--- ray/src/gen/genprism.c 1996/03/19 16:30:56 2.6 +++ ray/src/gen/genprism.c 2003/06/08 12:03:09 2.9 @@ -1,9 +1,6 @@ -/* Copyright (c) 1996 Regents of the University of California */ - #ifndef lint -static char SCCSid[] = "$SunId$ LBL"; +static const char RCSid[] = "$Id: genprism.c,v 2.9 2003/06/08 12:03:09 schorsch Exp $"; #endif - /* * genprism.c - generate a prism. * 2D vertices in the xy plane are given on the @@ -13,23 +10,20 @@ static char SCCSid[] = "$SunId$ LBL"; */ #include - +#include +#include #include - #include #define MAXVERT 1024 /* maximum # vertices */ #define FTINY 1e-6 -#ifdef DCL_ATOF -extern double atof(); -#endif - char *pmtype; /* material type */ char *pname; /* name */ double lvect[3] = {0.0, 0.0, 1.0}; +int lvdir = 1; double llen = 1.0; double vert[MAXVERT][2]; @@ -40,100 +34,12 @@ double a[MAXVERT]; /* corner trim sizes */ int do_ends = 1; /* include end caps */ int iscomplete = 0; /* polygon is already completed */ -double crad = 0.0; /* radius for corners */ +double crad = 0.0; /* radius for corners (sign from lvdir) */ -#define rounding (crad > FTINY) +extern double compute_rounding(); -main(argc, argv) -int argc; -char **argv; -{ - int an; - - if (argc < 4) - goto userr; - - pmtype = argv[1]; - pname = argv[2]; - - if (!strcmp(argv[3], "-")) { - readverts(NULL); - an = 4; - } else if (isdigit(argv[3][0])) { - nverts = atoi(argv[3]); - if (argc-3 < 2*nverts) - goto userr; - for (an = 0; an < nverts; an++) { - vert[an][0] = atof(argv[2*an+4]); - vert[an][1] = atof(argv[2*an+5]); - } - an = 2*nverts+4; - } else { - readverts(argv[3]); - an = 4; - } - if (nverts < 3) { - fprintf(stderr, "%s: not enough vertices\n", argv[0]); - exit(1); - } - - for ( ; an < argc; an++) { - if (argv[an][0] != '-') - goto userr; - switch (argv[an][1]) { - case 'l': /* length vector */ - lvect[0] = atof(argv[++an]); - lvect[1] = atof(argv[++an]); - lvect[2] = atof(argv[++an]); - llen = sqrt(lvect[0]*lvect[0] + lvect[1]*lvect[1] + - lvect[2]*lvect[2]); - if (llen <= FTINY) { - fprintf(stderr, "%s: zero extrusion vector\n", - argv[0]); - exit(1); - } - break; - case 'r': /* radius */ - crad = atof(argv[++an]); - break; - case 'e': /* ends */ - do_ends = !do_ends; - break; - case 'c': /* complete */ - iscomplete = !iscomplete; - break; - default: - goto userr; - } - } - if (rounding) { - if (crad > fabs(lvect[2])) { - fprintf(stderr, "%s: rounding greater than height\n", - argv[0]); - exit(1); - } - compute_rounding(); - } - printhead(argc, argv); - - if (do_ends) - if (rounding) - printrends(); - else - printends(); - - printsides(rounding); - - exit(0); -userr: - fprintf(stderr, "Usage: %s material name ", argv[0]); - fprintf(stderr, "{ - | vfile | N v1 v2 .. vN } "); - fprintf(stderr, "[-l lvect][-r radius][-c][-e]\n"); - exit(1); -} - - +static void readverts(fname) /* read vertices from a file */ char *fname; { @@ -151,11 +57,80 @@ char *fname; } +static void +side(n0, n1) /* print single side */ +register int n0, n1; +{ + printf("\n%s polygon %s.