root/radiance/ray/src/gen/gendaymtx.c
Revision: 2.42
Committed: Thu Feb 27 19:00:00 2025 UTC (2 months, 3 weeks ago) by greg
Changes since 2.41: +14 -12 lines
fix(gendaymtx): Issue with interpretation of minutes in EPW input
# User Rev Content
1 greg 2.1 #ifndef lint
2 greg 2.42 static const char RCSid[] = "$Id: gendaymtx.c,v 2.41 2025/02/26 20:39:28 greg Exp $";
3 greg 2.1 #endif
4     /*
5     * gendaymtx.c
6     *
7     * Generate a daylight matrix based on Perez Sky Model.
8     *
9     * Most of this code is borrowed (see copyright below) from Ian Ashdown's
10     * excellent re-implementation of Jean-Jacques Delaunay's gendaylit.c
11     *
12     * Created by Greg Ward on 1/16/13.
13     */
14
15     /*********************************************************************
16     *
17     * H32_gendaylit.CPP - Perez Sky Model Calculation
18     *
19     * Version: 1.00A
20     *
21     * History: 09/10/01 - Created.
22     * 11/10/08 - Modified for Unix compilation.
23     * 11/10/12 - Fixed conditional __max directive.
24     * 1/11/13 - Tweaks and optimizations (G.Ward)
25     *
26     * Compilers: Microsoft Visual C/C++ Professional V10.0
27     *
28     * Author: Ian Ashdown, P.Eng.
29     * byHeart Consultants Limited
30     * 620 Ballantree Road
31     * West Vancouver, B.C.
32     * Canada V7S 1W3
33     * e-mail: [email protected]
34     *
35     * References: Perez, R., P. Ineichen, R. Seals, J. Michalsky, and R.
36     * Stewart. 1990. ìModeling Daylight Availability and
37     * Irradiance Components from Direct and Global
38     * Irradiance,î Solar Energy 44(5):271-289.
39     *
40     * Perez, R., R. Seals, and J. Michalsky. 1993.
41     * ìAll-Weather Model for Sky Luminance Distribution -
42     * Preliminary Configuration and Validation,î Solar Energy
43     * 50(3):235-245.
44     *
45     * Perez, R., R. Seals, and J. Michalsky. 1993. "ERRATUM to
46     * All-Weather Model for Sky Luminance Distribution -
47     * Preliminary Configuration and Validation,î Solar Energy
48     * 51(5):423.
49     *
50     * NOTE: This program is a completely rewritten version of
51     * gendaylit.c written by Jean-Jacques Delaunay (1994).
52     *
53     * Copyright 2009-2012 byHeart Consultants Limited. All rights
54     * reserved.
55     *
56     * Redistribution and use in source and binary forms, with or without
57     * modification, are permitted for personal and commercial purposes
58     * provided that redistribution of source code must retain the above
59     * copyright notice, this list of conditions and the following
60     * disclaimer:
61     *
62     * THIS SOFTWARE IS PROVIDED "AS IS" AND ANY EXPRESSED OR IMPLIED
63     * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES
64     * OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
65     * DISCLAIMED. IN NO EVENT SHALL byHeart Consultants Limited OR
66     * ITS EMPLOYEES BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
67     * SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
68     * LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF
69     * USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED
70     * AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
71     * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN
72     * ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
73     * POSSIBILITY OF SUCH DAMAGE.
74     *
75     *********************************************************************/
76
77     /* Zenith is along the Z-axis */
78     /* X-axis points east */
79     /* Y-axis points north */
80     /* azimuth is measured as degrees or radians east of North */
81
82     /* Include files */
83     #define _USE_MATH_DEFINES
84     #include <stdlib.h>
85     #include <ctype.h>
86 greg 2.30 #include "platform.h"
87 greg 2.1 #include "rtmath.h"
88 greg 2.23 #include "rtio.h"
89 greg 2.1 #include "color.h"
90 greg 2.30 #include "sun.h"
91 greg 2.41 #include "loadEPW.h"
92 greg 2.1
93 greg 2.38 char *progname; /* Program name */
94 greg 2.1 const double DC_SolarConstantE = 1367.0; /* Solar constant W/m^2 */
95     const double DC_SolarConstantL = 127.5; /* Solar constant klux */
96
97     double altitude; /* Solar altitude (radians) */
98     double azimuth; /* Solar azimuth (radians) */
99     double apwc; /* Atmospheric precipitable water content */
100     double dew_point = 11.0; /* Surface dew point temperature (deg. C) */
101     double diff_illum; /* Diffuse illuminance */
102     double diff_irrad; /* Diffuse irradiance */
103     double dir_illum; /* Direct illuminance */
104     double dir_irrad; /* Direct irradiance */
105     int julian_date; /* Julian date */
106     double perez_param[5]; /* Perez sky model parameters */
107     double sky_brightness; /* Sky brightness */
108     double sky_clearness; /* Sky clearness */
109     double solar_rad; /* Solar radiance */
110     double sun_zenith; /* Sun zenith angle (radians) */
111     int input = 0; /* Input type */
112 greg 2.11 int output = 0; /* Output type */
113 greg 2.1
114     extern double dmax( double, double );
115     extern double CalcAirMass();
116     extern double CalcDiffuseIllumRatio( int );
117     extern double CalcDiffuseIrradiance();
118     extern double CalcDirectIllumRatio( int );
119     extern double CalcDirectIrradiance();
120     extern double CalcEccentricity();
121     extern double CalcPrecipWater( double );
122     extern double CalcRelHorzIllum( float *parr );
123     extern double CalcRelLuminance( double, double );
124     extern double CalcSkyBrightness();
125     extern double CalcSkyClearness();
126     extern int CalcSkyParamFromIllum();
127     extern int GetCategoryIndex();
128     extern void CalcPerezParam( double, double, double, int );
129     extern void CalcSkyPatchLumin( float *parr );
130     extern void ComputeSky( float *parr );
131
132 greg 2.40
133     extern double solar_sunset(int month, int day);
134     extern double solar_sunrise(int month, int day);
135
136 greg 2.1 /* Degrees into radians */
137     #define DegToRad(deg) ((deg)*(PI/180.))
