root/radiance/ray/src/gen/genprism.c
Revision: 2.12
Committed: Sun Nov 16 10:29:38 2003 UTC (21 years, 5 months ago) by schorsch
CVS Tags: rad5R2, rad4R2P2, rad5R0, rad5R1, rad3R7P2, rad3R7P1, rad4R2, rad4R1, rad4R0, rad3R6, rad3R6P1, rad3R8, rad3R9, rad4R2P1
# User Rev Content
1 greg 1.1 #ifndef lint
2 schorsch 2.12 static const char RCSid[] = "$Id: genprism.c,v 2.11 2003/07/21 22:30:18 schorsch Exp $";
3 greg 1.1 #endif
4     /*
5     * genprism.c - generate a prism.
6     * 2D vertices in the xy plane are given on the
7     * command line or from a file. Their order together
8     * with the extrude direction will determine surface
9     * orientation.
10     */
11
12     #include <stdio.h>
13 schorsch 2.9 #include <string.h>
14 greg 2.8 #include <stdlib.h>
15 greg 2.3 #include <math.h>
16 greg 1.1 #include <ctype.h>
17
18     #define MAXVERT 1024 /* maximum # vertices */
19 greg 2.2
20 greg 2.6 #define FTINY 1e-6
21 greg 2.4
22 greg 1.1 char *pmtype; /* material type */
23     char *pname; /* name */
24
25     double lvect[3] = {0.0, 0.0, 1.0};
26 greg 2.7 int lvdir = 1;
27 greg 2.6 double llen = 1.0;
28 greg 1.1
29     double vert[MAXVERT][2];
30     int nverts = 0;
31
32 greg 2.6 double u[MAXVERT][2]; /* edge unit vectors */
33     double a[MAXVERT]; /* corner trim sizes */
34
35 greg 1.1 int do_ends = 1; /* include end caps */
36     int iscomplete = 0; /* polygon is already completed */
37 greg 2.7 double crad = 0.0; /* radius for corners (sign from lvdir) */
38 greg 1.1
39 schorsch 2.10 static double compute_rounding(void);
40 greg 1.1
41 greg 2.6
42 schorsch 2.9 static void
43 greg 1.1 readverts(fname) /* read vertices from a file */
44 greg 1.2 char *fname;
45 greg 1.1 {
46     FILE *fp;
47
48 greg 2.6 if (fname == NULL)
49 greg 1.1 fp = stdin;
50 greg 2.6 else if ((fp = fopen(fname, "r")) == NULL) {
51 greg 1.1 fprintf(stderr, "%s: cannot open\n", fname);
52     exit(1);
53     }
54     while (fscanf(fp, "%lf %lf", &vert[nverts][0], &vert[nverts][1]) == 2)
55 greg 2.6 nverts++;
56     fclose(fp);
57     }
58
59
60 schorsch 2.9 static void
61     side(n0, n1) /* print single side */
62     register int n0, n1;
63     {
64     printf("\n%s polygon %s.%d\n", pmtype, pname, n0+1);
65     printf("0\n0\n12\n");
66     printf("\t%18.12g\t%18.12g\t%18.12g\n", vert[n0][0],
67     vert[n0][1], 0.0);
68     printf("\t%18.12g\t%18.12g\t%18.12g\n", vert[n0][0]+lvect[0],
69     vert[n0][1]+lvect[1], lvect[2]);
70     printf("\t%18.12g\t%18.12g\t%18.12g\n", vert[n1][0]+lvect[0],
71     vert[n1][1]+lvect[1], lvect[2]);
72     printf("\t%18.12g\t%18.12g\t%18.12g\n", vert[n1][0],
73     vert[n1][1], 0.0);
74     }
75
76
77     static void
78     rside(n0, n1) /* print side with rounded edge */
79     register int n0, n1;
80     {
81     double s, c, t[3];
82
83     /* compute tanget offset vector */
84     s = lvdir*(lvect[1]*u[n1][0] - lvect[0]*u[n1][1])/llen;
85     if (s < -FTINY || s > FTINY) {
86     c = sqrt(1. - s*s);
87     t[0] = (c - 1.)*u[n1][1];
88     t[1] = (1. - c)*u[n1][0];
89     t[2] = s;
90     } else
91     t[0] = t[1] = t[2] = 0.;
92     /* output side */
93     printf("\n%s polygon %s.%d\n", pmtype, pname, n0+1);
94     printf("0\n0\n12\n");
95     printf("\t%18.12g\t%18.12g\t%18.12g\n",
96     vert[n0][0] + crad*(t[0] - a[n0]*u[n1][0]),
97     vert[n0][1] + crad*(t[1] - a[n0]*u[n1][1]),
98     crad*(t[2] + 1.));
99     printf("\t%18.12g\t%18.12g\t%18.12g\n",
100     vert[n0][0] + lvect[0] + crad*(t[0] - a[n0]*u[n1][0]),
101     vert[n0][1] + lvect[1] + crad*(t[1] - a[n0]*u[n1][1]),
102     lvect[2] + crad*(t[2] - 1.));
103     printf("\t%18.12g\t%18.12g\t%18.12g\n",
104     vert[n1][0] + lvect[0] + crad*(t[0] + a[n1]*u[n1][0]),
105     vert[n1][1] + lvect[1] + crad*(t[1] + a[n1]*u[n1][1]),
106     lvect[2] + crad*(t[2] - 1.));
107     printf("\t%18.12g\t%18.12g\t%18.12g\n",
108     vert[n1][0] + crad*(t[0] + a[n1]*u[n1][0]),
109     vert[n1][1] + crad*(t[1] + a[n1]*u[n1][1]),
110     crad*(t[2] + 1.));
111     /* output joining edge */
112     if (lvdir*a[n1] < 0.)