%d\n", pmtype, pname, n0+1); + printf("0\n0\n12\n"); + printf("\t%18.12g\t%18.12g\t%18.12g\n", vert[n0][0], + vert[n0][1], 0.0); + printf("\t%18.12g\t%18.12g\t%18.12g\n", vert[n0][0]+lvect[0], + vert[n0][1]+lvect[1], lvect[2]); + printf("\t%18.12g\t%18.12g\t%18.12g\n", vert[n1][0]+lvect[0], + vert[n1][1]+lvect[1], lvect[2]); + printf("\t%18.12g\t%18.12g\t%18.12g\n", vert[n1][0], + vert[n1][1], 0.0); +} + + +static void +rside(n0, n1) /* print side with rounded edge */ +register int n0, n1; +{ + double s, c, t[3]; + + /* compute tanget offset vector */ + s = lvdir*(lvect[1]*u[n1][0] - lvect[0]*u[n1][1])/llen; + if (s < -FTINY || s > FTINY) { + c = sqrt(1. - s*s); + t[0] = (c - 1.)*u[n1][1]; + t[1] = (1. - c)*u[n1][0]; + t[2] = s; + } else + t[0] = t[1] = t[2] = 0.; + /* output side */ + printf("\n%s polygon %s.%d\n", pmtype, pname, n0+1); + printf("0\n0\n12\n"); + printf("\t%18.12g\t%18.12g\t%18.12g\n", + vert[n0][0] + crad*(t[0] - a[n0]*u[n1][0]), + vert[n0][1] + crad*(t[1] - a[n0]*u[n1][1]), + crad*(t[2] + 1.)); + printf("\t%18.12g\t%18.12g\t%18.12g\n", + vert[n0][0] + lvect[0] + crad*(t[0] - a[n0]*u[n1][0]), + vert[n0][1] + lvect[1] + crad*(t[1] - a[n0]*u[n1][1]), + lvect[2] + crad*(t[2] - 1.)); + printf("\t%18.12g\t%18.12g\t%18.12g\n", + vert[n1][0] + lvect[0] + crad*(t[0] + a[n1]*u[n1][0]), + vert[n1][1] + lvect[1] + crad*(t[1] + a[n1]*u[n1][1]), + lvect[2] + crad*(t[2] - 1.)); + printf("\t%18.12g\t%18.12g\t%18.12g\n", + vert[n1][0] + crad*(t[0] + a[n1]*u[n1][0]), + vert[n1][1] + crad*(t[1] + a[n1]*u[n1][1]), + crad*(t[2] + 1.)); + /* output joining edge */ + if (lvdir*a[n1] < 0.) + return; + printf("\n%s cylinder %s.e%d\n", pmtype, pname, n0+1); + printf("0\n0\n7\n"); + printf("\t%18.12g\t%18.12g\t%18.12g\n", + vert[n1][0] + crad*(a[n1]*u[n1][0] - u[n1][1]), + vert[n1][1] + crad*(a[n1]*u[n1][1] + u[n1][0]), + crad); + printf("\t%18.12g\t%18.12g\t%18.12g\n", + vert[n1][0] + lvect[0] + crad*(a[n1]*u[n1][0] - u[n1][1]), + vert[n1][1] + lvect[1] + crad*(a[n1]*u[n1][1] + u[n1][0]), + lvect[2] - crad); + printf("\t%18.12g\n", lvdir*crad); +} + + +static double compute_rounding() /* compute vectors for rounding operations */ { register int i; register double *v0, *v1; - double l; + double l, asum; v0 = vert[nverts-1]; for (i = 0; i < nverts; i++) { /* compute u[*] */ @@ -171,6 +146,7 @@ compute_rounding() /* compute vectors for rounding op u[i][1] /= l; v0 = v1; } + asum = 0.; v1 = u[0]; for (i = nverts; i--; ) { /* compute a[*] */ v0 = u[i]; @@ -183,14 +159,17 @@ compute_rounding() /* compute vectors for rounding op a[i] = 0.; else { a[i] = sqrt((1-l)/(1+l)); - if ((v1[0]*v0[1]-v1[1]*v0[0] > 0.) != (lvect[2] > 0.)) + asum += l = v1[0]*v0[1]-v1[1]*v0[0]; + if (l < 0.) a[i] = -a[i]; } v1 = v0; } + return(asum*.5); } +static void printends() /* print ends of prism */ { register int i; @@ -209,6 +188,7 @@ printends() /* print ends of prism */ } +static void printrends() /* print ends of prism with rounding */ { register int i; @@ -222,6 +202,15 @@ printrends() /* print ends of prism with rounding */ vert[i][1] + crad*(a[i]*u[i][1] + u[i][0]), 0.0); } + /* top face */ + printf("\n%s polygon %s.t\n", pmtype, pname); + printf("0\n0\n%d\n", nverts*3); + for (i = nverts; i--; ) { + printf("\t%18.12g\t%18.12g\t%18.12g\n", + vert[i][0] + lvect[0] + crad*(a[i]*u[i][0] - u[i][1]), + vert[i][1] + lvect[1] + crad*(a[i]*u[i][1] + u[i][0]), + lvect[2]); + } /* bottom corners and edges */ c0[0] = cl[0] = vert[nverts-1][0] + crad*(a[nverts-1]*u[nverts-1][0] - u[nverts-1][1]); @@ -236,27 +225,18 @@ printrends() /* print ends of prism with rounding */ } else { c1[0] = cl[0]; c1[1] = cl[1]; c1[2] = cl[2]; } - if (a[i] > 0.) { + if (lvdir*a[i] > 0.) { printf("\n%s sphere %s.bc%d\n", pmtype, pname, i+1); printf("0\n0\n4 %18.12g %18.12g %18.12g %18.12g\n", - c1[0], c1[1], c1[2], crad); + c1[0], c1[1], c1[2], lvdir*crad); } printf("\n%s cylinder %s.be%d\n", pmtype, pname, i+1); printf("0\n0\n7\n"); printf("\t%18.12g\t%18.12g\t%18.12g\n", c0[0], c0[1], c0[2]); printf("\t%18.12g\t%18.12g\t%18.12g\n", c1[0], c1[1], c1[2]); - printf("\t%18.12g\n", crad); + printf("\t%18.12g\n", lvdir*crad); c0[0] = c1[0]; c0[1] = c1[1]; c0[2] = c1[2]; } - /* top face */ - printf("\n%s polygon %s.t\n", pmtype, pname); - printf("0\n0\n%d\n", nverts*3); - for (i = nverts; i--; ) { - printf("\t%18.12g\t%18.12g\t%18.12g\n", - vert[i][0] + lvect[0] + crad*(a[i]*u[i][0] - u[i][1]), - vert[i][1] + lvect[1] + crad*(a[i]*u[i][1] + u[i][0]), - lvect[2]); - } /* top corners and edges */ c0[0] = cl[0] = vert[nverts-1][0] + lvect[0] + crad*(a[nverts-1]*u[nverts-1][0] - u[nverts-1][1]); @@ -273,21 +253,22 @@ printrends() /* print ends of prism with rounding */ } else { c1[0] = cl[0]; c1[1] = cl[1]; c1[2] = cl[2]; } - if (a[i] > 0.) { + if (lvdir*a[i] > 0.) { printf("\n%s sphere %s.tc%d\n", pmtype, pname, i+1); printf("0\n0\n4 %18.12g %18.12g %18.12g %18.12g\n", - c1[0], c1[1], c1[2], crad); + c1[0], c1[1], c1[2], lvdir*crad); } printf("\n%s cylinder %s.te%d\n", pmtype, pname, i+1); printf("0\n0\n7\n"); printf("\t%18.12g\t%18.12g\t%18.12g\n", c0[0], c0[1], c0[2]); printf("\t%18.12g\t%18.12g\t%18.12g\n", c1[0], c1[1], c1[2]); - printf("\t%18.12g\n", crad); + printf("\t%18.12g\n", lvdir*crad); c0[0] = c1[0]; c0[1] = c1[1]; c0[2] = c1[2]; } } +static void printsides(round) /* print prism sides */ int round; { @@ -306,72 +287,7 @@ int round; } -side(n0, n1) /* print single side */ -register int n0, n1; -{ - printf("\n%s polygon %s.%d\n", pmtype, pname, n0+1); - printf("0\n0\n12\n"); - printf("\t%18.12g\t%18.12g\t%18.12g\n", vert[n0][0], - vert[n0][1], 0.0); - printf("\t%18.12g\t%18.12g\t%18.12g\n", vert[n0][0]+lvect[0], - vert[n0][1]+lvect[1], lvect[2]); - printf("\t%18.12g\t%18.12g\t%18.12g\n", vert[n1][0]+lvect[0], - vert[n1][1]+lvect[1], lvect[2]); - printf("\t%18.12g\t%18.12g\t%18.12g\n", vert[n1][0], - vert[n1][1], 0.0); -} - - -rside(n0, n1) /* print side with rounded edge */ -register int n0, n1; -{ - double s, c, t[3]; - - /* compute tanget offset vector */ - s = (lvect[1]*u[n1][0] - lvect[0]*u[n1][1])/llen; - if (s < -FTINY || s > FTINY) { - c = sqrt(1. - s*s); - t[0] = (c - 1.)*u[n1][1]; - t[1] = (1. - c)*u[n1][0]; - t[2] = s; - } else - t[0] = t[1] = t[2] = 0.; - /* output side */ - printf("\n%s polygon %s.