root/radiance/ray/src/gen/genprism.c
Revision: 2.14
Committed: Sat Jun 7 05:09:45 2025 UTC (7 hours, 30 minutes ago) by greg
2 static const char RCSid[] = "$Id: genprism.c,v 2.13 2020/07/25 19:18:01 greg Exp $";
5 * genprism.c - generate a prism.
6 * 2D vertices in the xy plane are given on the
7 * command line or from a file. Their order together
8 * with the extrude direction will determine surface
9 * orientation.
10 */
11
12 #include "rtio.h"
13 #include "paths.h"
14 #include <math.h>
15 #include <ctype.h>
16
17 #define MAXVERT 1024 /* maximum # vertices */
18
19 #define FTINY 1e-6
20
21 char *pmtype; /* material type */
22 char *pname; /* name */
23
24 double lvect[3] = {0.0, 0.0, 1.0};
25 int lvdir = 1;
26 double llen = 1.0;
27
28 double vert[MAXVERT][2];
29 int nverts = 0;
30
31 double u[MAXVERT][2]; /* edge unit vectors */
32 double a[MAXVERT]; /* corner trim sizes */
33
34 int do_ends = 1; /* include end caps */
35 int iscomplete = 0; /* polygon is already completed */
36 double crad = 0.0; /* radius for corners (sign from lvdir) */
37
38 static double compute_rounding(void);
39
40
41 static void
42 readverts(char *fname) /* read vertices from a file */
43 {
44 FILE *fp;
45
46 if (fname == NULL)
47 fp = stdin;
48 else if ((fp = fopen(fname, "r")) == NULL) {
49 fprintf(stderr, "%s: cannot open\n", fname);
50 exit(1);
51 }
52 while (fscanf(fp, "%lf %lf", &vert[nverts][0], &vert[nverts][1]) == 2)
53 nverts++;
54 fclose(fp);
55 }
56
57
58 static void
59 side(int n0, int n1) /* print single side */
60 {
61 printf("\n%s polygon %s.%d\n", pmtype, pname, n0+1);
62 printf("0\n0\n12\n");
63 printf("\t%18.12g\t%18.12g\t%18.12g\n", vert[n0][0],
64 vert[n0][1], 0.0);
65 printf("\t%18.12g\t%18.12g\t%18.12g\n", vert[n0][0]+lvect[0],
66 vert[n0][1]+lvect[1], lvect[2]);
67 printf("\t%18.12g\t%18.12g\t%18.12g\n", vert[n1][0]+lvect[0],
68 vert[n1][1]+lvect[1], lvect[2]);
69 printf("\t%18.12g\t%18.12g\t%18.12g\n", vert[n1][0],
70 vert[n1][1], 0.0);
71 }
72
73
74 static void
75 rside(int n0, int n1) /* print side with rounded edge */
76 {
77 double s, c, t[3];
78
79 /* compute tanget offset vector */
80 s = lvdir*(lvect[1]*u[n1][0] - lvect[0]*u[n1][1])/llen;
81 if (s < -FTINY || s > FTINY) {
82 c = sqrt(1. - s*s);
83 t[0] = (c - 1.)*u[n1][1];
84 t[1] = (1. - c)*u[n1][0];
85 t[2] = s;
86 } else
87 t[0] = t[1] = t[2] = 0.;
88 /* output side */
89 printf("\n%s polygon %s.%d\n", pmtype, pname, n0+1);
90 printf("0\n0\n12\n");
91 printf("\t%18.12g\t%18.12g\t%18.12g\n",
92 vert[n0][0] + crad*(t[0] - a[n0]*u[n1][0]),
93 vert[n0][1] + crad*(t[1] - a[n0]*u[n1][1]),
94 crad*(t[2] + 1.));
95 printf("\t%18.12g\t%18.12g\t%18.12g\n",
96 vert[n0][0] + lvect[0] + crad*(t[0] - a[n0]*u[n1][0]),
97 vert[n0][1] + lvect[1] + crad*(t[1] - a[n0]*u[n1][1]),
98 lvect[2] + crad*(t[2] - 1.));
99 printf("\t%18.12g\t%18.12g\t%18.12g\n",
100 vert[n1][0] + lvect[0] + crad*(t[0] + a[n1]*u[n1][0]),
101 vert[n1][1] + lvect[1] + crad*(t[1] + a[n1]*u[n1][1]),
102 lvect[2] + crad*(t[2] - 1.));
103 printf("\t%18.12g\t%18.12g\t%18.12g\n",
104 vert[n1][0] + crad*(t[0] + a[n1]*u[n1][0]),
105 vert[n1][1] + crad*(t[1] + a[n1]*u[n1][1]),
106 crad*(t[2] + 1.));
107 /* output joining edge */
108 if (lvdir*a[n1] < 0.)
