* Get solar radiance */ |
306 |
double sun_radiance[NSSAMP] = {0}; |
307 |
get_solar_radiance(tau, scat, scat1m, sundir, ER, sun_ct, sun_radiance); |
308 |
if (ccover > 0) { |
309 |
double zenithbr = get_zenith_brightness(sundir); |
310 |
double skybr = get_overcast_brightness(sundir[2], zenithbr); |
311 |
int l; |
312 |
for (l = 0; l < NSSAMP; ++l) { |
313 |
sun_radiance[l] = |
314 |
wmean2(sun_radiance[l], D6415[l] * skybr / WVLSPAN, ccover); |
315 |
316 |
317 |
/* weight by proximity */ |
318 |
wtot = 0; |
319 |
320 |
wtot += wta[i] = 1. / (1.002 - near_dprod[i]); |
321 |
/* add to nearest patch radiances */ |
322 |
for (i = nsuns; i--;) { |
323 |
float *pdest = parr + NSSAMP * near_patch[i]; |
324 |
int k; |
325 |
for (k = 0; k < NSSAMP; k++) { |
326 |
*pdest++ = sun_radiance[k] * wta[i] / wtot; |
327 |
328 |
329 |
330 |
331 |
void calc_sky_patch_radiance(DATARRAY *scat, DATARRAY *scat1m, double ccover, |
332 |
float *parr) { |
333 |
int i; |
334 |
double mu_sky; /* Sun-sky point azimuthal angle */ |
335 |
double sspa; /* Sun-sky point angle */ |
336 |
FVECT view_point = {0, 0, ER}; |
337 |
for (i = 1; i < nskypatch; i++) { |
338 |
FVECT rdir_sky; |
339 |
int k; |
340 |
vectorize(rh_palt[i], rh_pazi[i], rdir_sky); |
341 |
mu_sky = fdot(view_point, rdir_sky) / ER; |
342 |
sspa = fdot(rdir_sky, sundir); |
343 |
SCOLOR sky_radiance = {0}; |
344 |
345 |
get_sky_radiance(scat, scat1m, ER, mu_sky, sun_ct, sspa, sky_radiance); |
346 |
for (k = 0; k < NSSAMP; ++k) { |
347 |
sky_radiance[k] *= WVLSPAN; |
348 |
349 |
350 |
if (ccover > 0) { |
351 |
352 |
double grndbr = zenithbr * GNORM; |
353 |
double skybr = get_overcast_brightness(rdir_sky[2], zenithbr); |
354 |
int k; |
355 |
356 |
sky_radiance[k] = wmean2(sky_radiance[k], skybr * D6415[k], ccover); |
357 |
358 |
359 |
360 |
361 |
parr[NSSAMP * i + k] = sky_radiance[k]; |
362 |
363 |
364 |
365 |
366 |
/* Return maximum of two doubles */ |
367 |
static inline double dmax(double a, double b) { return (a > b) ? a : b; } |
368 |
369 |
/* Compute sky patch radiance values (modified by GW) */ |
370 |
void compute_sky(DATARRAY *tau, DATARRAY *scat, DATARRAY *scat1m, |
371 |
372 |
int index; /* Category index */ |
373 |
int i; |
374 |
float sun_zenith; |
375 |
376 |
SCOLOR ground_radiance = {0}; |
377 |
SCOLR sky_sclr = {0}; |
378 |
SCOLR ground_sclr = {0}; |
379 |
380 |
const double radius = VLEN(view_point); |
381 |
const double sun_ct = fdot(view_point, sundir) / radius; |
382 |
const FVECT rdir_grnd = {0, 0, -1}; |
383 |
const double mu_grnd = fdot(view_point, rdir_grnd) / radius; |
384 |
const double nu_grnd = fdot(rdir_grnd, sundir); |
385 |
int j; |
386 |
387 |
/* Calculate sun zenith angle (don't let it dip below horizon) */ |
388 |
