| 1 |
#ifndef lint |
| 2 |
static const char RCSid[] = "$Id: genprism.c,v 2.12 2003/11/16 10:29:38 schorsch Exp $"; |
| 3 |
#endif |
| 4 |
| 5 |
* genprism.c - generate a prism. |
| 6 |
* 2D vertices in the xy plane are given on the |
| 7 |
* command line or from a file. Their order together |
| 8 |
* with the extrude direction will determine surface |
| 9 |
* orientation. |
| 10 |
| 11 |
| 12 |
#include "rtio.h" |
| 13 |
#include <stdlib.h> |
| 14 |
#include <math.h> |
| 15 |
#include <ctype.h> |
| 16 |
| 17 |
#define MAXVERT 1024 /* maximum # vertices */ |
| 18 |
| 19 |
#define FTINY 1e-6 |
| 20 |
| 21 |
char *pmtype; /* material type */ |
| 22 |
char *pname; /* name */ |
| 23 |
| 24 |
double lvect[3] = {0.0, 0.0, 1.0}; |
| 25 |
int lvdir = 1; |
| 26 |
double llen = 1.0; |
| 27 |
| 28 |
double vert[MAXVERT][2]; |
| 29 |
int nverts = 0; |
| 30 |
| 31 |
double u[MAXVERT][2]; /* edge unit vectors */ |
| 32 |
double a[MAXVERT]; /* corner trim sizes */ |
| 33 |
| 34 |
int do_ends = 1; /* include end caps */ |
| 35 |
int iscomplete = 0; /* polygon is already completed */ |
| 36 |
double crad = 0.0; /* radius for corners (sign from lvdir) */ |
| 37 |
| 38 |
static double compute_rounding(void); |
| 39 |
| 40 |
| 41 |
static void |
| 42 |
readverts(char *fname) /* read vertices from a file */ |
| 43 |
| 44 |
FILE *fp; |
| 45 |
| 46 |
if (fname == NULL) |
| 47 |
fp = stdin; |
| 48 |
else if ((fp = fopen(fname, "r")) == NULL) { |
| 49 |
fprintf(stderr, "%s: cannot open\n", fname); |
| 50 |
exit(1); |
| 51 |
| 52 |
while (fscanf(fp, "%lf %lf", &vert[nverts][0], &vert[nverts][1]) == 2) |
| 53 |
nverts++; |
| 54 |
fclose(fp); |
| 55 |
| 56 |
| 57 |
| 58 |
static void |
| 59 |
side(int n0, int n1) /* print single side */ |
| 60 |
| 61 |
printf("\n%s polygon %s.%d\n", pmtype, pname, n0+1); |
| 62 |
printf("0\n0\n12\n"); |
| 63 |
printf("\t%18.12g\t%18.12g\t%18.12g\n", vert[n0][0], |
| 64 |
vert[n0][1], 0.0); |
| 65 |
printf("\t%18.12g\t%18.12g\t%18.12g\n", vert[n0][0]+lvect[0], |
| 66 |
vert[n0][1]+lvect[1], lvect[2]); |
| 67 |
printf("\t%18.12g\t%18.12g\t%18.12g\n", vert[n1][0]+lvect[0], |
| 68 |
vert[n1][1]+lvect[1], lvect[2]); |
| 69 |
printf("\t%18.12g\t%18.12g\t%18.12g\n", vert[n1][0], |
| 70 |
vert[n1][1], 0.0); |
| 71 |
| 72 |
| 73 |
| 74 |
static void |
| 75 |
rside(int n0, int n1) /* print side with rounded edge */ |
| 76 |
| 77 |
double s, c, t[3]; |
| 78 |
| 79 |
/* compute tanget offset vector */ |
| 80 |
s = lvdir*(lvect[1]*u[n1][0] - lvect[0]*u[n1][1])/llen; |
| 81 |
if (s < -FTINY || s > FTINY) { |
| 82 |
c = sqrt(1. - s*s); |
| 83 |
t[0] = (c - 1.)*u[n1][1]; |
| 84 |
t[1] = (1. - c)*u[n1][0]; |
| 85 |
t[2] = s; |
| 86 |
} else |
| 87 |
t[0] = t[1] = t[2] = 0.; |
| 88 |
/* output side */ |