109 return;
110 printf("\n%s cylinder %s.e%d\n", pmtype, pname, n0+1);
111 printf("0\n0\n7\n");
112 printf("\t%18.12g\t%18.12g\t%18.12g\n",
113 vert[n1][0] + crad*(a[n1]*u[n1][0] - u[n1][1]),
114 vert[n1][1] + crad*(a[n1]*u[n1][1] + u[n1][0]),
115 crad);
116 printf("\t%18.12g\t%18.12g\t%18.12g\n",
117 vert[n1][0] + lvect[0] + crad*(a[n1]*u[n1][0] - u[n1][1]),
118 vert[n1][1] + lvect[1] + crad*(a[n1]*u[n1][1] + u[n1][0]),
119 lvect[2] - crad);
120 printf("\t%18.12g\n", lvdir*crad);
121 }
122
123
124 static double
125 compute_rounding(void) /* compute vectors for rounding operations */
126 {
127 int i;
128 double *v0, *v1;
129 double l, asum;
130
131 v0 = vert[nverts-1];
132 for (i = 0; i < nverts; i++) { /* compute u[*] */
133 v1 = vert[i];
134 u[i][0] = v0[0] - v1[0];
135 u[i][1] = v0[1] - v1[1];
136 l = sqrt(u[i][0]*u[i][0] + u[i][1]*u[i][1]);
137 if (l <= FTINY) {
138 fprintf(stderr, "Degenerate side in prism\n");
139 exit(1);
140 }
141 u[i][0] /= l;
142 u[i][1] /= l;
143 v0 = v1;
144 }
145 asum = 0.;
146 v1 = u[0];
147 for (i = nverts; i--; ) { /* compute a[*] */
148 v0 = u[i];
149 l = v0[0]*v1[0] + v0[1]*v1[1];
150 if (1+l <= FTINY) {
151 fprintf(stderr, "Overlapping sides in prism\n");
152 exit(1);
153 }
154 if (1-l <= 0.)
155 a[i] = 0.;
156 else {
157 a[i] = sqrt((1-l)/(1+l));
158 asum += l = v1[0]*v0[1]-v1[1]*v0[0];
159 if (l < 0.)
