1 |
greg |
2.1 |
2 |
Glazing system multi-layer optics calculation. |
3 |
Source equations: LBNL WINDOW technical documention. |
4 |
System calcuation: Section 7.6.1 |
5 |
Anuglar calculation Section 7.7 |
6 |
T. Wang |
7 |
8 |
9 |
#include "rtmath.h" |
10 |
#include "color.h" |
11 |
#include "data.h" |
12 |
13 |
enum { |
14 |
NTHETA = 59, |
15 |
MAX_NAME = 256, |
16 |
17 |
18 |
const double DBL_EPSILON = 1E-9; |
19 |
greg |
2.2 |
const double LARGE_DOUBE = 3.40282347E+38; |
20 |
greg |
2.1 |
const double RAD_PER_DEG = 0.0174532925199; |
21 |
const double COEFFS_TAU_CLEAR[] = {-0.0015, 3.355, -3.84, 1.46, 0.0288}; |
22 |
const double COEFFS_TAU_BRONZE[] = {0.002, 2.813, -2.341, -0.05725, 0.599}; |
23 |
const double COEFFS_RHO_CLEAR[] = {0.999, -0.563, 2.043, -2.532, 1.054}; |
24 |
const double COEFFS_RHO_BRONZE[] = {0.997, -1.868, 6.513, -7.862, 3.225}; |
25 |
26 |
const double THETAS[NTHETA] = { |
27 |
0., 5., 10., 15., 20., 25., 30., 35., 40., |
28 |
41., 42., 43., 44., 45., 46., 47., 48., 49, 50., |
29 |
51., 52., 53., 54., 55., 56., 57., 58., 59, 60., |
30 |
61., 62., 63., 64., 65., 66., 67., 68., 69, 70., |
31 |
71., 72., 73., 74., 75., 76., 77., 78., 79, 80., |
32 |
81., 82., 83., 84., 85., 86., 87., 88., 89, 90., |
33 |
34 |
35 |
36 |
char *progname; |
37 |
38 |
typedef struct { |
39 |
char *filename; |
40 |
int is_mono; |
41 |
double thickness_m; |
42 |
43 |
/* Interpolated data at standard wavelengths */ |
44 |
double *t_0; |
45 |
double *rf_0; |
46 |
double *rb_0; |
47 |
48 |
/* Calculated angular data */ |
49 |
double *t_lambda_theta; |
50 |
double *rf_lambda_theta; |
51 |
double *rb_lambda_theta; |
52 |
53 |
} GlazingLayer; |
54 |
55 |
56 |
greg |
2.2 |
static inline double polynomial_5(double x, const double coeffs[5]) { |
57 |
greg |
2.1 |
return x * ( x * ( x * (coeffs[4] * x + coeffs[3]) + coeffs[2]) + coeffs[1]) + coeffs[0]; |
58 |
59 |
60 |
61 |
/* Calculate rho0 (unpolarized reflectance of a single surface) */ |
62 |
static void rho0_calc(const double *t_0, const double *r_0, const int nwvl, double *rho0) { |
63 |
for (int i = 0; i < nwvl; ++i) { |
64 |
const double beta = t_0[i] * t_0[i] - r_0[i] * r_0[i] + 2.0 * r_0[i] + 1.0; |
65 |
double denominator = 2.0 * (2.0 - r_0[i]); |
66 |
if (fabs(denominator) < DBL_EPSILON) |
67 |
denominator = DBL_EPSILON; |
68 |
double discriminant = beta * beta - 2.0 * denominator * r_0[i]; |
69 |
if (discriminant < 0.0) |
70 |
discriminant = 0.0; |
71 |
rho0[i] = (beta - sqrt(discriminant)) / denominator; |
72 |
if (rho0[i] < 0.0) |
73 |
rho0[i] = 0.0; |
74 |
if (rho0[i] > 1.0) |
75 |
rho0[i] = 1.0; |
76 |
77 |
78 |
79 |
/* refraction index calc */ |
80 |
static void n_calc(const double *rho_0, const int nwvl, double *n) |
81 |
82 |
for (int i=0; i < nwvl; ++i) { |
83 |