138
139     /* Radiuans into degrees */
140     #define RadToDeg(rad) ((rad)*(180./PI))
141
142     /* Perez sky model coefficients */
143
144     /* Reference: Perez, R., R. Seals, and J. Michalsky, 1993. "All- */
145     /* Weather Model for Sky Luminance Distribution - */
146     /* Preliminary Configuration and Validation," Solar */
147     /* Energy 50(3):235-245, Table 1. */
148
149     static const double PerezCoeff[8][20] =
150     {
151     /* Sky clearness (epsilon): 1.000 to 1.065 */
152     { 1.3525, -0.2576, -0.2690, -1.4366, -0.7670,
153     0.0007, 1.2734, -0.1233, 2.8000, 0.6004,
154     1.2375, 1.0000, 1.8734, 0.6297, 0.9738,
155     0.2809, 0.0356, -0.1246, -0.5718, 0.9938 },
156     /* Sky clearness (epsilon): 1.065 to 1.230 */
157     { -1.2219, -0.7730, 1.4148, 1.1016, -0.2054,
158     0.0367, -3.9128, 0.9156, 6.9750, 0.1774,
159     6.4477, -0.1239, -1.5798, -0.5081, -1.7812,
160     0.1080, 0.2624, 0.0672, -0.2190, -0.4285 },
161     /* Sky clearness (epsilon): 1.230 to 1.500 */
162     { -1.1000, -0.2515, 0.8952, 0.0156, 0.2782,
163     -0.1812, - 4.5000, 1.1766, 24.7219, -13.0812,
164     -37.7000, 34.8438, -5.0000, 1.5218, 3.9229,
165     -2.6204, -0.0156, 0.1597, 0.4199, -0.5562 },
166     /* Sky clearness (epsilon): 1.500 to 1.950 */
167     { -0.5484, -0.6654, -0.2672, 0.7117, 0.7234,
168     -0.6219, -5.6812, 2.6297, 33.3389, -18.3000,
169     -62.2500, 52.0781, -3.5000, 0.0016, 1.1477,
170     0.1062, 0.4659, -0.3296, -0.0876, -0.0329 },
171     /* Sky clearness (epsilon): 1.950 to 2.800 */
172     { -0.6000, -0.3566, -2.5000, 2.3250, 0.2937,
173     0.0496, -5.6812, 1.8415, 21.0000, -4.7656 ,
174     -21.5906, 7.2492, -3.5000, -0.1554, 1.4062,
175     0.3988, 0.0032, 0.0766, -0.0656, -0.1294 },
176     /* Sky clearness (epsilon): 2.800 to 4.500 */
177     { -1.0156, -0.3670, 1.0078, 1.4051, 0.2875,
178     -0.5328, -3.8500, 3.3750, 14.0000, -0.9999,
179     -7.1406, 7.5469, -3.4000, -0.1078, -1.0750,
180     1.5702, -0.0672, 0.4016, 0.3017, -0.4844 },
181     /* Sky clearness (epsilon): 4.500 to 6.200 */
182     { -1.0000, 0.0211, 0.5025, -0.5119, -0.3000,
183     0.1922, 0.7023, -1.6317, 19.0000, -5.0000,
184     1.2438, -1.9094, -4.0000, 0.0250, 0.3844,
185     0.2656, 1.0468, -0.3788, -2.4517, 1.4656 },
186     /* Sky clearness (epsilon): 6.200 to ... */
187     { -1.0500, 0.0289, 0.4260, 0.3590, -0.3250,
188     0.1156, 0.7781, 0.0025, 31.0625, -14.5000,
189     -46.1148, 55.3750, -7.2312, 0.4050, 13.3500,
190     0.6234, 1.5000, -0.6426, 1.8564, 0.5636 }
191     };
192
193     /* Perez irradiance component model coefficients */
194
195     /* Reference: Perez, R., P. Ineichen, R. Seals, J. Michalsky, and R. */
196     /* Stewart. 1990. ìModeling Daylight Availability and */
197     /* Irradiance Components from Direct and Global */
198     /* Irradiance,î Solar Energy 44(5):271-289. */
199
200     typedef struct
201     {
202     double lower; /* Lower bound */
203     double upper; /* Upper bound */
204     } CategoryBounds;
205
206     /* Perez sky clearness (epsilon) categories (Table 1) */
207     static const CategoryBounds SkyClearCat[8] =
208     {
209     { 1.000, 1.065 }, /* Overcast */
210     { 1.065, 1.230 },
211     { 1.230, 1.500 },
212     { 1.500, 1.950 },
213     { 1.950, 2.800 },
214     { 2.800, 4.500 },
215     { 4.500, 6.200 },
216 greg 2.12 { 6.200, 12.01 } /* Clear */
217 greg 2.1 };
218
219     /* Luminous efficacy model coefficients */
220     typedef struct
221     {
222     double a;
223     double b;
224     double c;
225     double d;
226     } ModelCoeff;
227
228     /* Diffuse luminous efficacy model coefficients (Table 4, Eqn. 7) */
229     static const ModelCoeff DiffuseLumEff[8] =
230     {
231     { 97.24, -0.46, 12.00, -8.91 },
232     { 107.22, 1.15, 0.59, -3.95 },
233     { 104.97, 2.96, -5.53, -8.77 },
234     { 102.39, 5.59, -13.95, -13.90 },
235     { 100.71, 5.94, -22.75, -23.74 },
236     { 106.42, 3.83, -36.15, -28.83 },
237     { 141.88, 1.90, -53.24, -14.03 },
238     { 152.23, 0.35, -45.27, -7.98 }
239     };
240
241     /* Direct luminous efficacy model coefficients (Table 4, Eqn. 8) */
242     static const ModelCoeff DirectLumEff[8] =
243     {
244     { 57.20, -4.55, -2.98, 117.12 },
245     { 98.99, -3.46, -1.21, 12.38 },
246     { 109.83, -4.90, -1.71, -8.81 },
247     { 110.34, -5.84, -1.99, -4.56 },
248     { 106.36, -3.97, -1.75, -6.16 },
249     { 107.19, -1.25, -1.51, -26.73 },
250     { 105.75, 0.77, -1.26, -34.44 },
251     { 101.18, 1.58, -1.10, -8.29 }
252     };
253
254 greg 2.3 #ifndef NSUNPATCH
255 greg 2.10 #define NSUNPATCH 4 /* max. # patches to spread sun into */
256 greg 2.3 #endif
257
258 greg 2.35 #define SUN_ANG_DEG 0.533 /* sun full-angle in degrees */
259
260 greg 2.10 int nsuns = NSUNPATCH; /* number of sun patches to use */
261     double fixed_sun_sa = -1; /* fixed solid angle per sun? */
262
263 greg 2.1 int verbose = 0; /* progress reports to stderr? */
264
265     int outfmt = 'a'; /* output format */
266
267     int rhsubdiv = 1; /* Reinhart sky subdivisions */
268
269 greg 2.4 COLOR skycolor = {.96, 1.004, 1.118}; /* sky coloration */
270     COLOR suncolor = {1., 1., 1.}; /* sun color */
271     COLOR grefl = {.2, .2, .2}; /* ground reflectance */
272 greg 2.1
273     int nskypatch; /* number of Reinhart patches */
274     float *rh_palt; /* sky patch altitudes (radians) */
275     float *rh_pazi; /* sky patch azimuths (radians) */
276     float *rh_dom; /* sky patch solid angle (sr) */
277
278 greg 2.36 #define vector(v,alt,azi) ( (v)[1] = cos(alt), \
279     (v)[0] = (v)[1]*sin(azi), \
280     (v)[1] *= cos(azi), \
281     (v)[2] = sin(alt) )
282 greg 2.1
283     #define rh_vector(v,i) vector(v,rh_palt[i],rh_pazi[i])
284
285     #define rh_cos(i) tsin(rh_palt[i])
286
287 greg 2.36 #define solar_minute(jd,hr) ((24*60)*((jd)-1)+(int)((hr)*60.+.5))
288
289 greg 2.1 extern int rh_init(void);
290     extern float * resize_dmatrix(float *mtx_data, int nsteps, int npatch);
