1 |
/* Copyright (c) 1987 Regents of the University of California */ |
2 |
3 |
#ifndef lint |
4 |
static char SCCSid[] = "$SunId$ LBL"; |
5 |
#endif |
6 |
7 |
8 |
* genprism.c - generate a prism. |
9 |
* 2D vertices in the xy plane are given on the |
10 |
* command line or from a file. Their order together |
11 |
* with the extrude direction will determine surface |
12 |
* orientation. |
13 |
14 |
* 8/24/87 |
15 |
16 |
17 |
#include <stdio.h> |
18 |
19 |
#include <ctype.h> |
20 |
21 |
#define MAXVERT 1024 /* maximum # vertices */ |
22 |
23 |
#ifndef atof |
24 |
extern double atof(); |
25 |
#endif |
26 |
27 |
char *pmtype; /* material type */ |
28 |
char *pname; /* name */ |
29 |
30 |
double lvect[3] = {0.0, 0.0, 1.0}; |
31 |
32 |
double vert[MAXVERT][2]; |
33 |
int nverts = 0; |
34 |
35 |
int do_ends = 1; /* include end caps */ |
36 |
int iscomplete = 0; /* polygon is already completed */ |
37 |
38 |
39 |
main(argc, argv) |
40 |
int argc; |
41 |
char **argv; |
42 |
43 |
int an; |
44 |
45 |
if (argc < 4) |
46 |
goto userr; |
47 |
48 |
pmtype = argv[1]; |
49 |
pname = argv[2]; |
50 |
51 |
if (!strcmp(argv[3], "-")) { |
52 |
readverts(NULL); |
53 |
an = 4; |
54 |
} else if (isdigit(argv[3][0])) { |
55 |
nverts = atoi(argv[3]); |
56 |
if (argc-3 < 2*nverts) |
57 |
goto userr; |
58 |
for (an = 0; an < nverts; an++) { |
59 |
vert[an][0] = atof(argv[2*an+4]); |
60 |
vert[an][1] = atof(argv[2*an+5]); |
61 |
62 |
an = 2*nverts+4; |
63 |
} else { |
64 |
readverts(argv[3]); |
65 |
an = 4; |
66 |
67 |
if (nverts < 3) { |
68 |
fprintf(stderr, "%s: not enough vertices\n", argv[0]); |
69 |
exit(1); |
70 |
71 |
72 |
for ( ; an < argc; an++) { |
73 |
if (argv[an][0] != '-') |
74 |
goto userr; |
75 |
switch (argv[an][1]) { |
76 |
case 'l': /* length vector */ |
77 |
lvect[0] = atof(argv[++an]); |
78 |
lvect[1] = atof(argv[++an]); |
79 |
lvect[2] = atof(argv[++an]); |
80 |
break; |
81 |
case 'e': /* ends */ |
82 |
do_ends = !do_ends; |
83 |
break; |
84 |
case 'c': /* complete */ |
85 |
iscomplete = !iscomplete; |
86 |
break; |
87 |
default: |
88 |
goto userr; |
89 |
90 |
91 |
92 |
printhead(argc, argv); |
93 |
94 |
if (do_ends) |
95 |
printends(); |
96 |
printsides(); |
97 |
98 |
return(0); |
99 |
userr: |
100 |
fprintf(stderr, "Usage: %s material name ", argv[0]); |
101 |
fprintf(stderr, "{ - | vfile | N v1 v2 .. vN } "); |
102 |
fprintf(stderr, "[-l lvect][-c][-e]\n"); |
103 |
exit(1); |
104 |
105 |
106 |
107 |
readverts(fname) /* read vertices from a file */ |
108 |
char *fname; |
109 |
110 |
FILE *fp; |
111 |
112 |
if (fname == NULL) |
113 |
fp = stdin; |
114 |
else if ((fp = fopen(fname, "r")) == NULL) { |
115 |
fprintf(stderr, "%s: cannot open\n", fname); |
116 |
exit(1); |
117 |
118 |
while (fscanf(fp, "%lf %lf", &vert[nverts][0], &vert[nverts][1]) == 2) |
119 |
nverts++; |
120 |
fclose(fp); |
121 |
122 |
123 |
124 |
printends() /* print ends of prism */ |
125 |
126 |
register int i; |
127 |
128 |
printf("\n%s polygon %s.b\n", pmtype, pname); |
129 |
printf("0\n0\n%d\n", nverts*3); |
130 |
for (i = 0; i < nverts; i++) { |
131 |
printf("\t%18.12g\t%18.12g\t%18.12g\n", |
132 |
vert[i][0], |
133 |
vert[i][1], |
134 |
0.0); |
135 |
136 |
printf("\n%s polygon %s.e\n", pmtype, pname); |
137 |
138 |
for (i = nverts-1; i >= 0; i--) { |
139 |
140 |
vert[i][0]+lvect[0], |
141 |
vert[i][1]+lvect[1], |
142 |
lvect[2]); |
143 |
144 |
145 |
146 |
147 |
printsides() /* print prism sides */ |
148 |
149 |
register int i; |
150 |
151 |
for (i = 0; i < nverts-1; i++) |
152 |
side(i, i+1); |
153 |
if (!iscomplete) |
154 |
side(nverts-1, 0); |
155 |
156 |
157 |
158 |
side(n1, n2) /* print single side */ |
159 |
register int n1, n2; |
160 |
161 |
printf("\n%s polygon %s.%d\n", pmtype, pname, n1+1); |
162 |
printf("0\n0\n12\n"); |
163 |
164 |
vert[n1][0], |
165 |
vert[n1][1], |
166 |
0.0); |
167 |
168 |
vert[n1][0]+lvect[0], |
169 |
vert[n1][1]+lvect[1], |
170 |
lvect[2]); |
171 |
172 |
vert[n2][0]+lvect[0], |
173 |
vert[n2][1]+lvect[1], |
174 |
lvect[2]); |
175 |
176 |
vert[n2][0], |
177 |
vert[n2][1], |
178 |
0.0); |
179 |
180 |
181 |
182 |
printhead(ac, av) /* print command header */ |
183 |
register int ac; |
184 |
register char **av; |
185 |
186 |
putchar('#'); |
187 |
while (ac--) { |
188 |
putchar(' '); |
189 |
fputs(*av++, stdout); |
190 |
191 |
putchar('\n'); |
192 |