const double sqrt_rho = sqrt(rho_0[i]); |
84 |
n[i] = ((1.0 - sqrt_rho) < DBL_EPSILON) ? 1.0 : (1.0 + sqrt_rho) / (1.0 - sqrt_rho); |
85 |
86 |
87 |
88 |
/* Calculate absoprtion coefficient */ |
89 |
static void alpha_calc(const double *t0, const double *r0, const double *rho0, |
90 |
const double thickness_m, const int nwvl, double *abs_coeff) |
91 |
92 |
93 |
const double numerator = r0[i] - rho0[i]; |
94 |
const double denominator = rho0[i] * t0[i]; |
95 |
if (denominator > DBL_EPSILON && numerator > DBL_EPSILON) { |
96 |
const double log_val = log(numerator / denominator); |
97 |
abs_coeff[i] = -log_val / thickness_m; |
98 |
} else { |
99 |
abs_coeff[i] = 1.0; |
100 |
101 |
if (abs_coeff[i] < 0.0 || isnan(abs_coeff[i]) || isinf(abs_coeff[i])) { |
102 |
abs_coeff[i] = 0.0; |
103 |
104 |
105 |
106 |
107 |
108 |
void angular_monolithic(GlazingLayer *layer, const int nwvl) { |
109 |
double *rho_0 = malloc(nwvl * sizeof(double)); |
110 |
double *refrac = malloc(nwvl * sizeof(double)); |
111 |
double *abs_coeff = malloc(nwvl * sizeof(double)); |
112 |
113 |
rho0_calc(layer->t_0, layer->rf_0, nwvl, rho_0); |
114 |
n_calc(rho_0, nwvl, refrac); |
115 |
alpha_calc(layer->t_0, layer->rf_0, rho_0, layer->thickness_m, nwvl, abs_coeff); |
116 |
117 |
for (int itheta = 0; itheta < NTHETA; ++itheta) { |
118 |
double phi = THETAS[itheta] * RAD_PER_DEG; |
119 |
double cos_phi = cos(phi); |
120 |
double sin_phi = sin(phi); |
121 |
122 |
for (int iwvl = 0; iwvl < nwvl; ++iwvl) { |
123 |
double sin_phi_prime_sq = sin_phi * sin_phi / (refrac[iwvl] * refrac[iwvl]); |
124 |
125 |
double cos_phi_prime = (sin_phi_prime_sq >= 1.0) ? 0.0 : sqrt(1.0 - sin_phi_prime_sq); |
126 |
127 |
double rho_lambda; |
128 |
if (cos_phi_prime <= DBL_EPSILON) { |
129 |
rho_lambda = 1.0; |
130 |
} else { |
131 |
double nf_cos_phi = refrac[iwvl] * cos_phi; |
132 |
double nf_cos_phi_p = refrac[iwvl] * cos_phi_prime; |
133 |
double par_num = nf_cos_phi - cos_phi_prime; |
134 |
double par_den = nf_cos_phi + cos_phi_prime; |
135 |
double per_num = nf_cos_phi_p - cos_phi; |
136 |
double per_den = nf_cos_phi_p + cos_phi; |
137 |
if (fabs(par_den) < DBL_EPSILON || fabs(per_den) < DBL_EPSILON) { |
138 |
rho_lambda = 1.0; |
139 |
} else { |
140 |
double par_comp = pow(par_num / par_den, 2.0); |
141 |
double per_comp = pow(per_num / per_den, 2.0); |
142 |
rho_lambda = 0.5 * (par_comp + per_comp); |
143 |
144 |
145 |
if (rho_lambda < 0.0) |
146 |
rho_lambda = 0.0; |
147 |
if (rho_lambda > 1.0) |
148 |
rho_lambda = 1.0; |
149 |
150 |
greg |
2.2 |
double exp_arg = (cos_phi_prime < DBL_EPSILON) ? -LARGE_DOUBE : (-abs_coeff[iwvl] * layer->thickness_m / cos_phi_prime); |
151 |
greg |
2.1 |
/* Clamp exponent argument to prevent overflow in exp() */ |
152 |
if (exp_arg < -700.0) |