291 greg 2.36 extern void OutputSun(int id, int goodsun, FILE *fp, FILE *mfp);
292 greg 2.1 extern void AddDirect(float *parr);
293
294 greg 2.14
295     static const char *
296     getfmtname(int fmt)
297     {
298     switch (fmt) {
299     case 'a':
300     return("ascii");
301     case 'f':
302     return("float");
303     case 'd':
304     return("double");
305     }
306     return("unknown");
307     }
308
309
310 greg 2.1 int
311     main(int argc, char *argv[])
312     {
313 greg 2.41 EPWheader *epw = NULL; /* EPW/WEA input file */
314     EPWrecord erec; /* current EPW/WEA input record */
315     float dpthist[2]; /* previous dew point temps */
316     double dir, dif;
317 greg 2.14 int doheader = 1; /* output header? */
318 greg 2.8 double rotation = 0; /* site rotation (degrees) */
319 greg 2.1 double elevation; /* site elevation (meters) */
320 greg 2.36 int leap_day = 0; /* add leap day? */
321 greg 2.37 int sun_hours_only = 0; /* only output sun hours? */
322 greg 2.1 int dir_is_horiz; /* direct is meas. on horizontal? */
323 greg 2.34 FILE *sunsfp = NULL; /* output file for individual suns */
324 greg 2.36 FILE *modsfp = NULL; /* modifier output file */
325 greg 2.1 float *mtx_data = NULL; /* our matrix data */
326 greg 2.28 int avgSky = 0; /* compute average sky r.t. matrix? */
327 greg 2.27 int ntsteps = 0; /* number of time steps */
328 greg 2.28 int tstorage = 0; /* number of allocated time steps */
329     int nstored = 0; /* number of time steps in matrix */
330 greg 2.1 int last_monthly = 0; /* month of last report */
331     int mtx_offset;
332     int i, j;
333 greg 2.40 double timeinterval = 0;
334 greg 2.1
335     progname = argv[0];
336     /* get options */
337     for (i = 1; i < argc && argv[i][0] == '-'; i++)
338     switch (argv[i][1]) {
339 greg 2.4 case 'g': /* ground reflectance */
340     grefl[0] = atof(argv[++i]);
341     grefl[1] = atof(argv[++i]);
342     grefl[2] = atof(argv[++i]);
343 greg 2.1 break;
344 greg 2.4 case 'v': /* verbose progress reports */
345 greg 2.1 verbose++;
346     break;
347 greg 2.14 case 'h': /* turn off header */
348     doheader = 0;
349     break;
350 greg 2.4 case 'o': /* output format */
351 greg 2.1 switch (argv[i][2]) {
352     case 'f':
353     case 'd':
354     case 'a':
355     outfmt = argv[i][2];
356     break;
357     default:
358     goto userr;
359     }
360     break;
361 greg 2.11 case 'O': /* output type */
362     switch (argv[i][2]) {
363     case '0':
364     output = 0;
365     break;
366     case '1':
367     output = 1;
368     break;
369     default:
370     goto userr;
371     }
372     if (argv[i][3])
373     goto userr;
374     break;
375 greg 2.4 case 'm': /* Reinhart subdivisions */
376 greg 2.1 rhsubdiv = atoi(argv[++i]);
377     break;
378 greg 2.4 case 'c': /* sky color */
379 greg 2.1 skycolor[0] = atof(argv[++i]);
380     skycolor[1] = atof(argv[++i]);
381     skycolor[2] = atof(argv[++i]);
382     break;
383 greg 2.36 case 'D': /* output suns to file */
384     if (strcmp(argv[++i], "-")) {
385     sunsfp = fopen(argv[i], "w");
386     if (sunsfp == NULL) {
387     fprintf(stderr,
388     "%s: cannot open '%s' for output\n",
389     progname, argv[i]);
390     exit(1);
391     }
392     break; /* still may output matrix */
393     }
394     sunsfp = stdout; /* sending to stdout, so... */
395     /* fall through */
396 greg 2.34 case 'n': /* no matrix output */
397     avgSky = -1;
398     rhsubdiv = 1;
399     /* fall through */
400 greg 2.4 case 'd': /* solar (direct) only */
401 greg 2.1 skycolor[0] = skycolor[1] = skycolor[2] = 0;
402 greg 2.33 grefl[0] = grefl[1] = grefl[2] = 0;
403 greg 2.1 break;
404 greg 2.36 case 'M': /* send sun modifiers to file */
405     if ((modsfp = fopen(argv[++i], "w")) == NULL) {
406 greg 2.34 fprintf(stderr, "%s: cannot open '%s' for output\n",
407 greg 2.35 progname, argv[i]);
408 greg 2.34 exit(1);
409     }
410     break;
411 greg 2.4 case 's': /* sky only (no direct) */
412     suncolor[0] = suncolor[1] = suncolor[2] = 0;
413 greg 2.1 break;
414 greg 2.37 case 'u': /* solar hours only */
415     sun_hours_only = 1;
416     break;
417 greg 2.8 case 'r': /* rotate distribution */
418     if (argv[i][2] && argv[i][2] != 'z')
419     goto userr;
420     rotation = atof(argv[++i]);
421     break;
422 greg 2.10 case '5': /* 5-phase calculation */
423     nsuns = 1;
424 greg 2.19 fixed_sun_sa = PI/360.*atof(argv[++i]);
425 greg 2.21 if (fixed_sun_sa <= 0) {
426     fprintf(stderr, "%s: missing solar disk size argument for '-5' option\n",
427 greg 2.35 progname);
428 greg 2.21 exit(1);
429     }
430 greg 2.19 fixed_sun_sa *= fixed_sun_sa*PI;
431 greg 2.10 break;
432 greg 2.27 case 'A': /* compute average sky */
433     avgSky = 1;
434     break;
435 greg 2.40 case 'i':
436     timeinterval = atof(argv[++i]);
437     break;
438 greg 2.1 default:
439     goto userr;
440     }
441 greg 2.41 if ((i < argc-1) | (i > argc))
442 greg 2.1 goto userr;
443 greg 2.41 epw = EPWopen(argv[i]);
444     if (epw == NULL)
445 greg 2.1 exit(1);
446 greg 2.36 if ((modsfp != NULL) & (sunsfp == NULL))
447     fprintf(stderr, "%s: warning -M output will be empty without -D\n",
448     progname);
449 greg 2.1 if (verbose) {
450     if (i == argc-1)
451     fprintf(stderr, "%s: reading weather tape '%s'\n",
452     progname, argv[i]);
453     else
454     fprintf(stderr, "%s: reading weather tape from <stdin>\n",
455     progname);
456     }
457     /* read weather tape header */
458 greg 2.41 s_latitude = epw->loc.latitude;
459     s_longitude = -epw->loc.longitude;
460     s_meridian = -15.*epw->loc.timezone;
461     elevation = epw->loc.elevation;
462     switch (epw->isWEA) { /* translate units */
463     case WEAnot:
464     case WEAradnorm:
465 greg 2.1 input = 1; /* radiometric quantities */
466     dir_is_horiz = 0; /* direct is perpendicular meas. */
467     break;
468 greg 2.41 case WEAradhoriz:
469 greg 2.1 input = 1; /* radiometric quantities */
470     dir_is_horiz = 1; /* solar measured horizontally */
471     break;
472 greg 2.41 case WEAphotnorm:
473 greg 2.1 input = 2; /* photometric quantities */
474     dir_is_horiz = 0; /* direct is perpendicular meas. */
475     break;
476     default:
477     goto fmterr;
478     }
479     rh_init(); /* initialize sky patches */
480     if (verbose) {
481 greg 2.41 fprintf(stderr, "%s: location '%s, %s'\n", progname,
482     epw->loc.city, epw->loc.country);
483 greg 2.1 fprintf(stderr, "%s: (lat,long)=(%.1f,%.1f) degrees north, west\n",
484     progname, s_latitude, s_longitude);
485 greg 2.35 if (avgSky >= 0)
486     fprintf(stderr, "%s: %d sky patches\n",
487     progname, nskypatch);
488     if (sunsfp)
489 greg 2.39 fprintf(stderr, "%s: outputting suns to %s\n",
490     progname, sunsfp==stdout ? "stdout" : "file");
491 greg 2.8 if (rotation != 0)
492     fprintf(stderr, "%s: rotating output %.0f degrees\n",
493     progname, rotation);
494 greg 2.1 }
495 greg 2.2 /* convert quantities to radians */
496     s_latitude = DegToRad(s_latitude);
497     s_longitude = DegToRad(s_longitude);
498     s_meridian = DegToRad(s_meridian);
499 greg 2.27 /* initial allocation */
500 greg 2.28 mtx_data = resize_dmatrix(mtx_data, tstorage=2, nskypatch);
501 greg 2.41 dpthist[0] = -100;
502 greg 2.1 /* process each time step in tape */
503 greg 2.41 while ((j = EPWread(epw, &erec)) > 0) {
504 greg 2.42 const int mo = erec.date.month+1;
505     const int da = erec.date.day;
506     const double hr = erec.date.hour;
507 greg 2.40 double sda, sta, st;
508 greg 2.37 int sun_in_sky;
509 greg 2.42 /* 3-hour dew point temp */
510     if (EPWisset(&erec,dptemp)) {
511     if (dpthist[0] < -99)
512     dpthist[0] = dpthist[1] = erec.dptemp;
513     dew_point = (1./3.)*(dpthist[0] + dpthist[1] + erec.dptemp);
514     dpthist[0] = dpthist[1]; dpthist[1] = erec.dptemp;
515     } else
516     dpthist[0] = -100;
517 greg 2.1 /* compute solar position */
518 greg 2.36 if ((mo == 2) & (da == 29)) {
519     julian_date = 60;
520     leap_day = 1;
521     } else
522     julian_date = jdate(mo, da) + leap_day;
523 greg 2.1 sda = sdec(julian_date);
524     sta = stadj(julian_date);
525 greg 2.40 st = hr + sta;
526
527     if (timeinterval > 0) {
528     if (fabs(solar_sunrise(mo, da) - st) <= timeinterval/120)
529     st = (st + timeinterval/120 + solar_sunrise(mo, da))/2;
530     else if (fabs(solar_sunset(mo, da) - st) < timeinterval/120)
531     st = (st - timeinterval/120 + solar_sunset(mo, da))/2;
532     }
533     altitude = salt(sda, st);
534 greg 2.37 sun_in_sky = (altitude > -DegToRad(SUN_ANG_DEG/2.));
535 greg 2.42 if (sun_hours_only & !sun_in_sky)
536 greg 2.37 continue; /* skipping nighttime points */
537 greg 2.40 azimuth = sazi(sda, st) + PI - DegToRad(rotation);
538 greg 2.36
539 greg 2.41 switch (epw->isWEA) { /* translate units */
540     case WEAnot:
541     case WEAradnorm:
542     if (!EPWisset(&erec,dirirrad) |
543     !EPWisset(&erec,horizdiffirrad)) {
544     fprintf(stderr, "%s: missing required irradiances at line %d\n",
545     progname, epw->lino);
546     exit(1);
547     }
548     dir = erec.dirirrad;
549     dif = erec.horizdiffirrad;
550     break;
551     case WEAradhoriz:
552     dir = erec.globhorizirrad - erec.horizdiffirrad;
553     dif = erec.horizdiffirrad;
554     break;
555     case WEAphotnorm:
556     dir = erec.dirillum;
557     dif = erec.diffillum;
558     break;
559     }
560 greg 2.37 mtx_offset = 3*nskypatch*nstored;
561     nstored += !avgSky | !nstored;
562     /* make space for next row */
563     if (nstored > tstorage) {
564     tstorage += (tstorage>>1) + nstored + 7;
565     mtx_data = resize_dmatrix(mtx_data, tstorage, nskypatch);
566     }
567     ntsteps++; /* keep count of time steps */
568
569 greg 2.36 if (dir+dif <= 1e-4) { /* effectively nighttime? */
570     if (!avgSky | !mtx_offset)
571     memset(mtx_data+mtx_offset, 0,
572     sizeof(float)*3*nskypatch);
573 greg 2.37 /* output black sun? */
574     if (sunsfp && sun_in_sky)
575 greg 2.36 OutputSun(solar_minute(julian_date,hr), 0,
576     sunsfp, modsfp);
577     continue;
578     }
579 greg 2.38 if (!sun_in_sky && dir > (input==1 ? 20. : 20.*WHTEFFICACY))
580     fprintf(stderr,
581     "%s: warning - unusually bright at %.1f on %d-%d\n",
582     progname, hr, mo, da);
583 greg 2.1 /* convert measured values */
584 greg 2.38 if (dir_is_horiz && altitude > FTINY)
585 greg 2.1 dir /= sin(altitude);
586     if (input == 1) {
587     dir_irrad = dir;
588     diff_irrad = dif;
589     } else /* input == 2 */ {
590     dir_illum = dir;
591     diff_illum = dif;
592     }
593     /* compute sky patch values */
594     ComputeSky(mtx_data+mtx_offset);
595 greg 2.37 /* output sun if requested */
596     if (sunsfp && sun_in_sky)
597 greg 2.36 OutputSun(solar_minute(julian_date,hr), 1,
598     sunsfp, modsfp);
599 greg 2.35
600 greg 2.34 if (avgSky < 0) /* no matrix? */
601     continue;
602
603 greg 2.4 AddDirect(mtx_data+mtx_offset);
604 greg 2.27 /* update cumulative sky? */
605     for (i = 3*nskypatch*(avgSky&(ntsteps>1)); i--; )
606     mtx_data[i] += mtx_data[mtx_offset+i];
607 greg 2.34 /* monthly reporting */
608     if (verbose && mo != last_monthly)
609     fprintf(stderr, "%s: stepping through month %d...\n",
610     progname, last_monthly=mo);
611 greg 2.36 /* note whether leap-day was given */
612 greg 2.34 }
613 greg 2.41 if (j != EOF) {
614     fprintf(stderr, "%s: error on input\n", progname);
615     exit(1);
616     }
617     EPWclose(epw); epw = NULL;
618 greg 2.34 if (!ntsteps) {
619     fprintf(stderr, "%s: no valid time steps on input\n", progname);
620     exit(1);
621 greg 2.1 }
622 greg 2.34 if (avgSky < 0) /* no matrix output? */
623     goto alldone;
624
625 greg 2.27 dif = 1./(double)ntsteps; /* average sky? */
626     for (i = 3*nskypatch*(avgSky&(ntsteps>1)); i--; )
627     mtx_data[i] *= dif;
628 greg 2.1 /* write out matrix */
629 greg 2.14 if (outfmt != 'a')
630     SET_FILE_BINARY(stdout);
631 greg 2.1 #ifdef getc_unlocked
632     flockfile(stdout);
633     #endif
634     if (verbose)
