root/radiance/ray/src/gen/genrev.c
Sat Jun 7 05:09:45 2025 UTC (8 weeks, 2 days ago) by greg
CVS Tags: HEAD, rad6R0
Diff to previous 2.17 , to selected 2.7
Wed Apr 23 01:57:04 2025 UTC (3 months, 1 week ago) by greg
Changes since 2.16: +13 -8 lines
Diff to previous 2.16 , to selected 2.7
fix: Functio prototypes and other fixes to reduce compiler warnings
Fri Apr 18 23:02:53 2025 UTC (3 months, 2 weeks ago) by greg
Diff to previous 2.15 , to selected 2.7
perf(gensurf,genrev,genworm): Added call to doptimize() for expressions
Tue Dec 10 17:22:39 2024 UTC (7 months, 3 weeks ago) by greg
Diff to previous 2.14 , to selected 2.7
perf(gensurf,genrev,genworm): Fixed setting of eclock that was out-of-date with change from 90's
Sat Dec 28 18:05:14 2019 UTC (5 years, 7 months ago) by greg
CVS Tags: rad5R3, rad5R4
Changes since 2.13: +1 -3 lines
Sat Dec 7 02:21:42 2019 UTC (5 years, 7 months ago) by greg
Changed gen{worm,surf,rev} to accept expressions for number of segments
Fri May 4 23:56:49 2018 UTC (7 years, 3 months ago) by greg
Changes since 2.11: +11 -4 lines
Fri Jan 12 00:50:17 2018 UTC (7 years, 6 months ago) by greg
Added missing esupport settings for constant expression reduction
Sat Oct 11 04:39:34 2008 UTC (16 years, 9 months ago) by greg
CVS Tags: rad4R0, rad4R1, rad4R2, rad4R2P1, rad4R2P2, rad5R0, rad5R1
Eliminated redundant include
Sat Oct 11 04:29:39 2008 UTC (16 years, 9 months ago) by greg
Changes since 2.8: +12 -12 lines
Added significant digits to output to avoid problems with thin cups/cones
Sat Aug 21 11:54:06 2004 UTC (20 years, 11 months ago) by greg
Changes since 2.7: +5 -40 lines
Sun Nov 16 10:29:38 2003 UTC (21 years, 8 months ago) by schorsch
Changes since 2.6: +8 -5 lines
Mon Aug 4 22:37:53 2003 UTC (22 years ago) by greg
Changes since 2.5: +5 -7 lines
Sun Jun 8 12:03:09 2003 UTC (22 years, 2 months ago) by schorsch
Changes since 2.4: +92 -88 lines
Sat Feb 22 02:07:23 2003 UTC (22 years, 5 months ago) by greg
Changes since 2.3: +6 -4 lines
Thu Nov 18 09:33:01 1993 UTC (31 years, 8 months ago) by greg
minor compiler warning fixes
Fri Oct 2 16:11:28 1992 UTC (32 years, 10 months ago) by greg
Tue Nov 12 17:05:00 1991 UTC (33 years, 9 months ago) by greg
Diff to previous 1.10 , to selected 2.7
Tue Aug 13 16:07:10 1991 UTC (34 years ago) by greg
Diff to previous 1.9 , to selected 2.7
changed private variable names with `SYS` context
Tue Apr 23 15:51:17 1991 UTC (34 years, 3 months ago) by greg
Diff to previous 1.8 , to selected 2.7
Tue Apr 23 13:05:01 1991 UTC (34 years, 3 months ago) by greg
Diff to previous 1.7 , to selected 2.7
changed arguments to varset()
Fri Jul 20 14:35:58 1990 UTC (35 years ago) by greg
Diff to previous 1.6 , to selected 2.7
Fri Jul 20 14:33:10 1990 UTC (35 years ago) by greg
Diff to previous 1.5 , to selected 2.7
added zero initialization of eclock
Wed Mar 7 11:14:40 1990 UTC (35 years, 5 months ago) by greg
Changes since 1.4: +17 -3 lines
Diff to previous 1.4 , to selected 2.7
added bezier and bspline functions
Fri Mar 2 17:24:07 1990 UTC (35 years, 5 months ago) by greg
Changes since 1.3: +15 -1 lines
Diff to previous 1.3 , to selected 2.7
Added Bezier cubic function
Wed Oct 18 17:43:46 1989 UTC (35 years, 9 months ago) by greg
changed "phong" to "Phong"
Sun Sep 10 16:45:14 1989 UTC (35 years, 11 months ago) by greg
fixed location of SCCSid
Thu Feb 2 11:16:29 1989 UTC (36 years, 6 months ago) by greg
Diff to selected 2.7