/* Also limit minimum angle to keep circumsolar off zenith */ |
389 |
if (altitude <= 0.0) |
390 |
sun_zenith = DegToRad(90.0); |
391 |
else if (altitude >= DegToRad(87.0)) |
392 |
sun_zenith = DegToRad(3.0); |
393 |
else |
394 |
sun_zenith = DegToRad(90.0) - altitude; |
395 |
396 |
/* Compute ground radiance (include solar contribution if any) */ |
397 |
get_ground_radiance(tau, scat, scat1m, irrad, view_point, rdir_grnd, radius, |
398 |
mu_grnd, sun_ct, nu_grnd, grefl, sundir, parr); |
399 |
for (j = 0; j < NSSAMP; j++) { |
400 |
parr[j] *= WVLSPAN; |
401 |
402 |
calc_sky_patch_radiance(scat, scat1m, ccover, parr); |
403 |
404 |
405 |
int main(int argc, char *argv[]) { |
406 |
407 |
char buf[256]; |
408 |
int doheader = 1; /* output header? */ |
409 |
double rotation = 0.0; |
410 |
double elevation = 0; |
411 |
int leap_day = 0; /* add leap day? */ |
412 |
int sun_hours_only = 0; /* only output sun hours? */ |
413 |
float *mtx_data = NULL; |
414 |
int ntsteps = 0; /* number of time steps */ |
415 |
int tstorage = 0; /* number of allocated time steps */ |
416 |
int nstored = 0; /* number of time steps in matrix */ |
417 |
int last_monthly = 0; /* month of last report */ |
418 |
int mo, da; |
419 |
double hr, aod, cc; |
420 |
double dni, dhi; |
421 |
int mtx_offset = 0; |
422 |
int i, j; |
423 |
char lstag[3]; |
424 |
char *mie_path = getpath("mie_ca.dat", getrlibpath(), R_OK); |
425 |
char *ddir = "."; |
426 |
char mie_name[20] = "mie_ca"; |
427 |
int num_threads = 1; |
428 |
int sorder = 4; |
429 |
int solar_only = 0; |
430 |
int sky_only = 0; |
431 |
432 |
433 |
progname = argv[0]; |
434 |
435 |
for (i = 1; i < argc && argv[i][0] == '-'; i++) { |
436 |
switch (argv[i][1]) { |
437 |
case 'd': /* solar (direct) only */ |
438 |
solar_only = 1; |
439 |
break; |
440 |
case 's': /* sky only (no direct) */ |
441 |
sky_only = 1; |
442 |
break; |
443 |
case 'g': |
444 |
grefl = atof(argv[++i]); |
445 |
break; |
446 |
case 'm': |
447 |
rhsubdiv = atoi(argv[++i]); |
448 |
break; |
449 |
case 'n': |
450 |
num_threads = atoi(argv[++i]); |
451 |
break; |
452 |
case 'r': /* rotate distribution */ |
453 |
if (argv[i][2] && argv[i][2] != 'z') |
454 |
goto userr; |
455 |
rotation = atof(argv[++i]); |
456 |
break; |
457 |
case 'u': /* solar hours only */ |
458 |
sun_hours_only = 1; |
459 |
break; |
460 |
case 'p': |
461 |
ddir = argv[++i]; |
462 |
break; |
463 |
case 'v': /* verbose progress reports */ |
464 |
verbose++; |
465 |
break; |
466 |
case 'h': /* turn off header */ |
467 |
doheader = 0; |
468 |
break; |
469 |
case '5': /* 5-phase calculation */ |
470 |
nsuns = 1; |
471 |
fixed_sun_sa = PI / 360. * atof(argv[++i]); |
472 |
if (fixed_sun_sa <= 0) { |
473 |
fprintf(stderr, |
474 |