635     fprintf(stderr, "%s: writing %smatrix with %d time steps...\n",
636 greg 2.28 progname, outfmt=='a' ? "" : "binary ", nstored);
637 greg 2.14 if (doheader) {
638     newheader("RADIANCE", stdout);
639     printargs(argc, argv, stdout);
640     printf("LATLONG= %.8f %.8f\n", RadToDeg(s_latitude),
641     -RadToDeg(s_longitude));
642     printf("NROWS=%d\n", nskypatch);
643 greg 2.28 printf("NCOLS=%d\n", nstored);
644 greg 2.14 printf("NCOMP=3\n");
645 greg 2.29 if ((outfmt == 'f') | (outfmt == 'd'))
646     fputendian(stdout);
647 greg 2.18 fputformat((char *)getfmtname(outfmt), stdout);
648 greg 2.14 putchar('\n');
649     }
650 greg 2.1 /* patches are rows (outer sort) */
651     for (i = 0; i < nskypatch; i++) {
652     mtx_offset = 3*i;
653     switch (outfmt) {
654     case 'a':
655 greg 2.28 for (j = 0; j < nstored; j++) {
656 greg 2.3 printf("%.3g %.3g %.3g\n", mtx_data[mtx_offset],
657 greg 2.1 mtx_data[mtx_offset+1],
658     mtx_data[mtx_offset+2]);
659     mtx_offset += 3*nskypatch;
660     }
661 greg 2.28 if (nstored > 1)
662 greg 2.2 fputc('\n', stdout);
663 greg 2.1 break;
664     case 'f':
665 greg 2.28 for (j = 0; j < nstored; j++) {
666 greg 2.23 putbinary(mtx_data+mtx_offset, sizeof(float), 3,
667 greg 2.1 stdout);
668     mtx_offset += 3*nskypatch;
669     }
670     break;
671     case 'd':
672 greg 2.28 for (j = 0; j < nstored; j++) {
673 greg 2.1 double ment[3];
674     ment[0] = mtx_data[mtx_offset];
675     ment[1] = mtx_data[mtx_offset+1];
676     ment[2] = mtx_data[mtx_offset+2];
677 greg 2.23 putbinary(ment, sizeof(double), 3, stdout);
678 greg 2.1 mtx_offset += 3*nskypatch;
679     }
680     break;
681     }
682     if (ferror(stdout))
683     goto writerr;
684     }
685 greg 2.34 alldone:
686     if (fflush(NULL) == EOF)
687 greg 2.1 goto writerr;
688     if (verbose)
689     fprintf(stderr, "%s: done.\n", progname);
690     exit(0);
691     userr:
692 greg 2.37 fprintf(stderr, "Usage: %s [-v][-h][-A][-d|-s|-n][-u][-D file [-M modfile]][-r deg][-m N][-g r g b][-c r g b][-o{f|d}][-O{0|1}] [tape.wea]\n",
693 greg 2.1 progname);
694     exit(1);
695     fmterr:
696 greg 2.34 fprintf(stderr, "%s: weather tape format error in header\n", progname);
697 greg 2.1 exit(1);
698     writerr:
699     fprintf(stderr, "%s: write error on output\n", progname);
700     exit(1);
701     }
702
703 greg 2.40
704 greg 2.1 /* Return maximum of two doubles */
705     double dmax( double a, double b )
706     { return (a > b) ? a : b; }
707
708     /* Compute sky patch radiance values (modified by GW) */
709     void
710     ComputeSky(float *parr)
711     {
712     int index; /* Category index */
713     double norm_diff_illum; /* Normalized diffuse illuimnance */
714     int i;
715 greg 2.42
716 greg 2.1 /* Calculate atmospheric precipitable water content */
717     apwc = CalcPrecipWater(dew_point);
718
719 greg 2.6 /* Calculate sun zenith angle (don't let it dip below horizon) */
720     /* Also limit minimum angle to keep circumsolar off zenith */
721     if (altitude <= 0.0)
722     sun_zenith = DegToRad(90.0);
723     else if (altitude >= DegToRad(87.0))
724     sun_zenith = DegToRad(3.0);
725     else
726     sun_zenith = DegToRad(90.0) - altitude;
727 greg 2.1
728     /* Compute the inputs for the calculation of the sky distribution */
729
730     if (input == 0) /* XXX never used */
731     {
732     /* Calculate irradiance */
733     diff_irrad = CalcDiffuseIrradiance();
734     dir_irrad = CalcDirectIrradiance();
735
736     /* Calculate illuminance */
737     index = GetCategoryIndex();
738     diff_illum = diff_irrad * CalcDiffuseIllumRatio(index);
739     dir_illum = dir_irrad * CalcDirectIllumRatio(index);
740     }
741     else if (input == 1)
742     {
743     sky_brightness = CalcSkyBrightness();
744     sky_clearness = CalcSkyClearness();
745
746 greg 2.9 /* Limit sky clearness */
747     if (sky_clearness > 11.9)
748     sky_clearness = 11.9;
749 greg 2.40 else if (sky_clearness < 1.0)
750     sky_clearness = 1.0;
751 greg 2.9
752     /* Limit sky brightness */
753     if (sky_brightness < 0.01)
754 greg 2.11 sky_brightness = 0.01;
755 greg 2.40 else if (sky_brightness > 0.6)
756     sky_brightness = 0.6;
757 greg 2.9
758 greg 2.1 /* Calculate illuminance */
759     index = GetCategoryIndex();
760     diff_illum = diff_irrad * CalcDiffuseIllumRatio(index);
761     dir_illum = dir_irrad * CalcDirectIllumRatio(index);
762     }
763     else if (input == 2)
764     {
765     /* Calculate sky brightness and clearness from illuminance values */
766     index = CalcSkyParamFromIllum();
767     }
768
769 greg 2.11 if (output == 1) { /* hack for solar radiance */
770     diff_illum = diff_irrad * WHTEFFICACY;
771     dir_illum = dir_irrad * WHTEFFICACY;
772     }
773 greg 2.1 /* Compute ground radiance (include solar contribution if any) */
774 greg 2.3 parr[0] = diff_illum;
775 greg 2.1 if (altitude > 0)
776 greg 2.3 parr[0] += dir_illum * sin(altitude);
777 greg 2.4 parr[2] = parr[1] = parr[0] *= (1./PI/WHTEFFICACY);
778     multcolor(parr, grefl);
779 greg 2.1
780 greg 2.32 if (bright(skycolor) <= 1e-4) { /* 0 sky component? */
781     memset(parr+3, 0, sizeof(float)*3*(nskypatch-1));
782     return;
783     }
784 greg 2.1 /* Calculate Perez sky model parameters */
785     CalcPerezParam(sun_zenith, sky_clearness, sky_brightness, index);
786
787     /* Calculate sky patch luminance values */
788     CalcSkyPatchLumin(parr);
789
790     /* Calculate relative horizontal illuminance */
791     norm_diff_illum = CalcRelHorzIllum(parr);
792
793 greg 2.13 /* Check for zero sky -- make uniform in that case */
794     if (norm_diff_illum <= FTINY) {
795     for (i = 1; i < nskypatch; i++)
796     setcolor(parr+3*i, 1., 1., 1.);
797     norm_diff_illum = PI;
798     }
799 greg 2.1 /* Normalization coefficient */
800     norm_diff_illum = diff_illum / norm_diff_illum;
801
802     /* Apply to sky patches to get absolute radiance values */
803     for (i = 1; i < nskypatch; i++) {
804 greg 2.7 scalecolor(parr+3*i, norm_diff_illum*(1./WHTEFFICACY));