160 a[i] = -a[i];
161 }
162 v1 = v0;
163 }
164 return(asum*.5);
165 }
166
167
168 static void
169 printends(void) /* print ends of prism */
170 {
171 int i;
172 /* bottom face */
173 printf("\n%s polygon %s.b\n", pmtype, pname);
174 printf("0\n0\n%d\n", nverts*3);
175 for (i = 0; i < nverts; i++)
176 printf("\t%18.12g\t%18.12g\t%18.12g\n", vert[i][0],
177 vert[i][1], 0.0);
178 /* top face */
179 printf("\n%s polygon %s.t\n", pmtype, pname);
180 printf("0\n0\n%d\n", nverts*3);
181 for (i = nverts; i--; )
182 printf("\t%18.12g\t%18.12g\t%18.12g\n", vert[i][0]+lvect[0],
183 vert[i][1]+lvect[1], lvect[2]);
184 }
185
186
187 static void
188 printrends(void) /* print ends of prism with rounding */
189 {
190 int i;
191 double c0[3], c1[3], cl[3];
192 /* bottom face */
193 printf("\n%s polygon %s.b\n", pmtype, pname);
194 printf("0\n0\n%d\n", nverts*3);
195 for (i = 0; i < nverts; i++) {
196 printf("\t%18.12g\t%18.12g\t%18.12g\n",
197 vert[i][0] + crad*(a[i]*u[i][0] - u[i][1]),
198 vert[i][1] + crad*(a[i]*u[i][1] + u[i][0]),
199 0.0);
200 }
201 /* top face */
202 printf("\n%s polygon %s.t\n", pmtype, pname);
203 printf("0\n0\n%d\n", nverts*3);
204 for (i = nverts; i--; ) {
205 printf("\t%18.12g\t%18.12g\t%18.12g\n",
206 vert[i][0] + lvect[0] + crad*(a[i]*u[i][0] - u[i][1]),
207 vert[i][1] + lvect[1] + crad*(a[i]*u[i][1] + u[i][0]),
208 lvect[2]);
209 }
210 /* bottom corners and edges */
211 c0[0] = cl[0] = vert[nverts-1][0] +
212 crad*(a[nverts-1]*u[nverts-1][0] - u[nverts-1][1]);
213 c0[1] = cl[1] = vert[nverts-1][1] +
214 crad*(a[nverts-1]*u[nverts-1][1] + u[nverts-1][0]);
215 c0[2] = cl[2] = crad;
216 for (i = 0; i < nverts; i++) {
217 if (i < nverts-1) {
218 c1[0] = vert[i][0] + crad*(a[i]*u[i][0] - u[i][1]);
219 c1[1] = vert[i][1] + crad*(a[i]*u[i][1] + u[i][0]);
220 c1[2] = crad;
221 } else {
222 c1[0] = cl[0]; c1[1] = cl[1]; c1[2] = cl[2];
223 }
224 if (lvdir*a[i] > 0.) {
225 printf("\n%s sphere %s.bc%d\n", pmtype, pname, i+1);
226 printf("0\n0\n4 %18.12g %18.12g %18.12g %18.12g\n",
227 c1[0], c1[1], c1[2], lvdir*crad);
228 }
229 printf("\n%s cylinder %s.be%d\n", pmtype, pname, i+1);
230 printf("0\n0\n7\n");
231 printf("\t%18.12g\t%18.12g\t%18.12g\n", c0[0], c0[1], c0[2]);
232 printf("\t%18.12g\t%18.12g\t%18.12g\n", c1[0], c1[1], c1[2]);
233 printf("\t%18.12g\n", lvdir*crad);
234 c0[0] = c1[0]; c0[1] = c1[1]; c0[2] = c1[2];
235 }
236 /* top corners and edges */
237 c0[0] = cl[0] = vert[nverts-1][0] + lvect[0] +
238 crad*(a[nverts-1]*u[nverts-1][0] - u[nverts-1][1]);
239 c0[1] = cl[1] = vert[nverts-1][1] + lvect[1] +
240 crad*(a[nverts-1]*u[nverts-1][1] + u[nverts-1][0]);
241 c0[2] = cl[2] = lvect[2] - crad;
242 for (i = 0; i < nverts; i++) {
243 if (i < nverts-1) {
244 c1[0] = vert[i][0] + lvect[0] +
245 crad*(a[i]*u[i][0] - u[i][1]);
246 c1[1] = vert[i][1] + lvect[1] +
247 crad*(a[i]*u[i][1] + u[i][0]);
248 c1[2] = lvect[2] - crad;
249 } else {
