root/radiance/ray/src/gen/genprism.c
Revision: 2.5
Committed: Thu Feb 22 14:38:51 1996 UTC (29 years, 1 month ago) by greg
Changes since 2.4: +13 -5 lines
added checking for too many vertices
1 /* Copyright (c) 1987 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * genprism.c - generate a prism.
9 * 2D vertices in the xy plane are given on the
10 * command line or from a file. Their order together
11 * with the extrude direction will determine surface
12 * orientation.
13 */
14
15 #include <stdio.h>
16
17 #include <math.h>
18
19 #include <ctype.h>
20
21 #define MAXVERT 1024 /* maximum # vertices */
22
23 #ifdef DCL_ATOF
24 extern double atof();
25 #endif
26
27 char *pmtype; /* material type */
28 char *pname; /* name */
29
30 double lvect[3] = {0.0, 0.0, 1.0};
31
32 double vert[MAXVERT][2];
33 int nverts = 0;
34
35 int do_ends = 1; /* include end caps */
36 int iscomplete = 0; /* polygon is already completed */
37
38
39 main(argc, argv)
40 int argc;
41 char **argv;
42 {
43 int an;
44
45 if (argc < 4)
46 goto userr;
47
48 pmtype = argv[1];
49 pname = argv[2];
50
51 if (!strcmp(argv[3], "-")) {
52 readverts(NULL);
53 an = 4;
54 } else if (isdigit(argv[3][0])) {
55 nverts = atoi(argv[3]);
56 if (nverts > MAXVERT) {
57 fprintf(stderr, "%s: too many vertices (%d limit)\n",
58 argv[0], MAXVERT);
59 exit(1);
60 }
61 if (argc-3 < 2*nverts)
62 goto userr;
63 for (an = 0; an < nverts; an++) {
64 vert[an][0] = atof(argv[2*an+4]);
65 vert[an][1] = atof(argv[2*an+5]);
66 }
67 an = 2*nverts+4;
68 } else {
69 readverts(argv[3]);
70 an = 4;
71 }
72 if (nverts < 3) {
73 fprintf(stderr, "%s: not enough vertices\n", argv[0]);
74 exit(1);
75 }
76
77 for ( ; an < argc; an++) {
78 if (argv[an][0] != '-')
79 goto userr;
80 switch (argv[an][1]) {
81 case 'l': /* length vector */
82 lvect[0] = atof(argv[++an]);
83 lvect[1] = atof(argv[++an]);
84 lvect[2] = atof(argv[++an]);
85 break;
86 case 'e': /* ends */
87 do_ends = !do_ends;
88 break;
89 case 'c': /* complete */
90 iscomplete = !iscomplete;
91 break;
92 default:
93 goto userr;
94 }
95 }
96
97 printhead(argc, argv);
98
99 if (do_ends)
100 printends();
101 printsides();
102
103 return(0);
104 userr:
105 fprintf(stderr, "Usage: %s material name ", argv[0]);
106 fprintf(stderr, "{ - | vfile | N v1 v2 .. vN } ");
107 fprintf(stderr, "[-l lvect][-c][-e]\n");
108 exit(1);
109 }
110
111
112 readverts(fname) /* read vertices from a file */
113 char *fname;
114 {
115 FILE *fp;
116
117 if (fname == NULL) {
118 fp = stdin;
119 fname = "<stdin>";
120 } else if ((fp = fopen(fname, "r")) == NULL) {
121 fprintf(stderr, "%s: cannot open\n", fname);
122 exit(1);
123 }
124 while (fscanf(fp, "%lf %lf", &vert[nverts][0], &vert[nverts][1]) == 2)
125 if (++nverts >= MAXVERT) {
126 fprintf(stderr, "%s: too many vertices (%d limit)\n",
127 fname, MAXVERT-1);
128 exit(1);
129 }
130 fclose(fp);
131 }
132
133
134 printends() /* print ends of prism */
135 {
136 register int i;
137
138 printf("\n%s polygon %s.b\n", pmtype, pname);
139 printf("0\n0\n%d\n", nverts*3);
140 for (i = 0; i < nverts; i++) {
141 printf("\t%18.12g\t%18.12g\t%18.12g\n",
142 vert[i][0],
143 vert[i][1],
144 0.0);
145 }
146 printf("\n%s polygon %s.e\n", pmtype, pname);
147 printf("0\n0\n%d\n", nverts*3);
148 for (i = nverts-1; i >= 0; i--) {
149 printf("\t%18.12g\t%18.12g\t%18.12g\n",
150 vert[i][0]+lvect[0],
151 vert[i][1]+lvect[1],
152 lvect[2]);
153 }
154 }
155
156
157 printsides() /* print prism sides */
158 {
159 register int i;
160
161 for (i = 0; i < nverts-1; i++)
162 side(i, i+1);
163 if (!iscomplete)
164 side(nverts-1, 0);
165 }
166
167
168 side(n1, n2) /* print single side */
169 register int n1, n2;
170 {
171 printf("\n%s polygon %s.%d\n", pmtype, pname, n1+1);
172 printf("0\n0\n12\n");
173 printf("\t%18.12g\t%18.12g\t%18.12g\n",
174 vert[n1][0],
175 vert[n1][1],
176 0.0);
177 printf("\t%18.12g\t%18.12g\t%18.12g\n",
178 vert[n1][0]+lvect[0],
179 vert[n1][1]+lvect[1],
180 lvect[2]);
181 printf("\t%18.12g\t%18.12g\t%18.12g\n",
182 vert[n2][0]+lvect[0],
183 vert[n2][1]+lvect[1],
184 lvect[2]);
185 printf("\t%18.12g\t%18.12g\t%18.12g\n",
186 vert[n2][0],
187 vert[n2][1],
188 0.0);
189 }
190
191
192 printhead(ac, av) /* print command header */
193 register int ac;
194 register char **av;
195 {
196 putchar('#');
197 while (ac--) {
198 putchar(' ');
199 fputs(*av++, stdout);
200 }
201 putchar('\n');
202 }