805 greg 2.1 multcolor(parr+3*i, skycolor);
806     }
807     }
808
809 greg 2.40
810     double
811     solar_sunset(int month, int day)
812     {
813     float W;
814     W = -1 * (tan(s_latitude) * tan(sdec(jdate(month, day))));
815     return(12 + (M_PI / 2 - atan2(W, sqrt(1 - W * W))) * 180 / (M_PI * 15));
816     }
817
818
819     double
820     solar_sunrise(int month, int day)
821     {
822     float W;
823     W = -1 * (tan(s_latitude) * tan(sdec(jdate(month, day))));
824     return(12 - (M_PI / 2 - atan2(W, sqrt(1 - W * W))) * 180 / (M_PI * 15));
825     }
826
827
828 greg 2.1 /* Add in solar direct to nearest sky patches (GW) */
829     void
830     AddDirect(float *parr)
831     {
832     FVECT svec;
833 greg 2.3 double near_dprod[NSUNPATCH];
834     int near_patch[NSUNPATCH];
835     double wta[NSUNPATCH], wtot;
836 greg 2.1 int i, j, p;
837
838 greg 2.4 if (dir_illum <= 1e-4 || bright(suncolor) <= 1e-4)
839 greg 2.1 return;
840 greg 2.10 /* identify nsuns closest patches */
841     if (nsuns > NSUNPATCH)
842     nsuns = NSUNPATCH;
843     else if (nsuns <= 0)
844     nsuns = 1;
845     for (i = nsuns; i--; )
846 greg 2.1 near_dprod[i] = -1.;
847     vector(svec, altitude, azimuth);
848     for (p = 1; p < nskypatch; p++) {
849     FVECT pvec;
850     double dprod;
851     rh_vector(pvec, p);
852     dprod = DOT(pvec, svec);
853 greg 2.10 for (i = 0; i < nsuns; i++)
854 greg 2.1 if (dprod > near_dprod[i]) {
855 greg 2.10 for (j = nsuns; --j > i; ) {
856 greg 2.1 near_dprod[j] = near_dprod[j-1];
857     near_patch[j] = near_patch[j-1];
858     }
859     near_dprod[i] = dprod;
860     near_patch[i] = p;
861     break;
862     }
863     }
864     wtot = 0; /* weight by proximity */
865 greg 2.10 for (i = nsuns; i--; )
866 greg 2.1 wtot += wta[i] = 1./(1.002 - near_dprod[i]);
867     /* add to nearest patch radiances */
868 greg 2.10 for (i = nsuns; i--; ) {
869 greg 2.2 float *pdest = parr + 3*near_patch[i];
870 greg 2.10 float val_add = wta[i] * dir_illum / (WHTEFFICACY * wtot);
871
872     val_add /= (fixed_sun_sa > 0) ? fixed_sun_sa
873     : rh_dom[near_patch[i]] ;
874 greg 2.4 *pdest++ += val_add*suncolor[0];
875     *pdest++ += val_add*suncolor[1];
876     *pdest++ += val_add*suncolor[2];
877 greg 2.2 }
878 greg 2.1 }
879
880 greg 2.35 /* Output a sun to indicated file if appropriate for this time step */
881     void
882 greg 2.36 OutputSun(int id, int goodsun, FILE *fp, FILE *mfp)
883 greg 2.35 {
884     double srad;
885     FVECT sv;
886
887 greg 2.36 srad = DegToRad(SUN_ANG_DEG/2.);
888     srad = goodsun ? dir_illum/(WHTEFFICACY * PI*srad*srad) : 0;
889 greg 2.35 vector(sv, altitude, azimuth);
890     fprintf(fp, "\nvoid light solar%d\n0\n0\n", id);
891     fprintf(fp, "3 %.3e %.3e %.3e\n", srad*suncolor[0],
892     srad*suncolor[1], srad*suncolor[2]);
893     fprintf(fp, "\nsolar%d source sun%d\n0\n0\n", id, id);
894     fprintf(fp, "4 %.6f %.6f %.6f %.4f\n", sv[0], sv[1], sv[2], SUN_ANG_DEG);
895 greg 2.36
896     if (mfp != NULL) /* saving modifier IDs? */
897     fprintf(mfp, "solar%d\n", id);
898 greg 2.35 }
899
900 greg 2.1 /* Initialize Reinhart sky patch positions (GW) */
901     int
902     rh_init(void)
903     {
904     #define NROW 7
905     static const int tnaz[NROW] = {30, 30, 24, 24, 18, 12, 6};
906     const double alpha = (PI/2.)/(NROW*rhsubdiv + .5);
907     int p, i, j;
908     /* allocate patch angle arrays */
909     nskypatch = 0;
910     for (p = 0; p < NROW; p++)
911     nskypatch += tnaz[p];
912     nskypatch *= rhsubdiv*rhsubdiv;
913     nskypatch += 2;
914     rh_palt = (float *)malloc(sizeof(float)*nskypatch);
915     rh_pazi = (float *)malloc(sizeof(float)*nskypatch);
916     rh_dom = (float *)malloc(sizeof(float)*nskypatch);
917     if ((rh_palt == NULL) | (rh_pazi == NULL) | (rh_dom == NULL)) {
918     fprintf(stderr, "%s: out of memory in rh_init()\n", progname);
919     exit(1);
920     }
921     rh_palt[0] = -PI/2.; /* ground & zenith patches */
922     rh_pazi[0] = 0.;
923     rh_dom[0] = 2.*PI;
924     rh_palt[nskypatch-1] = PI/2.;
925     rh_pazi[nskypatch-1] = 0.;
926     rh_dom[nskypatch-1] = 2.*PI*(1. - cos(alpha*.5));
927     p = 1; /* "normal" patches */
928     for (i = 0; i < NROW*rhsubdiv; i++) {
929     const float ralt = alpha*(i + .5);
930     const int ninrow = tnaz[i/rhsubdiv]*rhsubdiv;
931 greg 2.3 const float dom = 2.*PI*(sin(alpha*(i+1)) - sin(alpha*i)) /
932     (double)ninrow;
933 greg 2.1 for (j = 0; j < ninrow; j++) {
934     rh_palt[p] = ralt;
935     rh_pazi[p] = 2.*PI * j / (double)ninrow;
936     rh_dom[p++] = dom;
937     }
938     }
939     return nskypatch;
940     #undef NROW
941     }
942
943     /* Resize daylight matrix (GW) */
944     float *
945     resize_dmatrix(float *mtx_data, int nsteps, int npatch)
946     {
947     if (mtx_data == NULL)
948     mtx_data = (float *)malloc(sizeof(float)*3*nsteps*npatch);
949     else
950     mtx_data = (float *)realloc(mtx_data,
951     sizeof(float)*3*nsteps*npatch);
952     if (mtx_data == NULL) {
953     fprintf(stderr, "%s: out of memory in resize_dmatrix(%d,%d)\n",
954     progname, nsteps, npatch);
955     exit(1);
956     }
957     return(mtx_data);
958     }
959
960     /* Determine category index */
961     int GetCategoryIndex()
962     {
963     int index; /* Loop index */
964
965     for (index = 0; index < 8; index++)
966     if ((sky_clearness >= SkyClearCat[index].lower) &&
967     (sky_clearness < SkyClearCat[index].upper))
968     break;
969
970     return index;
971     }
972
973     /* Calculate diffuse illuminance to diffuse irradiance ratio */
974
975     /* Reference: Perez, R., P. Ineichen, R. Seals, J. Michalsky, and R. */
976     /* Stewart. 1990. ìModeling Daylight Availability and */
977     /* Irradiance Components from Direct and Global */
978     /* Irradiance,î Solar Energy 44(5):271-289, Eqn. 7. */
979
980     double CalcDiffuseIllumRatio( int index )
981     {
982     ModelCoeff const *pnle; /* Category coefficient pointer */