| 89 |
| 90 |
| 91 |
printf("\t%18.12g\t%18.12g\t%18.12g\n", |
| 92 |
vert[n0][0] + crad*(t[0] - a[n0]*u[n1][0]), |
| 93 |
vert[n0][1] + crad*(t[1] - a[n0]*u[n1][1]), |
| 94 |
crad*(t[2] + 1.)); |
| 95 |
| 96 |
vert[n0][0] + lvect[0] + crad*(t[0] - a[n0]*u[n1][0]), |
| 97 |
vert[n0][1] + lvect[1] + crad*(t[1] - a[n0]*u[n1][1]), |
| 98 |
lvect[2] + crad*(t[2] - 1.)); |
| 99 |
| 100 |
vert[n1][0] + lvect[0] + crad*(t[0] + a[n1]*u[n1][0]), |
| 101 |
vert[n1][1] + lvect[1] + crad*(t[1] + a[n1]*u[n1][1]), |
| 102 |
| 103 |
| 104 |
vert[n1][0] + crad*(t[0] + a[n1]*u[n1][0]), |
| 105 |
vert[n1][1] + crad*(t[1] + a[n1]*u[n1][1]), |
| 106 |
| 107 |
/* output joining edge */ |
| 108 |
if (lvdir*a[n1] < 0.) |
| 109 |
return; |
| 110 |
printf("\n%s cylinder %s.e%d\n", pmtype, pname, n0+1); |
| 111 |
printf("0\n0\n7\n"); |
| 112 |
| 113 |
vert[n1][0] + crad*(a[n1]*u[n1][0] - u[n1][1]), |
| 114 |
vert[n1][1] + crad*(a[n1]*u[n1][1] + u[n1][0]), |
| 115 |
crad); |
| 116 |
| 117 |
vert[n1][0] + lvect[0] + crad*(a[n1]*u[n1][0] - u[n1][1]), |
| 118 |
vert[n1][1] + lvect[1] + crad*(a[n1]*u[n1][1] + u[n1][0]), |
| 119 |
lvect[2] - crad); |
| 120 |
printf("\t%18.12g\n", lvdir*crad); |
| 121 |
| 122 |
| 123 |
| 124 |
static double |
| 125 |
compute_rounding(void) /* compute vectors for rounding operations */ |
| 126 |
| 127 |
int i; |
| 128 |
double *v0, *v1; |
| 129 |
double l, asum; |
| 130 |
| 131 |
v0 = vert[nverts-1]; |
| 132 |
for (i = 0; i < nverts; i++) { /* compute u[*] */ |
| 133 |
v1 = vert[i]; |
| 134 |
u[i][0] = v0[0] - v1[0]; |
| 135 |
u[i][1] = v0[1] - v1[1]; |
| 136 |
l = sqrt(u[i][0]*u[i][0] + u[i][1]*u[i][1]); |
| 137 |
if (l <= FTINY) { |
| 138 |
fprintf(stderr, "Degenerate side in prism\n"); |
| 139 |
exit(1); |
| 140 |
| 141 |
u[i][0] /= l; |
| 142 |
u[i][1] /= l; |
| 143 |
v0 = v1; |
| 144 |
| 145 |
asum = 0.; |
| 146 |
v1 = u[0]; |
| 147 |
for (i = nverts; i--; ) { /* compute a[*] */ |
| 148 |
v0 = u[i]; |
| 149 |
l = v0[0]*v1[0] + v0[1]*v1[1]; |
| 150 |
if (1+l <= FTINY) { |
| 151 |
fprintf(stderr, "Overlapping sides in prism\n"); |
| 152 |
exit(1); |
| 153 |
| 154 |
if (1-l <= 0.) |
| 155 |
a[i] = 0.; |
| 156 |
else { |
| 157 |
a[i] = sqrt((1-l)/(1+l)); |
| 158 |
asum += l = v1[0]*v0[1]-v1[1]*v0[0]; |
| 159 |
if (l < 0.) |
| 160 |
a[i] = -a[i]; |
| 161 |
| 162 |
v1 = v0; |
| 163 |
| 164 |
return(asum*.5); |
| 165 |
| 166 |
| 167 |
| 168 |
static void |
| 169 |
printends(void) /* print ends of prism */ |
| 170 |
| 171 |
int i; |
| 172 |
/* bottom face */ |
| 173 |
printf("\n%s polygon %s.b\n", pmtype, pname); |
| 174 |
printf("0\n0\n%d\n", nverts*3); |
| 175 |
for (i = 0; i < nverts; i++) |
| 176 |
printf("\t%18.12g\t%18.12g\t%18.12g\n", vert[i][0], |
| 177 |
vert[i][1], 0.0); |