153 |
exp_arg = -700.0; |
154 |
155 |
double T_internal = exp(exp_arg); |
156 |
157 |
double denominator = 1.0 - rho_lambda * rho_lambda * T_internal * T_internal; |
158 |
159 |
double t_lambda, r_lambda; |
160 |
161 |
if (fabs(denominator) < DBL_EPSILON || rho_lambda >= 1.0) { |
162 |
t_lambda = 0.0; |
163 |
r_lambda = 1.0; |
164 |
} else { |
165 |
double tau_lambda = 1.0 - rho_lambda; |
166 |
t_lambda = tau_lambda * tau_lambda * T_internal / denominator; |
167 |
r_lambda = rho_lambda * (1.0 + t_lambda * T_internal); |
168 |
169 |
170 |
if (t_lambda < 0.0) |
171 |
t_lambda = 0.0; |
172 |
if (t_lambda > 1.0) |
173 |
t_lambda = 1.0; |
174 |
175 |
const int flat_idx = itheta * nwvl + iwvl; |
176 |
layer->t_lambda_theta[flat_idx] = t_lambda; |
177 |
layer->rf_lambda_theta[flat_idx] = r_lambda; |
178 |
layer->rb_lambda_theta[flat_idx] = r_lambda; |
179 |
180 |
181 |
greg |
2.2 |
free(rho_0); |
182 |
free(refrac); |
183 |
free(abs_coeff); |
184 |
greg |
2.1 |
185 |
186 |
187 |
void angular_coated(GlazingLayer *layer, const int nwvl) { |
188 |
189 |
const double phi = THETAS[itheta] * RAD_PER_DEG; |
190 |
const double cos_phi = cos(phi); |
191 |
192 |
193 |
const double t_0_lambda = layer->t_0[iwvl]; |
194 |
const double *coeffs_tau = (t_0_lambda > 0.645) ? COEFFS_TAU_CLEAR : COEFFS_TAU_BRONZE; |
195 |
const double *coeffs_rho = (t_0_lambda > 0.645) ? COEFFS_RHO_CLEAR : COEFFS_RHO_BRONZE; |
196 |
197 |
const double tau_bar = polynomial_5(cos_phi, coeffs_tau); |
198 |
const double rho_bar_term = polynomial_5(cos_phi, coeffs_rho); |
199 |
const double rho_bar = rho_bar_term - tau_bar; |
200 |
201 |
202 |
layer->t_lambda_theta[flat_idx] = t_0_lambda * tau_bar; |
203 |
layer->rf_lambda_theta[flat_idx] = layer->rf_0[iwvl] * (1.0 - rho_bar) + rho_bar; |
204 |
layer->rb_lambda_theta[flat_idx] = layer->rb_0[iwvl] * (1.0 - rho_bar) + rho_bar; |
205 |
206 |
207 |
208 |
209 |
210 |
void multi_layer_calc( |
211 |
GlazingLayer *layers, |
212 |
int nlayers, |
213 |
int nwvl, |
214 |
double *total_t, |
215 |
double *total_rf, |
216 |
double *total_rb) |
217 |
218 |
if (nlayers <= 0) |
219 |
return; |
220 |
221 |
size_t total_size = (size_t)NTHETA * nwvl * sizeof(double); |
222 |
223 |
memcpy(total_t, layers[0].t_lambda_theta, total_size); |
224 |
memcpy(total_rf, layers[0].rf_lambda_theta, total_size); |
225 |
memcpy(total_rb, layers[0].rb_lambda_theta, total_size); |
226 |
227 |
if (nlayers == 1) |
228 |
return; |
229 |
230 |
double *prev_t = malloc(total_size); |
231 |
double *prev_rf = malloc(total_size); |
232 |
double *prev_rb = malloc(total_size); |
233 |
234 |
if (!prev_t || !prev_rf || !prev_rb) |
235 |
perror("Failed to allocate temporary storage in multi_layer"); |
236 |
237 |
for (int j = 1; j < nlayers; ++j) { |
238 |
