root/radiance/ray/src/gen/genrev.c
Sat Oct 11 04:39:34 2008 UTC (15 years, 7 months ago) by greg
CVS Tags: rad4R0, rad4R1, rad4R2, rad4R2P1, rad4R2P2, rad5R0, rad5R1
Eliminated redundant include
Sat Oct 11 04:29:39 2008 UTC (15 years, 7 months ago) by greg
Changes since 2.8: +12 -12 lines
Added significant digits to output to avoid problems with thin cups/cones
Sat Aug 21 11:54:06 2004 UTC (19 years, 9 months ago) by greg
Changes since 2.7: +5 -40 lines
Changes since 2.6: +8 -5 lines
Mon Aug 4 22:37:53 2003 UTC (20 years, 10 months ago) by greg
Changes since 2.5: +5 -7 lines
Sun Jun 8 12:03:09 2003 UTC (20 years, 11 months ago) by schorsch
Changes since 2.4: +92 -88 lines
Changes since 2.3: +6 -4 lines
Thu Nov 18 09:33:01 1993 UTC (30 years, 6 months ago) by greg
minor compiler warning fixes
Fri Oct 2 16:11:28 1992 UTC (31 years, 8 months ago) by greg
Diff to previous 2.1
Tue Nov 12 17:05:00 1991 UTC (32 years, 6 months ago) by greg
Diff to previous 1.10
Tue Aug 13 16:07:10 1991 UTC (32 years, 9 months ago) by greg
Diff to previous 1.9
changed private variable names with `SYS` context
Tue Apr 23 15:51:17 1991 UTC (33 years, 1 month ago) by greg
Diff to previous 1.8
Tue Apr 23 13:05:01 1991 UTC (33 years, 1 month ago) by greg
Diff to previous 1.7
changed arguments to varset()
Fri Jul 20 14:35:58 1990 UTC (33 years, 10 months ago) by greg
Diff to previous 1.6
Fri Jul 20 14:33:10 1990 UTC (33 years, 10 months ago) by greg
Diff to previous 1.5
added zero initialization of eclock
Wed Mar 7 11:14:40 1990 UTC (34 years, 3 months ago) by greg
Changes since 1.4: +17 -3 lines
Diff to previous 1.4
added bezier and bspline functions
Fri Mar 2 17:24:07 1990 UTC (34 years, 3 months ago) by greg
Changes since 1.3: +15 -1 lines
Diff to previous 1.3
Added Bezier cubic function
Wed Oct 18 17:43:46 1989 UTC (34 years, 7 months ago) by greg
Diff to previous 1.2
changed "phong" to "Phong"
Sun Sep 10 16:45:14 1989 UTC (34 years, 8 months ago) by greg
fixed location of SCCSid
Thu Feb 2 11:16:29 1989 UTC (35 years, 4 months ago) by greg