983
984     /* Get category coefficient pointer */
985     pnle = &(DiffuseLumEff[index]);
986
987     return pnle->a + pnle->b * apwc + pnle->c * cos(sun_zenith) +
988     pnle->d * log(sky_brightness);
989     }
990
991     /* Calculate direct illuminance to direct irradiance ratio */
992
993     /* Reference: Perez, R., P. Ineichen, R. Seals, J. Michalsky, and R. */
994     /* Stewart. 1990. ìModeling Daylight Availability and */
995     /* Irradiance Components from Direct and Global */
996     /* Irradiance,î Solar Energy 44(5):271-289, Eqn. 8. */
997
998     double CalcDirectIllumRatio( int index )
999     {
1000     ModelCoeff const *pnle; /* Category coefficient pointer */
1001
1002     /* Get category coefficient pointer */
1003     pnle = &(DirectLumEff[index]);
1004
1005     /* Calculate direct illuminance from direct irradiance */
1006
1007     return dmax((pnle->a + pnle->b * apwc + pnle->c * exp(5.73 *
1008     sun_zenith - 5.0) + pnle->d * sky_brightness),
1009     0.0);
1010     }
1011
1012     /* Calculate sky brightness */
1013
1014     /* Reference: Perez, R., P. Ineichen, R. Seals, J. Michalsky, and R. */
1015     /* Stewart. 1990. ìModeling Daylight Availability and */
1016     /* Irradiance Components from Direct and Global */
1017     /* Irradiance,î Solar Energy 44(5):271-289, Eqn. 2. */
1018
1019     double CalcSkyBrightness()
1020     {
1021     return diff_irrad * CalcAirMass() / (DC_SolarConstantE *
1022     CalcEccentricity());
1023     }
1024
1025     /* Calculate sky clearness */
1026
1027     /* Reference: Perez, R., P. Ineichen, R. Seals, J. Michalsky, and R. */
1028     /* Stewart. 1990. ìModeling Daylight Availability and */
1029     /* Irradiance Components from Direct and Global */
1030     /* Irradiance,î Solar Energy 44(5):271-289, Eqn. 1. */
1031
1032     double CalcSkyClearness()
1033     {
1034     double sz_cubed; /* Sun zenith angle cubed */
1035
1036     /* Calculate sun zenith angle cubed */
1037 greg 2.11 sz_cubed = sun_zenith*sun_zenith*sun_zenith;
1038 greg 2.1
1039     return ((diff_irrad + dir_irrad) / diff_irrad + 1.041 *
1040     sz_cubed) / (1.0 + 1.041 * sz_cubed);
1041     }
1042
1043     /* Calculate diffuse horizontal irradiance from Perez sky brightness */
1044
1045     /* Reference: Perez, R., P. Ineichen, R. Seals, J. Michalsky, and R. */
1046     /* Stewart. 1990. ìModeling Daylight Availability and */
1047     /* Irradiance Components from Direct and Global */
1048     /* Irradiance,î Solar Energy 44(5):271-289, Eqn. 2 */
1049     /* (inverse). */
1050
1051     double CalcDiffuseIrradiance()
1052     {
1053     return sky_brightness * DC_SolarConstantE * CalcEccentricity() /
1054     CalcAirMass();
1055     }
1056
1057     /* Calculate direct normal irradiance from Perez sky clearness */
1058
1059     /* Reference: Perez, R., P. Ineichen, R. Seals, J. Michalsky, and R. */
1060     /* Stewart. 1990. ìModeling Daylight Availability and */
1061     /* Irradiance Components from Direct and Global */
1062     /* Irradiance,î Solar Energy 44(5):271-289, Eqn. 1 */
1063     /* (inverse). */
1064
1065     double CalcDirectIrradiance()
1066     {
1067     return CalcDiffuseIrradiance() * ((sky_clearness - 1.0) * (1 + 1.041
1068 greg 2.11 * sun_zenith*sun_zenith*sun_zenith));
1069 greg 2.1 }
1070
1071     /* Calculate sky brightness and clearness from illuminance values */
1072     int CalcSkyParamFromIllum()
1073     {
1074     double test1 = 0.1;
1075     double test2 = 0.1;
1076     int counter = 0;
1077     int index = 0; /* Category index */
1078
1079     /* Convert illuminance to irradiance */
1080     diff_irrad = diff_illum * DC_SolarConstantE /
1081     (DC_SolarConstantL * 1000.0);
1082     dir_irrad = dir_illum * DC_SolarConstantE /
1083     (DC_SolarConstantL * 1000.0);
1084
1085     /* Calculate sky brightness and clearness */
1086     sky_brightness = CalcSkyBrightness();
1087     sky_clearness = CalcSkyClearness();
1088
1089     /* Limit sky clearness */
1090     if (sky_clearness > 12.0)
1091     sky_clearness = 12.0;
1092
1093     /* Limit sky brightness */
1094 greg 2.9 if (sky_brightness < 0.01)
1095 greg 2.1 sky_brightness = 0.01;
1096
1097 greg 2.40 if (sky_clearness < 1.0000)
1098     {
1099     sky_clearness = 1.0000;
1100     }
1101
1102     if (sky_brightness > 0.6)
1103     {
1104     sky_brightness = 0.6;
1105     }
1106
1107 greg 2.1 while (((fabs(diff_irrad - test1) > 10.0) ||
1108     (fabs(dir_irrad - test2) > 10.0)) && !(counter == 5))
1109     {
1110     test1 = diff_irrad;
1111     test2 = dir_irrad;
1112     counter++;
1113
1114     /* Convert illuminance to irradiance */
1115     index = GetCategoryIndex();
1116     diff_irrad = diff_illum / CalcDiffuseIllumRatio(index);
1117 greg 2.26 dir_irrad = CalcDirectIllumRatio(index);
1118     if (dir_irrad > 0.1)
1119     dir_irrad = dir_illum / dir_irrad;
1120 greg 2.1
1121     /* Calculate sky brightness and clearness */
1122     sky_brightness = CalcSkyBrightness();
1123     sky_clearness = CalcSkyClearness();
1124
1125     /* Limit sky clearness */
1126     if (sky_clearness > 12.0)
1127     sky_clearness = 12.0;
1128
1129     /* Limit sky brightness */
1130 greg 2.9 if (sky_brightness < 0.01)
1131 greg 2.1 sky_brightness = 0.01;
1132 greg 2.40
1133     if (sky_clearness < 1.0000)
1134     {
1135     sky_clearness = 1.0000;
1136     }
1137
1138     if (sky_brightness > 0.6)
1139     {
1140     sky_brightness = 0.6;
1141     }
1142 greg 2.1 }
1143
1144     return GetCategoryIndex();
1145     }
1146
1147     /* Calculate relative luminance */
1148
1149     /* Reference: Perez, R., R. Seals, and J. Michalsky. 1993. */
1150     /* ìAll-Weather Model for Sky Luminance Distribution - */
1151     /* Preliminary Configuration and Validation,î Solar Energy */
1152     /* 50(3):235-245, Eqn. 1. */
1153
1154     double CalcRelLuminance( double gamma, double zeta )
1155     {
1156     return (1.0 + perez_param[0] * exp(perez_param[1] / cos(zeta))) *
1157     (1.0 + perez_param[2] * exp(perez_param[3] * gamma) +