memcpy(prev_t, total_t, total_size); |
239 |
memcpy(prev_rf, total_rf, total_size); |
240 |
memcpy(prev_rb, total_rb, total_size); |
241 |
242 |
double *t_j = layers[j].t_lambda_theta; |
243 |
double *rf_j = layers[j].rf_lambda_theta; |
244 |
double *rb_j = layers[j].rb_lambda_theta; |
245 |
246 |
247 |
248 |
const int idx = itheta * nwvl + iwvl; |
249 |
double denominator = 1.0 - rf_j[idx] * prev_rb[idx]; |
250 |
if (fabs(denominator) < DBL_EPSILON) { |
251 |
252 |
253 |
total_t[idx] = prev_t[idx] * t_j[idx] / denominator; |
254 |
total_rf[idx] = prev_rf[idx] + prev_t[idx] * prev_t[idx] * rf_j[idx] / denominator; |
255 |
total_rb[idx] = rb_j[idx] + t_j[idx] * t_j[idx] * prev_rb[idx] / denominator; |
256 |
257 |
258 |
259 |
free(prev_t); |
260 |
free(prev_rf); |
261 |
free(prev_rb); |
262 |
263 |
264 |
265 |
int add_layer(GlazingLayer **layers_array, int *count, int *capacity, |
266 |
const char *filename, double thickness_m, int is_monolithic) { |
267 |
if (*count >= *capacity) { |
268 |
*capacity = (*capacity == 0) ? 4 : *capacity * 2; |
269 |
GlazingLayer *new_layers = realloc(*layers_array, *capacity * sizeof(GlazingLayer)); |
270 |
if (!new_layers) { |
271 |
perror("Failed to reallocate memory for layers"); |
272 |
return 0; |
273 |
274 |
*layers_array = new_layers; |
275 |
276 |
277 |
memset(&((*layers_array)[*count]), 0, sizeof(GlazingLayer)); |
278 |
279 |
#ifdef _WIN32 |
280 |
(*layers_array)[*count].filename = _strdup(filename); |
281 |
#else |
282 |
(*layers_array)[*count].filename = strdup(filename); |
283 |
#endif |
284 |
285 |
if (!(*layers_array)[*count].filename) { |
286 |
perror("Failed to duplicate filename"); |
287 |
return 0; |
288 |
289 |
(*layers_array)[*count].is_mono = is_monolithic; |
290 |
(*layers_array)[*count].thickness_m = thickness_m; |
291 |
(*layers_array)[*count].t_0 = NULL; |
292 |
(*layers_array)[*count].rf_0 = NULL; |
293 |
(*layers_array)[*count].rb_0 = NULL; |
294 |
(*layers_array)[*count].t_lambda_theta = NULL; |
295 |
(*layers_array)[*count].rf_lambda_theta = NULL; |
296 |
(*layers_array)[*count].rb_lambda_theta = NULL; |
297 |
298 |
(*count)++; |
299 |
return 1; |
300 |
301 |
302 |
303 |
int interpolate(GlazingLayer *layer, const double wvl_start, const double wvl_end, const double wvl_interval, const int nwvl) { |
304 |
DATARRAY *dp = getdata(layer->filename); |
305 |
if (!dp) { |
306 |
fprintf(stderr, "Error: Cannot open file '%s'\n", layer->filename); |
307 |
return 0; |
308 |
309 |
310 |
layer->t_0 = malloc(nwvl * sizeof(double)); |
311 |
layer->rf_0 = malloc(nwvl * sizeof(double)); |
312 |
layer->rb_0 = malloc(nwvl * sizeof(double)); |
313 |
314 |
double wvl = wvl_start; |
315 |
int i = 0; |
316 |
while (wvl <= wvl_end) { |
317 |
double t_pt[2] = {2., wvl}; |
318 |
layer->t_0[i] = datavalue(dp, t_pt); |