113     return;
114     printf("\n%s cylinder %s.e%d\n", pmtype, pname, n0+1);
115     printf("0\n0\n7\n");
116     printf("\t%18.12g\t%18.12g\t%18.12g\n",
117     vert[n1][0] + crad*(a[n1]*u[n1][0] - u[n1][1]),
118     vert[n1][1] + crad*(a[n1]*u[n1][1] + u[n1][0]),
119     crad);
120     printf("\t%18.12g\t%18.12g\t%18.12g\n",
121     vert[n1][0] + lvect[0] + crad*(a[n1]*u[n1][0] - u[n1][1]),
122     vert[n1][1] + lvect[1] + crad*(a[n1]*u[n1][1] + u[n1][0]),
123     lvect[2] - crad);
124     printf("\t%18.12g\n", lvdir*crad);
125     }
126
127
128     static double
129 greg 2.6 compute_rounding() /* compute vectors for rounding operations */
130     {
131     register int i;
132     register double *v0, *v1;
133 greg 2.7 double l, asum;
134 greg 2.6
135     v0 = vert[nverts-1];
136     for (i = 0; i < nverts; i++) { /* compute u[*] */
137     v1 = vert[i];
138     u[i][0] = v0[0] - v1[0];
139     u[i][1] = v0[1] - v1[1];
140     l = sqrt(u[i][0]*u[i][0] + u[i][1]*u[i][1]);
141     if (l <= FTINY) {
142     fprintf(stderr, "Degenerate side in prism\n");
143 greg 2.5 exit(1);
144     }
145 greg 2.6 u[i][0] /= l;
146     u[i][1] /= l;
147     v0 = v1;
148     }
149 greg 2.7 asum = 0.;
150 greg 2.6 v1 = u[0];
151     for (i = nverts; i--; ) { /* compute a[*] */
152     v0 = u[i];
153     l = v0[0]*v1[0] + v0[1]*v1[1];
154     if (1+l <= FTINY) {
155     fprintf(stderr, "Overlapping sides in prism\n");
156     exit(1);
157     }
158     if (1-l <= 0.)
159     a[i] = 0.;
160     else {
161     a[i] = sqrt((1-l)/(1+l));
162 greg 2.7 asum += l = v1[0]*v0[1]-v1[1]*v0[0];
163     if (l < 0.)