| 178 |
/* top face */ |
| 179 |
printf("\n%s polygon %s.t\n", pmtype, pname); |
| 180 |
| 181 |
for (i = nverts; i--; ) |
| 182 |
printf("\t%18.12g\t%18.12g\t%18.12g\n", vert[i][0]+lvect[0], |
| 183 |
vert[i][1]+lvect[1], lvect[2]); |
| 184 |
| 185 |
| 186 |
| 187 |
static void |
| 188 |
printrends(void) /* print ends of prism with rounding */ |
| 189 |
| 190 |
int i; |
| 191 |
double c0[3], c1[3], cl[3]; |
| 192 |
/* bottom face */ |
| 193 |
| 194 |
| 195 |
for (i = 0; i < nverts; i++) { |
| 196 |
| 197 |
vert[i][0] + crad*(a[i]*u[i][0] - u[i][1]), |
| 198 |
vert[i][1] + crad*(a[i]*u[i][1] + u[i][0]), |
| 199 |
0.0); |
| 200 |
| 201 |
/* top face */ |
| 202 |
| 203 |
| 204 |
for (i = nverts; i--; ) { |
| 205 |
| 206 |
vert[i][0] + lvect[0] + crad*(a[i]*u[i][0] - u[i][1]), |
| 207 |
vert[i][1] + lvect[1] + crad*(a[i]*u[i][1] + u[i][0]), |
| 208 |
lvect[2]); |
| 209 |
| 210 |
/* bottom corners and edges */ |
| 211 |
c0[0] = cl[0] = vert[nverts-1][0] + |
| 212 |
crad*(a[nverts-1]*u[nverts-1][0] - u[nverts-1][1]); |
| 213 |
c0[1] = cl[1] = vert[nverts-1][1] + |
| 214 |
crad*(a[nverts-1]*u[nverts-1][1] + u[nverts-1][0]); |
| 215 |
c0[2] = cl[2] = crad; |
| 216 |
| 217 |
if (i < nverts-1) { |
| 218 |
c1[0] = vert[i][0] + crad*(a[i]*u[i][0] - u[i][1]); |
| 219 |
c1[1] = vert[i][1] + crad*(a[i]*u[i][1] + u[i][0]); |
| 220 |
c1[2] = crad; |
| 221 |
} else { |
| 222 |
c1[0] = cl[0]; c1[1] = cl[1]; c1[2] = cl[2]; |
| 223 |
| 224 |
if (lvdir*a[i] > 0.) { |
| 225 |
printf("\n%s sphere %s.bc%d\n", pmtype, pname, i+1); |
| 226 |
printf("0\n0\n4 %18.12g %18.12g %18.12g %18.12g\n", |
| 227 |
c1[0], c1[1], c1[2], lvdir*crad); |
| 228 |
| 229 |
printf("\n%s cylinder %s.be%d\n", pmtype, pname, i+1); |
| 230 |
| 231 |
printf("\t%18.12g\t%18.12g\t%18.12g\n", c0[0], c0[1], c0[2]); |
| 232 |
printf("\t%18.12g\t%18.12g\t%18.12g\n", c1[0], c1[1], c1[2]); |
| 233 |
| 234 |
c0[0] = c1[0]; c0[1] = c1[1]; c0[2] = c1[2]; |
| 235 |
| 236 |
/* top corners and edges */ |
| 237 |
c0[0] = cl[0] = vert[nverts-1][0] + lvect[0] + |
| 238 |
| 239 |
c0[1] = cl[1] = vert[nverts-1][1] + lvect[1] + |
| 240 |
| 241 |
c0[2] = cl[2] = lvect[2] - crad; |
| 242 |
| 243 |
| 244 |
c1[0] = vert[i][0] + lvect[0] + |
| 245 |
| 246 |
c1[1] = vert[i][1] + lvect[1] + |
| 247 |
| 248 |
c1[2] = lvect[2] - crad; |
| 249 |
} else { |
| 250 |
| 251 |
| 252 |
| 253 |
printf("\n%s sphere %s.tc%d\n", pmtype, pname, i+1); |
| 254 |
| 255 |
| 256 |
| 257 |
printf("\n%s cylinder %s.te%d\n", pmtype, pname, i+1); |
| 258 |
| 259 |
| 260 |
| 261 |
| 262 |
| 263 |
| 264 |
| 265 |
| 266 |
| 267 |
static void |
| 268 |
printsides(int round) /* print prism sides */ |
| 269 |
| 270 |
int i; |
| 271 |
| 272 |
for (i = 0; i < nverts-1; i++) |
| 273 |