319 |
double rf_pt[2] = {0., wvl}; |
320 |
layer->rf_0[i] = datavalue(dp, rf_pt); |
321 |
double rb_pt[2] = {1., wvl}; |
322 |
layer->rb_0[i] = datavalue(dp, rb_pt); |
323 |
wvl = wvl + wvl_interval; |
324 |
i = i + 1; |
325 |
326 |
327 |
freedata(dp); |
328 |
return 1; |
329 |
330 |
331 |
332 |
int write_output_file( |
333 |
const char *tfilename, |
334 |
const char *rfilename, |
335 |
const double *tdata, |
336 |
const double *rfdata, |
337 |
const double *rbdata, |
338 |
const double wvl_start, |
339 |
const double wvl_end, |
340 |
const int nwvl, |
341 |
int argc, char *argv[]) |
342 |
343 |
FILE *tfp = fopen(tfilename, "w"); |
344 |
FILE *rfp = fopen(rfilename, "w"); |
345 |
if (!tfp || !rfp) { |
346 |
fprintf(stderr, "Error: Cannot open output files\n"); |
347 |
return(0); |
348 |
349 |
350 |
fprintf(tfp, "# "); |
351 |
for (int i = 0; i< argc; ++i) { |
352 |
fprintf(tfp, "%s ", argv[i]); |
353 |
354 |
fprintf(tfp, "\n2\n0 0 %d", NTHETA); |
355 |
for (int i = 0; i < NTHETA; i++) { |
356 |
fprintf(tfp, " %d", (int)THETAS[i]); |
357 |
358 |
fprintf(tfp, "\n%.0f %.0f %d\n", wvl_start, wvl_end, nwvl); |
359 |
360 |
361 |
362 |
fprintf(tfp, "%.6f\n", tdata[itheta*nwvl+iwvl]); |
363 |
364 |
365 |
fclose(tfp); |
366 |
367 |
fprintf(rfp, "# "); |
368 |
369 |
fprintf(rfp, "%s ", argv[i]); |
370 |
371 |
fprintf(rfp, "\n2\n0 0 %d", NTHETA * 2 - 1); |
372 |
373 |
fprintf(rfp, " %d", (int)THETAS[i]); |
374 |
375 |
for (int i = NTHETA-2; i >= 0; --i) { |
376 |
fprintf(rfp, " %d", (int)(180 - THETAS[i])); |
377 |
378 |
fprintf(rfp, "\n%.0f %.0f %d\n", wvl_start, wvl_end, nwvl); |
379 |
380 |
381 |
382 |
fprintf(rfp, "%.6f\n", rfdata[itheta * nwvl + iwvl]); |
383 |
384 |
385 |
for (int itheta = NTHETA - 2; itheta >= 0 ; --itheta) { |
386 |
387 |
fprintf(rfp, "%.6f\n", rbdata[itheta * nwvl + iwvl]); |
388 |
389 |
390 |
391 |
fclose(rfp); |
392 |
return(1); |
393 |
394 |
395 |
396 |
void print_usage() { |
397 |
fprintf(stderr, "Usage: %s [-m monolithic_layer.dat thickness | -c coated_layer.dat] ...\n", progname); |
398 |
fprintf(stderr, "Calculate multi-layer glazing optics from spectral data files.\n"); |
399 |
fprintf(stderr, "Options:\n"); |
400 |
fprintf(stderr, " -m <filename> thickness Specify an uncoated (monolithic) glazing layer .dat file and its thickness (meter).\n"); |
401 |
fprintf(stderr, " -c <filename> Specify a coated or laminate glazing layer .dat file.\n"); |
402 |
fprintf(stderr, " -s start_wvl end_wvl interval Specify wavelength range and interval.\n"); |
403 |
fprintf(stderr, " -p prefix Specify prefix name to the output files.\n"); |
404 |
fprintf(stderr, " -h, --help Show this help message.\n"); |
405 |
fprintf(stderr, "Layer order is determined by the sequence of options on the command line.\n"); |