1158     perez_param[4] * cos(gamma) * cos(gamma));
1159     }
1160
1161     /* Calculate Perez sky model parameters */
1162
1163     /* Reference: Perez, R., R. Seals, and J. Michalsky. 1993. */
1164     /* ìAll-Weather Model for Sky Luminance Distribution - */
1165     /* Preliminary Configuration and Validation,î Solar Energy */
1166     /* 50(3):235-245, Eqns. 6 - 8. */
1167
1168     void CalcPerezParam( double sz, double epsilon, double delta,
1169     int index )
1170     {
1171     double x[5][4]; /* Coefficents a, b, c, d, e */
1172     int i, j; /* Loop indices */
1173
1174     /* Limit sky brightness */
1175     if (epsilon > 1.065 && epsilon < 2.8)
1176     {
1177     if (delta < 0.2)
1178     delta = 0.2;
1179     }
1180
1181     /* Get Perez coefficients */
1182     for (i = 0; i < 5; i++)
1183     for (j = 0; j < 4; j++)
1184     x[i][j] = PerezCoeff[index][4 * i + j];
1185
1186     if (index != 0)
1187     {
1188     /* Calculate parameter a, b, c, d and e (Eqn. 6) */
1189     for (i = 0; i < 5; i++)
1190     perez_param[i] = x[i][0] + x[i][1] * sz + delta * (x[i][2] +
1191     x[i][3] * sz);
1192     }
1193     else
1194     {
1195     /* Parameters a, b and e (Eqn. 6) */
1196     perez_param[0] = x[0][0] + x[0][1] * sz + delta * (x[0][2] +
1197     x[0][3] * sz);
1198     perez_param[1] = x[1][0] + x[1][1] * sz + delta * (x[1][2] +
1199     x[1][3] * sz);
1200     perez_param[4] = x[4][0] + x[4][1] * sz + delta * (x[4][2] +
1201     x[4][3] * sz);
1202
1203     /* Parameter c (Eqn. 7) */
1204     perez_param[2] = exp(pow(delta * (x[2][0] + x[2][1] * sz),
1205     x[2][2])) - x[2][3];
1206
1207     /* Parameter d (Eqn. 8) */
1208     perez_param[3] = -exp(delta * (x[3][0] + x[3][1] * sz)) +
1209     x[3][2] + delta * x[3][3];
1210     }
1211     }
1212
1213     /* Calculate relative horizontal illuminance (modified by GW) */
1214
1215     /* Reference: Perez, R., R. Seals, and J. Michalsky. 1993. */
1216     /* ìAll-Weather Model for Sky Luminance Distribution - */
1217     /* Preliminary Configuration and Validation,î Solar Energy */
1218     /* 50(3):235-245, Eqn. 3. */
1219
1220     double CalcRelHorzIllum( float *parr )
1221     {
1222     int i;
1223     double rh_illum = 0.0; /* Relative horizontal illuminance */
1224
1225     for (i = 1; i < nskypatch; i++)
1226 greg 2.7 rh_illum += parr[3*i+1] * rh_cos(i) * rh_dom[i];
1227 greg 2.1
1228 greg 2.7 return rh_illum;
1229 greg 2.1 }
1230
1231     /* Calculate earth orbit eccentricity correction factor */
1232
1233     /* Reference: Sen, Z. 2008. Solar Energy Fundamental and Modeling */
1234     /* Techniques. Springer, p. 72. */
1235
1236     double CalcEccentricity()
1237     {
1238     double day_angle; /* Day angle (radians) */
1239     double E0; /* Eccentricity */
1240
1241     /* Calculate day angle */
1242     day_angle = (julian_date - 1.0) * (2.0 * PI / 365.0);
1243
1244     /* Calculate eccentricity */
1245     E0 = 1.00011 + 0.034221 * cos(day_angle) + 0.00128 * sin(day_angle)
1246     + 0.000719 * cos(2.0 * day_angle) + 0.000077 * sin(2.0 *
1247     day_angle);
1248
1249     return E0;
1250     }
1251
1252     /* Calculate atmospheric precipitable water content */
1253
1254     /* Reference: Perez, R., P. Ineichen, R. Seals, J. Michalsky, and R. */
1255     /* Stewart. 1990. ìModeling Daylight Availability and */
1256     /* Irradiance Components from Direct and Global */
1257     /* Irradiance,î Solar Energy 44(5):271-289, Eqn. 3. */
1258
1259     /* Note: The default surface dew point temperature is 11 deg. C */
1260     /* (52 deg. F). Typical values are: */
1261
1262     /* Celsius Fahrenheit Human Perception */
1263     /* > 24 > 75 Extremely uncomfortable */
1264     /* 21 - 24 70 - 74 Very humid */
1265     /* 18 - 21 65 - 69 Somewhat uncomfortable */
1266     /* 16 - 18 60 - 64 OK for most people */
1267     /* 13 - 16 55 - 59 Comfortable */
1268     /* 10 - 12 50 - 54 Very comfortable */
1269     /* < 10 < 49 A bit dry for some */
1270
1271     double CalcPrecipWater( double dpt )
1272     { return exp(0.07 * dpt - 0.075); }
1273
1274     /* Calculate relative air mass */
1275
1276     /* Reference: Kasten, F. 1966. "A New Table and Approximation Formula */
1277     /* for the Relative Optical Air Mass," Arch. Meteorol. */
1278     /* Geophys. Bioklimataol. Ser. B14, pp. 206-233. */
1279
1280     /* Note: More sophisticated relative air mass models are */
1281     /* available, but they differ significantly only for */
1282     /* sun zenith angles greater than 80 degrees. */
1283
1284     double CalcAirMass()
1285     {
1286     return (1.0 / (cos(sun_zenith) + 0.15 * pow(93.885 -
1287     RadToDeg(sun_zenith), -1.253)));
1288     }
1289
1290     /* Calculate Perez All-Weather sky patch luminances (modified by GW) */
1291
1292     /* NOTE: The sky patches centers are determined in accordance with the */
1293     /* BRE-IDMP sky luminance measurement procedures. (See for example */
1294     /* Mardaljevic, J. 2001. "The BRE-IDMP Dataset: A New Benchmark */
1295     /* for the Validation of Illuminance Prediction Techniques," */
1296     /* Lighting Research & Technology 33(2):117-136.) */
1297
1298     void CalcSkyPatchLumin( float *parr )
1299     {
1300     int i;
1301     double aas; /* Sun-sky point azimuthal angle */
1302     double sspa; /* Sun-sky point angle */
1303     double zsa; /* Zenithal sun angle */
1304
1305     for (i = 1; i < nskypatch; i++)
1306     {
1307     /* Calculate sun-sky point azimuthal angle */
1308     aas = fabs(rh_pazi[i] - azimuth);
1309
1310     /* Calculate zenithal sun angle */
1311     zsa = PI * 0.5 - rh_palt[i];
1312
1313     /* Calculate sun-sky point angle (Equation 8-20) */
1314     sspa = acos(cos(sun_zenith) * cos(zsa) + sin(sun_zenith) *
1315     sin(zsa) * cos(aas));
1316
1317     /* Calculate patch luminance */
1318     parr[3*i] = CalcRelLuminance(sspa, zsa);
1319     if (parr[3*i] < 0) parr[3*i] = 0;
1320     parr[3*i+2] = parr[3*i+1] = parr[3*i];
1321     }
1322     }