"%s: missing solar disk size argument for '-5' option\n", |
475 |
progname); |
476 |
exit(1); |
477 |
478 |
fixed_sun_sa *= fixed_sun_sa * PI; |
479 |
break; |
480 |
case 'o': /* output format */ |
481 |
switch (argv[i][2]) { |
482 |
case 'f': |
483 |
case 'd': |
484 |
case 'a': |
485 |
outfmt = argv[i][2]; |
486 |
break; |
487 |
default: |
488 |
goto userr; |
489 |
490 |
break; |
491 |
default: |
492 |
goto userr; |
493 |
494 |
495 |
if (i < argc - 1) |
496 |
goto userr; |
497 |
if (i == argc - 1 && freopen(argv[i], "r", stdin) == NULL) { |
498 |
fprintf(stderr, "%s: cannot open '%s' for input\n", progname, argv[i]); |
499 |
exit(1); |
500 |
501 |
if (verbose) { |
502 |
if (i == argc - 1) |
503 |
fprintf(stderr, "%s: reading weather tape '%s'\n", progname, argv[i]); |
504 |
else |
505 |
fprintf(stderr, "%s: reading weather tape from <stdin>\n", progname); |
506 |
507 |
/* read weather tape header */ |
508 |
if (scanf("place %[^\r\n] ", buf) != 1) |
509 |
goto fmterr; |
510 |
if (scanf("latitude %lf\n", &s_latitude) != 1) |
511 |
goto fmterr; |
512 |
if (scanf("longitude %lf\n", &s_longitude) != 1) |
513 |
goto fmterr; |
514 |
if (scanf("time_zone %lf\n", &s_meridian) != 1) |
515 |
goto fmterr; |
516 |
if (scanf("site_elevation %lf\n", &elevation) != 1) |
517 |
goto fmterr; |
518 |
if (scanf("weather_data_file_units %d\n", &input) != 1) |
519 |
goto fmterr; |
520 |
521 |
rh_init(); |
522 |
if (verbose) { |
523 |
fprintf(stderr, "%s: location '%s'\n", progname, buf); |
524 |
fprintf(stderr, "%s: (lat,long)=(%.1f,%.1f) degrees north, west\n", |
525 |
progname, s_latitude, s_longitude); |
526 |
if (rotation != 0) |
527 |
fprintf(stderr, "%s: rotating output %.0f degrees\n", progname, rotation); |
528 |
529 |
530 |
s_latitude = DegToRad(s_latitude); |
531 |
s_longitude = DegToRad(s_longitude); |
532 |
s_meridian = DegToRad(s_meridian); |
533 |
/* initial allocation */ |
534 |
mtx_data = resize_dmatrix(mtx_data, tstorage = 2, nskypatch); |
535 |
536 |
/* Load mie density data */ |
537 |
DATARRAY *mie_dp = getdata(mie_path); |
538 |
if (mie_dp == NULL) { |
539 |
fprintf(stderr, "Error reading mie data\n"); |
540 |
return 0; |
541 |
542 |
543 |
while (scanf("%d %d %lf %lf %lf %lf %lf\n", &mo, &da, &hr, &dni, &dhi, &aod, |
544 |
&cc) == 7) { |
545 |
if (aod == 0.0) { |
546 |
aod = AOD0_CA; |
547 |
fprintf(stderr, "aod is zero, using default value %.3f\n", AOD0_CA); |
548 |
549 |
double sda, sta; |
550 |
int sun_in_sky; |
551 |
/* compute solar position */ |
552 |
if ((mo == 2) & (da == 29)) { |
553 |
julian_date = 60; |
554 |
leap_day = 1; |
555 |
} else |
556 |
julian_date = jdate(mo, da) + leap_day; |
557 |
sda = sdec(julian_date); |
558 |
sta = stadj(julian_date); |
559 |
altitude = salt(sda, hr + sta); |