406 |
fprintf(stderr, "Output Files: prefix_t.dat, prefix_r.dat\n"); |
407 |
408 |
409 |
greg |
2.2 |
410 |
static void free_layer_data(GlazingLayer *layer) { |
411 |
if (!layer) return; |
412 |
413 |
free(layer->filename); |
414 |
free(layer->t_0); |
415 |
free(layer->rf_0); |
416 |
free(layer->rb_0); |
417 |
free(layer->t_lambda_theta); |
418 |
free(layer->rf_lambda_theta); |
419 |
free(layer->rb_lambda_theta); |
420 |
421 |
// Set pointers to NULL to prevent double-free errors |
422 |
layer->filename = NULL; |
423 |
layer->t_0 = NULL; |
424 |
layer->rf_0 = NULL; |
425 |
layer->rb_0 = NULL; |
426 |
layer->t_lambda_theta = NULL; |
427 |
layer->rf_lambda_theta = NULL; |
428 |
layer->rb_lambda_theta = NULL; |
429 |
430 |
431 |
432 |
greg |
2.1 |
void cleanup_layers(GlazingLayer *layers, int num_layers) { |
433 |
if (!layers) return; |
434 |
for (int i = 0; i < num_layers; ++i) { |
435 |
if (layers[i].filename) |
436 |
greg |
2.2 |
free_layer_data(&layers[i]); |
437 |
greg |
2.1 |
438 |
free(layers); |
439 |
440 |
441 |
442 |
int main(int argc, char *argv[]) |
443 |
444 |
GlazingLayer *layers = NULL; |
445 |
int num_layers = 0; |
446 |
int layer_capacity = 0; |
447 |
int success = 1; |
448 |
double wvl_start_nm = 380.; |
449 |
double wvl_end_nm = 780.; |
450 |
double wvl_interval_nm = 5.; |
451 |
int nwvl = 81; |
452 |
double thickness_m = 0.003; |
453 |
char *filename; |
454 |
char *prefix = "unnamed"; |
455 |
char file_t[MAX_NAME]; |
456 |
char file_r[MAX_NAME]; |
457 |
progname = argv[0]; |
458 |
if (argc <= 1) { |
459 |
print_usage(); |
460 |
return EXIT_FAILURE; |
461 |
462 |
463 |
for (int i=1; i < argc; ++i) { |
464 |
switch (argv[i][1]) { |
465 |
case 'm': |
466 |
filename = argv[++i]; |
467 |
thickness_m = atof(argv[++i]); |
468 |
if (!add_layer(&layers, &num_layers, &layer_capacity, filename, thickness_m, 1)) { |
469 |
greg |
2.2 |
cleanup_layers(layers, num_layers); |
470 |
471 |
greg |
2.1 |
472 |
break; |
473 |
case 'c': |
474 |
475 |
if (!add_layer(&layers, &num_layers, &layer_capacity, filename, thickness_m, 0)) { |
476 |
477 |
478 |
479 |
break; |
480 |
case 'p': |
481 |
prefix = argv[++i]; |
482 |
break; |
483 |
case 's': |
484 |
wvl_start_nm = atof(argv[++i]); |
485 |
wvl_end_nm = atof(argv[++i]); |
486 |
wvl_interval_nm = atof(argv[++i]); |
487 |
if (wvl_start_nm > wvl_end_nm) { |
488 |
fprintf(stderr, "Starting wavelength > End wavelength\n"); |
489 |
greg |
2.2 |
490 |
greg |
2.1 |
491 |
492 |
if (((int)(wvl_end_nm - wvl_start_nm) % (int)wvl_interval_nm) > 0) { |
493 |
fprintf(stderr, |
494 |
"Error: Wavelength range (%f to %f nm) must be evenly divisible by the interval (%f nm).\n", |
495 |
wvl_start_nm, wvl_end_nm, wvl_interval_nm); |
496 |
greg |
2.2 |
497 |
greg |
2.1 |
498 |
499 |
break; |
500 |