164 greg 2.6 a[i] = -a[i];
165     }
166     v1 = v0;
167     }
168 greg 2.7 return(asum*.5);
169 greg 1.1 }
170
171
172 schorsch 2.9 static void
173 greg 1.1 printends() /* print ends of prism */
174     {
175     register int i;
176 greg 2.6 /* bottom face */
177     printf("\n%s polygon %s.b\n", pmtype, pname);
178     printf("0\n0\n%d\n", nverts*3);
179     for (i = 0; i < nverts; i++)
180     printf("\t%18.12g\t%18.12g\t%18.12g\n", vert[i][0],
181     vert[i][1], 0.0);
182     /* top face */
183     printf("\n%s polygon %s.t\n", pmtype, pname);
184     printf("0\n0\n%d\n", nverts*3);
185     for (i = nverts; i--; )
186     printf("\t%18.12g\t%18.12g\t%18.12g\n", vert[i][0]+lvect[0],
187     vert[i][1]+lvect[1], lvect[2]);
188     }
189 greg 1.1
190 greg 2.6
191 schorsch 2.9 static void
192 greg 2.6 printrends() /* print ends of prism with rounding */
193     {
194     register int i;
195     double c0[3], c1[3], cl[3];
196     /* bottom face */
197 greg 1.1 printf("\n%s polygon %s.b\n", pmtype, pname);
198     printf("0\n0\n%d\n", nverts*3);
199     for (i = 0; i < nverts; i++) {
200     printf("\t%18.12g\t%18.12g\t%18.12g\n",
201 greg 2.6 vert[i][0] + crad*(a[i]*u[i][0] - u[i][1]),
202     vert[i][1] + crad*(a[i]*u[i][1] + u[i][0]),
203     0.0);
204 greg 1.1 }
205 greg 2.7 /* top face */
206     printf("\n%s polygon %s.t\n", pmtype, pname);
207     printf("0\n0\n%d\n", nverts*3);
208     for (i = nverts; i--; ) {
209     printf("\t%18.12g\t%18.12g\t%18.12g\n",
210     vert[i][0] + lvect[0] + crad*(a[i]*u[i][0] - u[i][1]),
211     vert[i][1] + lvect[1] + crad*(a[i]*u[i][1] + u[i][0]),
212     lvect[2]);
213     }
214 greg 2.6 /* bottom corners and edges */
215     c0[0] = cl[0] = vert[nverts-1][0] +
216     crad*(a[nverts-1]*u[nverts-1][0] - u[nverts-1][1]);
217     c0[1] = cl[1] = vert[nverts-1][1] +
218     crad*(a[nverts-1]*u[nverts-1][1] + u[nverts-1][0]);
219     c0[2] = cl[2] = crad;
220     for (i = 0; i < nverts; i++) {
221     if (i < nverts-1) {
222     c1[0] = vert[i][0] + crad*(a[i]*u[i][0] - u[i][1]);
223     c1[1] = vert[i][1] + crad*(a[i]*u[i][1] + u[i][0]);
224     c1[2] = crad;
225     } else {
226     c1[0] = cl[0]; c1[1] = cl[1]; c1[2] = cl[2];
227     }
228 greg 2.7 if (lvdir*a[i] > 0.) {
229 greg 2.6 printf("\n%s sphere %s.bc%d\n", pmtype, pname, i+1);
230     printf("0\n0\n4 %18.12g %18.12g %18.12g %18.12g\n",
231 greg 2.7 c1[0], c1[1], c1[2], lvdir*crad);
232 greg 2.6 }
233     printf("\n%s cylinder %s.be%d\n", pmtype, pname, i+1);
234     printf("0\n0\n7\n");
235     printf("\t%18.12g\t%18.12g\t%18.12g\n", c0[0], c0[1], c0[2]);
236     printf("\t%18.12g\t%18.12g\t%18.12g\n", c1[0], c1[1], c1[2]);
237 greg 2.7 printf("\t%18.12g\n", lvdir*crad);
238 greg 2.6 c0[0] = c1[0]; c0[1] = c1[1]; c0[2] = c1[2];
239     }
240     /* top corners and edges */
241     c0[0] = cl[0] = vert[nverts-1][0] + lvect[0] +
242     crad*(a[nverts-1]*u[nverts-1][0] - u[nverts-1][1]);
243     c0[1] = cl[1] = vert[nverts-1][1] + lvect[1] +
244     crad*(a[nverts-1]*u[nverts-1][1] + u[nverts-1][0]);
245     c0[2] = cl[2] = lvect[2] - crad;
246     for (i = 0; i < nverts; i++) {
247     if (i < nverts-1) {
248     c1[0] = vert[i][0] + lvect[0] +
249     crad*(a[i]*u[i][0] - u[i][1]);
250     c1[1] = vert[i][1] + lvect[1] +
251     crad*(a[i]*u[i][1] + u[i][0]);
252     c1[2] = lvect[2] - crad;
253     } else {
254     c1[0] = cl[0]; c1[1] = cl[1]; c1[2] = cl[2];
255     }
256 greg 2.7 if (lvdir*a[i] > 0.) {
257 greg 2.6 printf("\n%s sphere %s.tc%d\n", pmtype, pname, i+1);
258     printf("0\n0\n4 %18.12g %18.12g %18.12g %18.12g\n",