250 c1[0] = cl[0]; c1[1] = cl[1]; c1[2] = cl[2];
251 }
252 if (lvdir*a[i] > 0.) {
253 printf("\n%s sphere %s.tc%d\n", pmtype, pname, i+1);
254 printf("0\n0\n4 %18.12g %18.12g %18.12g %18.12g\n",
255 c1[0], c1[1], c1[2], lvdir*crad);
256 }
257 printf("\n%s cylinder %s.te%d\n", pmtype, pname, i+1);
258 printf("0\n0\n7\n");
259 printf("\t%18.12g\t%18.12g\t%18.12g\n", c0[0], c0[1], c0[2]);
260 printf("\t%18.12g\t%18.12g\t%18.12g\n", c1[0], c1[1], c1[2]);
261 printf("\t%18.12g\n", lvdir*crad);
262 c0[0] = c1[0]; c0[1] = c1[1]; c0[2] = c1[2];
263 }
264 }
265
266
267 static void
268 printsides(int round) /* print prism sides */
269 {
270 int i;
271
272 for (i = 0; i < nverts-1; i++)
273 if (round)
274 rside(i, i+1);
275 else
276 side(i, i+1);
277 if (!iscomplete) {
278 if (round)
279 rside(nverts-1, 0);
280 else
281 side(nverts-1, 0);
282 }
283 }
284
285
286 int
287 main(int argc, char **argv)
288 {
289 int an;
290
291 if (argc < 4)
292 goto userr;
293
294 pmtype = argv[1];
295 pname = argv[2];
296
297 if (!strcmp(argv[3], "-")) {
298 readverts(NULL);
299 an = 4;
300 } else if (isdigit(argv[3][0])) {
301 nverts = atoi(argv[3]);
302 if (argc-3 < 2*nverts)
303 goto userr;
304 for (an = 0; an < nverts; an++) {
305 vert[an][0] = atof(argv[2*an+4]);
306 vert[an][1] = atof(argv[2*an+5]);
307 }
308 an = 2*nverts+4;
309 } else {
310 readverts(argv[3]);
311 an = 4;
312 }
313 if (nverts < 3) {
314 fprintf(stderr, "%s: not enough vertices\n", argv[0]);
315 exit(1);
316 }
317
318 for ( ; an < argc; an++) {
319 if (argv[an][0] != '-')
320 goto userr;
321 switch (argv[an][1]) {
322 case 'l': /* length vector */
323 lvect[0] = atof(argv[++an]);
324 lvect[1] = atof(argv[++an]);
325 lvect[2] = atof(argv[++an]);
326 if (lvect[2] < -FTINY)
327 lvdir = -1;
328 else if (lvect[2] > FTINY)
329 lvdir = 1;
330 else {
331 fprintf(stderr,
332 "%s: illegal extrusion vector\n",
333 argv[0]);
334 exit(1);
335 }
336 llen = sqrt(lvect[0]*lvect[0] + lvect[1]*lvect[1] +
337 lvect[2]*lvect[2]);
338 break;
339 case 'r': /* radius */
340 crad = atof(argv[++an]);
341 break;
342 case 'e': /* ends */
343 do_ends = !do_ends;
344 break;
345 case 'c': /* complete */
346 iscomplete = !iscomplete;
347 break;
348 default:
349 goto userr;
350 }
351 }
352 if (crad > FTINY) {
353 if (crad > lvdir*lvect[2]) {
354 fprintf(stderr, "%s: rounding greater than height\n",
355 argv[0]);
356 exit(1);
357 }
358 crad *= lvdir; /* simplifies formulas */
359 compute_rounding();
360 fputs("# ", stdout);
361 printargs(argc, argv, stdout);
362 if (do_ends)
363 printrends();
364 printsides(1);
365 } else {
366 fputs("# ", stdout);
367 printargs(argc, argv, stdout);
368 if (do_ends)
369 printends();
370 printsides(0);
371 }
372 return(0);
373 userr:
374 fprintf(stderr, "Usage: %s material name ", argv[0]);
375 fprintf(stderr, "{ - | vfile | N v1 v2 .. vN } ");
376 fprintf(stderr, "[-l lvect][-r radius][-c][-e]\n");
377 return(1);
378 }
379