case 'h': |
501 |
print_usage(); |
502 |
return 1; |
503 |
default: |
504 |
break; |
505 |
506 |
507 |
snprintf(file_t, MAX_NAME, "%s_t.dat", prefix); |
508 |
snprintf(file_r, MAX_NAME, "%s_r.dat", prefix); |
509 |
510 |
if (fabs(wvl_start_nm - wvl_end_nm) < DBL_EPSILON && wvl_interval_nm > DBL_EPSILON) { |
511 |
nwvl = 1; |
512 |
} else { |
513 |
nwvl = (int)((wvl_end_nm - wvl_start_nm) / wvl_interval_nm + 1.5); |
514 |
515 |
516 |
if (num_layers == 0) { |
517 |
fprintf(stderr, "Error: No layers specified.\n"); |
518 |
print_usage(); |
519 |
520 |
521 |
522 |
523 |
if (!interpolate(&layers[i], wvl_start_nm, wvl_end_nm, wvl_interval_nm, nwvl)) { |
524 |
fprintf(stderr, "Error: Failed to parse or interpolate data for layer %d.\n", i + 1); |
525 |
success = 0; |
526 |
break; |
527 |
528 |
layers[i].t_lambda_theta = malloc(NTHETA * nwvl * sizeof(double)); |
529 |
layers[i].rf_lambda_theta = malloc(NTHETA * nwvl * sizeof(double)); |
530 |
layers[i].rb_lambda_theta = malloc(NTHETA * nwvl * sizeof(double)); |
531 |
532 |
if (layers[i].is_mono) { |
533 |
angular_monolithic(&layers[i], nwvl); |
534 |
} else { |
535 |
angular_coated(&layers[i], nwvl); |
536 |
537 |
538 |
539 |
if (!success) { |
540 |
541 |
542 |
543 |
544 |
545 |
size_t total_flat_size = (size_t)NTHETA * nwvl * sizeof(double); |
546 |
double *total_t = malloc(total_flat_size); |
547 |
double *total_rf = malloc(total_flat_size); |
548 |
double *total_rb = malloc(total_flat_size); |
549 |
550 |
if (!total_t || !total_rf || !total_rb) { |
551 |
perror("Failed to allocate memory for final results"); |
552 |
553 |
free(total_t); |
554 |
free(total_rf); |
555 |
free(total_rb); |
556 |
557 |
558 |
559 |
multi_layer_calc(layers, num_layers, nwvl, total_t, total_rf, total_rb); |
560 |
561 |
success &= write_output_file(file_t, file_r, total_t, total_rf, total_rb, wvl_start_nm, wvl_end_nm, nwvl, argc, argv); |
562 |
563 |
if (success) { |
564 |
printf("# "); |
565 |
for (int i = 0;i < argc; ++i) { |
566 |
printf("%s ", argv[i]); |
567 |
568 |
greg |
2.2 |
printf("\nvoid specdata refl_spec_%s\n", prefix); |
569 |
greg |
2.1 |
printf("4 noop %s . 'Acos(Rdot)/DEGREE'\n0\n0\n\n", file_r); |
570 |
greg |
2.2 |
printf("void specdata trans_spec_%s\n", prefix); |
571 |
greg |
2.1 |
printf("4 noop %s . 'Acos(abs(Rdot))/DEGREE'\n0\n0\n\n", file_t); |
572 |
greg |
2.2 |
printf("void WGMDfunc glaze_mat_%s\n13\n\trefl_spec_%s 1 0 0\n\ttrans_spec_%s 1 0 0\n\tvoid\n\t0 0 1 .\n0\n9 0 0 0 0 0 0 0 0 0\n", prefix, prefix, prefix); |
573 |
greg |
2.1 |
} else { |
574 |
fprintf(stderr, "Error: Failed to write one or more output files.\n"); |
575 |
576 |
577 |
578 |
free(total_t); |
579 |
free(total_rf); |
580 |
free(total_rb); |
581 |
582 |
return success ? EXIT_SUCCESS : EXIT_FAILURE; |
583 |
