fix: Functio prototypes and other fixes to reduce compiler warnings
perf(gensurf,genrev,genworm): Added call to doptimize() for expressions
perf(gensurf,genrev,genworm): Fixed setting of eclock that was out-of-date with change from 90's
Changed gen{worm,surf,rev} to accept expressions for number of segments
Added missing esupport settings for constant expression reduction
Eliminated redundant include
Added significant digits to output to avoid problems with thin cups/cones
Changes and check-in for 3.5 release Includes new source files and modifications not recorded for many years See ray/doc/notes/ReleaseNotes for notes between 3.1 and 3.5 release
minor compiler warning fixes
changed private variable names with `SYS` context
changed arguments to varset()
added zero initialization of eclock
added bezier and bspline functions
Added Bezier cubic function
changed "phong" to "Phong"
fixed location of SCCSid