%d\n", pmtype, pname, n0+1); - printf("0\n0\n12\n"); - printf("\t%18.12g\t%18.12g\t%18.12g\n", - vert[n0][0] + crad*(t[0] - a[n0]*u[n1][0]), - vert[n0][1] + crad*(t[1] - a[n0]*u[n1][1]), - crad*(t[2] + 1.)); - printf("\t%18.12g\t%18.12g\t%18.12g\n", - vert[n0][0] + lvect[0] + crad*(t[0] - a[n0]*u[n1][0]), - vert[n0][1] + lvect[1] + crad*(t[1] - a[n0]*u[n1][1]), - lvect[2] + crad*(t[2] - 1.)); - printf("\t%18.12g\t%18.12g\t%18.12g\n", - vert[n1][0] + lvect[0] + crad*(t[0] + a[n1]*u[n1][0]), - vert[n1][1] + lvect[1] + crad*(t[1] + a[n1]*u[n1][1]), - lvect[2] + crad*(t[2] - 1.)); - printf("\t%18.12g\t%18.12g\t%18.12g\n", - vert[n1][0] + crad*(t[0] + a[n1]*u[n1][0]), - vert[n1][1] + crad*(t[1] + a[n1]*u[n1][1]), - crad*(t[2] + 1.)); - /* output joining edge */ - if (a[n1] < 0.) - return; - printf("\n%s cylinder %s.e%d\n", pmtype, pname, n0+1); - printf("0\n0\n7\n"); - printf("\t%18.12g\t%18.12g\t%18.12g\n", - vert[n1][0] + crad*(a[n1]*u[n1][0] - u[n1][1]), - vert[n1][1] + crad*(a[n1]*u[n1][1] + u[n1][0]), - crad); - printf("\t%18.12g\t%18.12g\t%18.12g\n", - vert[n1][0] + lvect[0] + crad*(a[n1]*u[n1][0] - u[n1][1]), - vert[n1][1] + lvect[1] + crad*(a[n1]*u[n1][1] + u[n1][0]), - lvect[2] - crad); - printf("\t%18.12g\n", crad); -} - - +static void printhead(ac, av) /* print command header */ register int ac; register char **av; @@ -383,3 +299,98 @@ register char **av; } putchar('\n'); } + + +main(argc, argv) +int argc; +char **argv; +{ + int an; + + if (argc < 4) + goto userr; + + pmtype = argv[1]; + pname = argv[2]; + + if (!strcmp(argv[3], "-")) { + readverts(NULL); + an = 4; + } else if (isdigit(argv[3][0])) { + nverts = atoi(argv[3]); + if (argc-3 < 2*nverts) + goto userr; + for (an = 0; an < nverts; an++) { + vert[an][0] = atof(argv[2*an+4]); + vert[an][1] = atof(argv[2*an+5]); + } + an = 2*nverts+4; + } else { + readverts(argv[3]); + an = 4; + } + if (nverts < 3) { + fprintf(stderr, "%s: not enough vertices\n", argv[0]); + exit(1); + } + + for ( ; an < argc; an++) { + if (argv[an][0] != '-') + goto userr; + switch (argv[an][1]) { + case 'l': /* length vector */ + lvect[0] = atof(argv[++an]); + lvect[1] = atof(argv[++an]); + lvect[2] = atof(argv[++an]); + if (lvect[2] < -FTINY) + lvdir = -1; + else if (lvect[2] > FTINY) + lvdir = 1; + else { + fprintf(stderr, + "%s: illegal extrusion vector\n", + argv[0]); + exit(1); + } + llen = sqrt(lvect[0]*lvect[0] + lvect[1]*lvect[1] + + lvect[2]*lvect[2]); + break; + case 'r': /* radius */ + crad = atof(argv[++an]); + break; + case 'e': /* ends */ + do_ends = !do_ends; + break; + case 'c': /* complete */ + iscomplete = !iscomplete; + break; + default: + goto userr; + } + } + if (crad > FTINY) { + if (crad > lvdir*lvect[2]) { + fprintf(stderr, "%s: rounding greater than height\n", + argv[0]); + exit(1); + } + crad *= lvdir; /* simplifies formulas */ + compute_rounding(); + printhead(argc, argv); + if (do_ends) + printrends(); + printsides(1); + } else { + printhead(argc, argv); + if (do_ends) + printends(); + printsides(0); + } + exit(0); +userr: + fprintf(stderr, "Usage: %s material name ", argv[0]); + fprintf(stderr, "{ - | vfile | N v1 v2 .. vN } "); + fprintf(stderr, "[-l lvect][-r radius][-c][-e]\n"); + exit(1); +} +