560 |
sun_in_sky = (altitude > -DegToRad(SUN_ANG_DEG / 2.)); |
561 |
562 |
azimuth = sazi(sda, hr + sta) + PI - DegToRad(rotation); |
563 |
564 |
vectorize(altitude, azimuth, sundir); |
565 |
if (sun_hours_only && sundir[2] <= 0.) { |
566 |
continue; /* skipping nighttime points */ |
567 |
568 |
sun_ct = fdot(view_point, sundir) / ER; |
569 |
570 |
mtx_offset = NSSAMP * nskypatch * nstored; |
571 |
nstored += 1; |
572 |
printf("mtx_offset = %d nstored = %d nskypatch = %d\n", mtx_offset, nstored, |
573 |
nskypatch); |
574 |
/* make space for next row */ |
575 |
if (nstored > tstorage) { |
576 |
printf("make space for next row nstored = %d tstorage = %d\n", nstored, |
577 |
tstorage); |
578 |
tstorage += (tstorage >> 1) + nstored + 7; |
579 |
mtx_data = resize_dmatrix(mtx_data, tstorage, nskypatch); |
580 |
581 |
ntsteps++; /* keep count of time steps */ |
582 |
/* compute sky patch values */ |
583 |
Atmosphere clear_atmos = init_atmos(aod, grefl); |
584 |
int is_summer = (mo >= SUMMER_START && mo <= SUMMER_END); |
585 |
if (s_latitude < 0) { |
586 |
is_summer = !is_summer; |
587 |
588 |
set_rayleigh_density_profile(&clear_atmos, lstag, is_summer, s_latitude); |
589 |
590 |
clear_atmos.beta_m = mie_dp; |
591 |
592 |
char gsdir[PATH_MAX]; |
593 |
size_t siz = strlen(ddir); |
594 |
if (ISDIRSEP(ddir[siz - 1])) |
595 |
ddir[siz - 1] = '\0'; |
596 |
snprintf(gsdir, PATH_MAX, "%s%catmos_data", ddir, DIRSEP); |
597 |
if (!make_directory(gsdir)) { |
598 |
fprintf(stderr, "Failed creating atmos_data directory"); |
599 |
exit(1); |
600 |
601 |
DpPaths clear_paths = get_dppaths(gsdir, aod, mie_name, lstag); |
602 |
603 |
if (getpath(clear_paths.tau, ".", R_OK) == NULL || |
604 |
getpath(clear_paths.scat, ".", R_OK) == NULL || |
605 |
getpath(clear_paths.scat1m, ".", R_OK) == NULL || |
606 |
getpath(clear_paths.irrad, ".", R_OK) == NULL) { |
607 |
printf("# Pre-computing...\n"); |
608 |
if (!precompute(sorder, clear_paths, &clear_atmos, num_threads)) { |
609 |
fprintf(stderr, "Pre-compute failed\n"); |
610 |
return 0; |
611 |
612 |
613 |
614 |
DATARRAY *tau_clear_dp = getdata(clear_paths.tau); |
615 |
DATARRAY *irrad_clear_dp = getdata(clear_paths.irrad); |
616 |
DATARRAY *scat_clear_dp = getdata(clear_paths.scat); |
617 |
DATARRAY *scat1m_clear_dp = getdata(clear_paths.scat1m); |
618 |
619 |
if (!solar_only) |
620 |
compute_sky(tau_clear_dp, scat_clear_dp, scat1m_clear_dp, irrad_clear_dp, |
621 |
cc, mtx_data + mtx_offset); |
622 |
if (!sky_only) |
623 |
add_direct(tau_clear_dp, scat_clear_dp, scat1m_clear_dp, irrad_clear_dp, |
624 |
625 |
/* monthly reporting */ |
626 |
if (verbose && mo != last_monthly) |
627 |
fprintf(stderr, "%s: stepping through month %d...\n", progname, |
628 |
