root/radiance/ray/src/gen/genprism.c
Sat Jul 25 19:18:01 2020 UTC (4 years, 10 months ago) by greg
Changes since 2.12: +22 -41 lines
fix(genbox, genprism, gensky): normalizing headers for Windows
Sun Nov 16 10:29:38 2003 UTC (21 years, 6 months ago) by schorsch
Mon Jul 21 22:30:18 2003 UTC (21 years, 10 months ago) by schorsch
Changes since 2.10: +3 -2 lines
Sat Jul 12 09:41:41 2003 UTC (21 years, 10 months ago) by schorsch
Fixed prototype mismatch detected by Randolph Fritz.
Sun Jun 8 12:03:09 2003 UTC (22 years ago) by schorsch
Changes since 2.8: +171 -165 lines
Sat Feb 22 02:07:23 2003 UTC (22 years, 3 months ago) by greg
Changes since 2.7: +3 -8 lines
Tue Mar 19 20:59:22 1996 UTC (29 years, 2 months ago) by greg
Changes since 2.6: +47 -37 lines
numerous bug fixes associated with the -r option
Tue Mar 19 16:30:56 1996 UTC (29 years, 2 months ago) by greg
Changes since 2.5: +227 -44 lines
added -r option for smoothed edges
Thu Feb 22 14:38:51 1996 UTC (29 years, 3 months ago) by greg
Changes since 2.4: +13 -5 lines
added checking for too many vertices
Mon Aug 2 14:23:04 1993 UTC (31 years, 10 months ago) by greg
Changes since 2.3: +4 -0 lines
added conditional declaration of atof()
Fri Jun 4 14:32:05 1993 UTC (32 years ago) by greg
Changes since 2.2: +2 -4 lines
Removed unnecessary declaration of atof()
Thu Dec 19 15:08:51 1991 UTC (33 years, 5 months ago) by greg
Tue Nov 12 17:04:46 1991 UTC (33 years, 7 months ago) by greg
Diff to previous 1.2 , to selected 2.4
Tue Mar 14 15:08:35 1989 UTC (36 years, 3 months ago) by greg
Diff to previous 1.1 , to selected 2.4
fixed mistaken parameter
Thu Feb 2 11:16:28 1989 UTC (36 years, 4 months ago) by greg
Diff to selected 2.4