259 greg 2.7 c1[0], c1[1], c1[2], lvdir*crad);
260 greg 2.6 }
261     printf("\n%s cylinder %s.te%d\n", pmtype, pname, i+1);
262     printf("0\n0\n7\n");
263     printf("\t%18.12g\t%18.12g\t%18.12g\n", c0[0], c0[1], c0[2]);
264     printf("\t%18.12g\t%18.12g\t%18.12g\n", c1[0], c1[1], c1[2]);
265 greg 2.7 printf("\t%18.12g\n", lvdir*crad);
266 greg 2.6 c0[0] = c1[0]; c0[1] = c1[1]; c0[2] = c1[2];
267     }
268 greg 1.1 }
269
270
271 schorsch 2.9 static void
272 greg 2.6 printsides(round) /* print prism sides */
273     int round;
274 greg 1.1 {
275     register int i;
276
277     for (i = 0; i < nverts-1; i++)
278 greg 2.6 if (round)
279     rside(i, i+1);
280     else
281     side(i, i+1);
282 schorsch 2.11 if (!iscomplete) {
283 greg 2.6 if (round)
284     rside(nverts-1, 0);
285     else
286     side(nverts-1, 0);
287 schorsch 2.11 }
288 greg 1.1 }
289
290
291 schorsch 2.9 static void
292 greg 1.1 printhead(ac, av) /* print command header */
293     register int ac;
294     register char **av;
295     {
296     putchar('#');
297     while (ac--) {
298     putchar(' ');
299     fputs(*av++, stdout);
300     }
301     putchar('\n');
302     }
303 schorsch 2.9
304
305 schorsch 2.12 int
306 schorsch 2.9 main(argc, argv)
307     int argc;
308     char **argv;
309     {
310     int an;
311
312     if (argc < 4)
313     goto userr;
314
315     pmtype = argv[1];
316     pname = argv[2];
317
318     if (!strcmp(argv[3], "-")) {
319     readverts(NULL);
320     an = 4;
321     } else if (isdigit(argv[3][0])) {
322     nverts = atoi(argv[3]);
323     if (argc-3 < 2*nverts)
324     goto userr;
325     for (an = 0; an < nverts; an++) {
326     vert[an][0] = atof(argv[2*an+4]);
327     vert[an][1] = atof(argv[2*an+5]);
328     }
329     an = 2*nverts+4;
330     } else {
331     readverts(argv[3]);
332     an = 4;
333     }
334     if (nverts < 3) {
335     fprintf(stderr, "%s: not enough vertices\n", argv[0]);
336     exit(1);
337     }
338
339     for ( ; an < argc; an++) {
340     if (argv[an][0] != '-')
341     goto userr;
342     switch (argv[an][1]) {
343     case 'l': /* length vector */
344     lvect[0] = atof(argv[++an]);
345     lvect[1] = atof(argv[++an]);
346     lvect[2] = atof(argv[++an]);
347     if (lvect[2] < -FTINY)
348     lvdir = -1;
349     else if (lvect[2] > FTINY)
350     lvdir = 1;
351     else {
352     fprintf(stderr,
353     "%s: illegal extrusion vector\n",
354     argv[0]);
355     exit(1);
356     }
357     llen = sqrt(lvect[0]*lvect[0] + lvect[1]*lvect[1] +
358     lvect[2]*lvect[2]);
359     break;
360     case 'r': /* radius */
361     crad = atof(argv[++an]);
362     break;
363     case 'e': /* ends */
364     do_ends = !do_ends;
365     break;
366     case 'c': /* complete */
367     iscomplete = !iscomplete;
368     break;
369     default:
370     goto userr;
371     }
372     }
373     if (crad > FTINY) {
374     if (crad > lvdir*lvect[2]) {
375     fprintf(stderr, "%s: rounding greater than height\n",
376     argv[0]);
377     exit(1);
378     }
379     crad *= lvdir; /* simplifies formulas */
380     compute_rounding();
381     printhead(argc, argv);
382     if (do_ends)
383     printrends();
384     printsides(1);
385     } else {
386     printhead(argc, argv);
387     if (do_ends)
388     printends();
389     printsides(0);
390     }
391     exit(0);
392     userr:
393     fprintf(stderr, "Usage: %s material name ", argv[0]);
394     fprintf(stderr, "{ - | vfile | N v1 v2 .. vN } ");
395     fprintf(stderr, "[-l lvect][-r radius][-c][-e]\n");
396     exit(1);
397     }
398
