--- ray/src/gen/genprism.c 1991/11/12 17:04:46 2.1 +++ ray/src/gen/genprism.c 2003/02/22 02:07:23 2.8 @@ -1,42 +1,50 @@ -/* Copyright (c) 1987 Regents of the University of California */ - #ifndef lint -static char SCCSid[] = "$SunId$ LBL"; +static const char RCSid[] = "$Id: genprism.c,v 2.8 2003/02/22 02:07:23 greg Exp $"; #endif - /* * genprism.c - generate a prism. * 2D vertices in the xy plane are given on the * command line or from a file. Their order together * with the extrude direction will determine surface * orientation. - * - * 8/24/87 */ #include +#include + +#include + #include #define MAXVERT 1024 /* maximum # vertices */ +#define FTINY 1e-6 + char *pmtype; /* material type */ char *pname; /* name */ double lvect[3] = {0.0, 0.0, 1.0}; +int lvdir = 1; +double llen = 1.0; double vert[MAXVERT][2]; int nverts = 0; +double u[MAXVERT][2]; /* edge unit vectors */ +double a[MAXVERT]; /* corner trim sizes */ + int do_ends = 1; /* include end caps */ int iscomplete = 0; /* polygon is already completed */ +double crad = 0.0; /* radius for corners (sign from lvdir) */ +extern double compute_rounding(); + main(argc, argv) int argc; char **argv; { - double atof(); int an; if (argc < 4) @@ -74,7 +82,22 @@ char **argv; lvect[0] = atof(argv[++an]); lvect[1] = atof(argv[++an]); lvect[2] = atof(argv[++an]); + if (lvect[2] < -FTINY) + lvdir = -1; + else if (lvect[2] > FTINY) + lvdir = 1; + else { + fprintf(stderr, + "%s: illegal extrusion vector\n", + argv[0]); + exit(1); + } + llen = sqrt(lvect[0]*lvect[0] + lvect[1]*lvect[1] + + lvect[2]*lvect[2]); break; + case 'r': /* radius */ + crad = atof(argv[++an]); + break; case 'e': /* ends */ do_ends = !do_ends; break; @@ -85,18 +108,29 @@ char **argv; goto userr; } } - - printhead(argc, argv); - - if (do_ends) - printends(); - printsides(); - - return(0); + if (crad > FTINY) { + if (crad > lvdir*lvect[2]) { + fprintf(stderr, "%s: rounding greater than height\n", + argv[0]); + exit(1); + } + crad *= lvdir; /* simplifies formulas */ + compute_rounding(); + printhead(argc, argv); + if (do_ends) + printrends(); + printsides(1); + } else { + printhead(argc, argv); + if (do_ends) + printends(); + printsides(0); + } + exit(0); userr: fprintf(stderr, "Usage: %s material name ", argv[0]); fprintf(stderr, "{ - | vfile | N v1 v2 .. vN } "); - fprintf(stderr, "[-l lvect][-c][-e]\n"); + fprintf(stderr, "[-l lvect][-r radius][-c][-e]\n"); exit(1); } @@ -118,61 +152,228 @@ char *fname; } +double +compute_rounding() /* compute vectors for rounding operations */ +{ + register int i; + register double *v0, *v1; + double l, asum; + + v0 = vert[nverts-1]; + for (i = 0; i < nverts; i++) { /* compute u[*] */ + v1 = vert[i]; + u[i][0] = v0[0] - v1[0]; + u[i][1] = v0[1] - v1[1]; + l = sqrt(u[i][0]*u[i][0] + u[i][1]*u[i][1]); + if (l <= FTINY) { + fprintf(stderr, "Degenerate side in prism\n"); + exit(1); + } + u[i][0] /= l; + u[i][1] /= l; + v0 = v1; + } + asum = 0.; + v1 = u[0]; + for (i = nverts; i--; ) { /* compute a[*] */ + v0 = u[i]; + l = v0[0]*v1[0] + v0[1]*v1[1]; + if (1+l <= FTINY) { + fprintf(stderr, "Overlapping sides in prism\n"); + exit(1); + } + if (1-l <= 0.) + a[i] = 0.; + else { + a[i] = sqrt((1-l)/(1+l)); + asum += l = v1[0]*v0[1]-v1[1]*v0[0]; + if (l < 0.) + a[i] = -a[i]; + } + v1 = v0; + } + return(asum*.5); +} + + printends() /* print ends of prism */ { register int i; + /* bottom face */ + printf("\n%s polygon %s.b\n", pmtype, pname); + printf("0\n0\n%d\n", nverts*3); + for (i = 0; i < nverts; i++) + printf("\t%18.12g\t%18.12g\t%18.12g\n", vert[i][0], + vert[i][1], 0.0); + /* top face */ + printf("\n%s polygon %s.t\n", pmtype, pname); + printf("0\n0\n%d\n", nverts*3); + for (i = nverts; i--; ) + printf("\t%18.12g\t%18.12g\t%18.12g\n", vert[i][0]+lvect[0], + vert[i][1]+lvect[1], lvect[2]); +} + +printrends() /* print ends of prism with rounding */ +{ + register int i; + double c0[3], c1[3], cl[3]; + /* bottom face */ printf("\n%s polygon %s.b\n", pmtype, pname); printf("0\n0\n%d\n", nverts*3); for (i = 0; i < nverts; i++) { printf("\t%18.12g\t%18.12g\t%18.12g\n", - vert[i][0], - vert[i][1], - 0.0); + vert[i][0] + crad*(a[i]*u[i][0] - u[i][1]), + vert[i][1] + crad*(a[i]*u[i][1] + u[i][0]), + 0.0); } - printf("\n%s polygon %s.e\n", pmtype, pname); + /* top face */ + printf("\n%s polygon %s.t\n", pmtype, pname); printf("0\n0\n%d\n", nverts*3); - for (i = nverts-1; i >= 0; i--) { + for (i = nverts; i--; ) { printf("\t%18.12g\t%18.12g\t%18.12g\n", - vert[i][0]+lvect[0], - vert[i][1]+lvect[1], - lvect[2]); + vert[i][0] + lvect[0] + crad*(a[i]*u[i][0] - u[i][1]), + vert[i][1] + lvect[1] + crad*(a[i]*u[i][1] + u[i][0]), + lvect[2]); } + /* bottom corners and edges */ + c0[0] = cl[0] = vert[nverts-1][0] + + crad*(a[nverts-1]*u[nverts-1][0] - u[nverts-1][1]); + c0[1] = cl[1] = vert[nverts-1][1] + + crad*(a[nverts-1]*u[nverts-1][1] + u[nverts-1][0]); + c0[2] = cl[2] = crad; + for (i = 0; i < nverts; i++) { + if (i < nverts-1) { + c1[0] = vert[i][0] + crad*(a[i]*u[i][0] - u[i][1]); + c1[1] = vert[i][1] + crad*(a[i]*u[i][1] + u[i][0]); + c1[2] = crad; + } else { + c1[0] = cl[0]; c1[1] = cl[1]; c1[2] = cl[2]; + } + if (lvdir*a[i] > 0.) { + printf("\n%s sphere %s.bc%d\n", pmtype, pname, i+1); + printf("0\n0\n4 %18.12g %18.12g %18.12g %18.12g\n", + c1[0], c1[1], c1[2], lvdir*crad); + } + printf("\n%s cylinder %s.be%d\n", pmtype, pname, i+1); + printf("0\n0\n7\n"); + printf("\t%18.12g\t%18.12g\t%18.12g\n", c0[0], c0[1], c0[2]); + printf("\t%18.12g\t%18.12g\t%18.12g\n", c1[0], c1[1], c1[2]); + printf("\t%18.12g\n", lvdir*crad); + c0[0] = c1[0]; c0[1] = c1[1]; c0[2] = c1[2]; + } + /* top corners and edges */ + c0[0] = cl[0] = vert[nverts-1][0] + lvect[0] + + crad*(a[nverts-1]*u[nverts-1][0] - u[nverts-1][1]); + c0[1] = cl[1] = vert[nverts-1][1] + lvect[1] + + crad*(a[nverts-1]*u[nverts-1][1] + u[nverts-1][0]); + c0[2] = cl[2] = lvect[2] - crad; + for (i = 0; i < nverts; i++) { + if (i < nverts-1) { + c1[0] = vert[i][0] + lvect[0] + + crad*(a[i]*u[i][0] - u[i][1]); + c1[1] = vert[i][1] + lvect[1] + + crad*(a[i]*u[i][1] + u[i][0]); + c1[2] = lvect[2] - crad; + } else { + c1[0] = cl[0]; c1[1] = cl[1]; c1[2] = cl[2]; + } + if (lvdir*a[i] > 0.) { + printf("\n%s sphere %s.tc%d\n", pmtype, pname, i+1); + printf("0\n0\n4 %18.12g %18.12g %18.12g %18.12g\n", + c1[0], c1[1], c1[2], lvdir*crad); + } + printf("\n%s cylinder %s.te%d\n", pmtype, pname, i+1); + printf("0\n0\n7\n"); + printf("\t%18.12g\t%18.12g\t%18.12g\n", c0[0], c0[1], c0[2]); + printf("\t%18.12g\t%18.12g\t%18.12g\n", c1[0], c1[1], c1[2]); + printf("\t%18.12g\n", lvdir*crad); + c0[0] = c1[0]; c0[1] = c1[1]; c0[2] = c1[2]; + } } -printsides() /* print prism sides */ +printsides(round) /* print prism sides */ +int round; { register int i; for (i = 0; i < nverts-1; i++) - side(i, i+1); + if (round) + rside(i, i+1); + else + side(i, i+1); if (!iscomplete) - side(nverts-1, 0); + if (round) + rside(nverts-1, 0); + else + side(nverts-1, 0); } -side(n1, n2) /* print single side */ -register int n1, n2; +side(n0, n1) /* print single side */ +register int n0, n1; { - printf("\n%s polygon %s.%d\n", pmtype, pname, n1+1); + printf("\n%s polygon %s.%d\n", pmtype, pname, n0+1); printf("0\n0\n12\n"); + printf("\t%18.12g\t%18.12g\t%18.12g\n", vert[n0][0], + vert[n0][1], 0.0); + printf("\t%18.12g\t%18.12g\t%18.12g\n", vert[n0][0]+lvect[0], + vert[n0][1]+lvect[1], lvect[2]); + printf("\t%18.12g\t%18.12g\t%18.12g\n", vert[n1][0]+lvect[0], + vert[n1][1]+lvect[1], lvect[2]); + printf("\t%18.12g\t%18.12g\t%18.12g\n", vert[n1][0], + vert[n1][1], 0.0); +} + + +rside(n0, n1) /* print side with rounded edge */ +register int n0, n1; +{ + double s, c, t[3]; + + /* compute tanget offset vector */ + s = lvdir*(lvect[1]*u[n1][0] - lvect[0]*u[n1][1])/llen; + if (s < -FTINY || s > FTINY) { + c = sqrt(1. - s*s); + t[0] = (c - 1.)*u[n1][1]; + t[1] = (1. - c)*u[n1][0]; + t[2] = s; + } else + t[0] = t[1] = t[2] = 0.; + /* output side */ + printf("\n%s polygon %s.%d\n", pmtype, pname, n0+1); + printf("0\n0\n12\n"); printf("\t%18.12g\t%18.12g\t%18.12g\n", - vert[n1][0], - vert[n1][1], - 0.0); + vert[n0][0] + crad*(t[0] - a[n0]*u[n1][0]), + vert[n0][1] + crad*(t[1] - a[n0]*u[n1][1]), + crad*(t[2] + 1.)); printf("\t%18.12g\t%18.12g\t%18.12g\n", - vert[n1][0]+lvect[0], - vert[n1][1]+lvect[1], - lvect[2]); + vert[n0][0] + lvect[0] + crad*(t[0] - a[n0]*u[n1][0]), + vert[n0][1] + lvect[1] + crad*(t[1] - a[n0]*u[n1][1]), + lvect[2] + crad*(t[2] - 1.)); printf("\t%18.12g\t%18.12g\t%18.12g\n", - vert[n2][0]+lvect[0], - vert[n2][1]+lvect[1], - lvect[2]); + vert[n1][0] + lvect[0] + crad*(t[0] + a[n1]*u[n1][0]), + vert[n1][1] + lvect[1] + crad*(t[1] + a[n1]*u[n1][1]), + lvect[2] + crad*(t[2] - 1.)); printf("\t%18.12g\t%18.12g\t%18.12g\n", - vert[n2][0], - vert[n2][1], - 0.0); + vert[n1][0] + crad*(t[0] + a[n1]*u[n1][0]), + vert[n1][1] + crad*(t[1] + a[n1]*u[n1][1]), + crad*(t[2] + 1.)); + /* output joining edge */ + if (lvdir*a[n1] < 0.) + return; + printf("\n%s cylinder %s.e%d\n", pmtype, pname, n0+1); + printf("0\n0\n7\n"); + printf("\t%18.12g\t%18.12g\t%18.12g\n", + vert[n1][0] + crad*(a[n1]*u[n1][0] - u[n1][1]), + vert[n1][1] + crad*(a[n1]*u[n1][1] + u[n1][0]), + crad); + printf("\t%18.12g\t%18.12g\t%18.12g\n", + vert[n1][0] + lvect[0] + crad*(a[n1]*u[n1][0] - u[n1][1]), + vert[n1][1] + lvect[1] + crad*(a[n1]*u[n1][1] + u[n1][0]), + lvect[2] - crad); + printf("\t%18.12g\n", lvdir*crad); }