if (round) |
| 274 |
rside(i, i+1); |
| 275 |
else |
| 276 |
side(i, i+1); |
| 277 |
if (!iscomplete) { |
| 278 |
if (round) |
| 279 |
rside(nverts-1, 0); |
| 280 |
else |
| 281 |
| 282 |
| 283 |
| 284 |
| 285 |
| 286 |
int |
| 287 |
main(int argc, char **argv) |
| 288 |
| 289 |
int an; |
| 290 |
| 291 |
if (argc < 4) |
| 292 |
goto userr; |
| 293 |
| 294 |
pmtype = argv[1]; |
| 295 |
pname = argv[2]; |
| 296 |
| 297 |
if (!strcmp(argv[3], "-")) { |
| 298 |
readverts(NULL); |
| 299 |
an = 4; |
| 300 |
} else if (isdigit(argv[3][0])) { |
| 301 |
nverts = atoi(argv[3]); |
| 302 |
if (argc-3 < 2*nverts) |
| 303 |
goto userr; |
| 304 |
for (an = 0; an < nverts; an++) { |
| 305 |
vert[an][0] = atof(argv[2*an+4]); |
| 306 |
vert[an][1] = atof(argv[2*an+5]); |
| 307 |
| 308 |
an = 2*nverts+4; |
| 309 |
} else { |
| 310 |
readverts(argv[3]); |
| 311 |
an = 4; |
| 312 |
| 313 |
if (nverts < 3) { |
| 314 |
fprintf(stderr, "%s: not enough vertices\n", argv[0]); |
| 315 |
exit(1); |
| 316 |
| 317 |
| 318 |
for ( ; an < argc; an++) { |
| 319 |
if (argv[an][0] != '-') |
| 320 |
goto userr; |
| 321 |
switch (argv[an][1]) { |
| 322 |
case 'l': /* length vector */ |
| 323 |
lvect[0] = atof(argv[++an]); |
| 324 |
lvect[1] = atof(argv[++an]); |
| 325 |
lvect[2] = atof(argv[++an]); |
| 326 |
if (lvect[2] < -FTINY) |
| 327 |
lvdir = -1; |
| 328 |
else if (lvect[2] > FTINY) |
| 329 |
lvdir = 1; |
| 330 |
else { |
| 331 |
fprintf(stderr, |
| 332 |
"%s: illegal extrusion vector\n", |
| 333 |
argv[0]); |
| 334 |
exit(1); |
| 335 |
| 336 |
llen = sqrt(lvect[0]*lvect[0] + lvect[1]*lvect[1] + |
| 337 |
lvect[2]*lvect[2]); |
| 338 |
break; |
| 339 |
case 'r': /* radius */ |
| 340 |
crad = atof(argv[++an]); |
| 341 |
break; |
| 342 |
case 'e': /* ends */ |
| 343 |
do_ends = !do_ends; |
| 344 |
break; |
| 345 |
case 'c': /* complete */ |
| 346 |
iscomplete = !iscomplete; |
| 347 |
break; |
| 348 |
default: |
| 349 |
goto userr; |
| 350 |
| 351 |
| 352 |
if (crad > FTINY) { |
| 353 |
if (crad > lvdir*lvect[2]) { |
| 354 |
fprintf(stderr, "%s: rounding greater than height\n", |
| 355 |
argv[0]); |
| 356 |
exit(1); |
| 357 |
| 358 |
crad *= lvdir; /* simplifies formulas */ |
| 359 |
compute_rounding(); |
| 360 |
fputs("# ", stdout); |
| 361 |
printargs(argc, argv, stdout); |
| 362 |
if (do_ends) |
| 363 |
printrends(); |
| 364 |
printsides(1); |
| 365 |
} else { |
| 366 |
| 367 |
| 368 |
if (do_ends) |
| 369 |
printends(); |
| 370 |
printsides(0); |
| 371 |
| 372 |
return(0); |
| 373 |
userr: |
| 374 |
fprintf(stderr, "Usage: %s material name ", argv[0]); |
| 375 |
fprintf(stderr, "{ - | vfile | N v1 v2 .. vN } "); |
| 376 |
fprintf(stderr, "[-l lvect][-r radius][-c][-e]\n"); |
| 377 |
return(1); |
| 378 |
| 379 |