last_monthly = mo); |
629 |
630 |
freedata(mie_dp); |
631 |
if (!ntsteps) { |
632 |
fprintf(stderr, "%s: no valid time steps on input\n", progname); |
633 |
exit(1); |
634 |
635 |
/* check for junk at end */ |
636 |
while ((i = fgetc(stdin)) != EOF) |
637 |
if (!isspace(i)) { |
638 |
fprintf(stderr, "%s: warning - unexpected data past EOT: ", progname); |
639 |
buf[0] = i; |
640 |
buf[1] = '\0'; |
641 |
fgets(buf + 1, sizeof(buf) - 1, stdin); |
642 |
fputs(buf, stderr); |
643 |
fputc('\n', stderr); |
644 |
break; |
645 |
646 |
/* write out matrix */ |
647 |
if (outfmt != 'a') |
648 |
SET_FILE_BINARY(stdout); |
649 |
#ifdef getc_unlocked |
650 |
flockfile(stdout); |
651 |
#endif |
652 |
if (verbose) |
653 |
fprintf(stderr, "%s: writing %smatrix with %d time steps...\n", progname, |
654 |
outfmt == 'a' ? "" : "binary ", nstored); |
655 |
if (doheader) { |
656 |
newheader("RADIANCE", stdout); |
657 |
printargs(argc, argv, stdout); |
658 |
printf("LATLONG= %.8f %.8f\n", RadToDeg(s_latitude), |
659 |
-RadToDeg(s_longitude)); |
660 |
printf("NROWS=%d\n", nskypatch); |
661 |
printf("NCOLS=%d\n", nstored); |
662 |
printf("NCOMP=%d\n", NSSAMP); |
663 |
if ((outfmt == 'f') | (outfmt == 'd')) |
664 |
fputendian(stdout); |
665 |
fputformat((char *)getfmtname(outfmt), stdout); |
666 |
putchar('\n'); |
667 |
668 |
/* patches are rows (outer sort) */ |
669 |
for (i = 0; i < nskypatch; i++) { |
670 |
mtx_offset = NSSAMP * i; |
671 |
switch (outfmt) { |
672 |
case 'a': |
673 |
for (j = 0; j < nstored; j++) { |
674 |
int k; |
675 |
676 |
printf("%.3g ", mtx_data[mtx_offset + k]); |
677 |
678 |
printf("\n"); |
679 |
mtx_offset += NSSAMP * nskypatch; |
680 |
681 |
if (nstored > 1) |
682 |
fputc('\n', stdout); |
683 |
break; |
684 |
case 'f': |
685 |
686 |
putbinary(mtx_data + mtx_offset, sizeof(float), NSSAMP, stdout); |
687 |
688 |
689 |
break; |
690 |
case 'd': |
691 |
692 |
double ment[NSSAMP]; |
693 |
for (j = 0; j < NSSAMP; j++) |
694 |
ment[j] = mtx_data[mtx_offset + j]; |
695 |
putbinary(ment, sizeof(double), NSSAMP, stdout); |
696 |
697 |
698 |
break; |
699 |
700 |
if (ferror(stdout)) |
701 |
goto writerr; |
702 |
703 |
alldone: |
704 |
if (fflush(NULL) == EOF) |
705 |
goto writerr; |
706 |
if (verbose) |
707 |
fprintf(stderr, "%s: done.\n", progname); |
708 |
exit(0); |
709 |
userr: |
710 |
fprintf(stderr, |
711 |
"Usage: %s [-v][-h][-A][-d|-s|-n][-u][-D file [-M modfile]][-r " |
712 |
"deg][-m N][-g r g b][-c r g b][-o{f|d}][-O{0|1}] [tape.wea]\n", |
713 |
progname); |
714 |
exit(1); |
715 |
fmterr: |
716 |
fprintf(stderr, "%s: weather tape format error in header\n", progname); |
717 |
exit(1); |
718 |
writerr: |
719 |
fprintf(stderr, "%s: write error on output\n", progname); |
720 |
exit(1); |
721 |
