root/radiance/ray/src/gen/genprism.c
Revision: 1.2
Committed: Tue Mar 14 15:08:35 1989 UTC (36 years, 5 months ago) by greg
fixed mistaken parameter
1 /* Copyright (c) 1987 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * genprism.c - generate a prism.
9 * 2D vertices in the xy plane are given on the
10 * command line or from a file. Their order together
11 * with the extrude direction will determine surface
12 * orientation.
13 *
14 * 8/24/87
15 */
16
17 #include <stdio.h>
18
19 #include <ctype.h>
20
21 #define MAXVERT 1024 /* maximum # vertices */
22
23 char *pmtype; /* material type */
24 char *pname; /* name */
25
26 double lvect[3] = {0.0, 0.0, 1.0};
27
28 double vert[MAXVERT][2];
29 int nverts = 0;
30
31 int do_ends = 1; /* include end caps */
32 int iscomplete = 0; /* polygon is already completed */
33
34
35 main(argc, argv)
36 int argc;
37 char **argv;
38 {
39 double atof();
40 int an;
41
42 if (argc < 4)
43 goto userr;
44
45 pmtype = argv[1];
46 pname = argv[2];
47
48 if (!strcmp(argv[3], "-")) {
49 readverts(NULL);
50 an = 4;
51 } else if (isdigit(argv[3][0])) {
52 nverts = atoi(argv[3]);
53 if (argc-3 < 2*nverts)
54 goto userr;
55 for (an = 0; an < nverts; an++) {
56 vert[an][0] = atof(argv[2*an+4]);
57 vert[an][1] = atof(argv[2*an+5]);
58 }
59 an = 2*nverts+4;
60 } else {
61 readverts(argv[3]);
62 an = 4;
63 }
64 if (nverts < 3) {
65 fprintf(stderr, "%s: not enough vertices\n", argv[0]);
66 exit(1);
67 }
68
69 for ( ; an < argc; an++) {
70 if (argv[an][0] != '-')
71 goto userr;
72 switch (argv[an][1]) {
73 case 'l': /* length vector */
74 lvect[0] = atof(argv[++an]);
75 lvect[1] = atof(argv[++an]);
76 lvect[2] = atof(argv[++an]);
77 break;
78 case 'e': /* ends */
79 do_ends = !do_ends;
80 break;
81 case 'c': /* complete */
82 iscomplete = !iscomplete;
83 break;
84 default:
85 goto userr;
86 }
87 }
88
89 printhead(argc, argv);
90
91 if (do_ends)
92 printends();
93 printsides();
94
95 return(0);
96 userr:
97 fprintf(stderr, "Usage: %s material name ", argv[0]);
98 fprintf(stderr, "{ - | vfile | N v1 v2 .. vN } ");
99 fprintf(stderr, "[-l lvect][-c][-e]\n");
100 exit(1);
101 }
102
103
104 readverts(fname) /* read vertices from a file */
105 char *fname;
106 {
107 FILE *fp;
108
109 if (fname == NULL)
110 fp = stdin;
111 else if ((fp = fopen(fname, "r")) == NULL) {
112 fprintf(stderr, "%s: cannot open\n", fname);
113 exit(1);
114 }
115 while (fscanf(fp, "%lf %lf", &vert[nverts][0], &vert[nverts][1]) == 2)
116 nverts++;
117 fclose(fp);
118 }
119
120
121 printends() /* print ends of prism */
122 {
123 register int i;
124
125 printf("\n%s polygon %s.b\n", pmtype, pname);
126 printf("0\n0\n%d\n", nverts*3);
127 for (i = 0; i < nverts; i++) {
128 printf("\t%18.12g\t%18.12g\t%18.12g\n",
129 vert[i][0],
130 vert[i][1],
131 0.0);
132 }
133 printf("\n%s polygon %s.e\n", pmtype, pname);
134 printf("0\n0\n%d\n", nverts*3);
135 for (i = nverts-1; i >= 0; i--) {
136 printf("\t%18.12g\t%18.12g\t%18.12g\n",
137 vert[i][0]+lvect[0],
138 vert[i][1]+lvect[1],
139 lvect[2]);
140 }
141 }
142
143
144 printsides() /* print prism sides */
145 {
146 register int i;
147
148 for (i = 0; i < nverts-1; i++)
149 side(i, i+1);
150 if (!iscomplete)
151 side(nverts-1, 0);
152 }
153
154
155 side(n1, n2) /* print single side */
156 register int n1, n2;
157 {
158 printf("\n%s polygon %s.%d\n", pmtype, pname, n1+1);
159 printf("0\n0\n12\n");
160 printf("\t%18.12g\t%18.12g\t%18.12g\n",
161 vert[n1][0],
162 vert[n1][1],
163 0.0);
164 printf("\t%18.12g\t%18.12g\t%18.12g\n",
165 vert[n1][0]+lvect[0],
166 vert[n1][1]+lvect[1],
167 lvect[2]);
168 printf("\t%18.12g\t%18.12g\t%18.12g\n",
169 vert[n2][0]+lvect[0],
170 vert[n2][1]+lvect[1],
171 lvect[2]);
172 printf("\t%18.12g\t%18.12g\t%18.12g\n",
173 vert[n2][0],
174 vert[n2][1],
175 0.0);
176 }
177
178
179 printhead(ac, av) /* print command header */
180 register int ac;
181 register char **av;
182 {
183 putchar('#');
184 while (ac--) {
185 putchar(' ');
186 fputs(*av++, stdout);
187 }
188 putchar('\n');
189 }
